AMMCLIB - BEMF Observer theory
5,547 次查看
lucabarbiero
is there a reference document or article describing the theory from which the AMCLIB_BemfObsrvDQ  has been implemented? The AMMCLIB user guide is quite brief, and only shows the final difference equations.
Thanks a lot!
Luca
标记 (1)
3 回复数
5,329 次查看
petervlna
After some investigation, all I can share with you are these 2 documents.
Author of this function is no longer in company.
regards,
Peter
5,329 次查看
lucabarbiero
Thank you, this helps. I appreciate!
Luca
5,329 次查看
petervlna
I will ask AMMCLIB owner if there are more details available and let you know.
regards,
Peter
