5775E Multi-pit settings
易衍玖
I want to add multiple pit modules by dragging and dropping to add different timers, but I ran into this problem. This issue is causing me to not be able to generate code automatically, is it a problem with my configuration or 5775E does not allow adding 2 pit. how do I fix it please.
Online etc.!!!!!!!
PetrS
there is just single PIT module on MPC5775E, so you have to add another channels as you did according you last thread.
BR, Petr
