This config tool simplifies PLL setting calculation and clock configuration for MPC5744P device.
Follow these steps
Note: Macros have to be enabled!
- put values into cells B11, Q10 and Q17 of the "Clocks" sheet
- check if it is Valid or Invalid
- "PLLconfig" sheet shows possible PLLs configurations
- check calculated frequency of System/Peripheral clocks
- if Invalid change source clock and Divider value to keep Max freq
3. Copy generated code by pressing "Copy Code" button
Example MPC5744P FlexCAN TX RXFIFO ISR GHS614 can not download
