Example MPC5777C MCAN-FD simpleTX RX-ISR GHS616
* Detailed Description:
* Configures the MCANs to transmit and receive a CAN FD message with or without
* bit rate switching for data phase. This is defined by BRS macro.
* Baudrate during arbitration phase is set to 500kbps, during data phase 1Mpbs
* because of PHY used on the EVB.
* In this config, MCAN_0 transmits a message. MCAN_1 receives the message.
* MCAN_0 sends message each 1sec. This interval is generated by PIT.
* Single TX buffer is used to send n bytes. The message ID is changed for each
* transmission. Two standard and 2 extended IDs are sent.
* MCAN_1 is configured to receive a message, ISR is used to read new message.
* There are 2 standard and 2 extended ID filter tables defined. Classic filter
* configuration is set, means filter ID & mask.
* Messages with matched standard ID are received into RXFIFO_0, messages with matched
* extended ID then stored in RXFIFO_1.
* EVB connection:
* J37 and J38 to position 2-3 to connect MCAN1 TX/RX to transceiver
* CAN0-CANH on P15-1 to CAN1-CANH on P14-1
* CAN0-CANL on P15-2 to CAN1-CANL on P14-2
* Test HW:         MPC5777C-512DS Rev.A + MPC57xx MOTHER BOARD Rev.C
* MCU:             PPC5777CMM03 2N45H CTZZS1521A
* Fsys:            PLL1 = core_clk = 264MHz, PLL0 = 192MHz
* Debugger:        Lauterbach Trace32
* Target:          internal_FLASH
* Terminal:        19200-8-no parity-1 stop bit-no flow control on eSCI_A
*           use USB connector (J21) on minimodule
* EVB connection:  ETPUA30 (PortP P23-15) --> USER_LED_1 (P7-1)
*                  ETPUA31 (PortP P23-14) --> USER_LED_2 (P7-2)
添付
コメント
Hello PetrS‌
Could you check my question about thie code?
when I cheked main.c, I think that #define MCAN1_BASE_ADDR 0xFFEE8000 is not correct.
As far as I know, MCAN1's base is 0xFFE3_8000...
Could you check it?
Thank you.
Hi Luke,
yes, you are correct. The MCAN1's base is 0xFFE3_8000 on MPC5777C.
In fact this macro is not used in the code, so have no effect.
It comes from other project (for MPC5777M I think) and I forgot to delete it.
BR, Petr
%3CLINGO-SUB%20id%3D%22lingo-sub-1106601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BE%8BMPC5777C%20MCAN-FD%20simpleTX%20RX-ISR%20GHS616%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3CBR%20%2F%3E*%E8%A9%B3%E7%B4%B0%E3%81%AA%E8%AA%AC%E6%98%8E%3A%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20CAN%20FD%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E6%9C%89%E7%84%A1%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81MCAN%20%E3%81%8C%20CAN%20FD%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E9%80%81%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%E3%83%87%E3%83%BC%E3%82%BF%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%20BRS%20%E3%83%9E%E3%82%AF%E3%83%AD%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%E3%82%A2%E3%83%BC%E3%83%93%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E4%B8%AD%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AF500kbps%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E4%B8%AD%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AF1Mpbs%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%20EVB%E3%81%ABPHY%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E*%20%3CBR%20%2F%3E*%20%E3%81%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%AF%E3%80%81MCAN_0%20%E3%81%8C%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82MCAN_1%20%E3%81%AF%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20MCAN_0%20%E3%81%AF%201%20%E7%A7%92%E3%81%94%E3%81%A8%E3%81%AB%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E9%96%93%E9%9A%94%E3%81%AF%20PIT%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%20%E5%8D%98%E4%B8%80%E3%81%AETX%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6n%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%20ID%20%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%E6%84%9F%E6%9F%93%E3%80%822%20%E3%81%A4%E3%81%AE%E6%A8%99%E6%BA%96%20ID%20%E3%81%A8%202%20%E3%81%A4%E3%81%AE%E6%8B%A1%E5%BC%B5%20ID%20%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20MCAN_1%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81ISR%E3%81%AF%E6%96%B0%E3%81%97%E3%81%84%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%202%20%E3%81%A4%E3%81%AE%E6%A8%99%E6%BA%96%20ID%20%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%A8%202%20%E3%81%A4%E3%81%AE%E6%8B%A1%E5%BC%B5%20ID%20%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%AF%E3%83%A9%E3%82%B7%E3%83%83%E3%82%AF%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3CBR%20%2F%3E*%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%80%81%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BFID%E3%81%A8%E3%83%9E%E3%82%B9%E3%82%AF%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%80%BB%E6%A8%99%E6%BA%96ID%E3%81%8C%E4%B8%80%E8%87%B4%E3%81%97%E3%81%9F%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AFRXFIFO_0%E3%81%AB%E5%8F%97%E4%BF%A1%E3%81%95%E3%82%8C%E3%80%81%E4%B8%80%E8%87%B4%E3%81%97%E3%81%9F%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%3CBR%20%2F%3E*%20%E6%8B%A1%E5%BC%B5%20ID%20%E3%81%AF%20RXFIFO_1%20%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20EVB%E6%8E%A5%E7%B6%9A%3A%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20J37%E3%81%8A%E3%82%88%E3%81%B3J38%E3%82%92%E4%BD%8D%E7%BD%AE2-3%E3%81%AB%E6%8A%BC%E3%81%97%E3%81%A6%E3%80%81MCAN1%20TX%20%2F%20RX%E3%82%92%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20P15-1%E3%81%AECAN0-CANH%E3%81%8B%E3%82%89P14-1%E3%81%AECAN1-CANH%3CBR%20%2F%3E%20*%20P15-2%20%E3%81%AE%20CAN0-CANL%20%E3%81%8B%E3%82%89%20P14-2%20%E3%81%AE%20CAN1-CANL%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20------------------------------------------------------------------------------%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E2%80%BB%E3%83%86%E3%82%B9%E3%83%88HW%3AMPC5777C-512DS%20Rev.A%20%2B%20MPC57xx%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E3%83%9E%E3%82%B6%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%20Rev.C%20*%20MCU%3APPC5777CMM03%202N45H%20CTZZS1521A%20*%20Fsys%3A%20PLL1%20%3D%20core_clk%20%3D%20264MHz%2C%20PLL0%20%3D%20192MHz%20*%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%3ALauterbach%20Trace32%20*%20%E5%AF%BE%E8%B1%A1%3Ainternal_FLASH%20*%E7%AB%AF%E6%9C%AB%3A19200-8-%E3%83%91%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AA%E3%81%97-1%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%93%E3%83%83%E3%83%88-eSCI_A%E3%81%AE%E3%83%95%E3%83%AD%E3%83%BC%E5%88%B6%E5%BE%A1%E3%81%AA%E3%81%97%3CBR%20%2F%3E%20*%E3%83%9F%E3%83%8B%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AEUSB%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF(J21)%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20%E2%80%BBEVB%E6%8E%A5%E7%B6%9A%3AETPUA30(PortP%20P23-15)--%26gt%3B%20-%3CBR%20%2F%3E%20%26gt%3B%20USER_LED_1(P7-1)%20%E2%80%BBETPUA31(PortP%20P23-14)%20-%20%26gt%3B--%26gt%3B%20USER_LED_2(P7-2)%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1106601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3CBR%20%2F%3E*%E8%A9%B3%E7%B4%B0%E3%81%AA%E8%AA%AC%E6%98%8E%3A%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20CAN%20FD%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E6%9C%89%E7%84%A1%E3%81%AB%E3%81%8B%E3%81%8B%E3%82%8F%E3%82%89%E3%81%9A%E3%80%81MCAN%20%E3%81%8C%20CAN%20FD%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E9%80%81%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%E3%83%87%E3%83%BC%E3%82%BF%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E3%81%AE%E3%83%93%E3%83%83%E3%83%88%E3%83%AC%E3%83%BC%E3%83%88%E5%88%87%E3%82%8A%E6%9B%BF%E3%81%88%E3%80%82%E3%81%93%E3%82%8C%E3%81%AF%20BRS%20%E3%83%9E%E3%82%AF%E3%83%AD%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%E3%82%A2%E3%83%BC%E3%83%93%E3%83%88%E3%83%AC%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E4%B8%AD%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AF500kbps%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%83%95%E3%82%A7%E3%83%BC%E3%82%BA%E4%B8%AD%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AF1Mpbs%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%20EVB%E3%81%ABPHY%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%9F%E3%82%81%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E*%20%3CBR%20%2F%3E*%20%E3%81%93%E3%81%AE%E8%A8%AD%E5%AE%9A%E3%81%A7%E3%81%AF%E3%80%81MCAN_0%20%E3%81%8C%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82MCAN_1%20%E3%81%AF%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20MCAN_0%20%E3%81%AF%201%20%E7%A7%92%E3%81%94%E3%81%A8%E3%81%AB%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E9%96%93%E9%9A%94%E3%81%AF%20PIT%20%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%20%E5%8D%98%E4%B8%80%E3%81%AETX%E3%83%90%E3%83%83%E3%83%95%E3%82%A1%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6n%E3%83%90%E3%82%A4%E3%83%88%E3%82%92%E9%80%81%E4%BF%A1%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%20ID%20%E3%81%AF%E3%80%81%E3%81%9D%E3%82%8C%E3%81%9E%E3%82%8C%E3%81%AB%E5%A4%89%E6%9B%B4%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3CBR%20%2F%3E*%E6%84%9F%E6%9F%93%E3%80%822%20%E3%81%A4%E3%81%AE%E6%A8%99%E6%BA%96%20ID%20%E3%81%A8%202%20%E3%81%A4%E3%81%AE%E6%8B%A1%E5%BC%B5%20ID%20%E3%81%8C%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E*%20MCAN_1%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81ISR%E3%81%AF%E6%96%B0%E3%81%97%E3%81%84%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AE%E8%AA%AD%E3%81%BF%E5%8F%96%E3%82%8A%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%202%20%E3%81%A4%E3%81%AE%E6%A8%99%E6%BA%96%20ID%20%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%A8%202%20%E3%81%A4%E3%81%AE%E6%8B%A1%E5%BC%B5%20ID%20%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%20%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%81%8C%E5%AE%9A%E7%BE%A9%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%82%AF%E3%83%A9%E3%82%B7%E3%83%83%E3%82%AF%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BF%E3%83%BC%3CBR%20%2F%3E*%E8%A8%AD%E5%AE%9A%E3%81%8C%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%80%81%E3%83%95%E3%82%A3%E3%83%AB%E3%82%BFID%E3%81%A8%E3%83%9E%E3%82%B9%E3%82%AF%E3%82%92%E6%84%8F%E5%91%B3%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E2%80%BB%E6%A8%99%E6%BA%96ID%E3%81%8C%E4%B8%80%E8%87%B4%E3%81%97%E3%81%9F%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AFRXFIFO_0%E3%81%AB%E5%8F%97%E4%BF%A1%E3%81%95%E3%82%8C%E3%80%81%E4%B8%80%E8%87%B4%E3%81%97%E3%81%9F%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%3CBR%20%2F%3E*%20%E6%8B%A1%E5%BC%B5%20ID%20%E3%81%AF%20RXFIFO_1%20%E3%81%AB%E4%BF%9D%E5%AD%98%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E*%3CBR%20%2F%3E%20*%20EVB%E6%8E%A5%E7%B6%9A%3A%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20J37%E3%81%8A%E3%82%88%E3%81%B3J38%E3%82%92%E4%BD%8D%E7%BD%AE2-3%E3%81%AB%E6%8A%BC%E3%81%97%E3%81%A6%E3%80%81MCAN1%20TX%20%2F%20RX%E3%82%92%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20P15-1%E3%81%AECAN0-CANH%E3%81%8B%E3%82%89P14-1%E3%81%AECAN1-CANH%3CBR%20%2F%3E%20*%20P15-2%20%E3%81%AE%20CAN0-CANL%20%E3%81%8B%E3%82%89%20P14-2%20%E3%81%AE%20CAN1-CANL%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20*%20------------------------------------------------------------------------------%3CBR%20%2F%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E2%80%BB%E3%83%86%E3%82%B9%E3%83%88HW%3AMPC5777C-512DS%20Rev.A%20%2B%20MPC57xx%3CBR%20%2F%3E%20%3CBR%20%2F%3E%E3%83%9E%E3%82%B6%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%20Rev.C%20*%20MCU%3APPC5777CMM03%202N45H%20CTZZS1521A%20*%20Fsys%3A%20PLL1%20%3D%20core_clk%20%3D%20264MHz%2C%20PLL0%20%3D%20192MHz%20*%E3%83%87%E3%83%90%E3%83%83%E3%82%AC%3ALauterbach%20Trace32%20*%20%E5%AF%BE%E8%B1%A1%3Ainternal_FLASH%20*%E7%AB%AF%E6%9C%AB%3A19200-8-%E3%83%91%E3%83%AA%E3%83%86%E3%82%A3%E3%81%AA%E3%81%97-1%E3%82%B9%E3%83%88%E3%83%83%E3%83%97%E3%83%93%E3%83%83%E3%83%88-eSCI_A%E3%81%AE%E3%83%95%E3%83%AD%E3%83%BC%E5%88%B6%E5%BE%A1%E3%81%AA%E3%81%97%3CBR%20%2F%3E%20*%E3%83%9F%E3%83%8B%E3%83%A2%E3%82%B8%E3%83%A5%E3%83%BC%E3%83%AB%E3%81%AEUSB%E3%82%B3%E3%83%8D%E3%82%AF%E3%82%BF(J21)%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20%E2%80%BBEVB%E6%8E%A5%E7%B6%9A%3AETPUA30(PortP%20P23-15)--%26gt%3B%20-%3CBR%20%2F%3E%20%26gt%3B%20USER_LED_1(P7-1)%20%E2%80%BBETPUA31(PortP%20P23-14)%20-%20%26gt%3B--%26gt%3B%20USER_LED_2(P7-2)%3CBR%20%2F%3E%20*%3CBR%20%2F%3E%20********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1106601%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%85%A8%E8%88%AC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1106602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AMCAN-FD%20simpleTX%20RX-ISR%20GHS616%20MPC5777C%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1106602%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FPetrS%22%20target%3D%22_blank%22%3EPetrS%3C%2FA%3E%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%93%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AE%E7%A7%81%E3%81%AE%E8%B3%AA%E5%95%8F%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3Emain.c%E3%81%A8%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E3%81%BF%E3%81%9F%E3%81%A8%E3%81%93%E3%82%8D%E3%80%81%23define%20MCAN1_BASE_ADDR%200xFFEE8000%20%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%AA%E3%81%84%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E7%9F%A5%E3%82%8B%E9%99%90%E3%82%8A%E3%80%81MCAN1%E3%81%AE%E3%83%99%E3%83%BC%E3%82%B9%E3%81%AF0xFFE3_8000...%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎09-22-2016 03:16 AM
更新者:
