Example MPC5748G SMPU initialization GHS614
Search instead for
No ratings
* Detailed Description:
* This example initializes SMPU_0 and SMPU_1 to cover all memory resources for
* all masters.
* Simple test case is used in this example: after initialization, SMPU
* configuration is changed to disable write access to last 4kB of RAM.
* Once this area is written by CPU, exception will occur due to access
* violation.
* Test HW:  MPC57xx
* Maskset:  1N81M
* Target :  SRAM
* Fsys:     160 MHz PLL
Version history
Revision #:
1 of 1
Last update:
‎10-01-2015 03:30 AM
Updated by:
