Example MPC5748G PretendedNetworkingCAN S32DS_1.0
* Detailed Description:
* Application performs basic initialization, setup PLL to maximum allowed
* frequency
* Mode transition to LPU_STOP is executed. CAN_0 is configured to wake up from
*  LPU_STOP to LPU_RUN using message with standard IDE = 0 as a wake up
*  preselected matching criteria. After wake up from LPU_STOP, user
*  LED1 is blinking.
* Modified files: mem.ld, sections.ld, startup.s, added file z2_restart.s
* Test HW:         MPC5748G-324DS, MPC574xG Motherboard
* MCU:             PPC5748GMMN6A 1N81M
* Fsys:            PLL0 160MHz
* Debugger:        Lauterbach Trace32
*                  PeMicro USB-ML-PPCNEXUS
* Target:          internal_FLASH (debug mode, release mode)
* EVB connection:  Default
Comments
Can I use U-multilink to test this code?When I use this tool, I can not debug properly.
%3CLINGO-SUB%20id%3D%22lingo-sub-1108821%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EExample%20MPC5748G%20PretendedNetworkingCAN%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108821%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Detailed%20Description%3A%3C%2FP%3E%3CP%3E*%20Application%20performs%20basic%20initialization%2C%20setup%20PLL%20to%20maximum%20allowed%3C%2FP%3E%3CP%3E*%20frequency%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20Mode%20transition%20to%20LPU_STOP%20is%20executed.%20CAN_0%20is%20configured%20to%20wake%20up%20from%3C%2FP%3E%3CP%3E*%26nbsp%3B%20LPU_STOP%20to%20LPU_RUN%20using%20message%20with%20standard%20IDE%20%3D%200%20as%20a%20wake%20up%3C%2FP%3E%3CP%3E*%26nbsp%3B%20preselected%20matching%20criteria.%20After%20wake%20up%20from%20LPU_STOP%2C%20user%3C%2FP%3E%3CP%3E*%26nbsp%3B%20LED1%20is%20blinking.%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20Modified%20files%3A%20mem.ld%2C%20sections.ld%2C%20startup.s%2C%20added%20file%20z2_restart.s%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MPC5748G-324DS%2C%20MPC574xG%20Motherboard%3C%2FP%3E%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5748GMMN6A%201N81M%3C%2FP%3E%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PLL0%20160MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20internal_FLASH%20(debug%20mode%2C%20release%20mode)%3C%2FP%3E%3CP%3E*%20EVB%20connection%3A%26nbsp%3B%20Default%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1108821%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20Detailed%20Description%3A%3C%2FP%3E%3CP%3E*%20Application%20performs%20basic%20initialization%2C%20setup%20PLL%20to%20maximum%20allowed%3C%2FP%3E%3CP%3E*%20frequency%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20Mode%20transition%20to%20LPU_STOP%20is%20executed.%20CAN_0%20is%20configured%20to%20wake%20up%20from%3C%2FP%3E%3CP%3E*%26nbsp%3B%20LPU_STOP%20to%20LPU_RUN%20using%20message%20with%20standard%20IDE%20%3D%200%20as%20a%20wake%20up%3C%2FP%3E%3CP%3E*%26nbsp%3B%20preselected%20matching%20criteria.%20After%20wake%20up%20from%20LPU_STOP%2C%20user%3C%2FP%3E%3CP%3E*%26nbsp%3B%20LED1%20is%20blinking.%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20Modified%20files%3A%20mem.ld%2C%20sections.ld%2C%20startup.s%2C%20added%20file%20z2_restart.s%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MPC5748G-324DS%2C%20MPC574xG%20Motherboard%3C%2FP%3E%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PPC5748GMMN6A%201N81M%3C%2FP%3E%3CP%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PLL0%20160MHz%3C%2FP%3E%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%3CP%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20internal_FLASH%20(debug%20mode%2C%20release%20mode)%3C%2FP%3E%3CP%3E*%20EVB%20connection%3A%26nbsp%3B%20Default%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1108821%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EGeneral%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1108822%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20Example%20MPC5748G%20PretendedNetworkingCAN%20S32DS_1.0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1108822%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3C%2FP%3E%3CP%3ECan%20I%20use%20U-multilink%20to%20test%20this%20code%3FWhen%20I%20use%20this%20tool%2C%20I%20can%20not%20debug%20properly.%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22pastedImage_1.png%22%20style%3D%22width%3A%20669px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F539i752AE45C5CDC4775%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22pastedImage_1.png%22%20alt%3D%22pastedImage_1.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3EpastedImage_1.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
No ratings
Version history
Last update:
‎03-24-2016 05:42 AM
Updated by:
