Example MPC5744P eTimer frequency measurement GHS614
* Detailed Description:
* Example gives possible implementation of input signal period/freq measurement.
* eTimer channel capture 1 and 2 features are used. CAPT1/CAPT2 capture counter
* value on rising/falling edge of input signal. The FIFO is set to 2 entries
* and ICF2 is monitored. Free-running mode is used here.
* eTimer channel 0-1 are cascaded to achieve 1sec/1Hz measuring with 32bit counter.
* EVB connection:
*   P8.2  - A[1]  .. eTimer0 channel1 input signal
*   P8.1  - A[0]  .. GPIO output, used to show measurement period
*   Route LINFlexD_0 TXD/RXD (PB2/PB3) signals to the main board RS-232 transceiver
*   Daughtercard:
*   J17.11–12 ON  .. Connect LINFlexD_0 TXD (PB2) to main board.
*   J17.8–9 ON .. Connect LINFlexD_0 RXD (PB3) to main board.
*   Motherboard
*   J14 - SCI_RX ON
*   J13 - SCI_TX ON
*   J25 - SCI_PWR ON
* connect pulse signal to the P8.2.
* See results on PC terminal (19200, 8N1, None).
* Change freq/duty of input signal.
* Test HW:  MPC57xx
* Maskset:  1N65H
* Target :  internal_FLASH
* Fsys:     200 MHz PLL with 40 MHz crystal reference
* Terminal: 19200, 8N1, None
添付
コメント
Pat
Hi Petr,
Is it possible to have the same using DMA ?
PetrS
Pat
Pat
Hi Petr,
Thank you very much for your help and your support.
Pat
Hi Petr,
could you compile this with S32DS? I see loads of samples using GHS, but as you know GHS is access is expensive. Beside startup code, would it be possible to take sources and integrate them into S32DS demo project? (Note: I haven't tried yet)
Kind regards
%3CLINGO-SUB%20id%3D%22lingo-sub-1121335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BE%8BMPC5744P%20eTimer%E5%91%A8%E6%B3%A2%E6%95%B0%E6%B8%AC%E5%AE%9A%20GHS614%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%A9%B3%E7%B4%B0%E8%AA%AC%E6%98%8E%3A%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E5%85%A5%E5%8A%9B%E4%BF%A1%E5%8F%B7%E5%91%A8%E6%9C%9F%2F%E5%91%A8%E6%B3%A2%E6%95%B0%E6%B8%AC%E5%AE%9A%E3%81%AE%E5%AE%9F%E8%A3%85%E4%BE%8B%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%20eTimer%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%BC1%E3%81%A82%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82CAPT1%2FCAPT2%20%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%3C%2FP%3E%3CP%3E*%20%E5%85%A5%E5%8A%9B%E4%BF%A1%E5%8F%B7%E3%81%AE%E7%AB%8B%E3%81%A1%E4%B8%8A%E3%81%8C%E3%82%8A%2F%E7%AB%8B%E3%81%A1%E4%B8%8B%E3%81%8C%E3%82%8A%E3%82%A8%E3%83%83%E3%82%B8%E3%81%AE%E5%80%A4%E3%80%82FIFO%20%E3%81%AF%202%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E*%E3%81%8A%E3%82%88%E3%81%B3ICF2%E3%81%8C%E7%9B%A3%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%83%95%E3%83%AA%E3%83%BC%E3%83%A9%E3%83%B3%E3%83%8B%E3%83%B3%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20eTimer%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB0-1%E3%81%AF%E3%82%AB%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%89%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%80%8132%E3%83%93%E3%83%83%E3%83%88%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%81%A71sec%2F1Hz%E3%81%AE%E6%B8%AC%E5%AE%9A%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E*%20EVB%E6%8E%A5%E7%B6%9A%3A%3C%2FP%3E%3CP%3E*%20P8.2-%20A%5B1%5D%20..eTimer0%20channel1%20%E5%85%A5%E5%8A%9B%E4%BF%A1%E5%8F%B7%3C%2FP%3E%3CP%3E%E2%80%BBP8.1-%20A%5B0%5D%20..GPIO%E5%87%BA%E5%8A%9B%E3%80%81%E6%B8%AC%E5%AE%9A%E5%91%A8%E6%9C%9F%E3%81%AE%E8%A1%A8%E7%A4%BA%E3%81%AB%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20LINFlexD_0%20TXD%2FRXD(PB2%2FPB3)%E4%BF%A1%E5%8F%B7%E3%82%92%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89RS-232%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%3C%2FP%3E%3CP%3E*%20%E3%83%89%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%AB%E3%83%BC%E3%83%89%3A%3C%2FP%3E%3CP%3E*%20J17.11%E2%80%9312%E3%82%AA%E3%83%B3%E3%80%82%E3%80%82LINFlexD_0%20TXD(PB2)%E3%82%92%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%20J17.8%E2%80%939%E3%82%AA%E3%83%B3%E3%80%82%E3%80%82LINFlexD_0%20RXD(PB3)%E3%82%92%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%E3%83%9E%E3%82%B6%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E*%20J14%20-%20SCI_RX%E3%82%AA%E3%83%B3%3C%2FP%3E%3CP%3E*%20J13%20-%20SCI_TX%E3%82%AA%E3%83%B3%3C%2FP%3E%3CP%3E*%20J25%20-%20SCI_PWR%E3%82%AA%E3%83%B3%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%E3%83%91%E3%83%AB%E3%82%B9%E4%BF%A1%E5%8F%B7%E3%82%92P8.2%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%BBPC%E7%AB%AF%E6%9C%AB(19200%E3%80%818N1%E3%80%81%E3%81%AA%E3%81%97)%E3%81%A7%E7%B5%90%E6%9E%9C%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E*%E5%85%A5%E5%8A%9B%E4%BF%A1%E5%8F%B7%E3%81%AE%E5%91%A8%E6%B3%A2%E6%95%B0%2F%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%E3%83%86%E3%82%B9%E3%83%88HW%3AMPC57xx%3C%2FP%3E%3CP%3E*%20Maskset%3A%26nbsp%3B%201N65H%3C%2FP%3E%3CP%3E*%E5%AF%BE%E8%B1%A1%3Ainternal_FLASH%3C%2FP%3E%3CP%3E*%20Fsys%3A200MHz%20PLL%E3%80%8140MHz%E6%B0%B4%E6%99%B6%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%3C%2FP%3E%3CP%3E*%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%3A19200%E3%80%818N1%E3%80%81%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1121335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E********************************************************************************%3C%2FP%3E%3CP%3E*%20%E8%A9%B3%E7%B4%B0%E8%AA%AC%E6%98%8E%3A%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20%E5%85%A5%E5%8A%9B%E4%BF%A1%E5%8F%B7%E5%91%A8%E6%9C%9F%2F%E5%91%A8%E6%B3%A2%E6%95%B0%E6%B8%AC%E5%AE%9A%E3%81%AE%E5%AE%9F%E8%A3%85%E4%BE%8B%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%20eTimer%E3%83%81%E3%83%A3%E3%83%B3%E3%83%8D%E3%83%AB%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%E3%83%BC1%E3%81%A82%E3%81%AE%E6%A9%9F%E8%83%BD%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%BE%E3%81%99%E3%80%82CAPT1%2FCAPT2%20%E3%82%AD%E3%83%A3%E3%83%97%E3%83%81%E3%83%A3%20%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%3C%2FP%3E%3CP%3E*%20%E5%85%A5%E5%8A%9B%E4%BF%A1%E5%8F%B7%E3%81%AE%E7%AB%8B%E3%81%A1%E4%B8%8A%E3%81%8C%E3%82%8A%2F%E7%AB%8B%E3%81%A1%E4%B8%8B%E3%81%8C%E3%82%8A%E3%82%A8%E3%83%83%E3%82%B8%E3%81%AE%E5%80%A4%E3%80%82FIFO%20%E3%81%AF%202%20%E3%82%A8%E3%83%B3%E3%83%88%E3%83%AA%E3%81%AB%E8%A8%AD%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FP%3E%3CP%3E*%E3%81%8A%E3%82%88%E3%81%B3ICF2%E3%81%8C%E7%9B%A3%E8%A6%96%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%93%E3%81%A7%E3%81%AF%E3%83%95%E3%83%AA%E3%83%BC%E3%83%A9%E3%83%B3%E3%83%8B%E3%83%B3%E3%82%B0%E3%83%A2%E3%83%BC%E3%83%89%E3%81%8C%E4%BD%BF%E7%94%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20eTimer%E3%83%81%E3%83%A3%E3%83%8D%E3%83%AB0-1%E3%81%AF%E3%82%AB%E3%82%B9%E3%82%B1%E3%83%BC%E3%83%89%E6%8E%A5%E7%B6%9A%E3%81%95%E3%82%8C%E3%80%8132%E3%83%93%E3%83%83%E3%83%88%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%81%A71sec%2F1Hz%E3%81%AE%E6%B8%AC%E5%AE%9A%E3%82%92%E5%AE%9F%E7%8F%BE%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%20style%3D%22min-height%3A%208pt%3B%20padding%3A%200px%3B%22%3E%26nbsp%3B%3C%2FP%3E%3CP%3E*%20EVB%E6%8E%A5%E7%B6%9A%3A%3C%2FP%3E%3CP%3E*%20P8.2-%20A%5B1%5D%20..eTimer0%20channel1%20%E5%85%A5%E5%8A%9B%E4%BF%A1%E5%8F%B7%3C%2FP%3E%3CP%3E%E2%80%BBP8.1-%20A%5B0%5D%20..GPIO%E5%87%BA%E5%8A%9B%E3%80%81%E6%B8%AC%E5%AE%9A%E5%91%A8%E6%9C%9F%E3%81%AE%E8%A1%A8%E7%A4%BA%E3%81%AB%E4%BD%BF%E7%94%A8%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20LINFlexD_0%20TXD%2FRXD(PB2%2FPB3)%E4%BF%A1%E5%8F%B7%E3%82%92%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89RS-232%E3%83%88%E3%83%A9%E3%83%B3%E3%82%B7%E3%83%BC%E3%83%90%E3%83%BC%E3%81%AB%E3%83%AB%E3%83%BC%E3%83%86%E3%82%A3%E3%83%B3%E3%82%B0%3C%2FP%3E%3CP%3E*%20%E3%83%89%E3%83%BC%E3%82%BF%E3%83%BC%E3%82%AB%E3%83%BC%E3%83%89%3A%3C%2FP%3E%3CP%3E*%20J17.11%E2%80%9312%E3%82%AA%E3%83%B3%E3%80%82%E3%80%82LINFlexD_0%20TXD(PB2)%E3%82%92%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%20J17.8%E2%80%939%E3%82%AA%E3%83%B3%E3%80%82%E3%80%82LINFlexD_0%20RXD(PB3)%E3%82%92%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%E3%83%9E%E3%82%B6%E3%83%BC%E3%83%9C%E3%83%BC%E3%83%89%3C%2FP%3E%3CP%3E*%20J14%20-%20SCI_RX%E3%82%AA%E3%83%B3%3C%2FP%3E%3CP%3E*%20J13%20-%20SCI_TX%E3%82%AA%E3%83%B3%3C%2FP%3E%3CP%3E*%20J25%20-%20SCI_PWR%E3%82%AA%E3%83%B3%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%E3%83%91%E3%83%AB%E3%82%B9%E4%BF%A1%E5%8F%B7%E3%82%92P8.2%E3%81%AB%E6%8E%A5%E7%B6%9A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E2%80%BBPC%E7%AB%AF%E6%9C%AB(19200%E3%80%818N1%E3%80%81%E3%81%AA%E3%81%97)%E3%81%A7%E7%B5%90%E6%9E%9C%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E*%E5%85%A5%E5%8A%9B%E4%BF%A1%E5%8F%B7%E3%81%AE%E5%91%A8%E6%B3%A2%E6%95%B0%2F%E3%83%87%E3%83%A5%E3%83%BC%E3%83%86%E3%82%A3%E3%82%92%E5%A4%89%E6%9B%B4%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E*%3C%2FP%3E%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%3CP%3E*%E3%83%86%E3%82%B9%E3%83%88HW%3AMPC57xx%3C%2FP%3E%3CP%3E*%20Maskset%3A%26nbsp%3B%201N65H%3C%2FP%3E%3CP%3E*%E5%AF%BE%E8%B1%A1%3Ainternal_FLASH%3C%2FP%3E%3CP%3E*%20Fsys%3A200MHz%20PLL%E3%80%8140MHz%E6%B0%B4%E6%99%B6%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%3C%2FP%3E%3CP%3E*%E3%82%BF%E3%83%BC%E3%83%9F%E3%83%8A%E3%83%AB%3A19200%E3%80%818N1%E3%80%81%E3%81%AA%E3%81%97%3C%2FP%3E%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1121335%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%85%A8%E8%88%AC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1121339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AeTimer%E5%91%A8%E6%B3%A2%E6%95%B0%E6%B8%AC%E5%AE%9AMPC5744P%20GHS614%E3%81%AE%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121339%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Petr%2C%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%92S32DS%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3FGHS%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%E3%81%AF%E3%81%9F%E3%81%8F%E3%81%95%E3%82%93%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%94%E5%AD%98%E7%9F%A5%E3%81%AE%E3%82%88%E3%81%86%E3%81%ABGHS%E3%81%AF%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%8C%E9%AB%98%E4%BE%A1%E3%81%A7%E3%81%99%E3%80%82%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%88%E3%82%A2%E3%83%83%E3%83%97%E3%82%B3%E3%83%BC%E3%83%89%E4%BB%A5%E5%A4%96%E3%81%AB%E3%82%82%E3%80%81%E3%82%BD%E3%83%BC%E3%82%B9%E3%82%92%E5%8F%96%E5%BE%97%E3%81%97%E3%81%A6S32DS%E3%83%87%E3%83%A2%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AB%E7%B5%B1%E5%90%88%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F(%E6%B3%A8%3A%E3%81%BE%E3%81%A0%E8%A9%A6%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93)%3C%2FP%3E%3CP%3E%E6%95%AC%E5%85%B7%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1121338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AeTimer%E5%91%A8%E6%B3%A2%E6%95%B0%E6%B8%AC%E5%AE%9AMPC5744P%20GHS614%E3%81%AE%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Petr%2C%3C%2FP%3E%3CP%3E%E7%9A%86%E6%A7%98%E3%81%AE%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%A8%E3%81%94%E6%94%AF%E6%8F%B4%E3%82%92%E8%B3%9C%E3%82%8A%E3%80%81%E8%AA%A0%E3%81%AB%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1121336%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%97%A5%E6%99%82%3AeTimer%E5%91%A8%E6%B3%A2%E6%95%B0%E6%B8%AC%E5%AE%9AMPC5744P%20GHS614%E3%81%AE%E4%BE%8B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1121336%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3EHi%20Petr%2C%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3EDMA%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E5%90%8C%E3%81%98%E3%81%93%E3%81%A8%E3%82%92%E8%A1%8C%E3%81%86%E3%81%93%E3%81%A8%E3%81%AF%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3CP%3E%3CA%20class%3D%22jx-jive-macro-user%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Fpeople%2FPetrS%22%20target%3D%22_blank%22%3EPetrS%3C%2FA%3E%20%3C%2FP%3E%3CP%3E%3C%2FP%3E%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%83%91%E3%83%83%E3%83%88%3C%2FP%3E%3C%2FLINGO-BODY%3E
評価なし
バージョン履歴
最終更新日:
‎03-20-2015 04:34 AM
更新者:
