Example MPC5554 eQADC+INTC Single Scan CW210
* Detailed Description:
* Initializes eQADC module, performs calibration and converts channel 0 and
* displays results into terminal window by interrupt service routine. Analog
* input AN[0] requires external connection to converted voltage (potentiometer).
* Test HW:        MPC5554EVB
* MCU:            MPC5554MVR132
* Fsys:           132/112/80/12 MHz
* Debugger:       Lauterbach Trace32
*                 PeMicro USB-ML-PPCNEXUS
* Target:         RAM, internal_FLASH
* Terminal:       19200-8-no parity-1 stop bit-no flow control on eSCI_A
* EVB connection: USER_DEV pin RV2(i.e. pin8) -> pin B7 on I/O header ring
*                 (potentiometer RV2 to analog input AN[0])
附件
评论
very good,thank you
Hello, I burned the program in this example into MPC5554evb, but I don’t know how to verify it. How can I test and verify this example on MPC5554evb?
%3CLINGO-SUB%20id%3D%22lingo-sub-1126361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E7%A4%BA%E4%BE%8B%20MPC5554%20eQADC%2BINTC%20%E5%8D%95%E6%89%AB%E6%8F%8F%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CPRE%20translate%3D%22no%22%3E********************************************************************************%3CBR%20%2F%3E*%20Detailed%20Description%3A%3CBR%20%2F%3E*%20Initializes%20eQADC%20module%2C%20performs%20calibration%20and%20converts%20channel%200%20and%3CBR%20%2F%3E*%20displays%20results%20into%20terminal%20window%20by%20interrupt%20service%20routine.%20Analog%3CBR%20%2F%3E*%20input%20AN%5B0%5D%20requires%20external%20connection%20to%20converted%20voltage%20(potentiometer).%3CBR%20%2F%3E*%20------------------------------------------------------------------------------%3CBR%20%2F%3E*%20Test%20HW%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MPC5554EVB%3CBR%20%2F%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MPC5554MVR132%3CBR%20%2F%3E*%20Fsys%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20132%2F112%2F80%2F12%20MHz%3CBR%20%2F%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3CBR%20%2F%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3CBR%20%2F%3E*%20Target%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20RAM%2C%20internal_FLASH%3CBR%20%2F%3E*%20Terminal%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%2019200-8-no%20parity-1%20stop%20bit-no%20flow%20control%20on%20eSCI_A%3CBR%20%2F%3E*%20EVB%20connection%3A%20USER_DEV%20pin%20RV2(i.e.%20pin8)%20-%26gt%3B%20pin%20B7%20on%20I%2FO%20header%20ring%3CBR%20%2F%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20(potentiometer%20RV2%20to%20analog%20input%20AN%5B0%5D)%26nbsp%3B%26nbsp%3B%3CBR%20%2F%3E*%3CBR%20%2F%3E********************************************************************************%3C%2FPRE%3E%3C%2FLINGO-BODY%3E%3CLINGO-TEASER%20id%3D%22lingo-teaser-1126361%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E********************************************************************************%3C%2FP%3E%0A%3CP%3E*%20%E8%AF%A6%E7%BB%86%E8%AF%B4%E6%98%8E%EF%BC%9A%3C%2FP%3E%0A%3CP%3E*%20%E5%88%9D%E5%A7%8B%E5%8C%96%20eQADC%20%E6%A8%A1%E5%9D%97%EF%BC%8C%E6%89%A7%E8%A1%8C%E6%A0%A1%E5%87%86%E5%B9%B6%E8%BD%AC%E6%8D%A2%E9%80%9A%E9%81%93%200%20%E5%92%8C%3C%2FP%3E%0A%3CP%3E*%20%E9%80%9A%E8%BF%87%E4%B8%AD%E6%96%AD%E6%9C%8D%E5%8A%A1%E7%A8%8B%E5%BA%8F%E5%B0%86%E7%BB%93%E6%9E%9C%E6%98%BE%E7%A4%BA%E5%88%B0%E7%BB%88%E7%AB%AF%E7%AA%97%E5%8F%A3%E3%80%82%E6%A8%A1%E6%8B%9F%3C%2FP%3E%0A%3CP%3E*%20%E8%BE%93%E5%85%A5%20AN%5B0%5D%20%E9%9C%80%E8%A6%81%E5%A4%96%E9%83%A8%E8%BF%9E%E6%8E%A5%E5%88%B0%E8%BD%AC%E6%8D%A2%E7%94%B5%E5%8E%8B%EF%BC%88%E7%94%B5%E4%BD%8D%E5%99%A8%EF%BC%89%E3%80%82%3C%2FP%3E%0A%3CP%3E*%20------------------------------------------------------------------------------%3C%2FP%3E%0A%3CP%3E*%20%E6%B5%8B%E8%AF%95%E7%A1%AC%E4%BB%B6%EF%BC%9AMPC5554EVB%3C%2FP%3E%0A%3CP%3E*%20MCU%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20MPC5554MVR132%3C%2FP%3E%0A%3CP%3E*%E7%B3%BB%E7%BB%9F%E9%A2%91%E7%8E%87%EF%BC%9A132%2F112%2F80%2F12%20MHz%3C%2FP%3E%0A%3CP%3E*%20Debugger%3A%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20Lauterbach%20Trace32%3C%2FP%3E%0A%3CP%3E*%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%26nbsp%3B%20PeMicro%20USB-ML-PPCNEXUS%3C%2FP%3E%0A%3CP%3E*%20%E7%9B%AE%E6%A0%87%EF%BC%9ARAM%E3%80%81internal_FLASH%3C%2FP%3E%0A%3CP%3E*%20%E7%BB%88%E7%AB%AF%EF%BC%9A19200-8-%E6%97%A0%E5%A5%87%E5%81%B6%E6%A0%A1%E9%AA%8C-1%20%E5%81%9C%E6%AD%A2%E4%BD%8D-eSCI_A%20%E4%B8%8A%E6%97%A0%E6%B5%81%E9%87%8F%E6%8E%A7%E5%88%B6%3C%2FP%3E%0A%3CP%3E*%20EVB%20%E8%BF%9E%E6%8E%A5%EF%BC%9AUSER_DEV%20%E5%BC%95%E8%84%9A%20RV2%EF%BC%88%E5%8D%B3%E5%BC%95%E8%84%9A%208%EF%BC%89-%26gt%3B%20I%2FO%20%E6%8E%A5%E5%A4%B4%E7%8E%AF%E4%B8%8A%E7%9A%84%E5%BC%95%E8%84%9A%20B7%3C%2FP%3E%0A%3CP%3E*%EF%BC%88%E7%94%B5%E4%BD%8D%E5%99%A8RV2%E8%BF%9E%E6%8E%A5%E8%87%B3%E6%A8%A1%E6%8B%9F%E8%BE%93%E5%85%A5AN%5B0%5D%EF%BC%89%3C%2FP%3E%0A%3CP%3E*%3C%2FP%3E%0A%3CP%3E********************************************************************************%3C%2FP%3E%3C%2FLINGO-TEASER%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1878110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20%E7%A4%BA%E4%BE%8B%20MPC5554%20eQADC%2BINTC%20%E5%8D%95%E6%89%AB%E6%8F%8F%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1878110%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%8A%8A%E8%BF%99%E4%B8%AA%E4%BE%8B%E5%AD%90%E4%B8%AD%E7%9A%84%E7%A8%8B%E5%BA%8F%E7%83%A7%E5%BD%95%E5%88%B0MPC5554evb%E4%B8%AD%EF%BC%8C%E4%BD%86%E6%98%AF%E4%B8%8D%E7%9F%A5%E9%81%93%E6%80%8E%E4%B9%88%E9%AA%8C%E8%AF%81%E3%80%82%E5%A6%82%E4%BD%95%E5%9C%A8%20MPC5554evb%20%E4%B8%8A%E6%B5%8B%E8%AF%95%E5%92%8C%E9%AA%8C%E8%AF%81%E6%AD%A4%E7%A4%BA%E4%BE%8B%EF%BC%9F%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1126362%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%E7%A4%BA%E4%BE%8B%20MPC5554%20eQADC%2BINTC%20%E5%8D%95%E6%89%AB%E6%8F%8F%20CW210%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1126362%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%26lt%3Bmeta%20http-equiv%3D%22Content-Type%22%20content%3D%22text%2Fhtml%3B%20charset%3Dutf-8%22%20%2F%26gt%3B%0A%3CP%3E%E9%9D%9E%E5%B8%B8%E5%A5%BD%EF%BC%8C%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E
无评分
版本历史
最后更新:
‎11-16-2022 07:27 AM
更新人:
