Write operation for internal flash in mcxa153 is not working
4,865 次查看
Gurunath
Hi, i want to use internal flash memory on mcxa-153 frdm development board, i went through the sdk example of flashiap in mcuxpresso ide , to know how to write or read from flash, but those API functions provided in example only works for read operation, any attempt to write to flash throws an bus fault.
below functions didnt work for me :-
FLASH_API->flash_erase_sector(&s_flashDriver, destAdrss, pflashSectorSize, kFLASH_ApiEraseKey);
FLASH_API->flash_program_page(&s_flashDriver, destAdrss, (uint8_t *)s_buffer, sizeof(s_buffer));
but any functions that attempts only to read flash is working fine like example:-
flash_verify_erase_sector(&s_flashDriver, destAdrss, pflashSectorSize);
FLASH_API->flash_verify_program(&s_flashDriver, destAdrss, sizeof(s_buffer), (const uint8_t *)s_buffer, &failedAddress, &failedData);
FLASH_API->flash_get_property(&s_flashDriver, kFLASH_PropertyPflashSectorSize, &pflashSectorSize);
destAdrss given here is last second sector address and block base address is 0x00 :-
#define SECTOR_INDEX_FROM_END 2U
destAdrss = pflashBlockBase + (pflashTotalSize - (SECTOR_INDEX_FROM_END * pflashSectorSize));
Can i please know if am missing something or using these functions wrongly?. Thank You
标签 (2)
4,669 次查看
Hello @Gurunath
Sorry above code is for new version SDK v2.16.0.
For SDK v2.14.0, please test below code:
__attribute__ ((weak)) void SystemInit (void) {
SCB->CPACR |= ((3UL << 0*2) | (3UL << 1*2)); /* set CP0, CP1 Full Access in Secure mode (enable PowerQuad) */
#if defined (__ARM_FEATURE_CMSE) && (__ARM_FEATURE_CMSE == 3U)
SCB_NS->CPACR |= ((3UL << 0*2) | (3UL << 1*2)); /* set CP0, CP1 Full Access in Normal mode (enable PowerQuad) */
#endif /* (__ARM_FEATURE_CMSE) && (__ARM_FEATURE_CMSE == 3U) */
SCB->NSACR |= ((3UL << 0) | (3UL << 10)); /* enable CP0, CP1, CP10, CP11 Non-secure Access */
#if defined(__MCUXPRESSO)
extern void(*const g_pfnVectors[]) (void);
SCB->VTOR = (uint32_t) &g_pfnVectors;
#else
extern void *__Vectors;
SCB->VTOR = (uint32_t) &__Vectors;
#endif
/* Enable the LPCAC */
SYSCON->LPCAC_CTRL |= SYSCON_LPCAC_CTRL_LPCAC_MEM_REQ_MASK;
SYSCON->LPCAC_CTRL &= ~SYSCON_LPCAC_CTRL_DIS_LPCAC_MASK;
/* Enable flash RWX when FLASH_ACL in IFR0 is invalid */
if ((*((volatile const uint32_t *)(0x1000000)) == 0xFFFFFFFFU) ||
((*((volatile const uint32_t *)(0x1000000)) == 0x59630000U) &&
(*((volatile const uint32_t *)(0x1000040)) == 0xFFFFFFFFU) &&
(*((volatile const uint32_t *)(0x1000044)) == 0xFFFFFFFFU)))
/* Enable MBC register written with GLIKEY index15 */
GLIKEY0->CTRL_0 = 0x00060000U;
GLIKEY0->CTRL_0 = 0x0002000FU;
GLIKEY0->CTRL_0 = 0x0001000FU;
GLIKEY0->CTRL_1 = 0x00290000U;
GLIKEY0->CTRL_1 = 0x00280000U;
GLIKEY0->CTRL_0 = 0x0000000FU;
/* Enable RWX for GLBAC0 */
MBC0->MBC0_MEMN_GLBAC[0] = 0x7700U;
/* Use GLBAC0 for all flash block */
// for (uint8_t i = 0; i < 2U; i++)
// MBC0->MBC_INDEX[0].MBC_DOM0_MEM0_BLK_CFG_W[i] = 0x00000000U;
MBC0->MBC_DOM0[0].MBC0_DOM_MEM0_BLK_CFG_W0 = 0x00000000U;
MBC0->MBC_DOM0[0].MBC0_DOM_MEM0_BLK_CFG_W1 = 0x00000000U;
/* Disable MBC register written */
SystemInitHook();
Alice
6 回复数
4,811 次查看
Hello @Gurunath
1) "below functions didn't work for me :"
->> Please describe more detail about how it didn't work. What the return status of "flash_program_page "?
2) Does the flashiap work well on your side? Please run it first.
Alice
4,808 次查看
Gurunath
Hi, i tried to run the example as it is without modification, but it didnt work, it gave an hard fault(bus error).
this error occurs only when functions like erase_sector or program_page were called(mostly those that performs write to flash).
Since in example, erase sector is being called first, execution doesnt return from function call due to this error, so the error message was not print based on return value.
i have got these active faults when run,
Active faults
Bus Fault (BFSR)
BFARVALID (7) BusFault Address Register (BFAR) valid flag
PRECISERR (1) Precise data bus error
Hard Fault (HFSR)
FORCED (30) Indicates a forced hard fault, generated by escalation of a fault with configurable priority that cannot be handled, either because of priority or because it is disabled
4,765 次查看
Hello @Gurunath
This is because in the default state after booting, the flash is protected by the ROM using the MBC and no erase/write operations are allowed. There are two ways to solve this:
  • Modify the CMPA to configure the default MBC setting as mentioned in the example's readme.
  • Configure the MBC in the application code, please refer to below code, this has been integrated in new SDK and will be released in next version.
#else
#endif
        MBC0->MBC_INDEX[0].MBC_MEMN_GLBAC[0] = 0x7700U;
  SystemInitHook();
Alice
4,711 次查看
Gurunath
Hi Alice, Thanks for clearing my doubt, i tried modifying system_init(), as you said but am getiing an error as mentioned below:
/device/system_MCXA153.c:98:17: error: 'MBC_Type' has no member named 'MBC_INDEX'
98 | MBC0->MBC_INDEX[0].MBC_MEMN_GLBAC[0] = 0x7700U;
../device/system_MCXA153.c:103:21: error: 'MBC_Type' has no member named 'MBC_INDEX'
103 | MBC0->MBC_INDEX[0].MBC_DOM0_MEM0_BLK_CFG_W[i] = 0x00000000U;
can you please help me with this?
Thank you
4,670 次查看
Hello @Gurunath
#else
#endif
SystemInitHook();
Alice
4,646 次查看
Gurunath
Thanks for the solution, It solved the issue.
%3CLINGO-SUB%20id%3D%22lingo-sub-1868376%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Emcxa153%20%E5%86%85%E9%83%A8%E9%97%AA%E5%AD%98%E7%9A%84%E5%86%99%E5%85%A5%E6%93%8D%E4%BD%9C%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868376%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%83%B3%E5%9C%A8%20mcxa-153%20frdm%20%E5%BC%80%E5%8F%91%E6%9D%BF%E4%B8%8A%E4%BD%BF%E7%94%A8%E5%86%85%E9%83%A8%E9%97%AA%E5%AD%98%EF%BC%8C%E6%88%91%E6%9F%A5%E7%9C%8B%E4%BA%86%20mcuxpresso%20ide%20%E4%B8%AD%20flashiap%20%E7%9A%84%20sdk%20%E7%A4%BA%E4%BE%8B%EF%BC%8C%E4%BA%86%E8%A7%A3%E5%A6%82%E4%BD%95%E5%86%99%E5%85%A5%E6%88%96%E8%AF%BB%E5%8F%96%E9%97%AA%E5%AD%98%EF%BC%8C%E4%BD%86%E7%A4%BA%E4%BE%8B%E4%B8%AD%E6%8F%90%E4%BE%9B%E7%9A%84%E9%82%A3%E4%BA%9B%20API%20%E5%87%BD%E6%95%B0%E4%BB%85%E9%80%82%E7%94%A8%E4%BA%8E%E8%AF%BB%E5%8F%96%E6%93%8D%E4%BD%9C%EF%BC%8C%E4%BB%BB%E4%BD%95%E5%86%99%E5%85%A5%E9%97%AA%E5%AD%98%E7%9A%84%E5%B0%9D%E8%AF%95%E9%83%BD%E4%BC%9A%E5%BC%95%E5%8F%91%E6%80%BB%E7%BA%BF%E6%95%85%E9%9A%9C%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E5%8A%9F%E8%83%BD%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%9A-%3C%2FP%3E%3CP%3EFLASH_API-%26gt%3Bflash_erase_sector(%26amp%3Bs_flashDriver%2C%20destAdrss%2C%20pflashSectorSize%2C%20kFLASH_ApiEraseKey)%3B%3C%2FP%3E%3CP%3EFLASH_API-%26gt%3Bflash_program_page(%26amp%3Bs_flashDriver%EF%BC%8C%E7%9B%AE%E6%A0%87%E5%9C%B0%E5%9D%80%EF%BC%8C(uint8_t%20*)s_buffer%EF%BC%8Csizeof(s_buffer))%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E4%BD%86%E4%BB%BB%E4%BD%95%E4%BB%85%E5%B0%9D%E8%AF%95%E8%AF%BB%E5%8F%96%E9%97%AA%E5%AD%98%E7%9A%84%E5%8A%9F%E8%83%BD%E9%83%BD%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E4%BE%8B%E5%A6%82%EF%BC%9A-%3C%2FP%3E%3CP%3Eflash_verify_erase_sector(%26amp%3Bs_flashDriver%2C%20destAdrss%2C%20pflashSectorSize)%3B%3C%2FP%3E%3CP%3EFLASH_API-%26gt%3Bflash_verify_program(%26amp%3Bs_flashDriver%EF%BC%8CdestAdrss%EF%BC%8Csizeof(s_buffer)%EF%BC%8C(const%20uint8_t%20*)s_buffer%EF%BC%8C%26amp%3BfailedAddress%EF%BC%8C%26amp%3BfailedData)%3B%3C%2FP%3E%3CP%3EFLASH_API-%26gt%3Bflash_get_property(%26amp%3Bs_flashDriver%EF%BC%8CkFLASH_PropertyPflashSectorSize%EF%BC%8C%26amp%3BpflashSectorSize)%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E9%87%8C%E7%BB%99%E5%87%BA%E7%9A%84%20destAdrss%20%E6%98%AF%E5%80%92%E6%95%B0%E7%AC%AC%E4%BA%8C%E4%B8%AA%E6%89%87%E5%8C%BA%E5%9C%B0%E5%9D%80%EF%BC%8C%E5%9D%97%E5%9F%BA%E5%9C%B0%E5%9D%80%E6%98%AF%200x00%20%3A-%3C%2FP%3E%3CP%3E%23%E5%AE%9A%E4%B9%89SECTOR_INDEX_FROM_END%202U%3C%2FP%3E%3CP%3EdestAdrss%20%3D%20pflashBlockBase%20%2B%20(pflashTotalSize%20-%20(SECTOR_INDEX_FROM_END%20*%20pflashSectorSize))%3B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%AF%B7%E9%97%AE%E6%88%91%E6%98%AF%E5%90%A6%E9%81%97%E6%BC%8F%E4%BA%86%E6%9F%90%E4%BA%9B%E4%B8%9C%E8%A5%BF%E6%88%96%E8%80%85%E9%94%99%E8%AF%AF%E5%9C%B0%E4%BD%BF%E7%94%A8%E4%BA%86%E8%BF%99%E4%BA%9B%E5%8A%9F%E8%83%BD%EF%BC%9F%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-1868376%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%90%AF%E5%8A%A8%20ROM%20%7C%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%20%7C%20%E9%97%AA%E5%AD%98%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EMCXA%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1878878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Amcxa153%20%E4%B8%AD%E7%9A%84%E5%86%85%E9%83%A8%E9%97%AA%E5%AD%98%E7%9A%84%E5%86%99%E5%85%A5%E6%93%8D%E4%BD%9C%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1878878%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%8C%E5%AE%83%E8%A7%A3%E5%86%B3%E4%BA%86%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1877991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Amcxa153%20%E4%B8%AD%E7%9A%84%E5%86%85%E9%83%A8%E9%97%AA%E5%AD%98%E7%9A%84%E5%86%99%E5%85%A5%E6%93%8D%E4%BD%9C%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1877991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232236%22%20target%3D%22_blank%22%3E%40Gurunath%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%8A%B1%E6%AD%89%EF%BC%8C%E4%BB%A5%E4%B8%8A%E4%BB%A3%E7%A0%81%E9%80%82%E7%94%A8%E4%BA%8E%E6%96%B0%E7%89%88%E6%9C%AC%20SDK%20v2.16.0%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%20SDK%20v2.14.0%EF%BC%8C%E8%AF%B7%E6%B5%8B%E8%AF%95%E4%BB%A5%E4%B8%8B%E4%BB%A3%E7%A0%81%EF%BC%9A%3C%2FP%3E%0A%3CDIV%20style%3D%22background-color%3A%20%23ffffff%3B%20padding%3A%200px%200px%200px%202px%3B%22%3E%0A%3CDIV%20style%3D%22color%3A%20%23000000%3B%20background-color%3A%20%23ffffff%3B%20font-family%3A%20'Consolas'%3B%20font-size%3A%2010pt%3B%20white-space%3A%20pre%3B%22%3E%0A%3CBLOCKQUOTE%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E__attribute__%3C%2FSPAN%3E%20%3CSPAN%3E((%E5%BC%B1))%3C%2FSPAN%3E%20%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3ESystemInit%3C%2FSPAN%3E%20%3CSPAN%3E(%3C%2FSPAN%3E%20%3CSPAN%3Evoid%3C%2FSPAN%3E%20%3CSPAN%3E)%20%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3ESCB-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECPACR%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3D%20((3UL%20%26lt%3B%26lt%3B%200*2)%20%7C%20(3UL%20%26lt%3B%26lt%3B%201*2))%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E5%9C%A8%E5%AE%89%E5%85%A8%E6%A8%A1%E5%BC%8F%E4%B8%8B%E8%AE%BE%E7%BD%AE%20CP0%E3%80%81CP1%20%E5%AE%8C%E5%85%A8%E8%AE%BF%E9%97%AE%EF%BC%88%E5%90%AF%E7%94%A8%20PowerQuad%EF%BC%89*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20%23e0e0e0%3B%20margin%3A%200%3B%22%3E%3CSPAN%3E%23%E5%A6%82%E6%9E%9C%3C%2FSPAN%3E%3CSPAN%3E%E5%AE%9A%E4%B9%89%EF%BC%88__ARM_FEATURE_CMSE%EF%BC%89%26amp%3B%26amp%3B%EF%BC%88__ARM_FEATURE_CMSE%20%3D%3D%203U%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20%23e0e0e0%3B%20margin%3A%200%3B%22%3E%3CSPAN%3ESCB_NS-%26gt%3BCPACR%20%7C%3D%20((3UL%20%26lt%3B%26lt%3B%200*2)%20%7C%20(3UL%20%26lt%3B%26lt%3B%201*2))%3B%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20%E5%9C%A8%E6%AD%A3%E5%B8%B8%E6%A8%A1%E5%BC%8F%E4%B8%8B%E8%AE%BE%E7%BD%AE%20CP0%E3%80%81CP1%20%E5%AE%8C%E5%85%A8%E8%AE%BF%E9%97%AE%EF%BC%88%E5%90%AF%E7%94%A8%20PowerQuad%EF%BC%89*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20%23e0e0e0%3B%20margin%3A%200%3B%22%3E%3CSPAN%3E%23endif%3C%2FSPAN%3E%20%3CSPAN%3E%2F*%20(__ARM_FEATURE_CMSE)%20%26amp%3B%26amp%3B%20(__ARM_FEATURE_CMSE%20%3D%3D%203U)%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20SCB-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ENSACR%3C%2FSPAN%3E%3CSPAN%3E%20%7C%3D%20((3UL%20%26lt%3B%26lt%3B%200)%20%7C%20(3UL%20%26lt%3B%26lt%3B%2010))%3B%20%3C%2FSPAN%3E%3CSPAN%3E%2F*%20enable%20CP0%2C%20CP1%2C%20CP10%2C%20CP11%20Non-secure%20Access%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%23if%3C%2FSPAN%3E%3CSPAN%3E%20defined(__MCUXPRESSO)%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%E5%A4%96%E9%83%A8%3C%2FSPAN%3E%3CSPAN%3E%E6%97%A0%E6%95%88%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%88*%3C%2FSPAN%3E%20%3CSPAN%3Econst%3C%2FSPAN%3E%20%3CSPAN%3Eg_pfnVectors%5B%5D%EF%BC%89%EF%BC%88%3C%2FSPAN%3E%3CSPAN%3E%E6%97%A0%E6%95%88%3C%2FSPAN%3E%3CSPAN%3E%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3ESCB-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3EVTOR%3C%2FSPAN%3E%20%3CSPAN%3E%3D%EF%BC%88%3C%2FSPAN%3E%20%3CSPAN%3Euint32_t%3C%2FSPAN%3E%20%3CSPAN%3E%EF%BC%89%26amp%3Bg_pfnVectors%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20%23e0e0e0%3B%20margin%3A%200%3B%22%3E%3CSPAN%3E%23else%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20%23e0e0e0%3B%20margin%3A%200%3B%22%3E%3CSPAN%3E%E5%A4%96%E9%83%A8%3C%2FSPAN%3E%3CSPAN%3E%E6%97%A0%E6%95%88%3C%2FSPAN%3E%3CSPAN%3E*__%E5%90%91%E9%87%8F%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20%23e0e0e0%3B%20margin%3A%200%3B%22%3E%3CSPAN%3E%20SCB-%26gt%3BVTOR%20%3D%20(uint32_t)%20%26amp%3B__Vectors%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22background-color%3A%20%23e0e0e0%3B%20margin%3A%200%3B%22%3E%3CSPAN%3E%23endif%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F*%20%E5%90%AF%E7%94%A8%20LPCAC%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3ESYSCON-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ELPCAC_CTRL%3C%2FSPAN%3E%20%3CSPAN%3E%7C%3D%20SYSCON_LPCAC_CTRL_LPCAC_MEM_REQ_MASK%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20SYSCON-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3ELPCAC_CTRL%3C%2FSPAN%3E%3CSPAN%3E%20%26amp%3B%3D%20~SYSCON_LPCAC_CTRL_DIS_LPCAC_MASK%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F*%20%E5%BD%93%20IFR0%20%E4%B8%AD%E7%9A%84%20FLASH_ACL%20%E6%97%A0%E6%95%88%E6%97%B6%E5%90%AF%E7%94%A8%E9%97%AA%E5%AD%98%20RWX%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3Eif%3C%2FSPAN%3E%3CSPAN%3E%20((*((%3C%2FSPAN%3E%3CSPAN%3Evolatile%3C%2FSPAN%3E%20%3CSPAN%3Econst%3C%2FSPAN%3E%20%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%20*)(0x1000000))%20%3D%3D%200xFFFFFFFFU)%20%7C%7C%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20((*((%3C%2FSPAN%3E%3CSPAN%3Evolatile%3C%2FSPAN%3E%20%3CSPAN%3Econst%3C%2FSPAN%3E%20%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%20*)(0x1000000))%20%3D%3D%200x59630000U)%20%26amp%3B%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20(*((%3C%2FSPAN%3E%3CSPAN%3Evolatile%3C%2FSPAN%3E%20%3CSPAN%3Econst%3C%2FSPAN%3E%20%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%20*)(0x1000040))%20%3D%3D%200xFFFFFFFFU)%20%26amp%3B%26amp%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20(*((%3C%2FSPAN%3E%3CSPAN%3Evolatile%3C%2FSPAN%3E%20%3CSPAN%3Econst%3C%2FSPAN%3E%20%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3E%20*)(0x1000044))%20%3D%3D%200xFFFFFFFFU)))%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F*%20%E5%90%AF%E7%94%A8%E4%BD%BF%E7%94%A8%20GLIKEY%20%E7%B4%A2%E5%BC%95%2015%20%E5%86%99%E5%85%A5%E7%9A%84%20MBC%20%E5%AF%84%E5%AD%98%E5%99%A8%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3EGLIKEY0-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECTRL_0%3C%2FSPAN%3E%20%3CSPAN%3E%3D%200x00060000U%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3EGLIKEY0-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECTRL_0%3C%2FSPAN%3E%20%3CSPAN%3E%3D%200x0002000FU%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3EGLIKEY0-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECTRL_0%3C%2FSPAN%3E%20%3CSPAN%3E%3D%200x0001000FU%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3EGLIKEY0-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECTRL_1%3C%2FSPAN%3E%20%3CSPAN%3E%3D%200x00290000U%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3EGLIKEY0-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECTRL_0%3C%2FSPAN%3E%20%3CSPAN%3E%3D%200x0002000FU%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3EGLIKEY0-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECTRL_1%3C%2FSPAN%3E%20%3CSPAN%3E%3D%200x00280000U%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3EGLIKEY0-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECTRL_0%3C%2FSPAN%3E%20%3CSPAN%3E%3D%200x0000000FU%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F*%20%E5%90%AF%E7%94%A8%20GLBAC0%20%E7%9A%84%20RWX%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20MBC0-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMBC0_MEMN_GLBAC%3C%2FSPAN%3E%3CSPAN%3E%5B0%5D%20%3D%200x7700U%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F*%20%E6%89%80%E6%9C%89%E9%97%AA%E5%AD%98%E5%9D%97%E5%9D%87%E4%BD%BF%E7%94%A8%20GLBAC0%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%20for%20(uint8_t%20i%20%3D%200%3B%20i%20%26lt%3B%202U%3B%20i%2B%2B)%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%20%7B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%20MBC0-%26gt%3BMBC_INDEX%5B0%5D.MBC_DOM0_MEM0_BLK_CFG_W%5Bi%5D%20%3D%200x00000000U%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F%2F%20%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20MBC0-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMBC_DOM0%3C%2FSPAN%3E%3CSPAN%3E%5B0%5D.%3C%2FSPAN%3E%3CSPAN%3EMBC0_DOM_MEM0_BLK_CFG_W0%3C%2FSPAN%3E%3CSPAN%3E%20%3D%200x00000000U%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20MBC0-%26gt%3B%3C%2FSPAN%3E%3CSPAN%3EMBC_DOM0%3C%2FSPAN%3E%3CSPAN%3E%5B0%5D.%3C%2FSPAN%3E%3CSPAN%3EMBC0_DOM_MEM0_BLK_CFG_W1%3C%2FSPAN%3E%3CSPAN%3E%20%3D%200x00000000U%3B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%2F*%20%E7%A6%81%E7%94%A8%20MBC%20%E5%AF%84%E5%AD%98%E5%99%A8%E5%86%99%E5%85%A5%20*%2F%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3EGLIKEY0-%26gt%3B%3C%2FSPAN%3E%20%3CSPAN%3ECTRL_0%3C%2FSPAN%3E%20%3CSPAN%3E%3D%200x0002000FU%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%20%E7%B3%BB%E7%BB%9F%E5%88%9D%E5%A7%8B%E5%8C%96%E9%92%A9%E5%AD%90()%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3C%2FBLOCKQUOTE%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3EBR%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20style%3D%22margin%3A%200%3B%22%3E%3CSPAN%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FSPAN%3E%3C%2FP%3E%0A%3C%2FDIV%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1875338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Amcxa153%20%E4%B8%AD%E7%9A%84%E5%86%85%E9%83%A8%E9%97%AA%E5%AD%98%E7%9A%84%E5%86%99%E5%85%A5%E6%93%8D%E4%BD%9C%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1875338%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E7%88%B1%E4%B8%BD%E4%B8%9D%EF%BC%8C%E6%84%9F%E8%B0%A2%E6%82%A8%E6%B6%88%E9%99%A4%E6%88%91%E7%9A%84%E7%96%91%E8%99%91%EF%BC%8C%E6%88%91%E5%B0%9D%E8%AF%95%E4%BF%AE%E6%94%B9%20system_init()%EF%BC%8C%E6%AD%A3%E5%A6%82%E6%82%A8%E6%89%80%E8%AF%B4%E7%9A%84%EF%BC%8C%E4%BD%86%E5%87%BA%E7%8E%B0%E4%BA%86%E5%A6%82%E4%B8%8B%E6%89%80%E7%A4%BA%E7%9A%84%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3E%2Fdevice%2Fsystem_MCXA153.c%3A98%3A17%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E2%80%9CMBC_Type%E2%80%9D%E6%B2%A1%E6%9C%89%E5%90%8D%E4%B8%BA%E2%80%9CMBC_INDEX%E2%80%9D%E7%9A%84%E6%88%90%E5%91%98%3CBR%20%2F%3E98%20%7C%2098%20MBC0-%26gt%3BMBC_INDEX%5B0%5D.MBC_MEMN_GLBAC%5B0%5D%20%3D%200x7700U%EF%BC%9B%3CBR%20%2F%3E%20%7C%20%5E~%3CBR%20%2F%3E%20..%2Fdevice%2Fsystem_MCXA153.c%3A103%3A21%3A%20%E9%94%99%E8%AF%AF%EF%BC%9A%E2%80%9CMBC_Type%E2%80%9D%E6%B2%A1%E6%9C%89%E5%90%8D%E4%B8%BA%E2%80%9CMBC_INDEX%E2%80%9D%E7%9A%84%E6%88%90%E5%91%98%3CBR%20%2F%3E103%20%7C%20MBC0-%26gt%3BMBC_INDEX%5B0%5D.MBC_DOM0_MEM0_BLK_CFG_W%5Bi%5D%20%3D%200x00000000U%3B%3C%2FP%3E%3CP%3E%E4%BD%A0%E8%83%BD%E5%B8%AE%E6%88%91%E4%B8%80%E4%B8%8B%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1874472%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Amcxa153%20%E4%B8%AD%E7%9A%84%E5%86%85%E9%83%A8%E9%97%AA%E5%AD%98%E7%9A%84%E5%86%99%E5%85%A5%E6%93%8D%E4%BD%9C%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1874472%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232236%22%20target%3D%22_blank%22%3E%40Gurunath%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%98%AF%E5%9B%A0%E4%B8%BA%E5%9C%A8%E5%90%AF%E5%8A%A8%E5%90%8E%E7%9A%84%E9%BB%98%E8%AE%A4%E7%8A%B6%E6%80%81%E4%B8%8B%EF%BC%8C%E9%97%AA%E5%AD%98%E5%8F%97%E5%88%B0%E4%BD%BF%E7%94%A8%20MBC%20%E7%9A%84%20ROM%20%E7%9A%84%E4%BF%9D%E6%8A%A4%EF%BC%8C%E4%B8%8D%E5%85%81%E8%AE%B8%E8%BF%9B%E8%A1%8C%E4%BB%BB%E4%BD%95%E6%93%A6%E9%99%A4%2F%E5%86%99%E5%85%A5%E6%93%8D%E4%BD%9C%E3%80%82%E6%9C%89%E4%B8%A4%E7%A7%8D%E6%96%B9%E6%B3%95%E5%8F%AF%E4%BB%A5%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9A%3C%2FP%3E%0A%3CUL%3E%0A%3CLI%3E%E4%BF%AE%E6%94%B9%20CMPA%20%E4%BB%A5%E9%85%8D%E7%BD%AE%E7%A4%BA%E4%BE%8B%E8%87%AA%E8%BF%B0%E6%96%87%E4%BB%B6%E4%B8%AD%E6%8F%90%E5%88%B0%E7%9A%84%E9%BB%98%E8%AE%A4%20MBC%20%E8%AE%BE%E7%BD%AE%E3%80%82%3C%2FLI%3E%0A%3CLI%3E%E5%9C%A8%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%BB%A3%E7%A0%81%E4%B8%AD%E9%85%8D%E7%BD%AEMBC%EF%BC%8C%E8%AF%B7%E5%8F%82%E8%80%83%E4%B8%8B%E9%9D%A2%E7%9A%84%E4%BB%A3%E7%A0%81%EF%BC%8C%E8%BF%99%E5%B7%B2%E7%BB%8F%E9%9B%86%E6%88%90%E5%9C%A8%E6%96%B0%E7%9A%84SDK%E4%B8%AD%EF%BC%8C%E5%B0%86%E5%9C%A8%E4%B8%8B%E4%B8%80%E4%B8%AA%E7%89%88%E6%9C%AC%E4%B8%AD%E5%8F%91%E5%B8%83%E3%80%82%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CPRE%20class%3D%22lia-code-sample%20%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3E__attribute__%20((weak))%20void%20SystemInit%20(void)%20%7B%0A%0A%20%20SCB-%26gt%3BCPACR%20%7C%3D%20((3UL%20%26lt%3B%26lt%3B%200*2)%20%7C%20(3UL%20%26lt%3B%26lt%3B%201*2))%3B%20%20%20%20%2F*%20set%20CP0%2C%20CP1%20Full%20Access%20in%20Secure%20mode%20(enable%20PowerQuad)%20*%2F%0A%23if%20defined%20(__ARM_FEATURE_CMSE)%20%26amp%3B%26amp%3B%20(__ARM_FEATURE_CMSE%20%3D%3D%203U)%0A%20%20SCB_NS-%26gt%3BCPACR%20%7C%3D%20((3UL%20%26lt%3B%26lt%3B%200*2)%20%7C%20(3UL%20%26lt%3B%26lt%3B%201*2))%3B%20%20%20%20%2F*%20set%20CP0%2C%20CP1%20Full%20Access%20in%20Normal%20mode%20(enable%20PowerQuad)%20*%2F%0A%23endif%20%2F*%20(__ARM_FEATURE_CMSE)%20%26amp%3B%26amp%3B%20(__ARM_FEATURE_CMSE%20%3D%3D%203U)%20*%2F%0A%0A%20%20SCB-%26gt%3BNSACR%20%7C%3D%20((3UL%20%26lt%3B%26lt%3B%200)%20%7C%20(3UL%20%26lt%3B%26lt%3B%2010))%3B%20%20%20%2F*%20enable%20CP0%2C%20CP1%2C%20CP10%2C%20CP11%20Non-secure%20Access%20*%2F%0A%0A%23if%20defined(__MCUXPRESSO)%0A%20%20%20%20extern%20void(*const%20g_pfnVectors%5B%5D)%20(void)%3B%0A%20%20%20%20SCB-%26gt%3BVTOR%20%3D%20(uint32_t)%20%26amp%3Bg_pfnVectors%3B%0A%23else%0A%20%20%20%20extern%20void%20*__Vectors%3B%0A%20%20%20%20SCB-%26gt%3BVTOR%20%3D%20(uint32_t)%20%26amp%3B__Vectors%3B%0A%23endif%0A%20%20%20%20%2F*%20Enable%20the%20LPCAC%20*%2F%0A%20%20%20%20SYSCON-%26gt%3BLPCAC_CTRL%20%7C%3D%20SYSCON_LPCAC_CTRL_LPCAC_MEM_REQ_MASK%3B%0A%20%20%20%20SYSCON-%26gt%3BLPCAC_CTRL%20%26amp%3B%3D%20~SYSCON_LPCAC_CTRL_DIS_LPCAC_MASK%3B%0A%0A%20%20%20%20%2F*%20Enable%20flash%20RWX%20when%20FLASH_ACL%20in%20IFR0%20is%20invalid%20*%2F%0A%20%20%20%20if%20((*((volatile%20const%20uint32_t%20*)(0x1000000))%20%3D%3D%200xFFFFFFFFU)%20%7C%7C%0A%20%20%20%20%20%20%20%20((*((volatile%20const%20uint32_t%20*)(0x1000000))%20%3D%3D%200x59630000U)%20%26amp%3B%26amp%3B%0A%20%20%20%20%20%20%20%20%20(*((volatile%20const%20uint32_t%20*)(0x1000040))%20%3D%3D%200xFFFFFFFFU)%20%26amp%3B%26amp%3B%0A%20%20%20%20%20%20%20%20%20(*((volatile%20const%20uint32_t%20*)(0x1000044))%20%3D%3D%200xFFFFFFFFU)))%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%2F*%20Enable%20MBC%20register%20written%20with%20GLIKEY%20index15%20*%2F%0A%20%20%20%20%20%20%20%20GLIKEY0-%26gt%3BCTRL_0%20%3D%200x00060000U%3B%0A%20%20%20%20%20%20%20%20GLIKEY0-%26gt%3BCTRL_0%20%3D%200x0002000FU%3B%0A%20%20%20%20%20%20%20%20GLIKEY0-%26gt%3BCTRL_0%20%3D%200x0001000FU%3B%0A%20%20%20%20%20%20%20%20GLIKEY0-%26gt%3BCTRL_1%20%3D%200x00290000U%3B%0A%20%20%20%20%20%20%20%20GLIKEY0-%26gt%3BCTRL_0%20%3D%200x0002000FU%3B%0A%20%20%20%20%20%20%20%20GLIKEY0-%26gt%3BCTRL_1%20%3D%200x00280000U%3B%0A%20%20%20%20%20%20%20%20GLIKEY0-%26gt%3BCTRL_0%20%3D%200x0000000FU%3B%0A%0A%20%20%20%20%20%20%20%20%2F*%20Enable%20RWX%20for%20GLBAC0%20*%2F%0A%20%20%20%20%20%20%20%20MBC0-%26gt%3BMBC_INDEX%5B0%5D.MBC_MEMN_GLBAC%5B0%5D%20%3D%200x7700U%3B%0A%0A%20%20%20%20%20%20%20%20%2F*%20Use%20GLBAC0%20for%20all%20flash%20block%20*%2F%0A%20%20%20%20%20%20%20%20for%20(uint8_t%20i%20%3D%200%3B%20i%20%26lt%3B%202U%3B%20i%2B%2B)%0A%20%20%20%20%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20%20%20%20%20MBC0-%26gt%3BMBC_INDEX%5B0%5D.MBC_DOM0_MEM0_BLK_CFG_W%5Bi%5D%20%3D%200x00000000U%3B%0A%20%20%20%20%20%20%20%20%7D%0A%0A%20%20%20%20%20%20%20%20%2F*%20Disable%20MBC%20register%20written%20*%2F%0A%20%20%20%20%20%20%20%20GLIKEY0-%26gt%3BCTRL_0%20%3D%200x0002000FU%3B%0A%20%20%20%20%7D%0A%20%20SystemInitHook()%3B%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1868776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Amcxa153%20%E4%B8%AD%E7%9A%84%E5%86%85%E9%83%A8%E9%97%AA%E5%AD%98%E7%9A%84%E5%86%99%E5%85%A5%E6%93%8D%E4%BD%9C%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868776%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E5%B0%9D%E8%AF%95%E6%8C%89%E5%8E%9F%E6%A0%B7%E8%BF%90%E8%A1%8C%E8%AF%A5%E7%A4%BA%E4%BE%8B%E8%80%8C%E4%B8%8D%E8%BF%9B%E8%A1%8C%E4%BF%AE%E6%94%B9%EF%BC%8C%E4%BD%86%E6%98%AF%E5%AE%83%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%8C%E5%87%BA%E7%8E%B0%E4%BA%86%E7%A1%AC%E6%95%85%E9%9A%9C%EF%BC%88%E6%80%BB%E7%BA%BF%E9%94%99%E8%AF%AF%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%85%E5%BD%93%E8%B0%83%E7%94%A8%E8%AF%B8%E5%A6%82erase_sector%E6%88%96program_page%E4%B9%8B%E7%B1%BB%E7%9A%84%E5%87%BD%E6%95%B0%EF%BC%88%E4%B8%BB%E8%A6%81%E6%98%AF%E6%89%A7%E8%A1%8C%E5%86%99%E5%85%A5%E9%97%AA%E5%AD%98%E7%9A%84%E5%87%BD%E6%95%B0%EF%BC%89%E6%97%B6%E6%89%8D%E4%BC%9A%E5%8F%91%E7%94%9F%E6%AD%A4%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%3CP%3E%E7%94%B1%E4%BA%8E%E5%9C%A8%E7%A4%BA%E4%BE%8B%E4%B8%AD%E9%A6%96%E5%85%88%E8%B0%83%E7%94%A8%E4%BA%86%E6%93%A6%E9%99%A4%E6%89%87%E5%8C%BA%EF%BC%8C%E7%94%B1%E4%BA%8E%E6%AD%A4%E9%94%99%E8%AF%AF%EF%BC%8C%E6%89%A7%E8%A1%8C%E4%B8%8D%E4%BC%9A%E4%BB%8E%E5%87%BD%E6%95%B0%E8%B0%83%E7%94%A8%E8%BF%94%E5%9B%9E%EF%BC%8C%E5%9B%A0%E6%AD%A4%E4%B8%8D%E4%BC%9A%E6%A0%B9%E6%8D%AE%E8%BF%94%E5%9B%9E%E5%80%BC%E6%89%93%E5%8D%B0%E9%94%99%E8%AF%AF%E6%B6%88%E6%81%AF%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E8%BF%90%E8%A1%8C%E6%97%B6%E9%81%87%E5%88%B0%E4%BA%86%E8%BF%99%E4%BA%9B%E6%B4%BB%E5%8A%A8%E6%95%85%E9%9A%9C%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%B4%BB%E5%8A%A8%E6%96%AD%E5%B1%82%3CBR%20%2F%3E%E6%80%BB%E7%BA%BF%E6%95%85%E9%9A%9C%20(BFSR)%3CBR%20%2F%3E%20BFARVALID%20(7)%20%E6%80%BB%E7%BA%BF%E6%95%85%E9%9A%9C%E5%9C%B0%E5%9D%80%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%88BFAR%EF%BC%89%E6%9C%89%E6%95%88%E6%A0%87%E5%BF%97%3CBR%20%2F%3EPRECISERR%20(1)%20%E7%B2%BE%E7%A1%AE%E6%95%B0%E6%8D%AE%E6%80%BB%E7%BA%BF%E9%94%99%E8%AF%AF%3CBR%20%2F%3E%E7%A1%AC%E6%95%85%E9%9A%9C%EF%BC%88HFSR%EF%BC%89%3CBR%20%2F%3E%20FORCED%EF%BC%8830%EF%BC%89%E8%A1%A8%E7%A4%BA%E5%BC%BA%E5%88%B6%E7%A1%AC%E6%95%85%E9%9A%9C%EF%BC%8C%E7%94%B1%E5%8F%AF%E9%85%8D%E7%BD%AE%E4%BC%98%E5%85%88%E7%BA%A7%E7%9A%84%E6%95%85%E9%9A%9C%E5%8D%87%E7%BA%A7%E8%80%8C%E4%BA%A7%E7%94%9F%EF%BC%8C%E7%94%B1%E4%BA%8E%E4%BC%98%E5%85%88%E7%BA%A7%E6%88%96%E8%A2%AB%E7%A6%81%E7%94%A8%E8%80%8C%E6%97%A0%E6%B3%95%E5%A4%84%E7%90%86%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1868764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9Amcxa153%20%E4%B8%AD%E7%9A%84%E5%86%85%E9%83%A8%E9%97%AA%E5%AD%98%E7%9A%84%E5%86%99%E5%85%A5%E6%93%8D%E4%BD%9C%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1868764%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F232236%22%20target%3D%22_blank%22%3E%40Gurunath%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E1)%E2%80%9C%3CSPAN%3E%E4%BB%A5%E4%B8%8B%E5%8A%9F%E8%83%BD%E5%AF%B9%E6%88%91%E6%9D%A5%E8%AF%B4%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%EF%BC%9A%3C%2FSPAN%3E%20%E2%80%9D%3C%2FP%3E%0A%3CP%3E-%26gt%3B%26gt%3B%20%E8%AF%B7%E6%9B%B4%E8%AF%A6%E7%BB%86%E5%9C%B0%E6%8F%8F%E8%BF%B0%E5%AE%83%E4%B8%BA%E4%BD%95%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E2%80%9C%20%3CSPAN%3Eflash_program_page%3C%2FSPAN%3E%20%E2%80%9D%E7%9A%84%E8%BF%94%E5%9B%9E%E7%8A%B6%E6%80%81%E6%98%AF%E4%BB%80%E4%B9%88%EF%BC%9F%3C%2FP%3E%0A%3CP%3E2)%20%E6%82%A8%E8%BF%99%E8%BE%B9%E7%9A%84%20flashiap%20%E8%BF%90%E8%A1%8C%E8%89%AF%E5%A5%BD%E5%90%97%EF%BC%9F%E8%AF%B7%E5%85%88%E8%BF%90%E8%A1%8C%E5%AE%83%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E7%88%B1%E4%B8%BD%E4%B8%9D%3C%2FP%3E%3C%2FLINGO-BODY%3E
