Wake up time benchmark i.MX93 from different sleep modes
2,038 次查看
Geuze
Hello everyone,
we would like to use the i.MX93for a GUI application which after some time enters a sleep mode. Now I would like to know if anyone has an idea how long it takes from the sleep mode to be fully operational again. I thought I have seen a table somewhere (for at least the time until the Linux terminal is ready) with the related benchmarks, but I can't find it anymore in the documentation.
Does anyone know where the documentation is or has even self measured or tested how long it takes to wakeup? The wakeup sources are the M33 LPUART or an attached touchscreen.
Best regards, Mike
1,882 次查看
Zhiming_Liu
All of the documentation is on this page, and there doesn't seem to be the documentation you describe.
https://www.nxp.com/products/processors-and-microcontrollers/arm-processors/i-mx-applications-proces...
You can remeasure the time according to AN14205.
Zhiming
6 回复数
2,019 次查看
Zhiming_Liu
1,981 次查看
Geuze
Hello Zhiming Liu,
thank you for your response, but these are not the measurements I had in mind. I am pretty sure, I found a documentation somewhere around where the time from leaving different sleep modes till the point where Linux terminal is ready for new inputs was measured. But sadly I cannot find this document anymore.
Best regards, Michael
1,964 次查看
Zhiming_Liu
Do you still remember the location of document, nxp website or community?
Zhiming
1,936 次查看
Geuze
Hello Zhiming,
I am pretty sure it was the NXP website. The page had almost the exact same look like the power benchmarks you posted in the previous answer.
In one column there where the different sleep modes listed and in one of the other colums there were the times until Linux terminal is ready for input. Maybe there were a few columns in between, but these were the ones which were important for my use case.
Michael
1,883 次查看
Zhiming_Liu
Zhiming
1,874 次查看
Geuze
Hello Zhiming,
thanks for your effort and time regarding my question.
I will mark your last post as solution for now. If I stumble upon the documentation I meant later, I will link it here.
Michael
