Voltage specification for externally provided clock signal (MCX A185 VLH)
ソリューションへジャンプ
846件の閲覧回数
wyss-11
I can not find the max. voltage allowed at the EXTAL48M pin for the MCXA185VLH MCU in the datasheets.
I know from the LPCxxx families of microcontrollers that the oscillator input is very picky about this amplitude (0.85Vpp or similar).
Can I feed an externally generated 3.3V oscillator clock signal directly to the EXTAL48M pin?
ラベル(2)
776件の閲覧回数
carlos_o
Hi @wyss-11
The VEC specification refers to the minimum voltage levels required by the external oscillator input to recognize valid low and high states.
When VDD = 3.3 V, 2.31 V is the minimum voltage that will be detected as a valid high level.
3 返答(返信)
800件の閲覧回数
wyss-11
Thanks for your post.
Yes, the datasheet specifies Vec (Externally provided input clock amplitude) with max. voltage as VIH. But as VIH is 0.7xVDD, this would mean that with VDD=3.3V, Vec max. would be 2.31V only.
So either this datasheet specification is wrong, or Vec max. is really 2.31V in case of VDD=3.3V?
777件の閲覧回数
carlos_o
Hi @wyss-11
817件の閲覧回数
carlos_o
Hi @wyss-11
Thanks for your post!
MCXA18 does have an EXTAL48M input voltage definition, but it is specified indirectly through the standard input thresholds VIH/VIL relative to VDD, not as a separate fixed EXTAL48M voltage value.
The datasheet only stands the Peak-to-peak amplitude of oscillation as typical value of 0.6V.
When VDD is 3.3 V, EXTAL48M can be driven by a 3.3 V external oscillator as long as the clock meets the VIH/VIL thresholds and does not exceed the VDD + 0.3 V input limit.
%3CLINGO-SUB%20id%3D%22lingo-sub-2383149%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A4%96%E9%83%A8%E4%BE%9B%E7%B5%A6%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E4%BF%A1%E5%8F%B7%E3%81%AE%E9%9B%BB%E5%9C%A7%E4%BB%95%E6%A7%98%EF%BC%88MCX%20A185%20VLH%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383149%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9C%80%E5%A4%A7%E5%80%A4%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E4%B8%8A%E3%81%AEMCXA185VLH%20MCU%E3%81%AEEXTAL48M%E3%83%94%E3%83%B3%E3%81%A7%E8%A8%B1%E5%AE%B9%E3%81%95%E3%82%8C%E3%82%8B%E9%9B%BB%E5%9C%A7%E3%80%82%3C%2FP%3E%3CP%3ELPCxxx%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA%E3%81%AE%E3%83%9E%E3%82%A4%E3%82%AF%E3%83%AD%E3%82%B3%E3%83%B3%E3%83%88%E3%83%AD%E3%83%BC%E3%83%A9%E3%81%A7%E3%81%AF%E3%80%81%E7%99%BA%E6%8C%AF%E5%99%A8%E5%85%A5%E5%8A%9B%E3%81%8C%E3%81%93%E3%81%AE%E6%8C%AF%E5%B9%85(0.85Vpp%E3%81%AA%E3%81%A9)%E3%81%AB%E9%9D%9E%E5%B8%B8%E3%81%AB%E5%8E%B3%E6%A0%BC%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%9F%A5%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%A4%96%E9%83%A8%E3%81%8B%E3%82%89%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%9F3.3V%E3%81%AE%E7%99%BA%E6%8C%AF%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E4%BF%A1%E5%8F%B7%E3%82%92%E7%9B%B4%E6%8E%A5EXTAL48M%E3%83%94%E3%83%B3%E3%81%AB%E9%80%81%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2383149%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%7C%E3%82%BF%E3%82%A4%E3%83%9E%E3%83%BC%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EMCXA%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Voltage%20specification%20for%20externally%20provided%20clock%20signal%20(MCX%20A185%20VLH)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%8A%95%E7%A8%BF%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%AF%E3%81%84%E3%80%81%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E3%81%AF%E6%9C%80%E5%A4%A7%20Vec%20(%E5%A4%96%E9%83%A8%E3%81%8B%E3%82%89%E6%8F%90%E4%BE%9B%E3%81%95%E3%82%8C%E3%82%8B%E5%85%A5%E5%8A%9B%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E6%8C%AF%E5%B9%85)%20%E3%81%8C%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E9%9B%BB%E5%9C%A7%E3%81%AFVIH%E3%81%A8%E3%81%97%E3%81%A6%E8%A1%A8%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%8B%E3%81%97%E3%80%81VIH%E3%81%AF0.7xVDD%E3%81%AA%E3%81%AE%E3%81%A7%E3%80%81VDD%3D3.3V%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E6%9C%80%E5%A4%A7%E3%83%99%E3%82%AF%E3%83%88%E3%83%AB%E3%80%82%E9%9B%BB%E5%9C%A7%E3%81%AF2.31V%E3%81%AE%E3%81%BF%E3%81%AB%E3%81%AA%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E3%81%A4%E3%81%BE%E3%82%8A%E3%80%81%E3%81%93%E3%81%AE%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AE%E4%BB%95%E6%A7%98%E3%81%8C%E9%96%93%E9%81%95%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%80%81VDD%3D3.3V%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81Vec%E3%81%AE%E6%9C%80%E5%A4%A7%E5%80%A4%E3%81%AF%E5%AE%9F%E9%9A%9B%E3%81%AB%E3%81%AF2.31V%E3%81%AA%E3%81%AE%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Voltage%20specification%20for%20externally%20provided%20clock%20signal%20(MCX%20A185%20VLH)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F194626%22%20target%3D%22_blank%22%3E%40wyss-11%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%8A%95%E7%A8%BF%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%0A%3CP%3EMCXA18%E3%81%AB%E3%81%AFEXTAL48M%E5%85%A5%E5%8A%9B%E9%9B%BB%E5%9C%A7%E3%81%AE%E5%AE%9A%E7%BE%A9%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81%E3%81%9D%E3%82%8C%E3%81%AF%E7%8B%AC%E7%AB%8B%E3%81%97%E3%81%9F%E5%9B%BA%E5%AE%9A%E3%81%AEEXTAL48M%E9%9B%BB%E5%9C%A7%E5%80%A4%E3%81%A8%E3%81%97%E3%81%A6%E3%81%A7%E3%81%AF%E3%81%AA%E3%81%8F%E3%80%81VDD%E3%81%AB%E5%AF%BE%E3%81%99%E3%82%8B%E6%A8%99%E6%BA%96%E5%85%A5%E5%8A%9B%E3%81%97%E3%81%8D%E3%81%84%E5%80%A4VIH%2FVIL%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E9%96%93%E6%8E%A5%E7%9A%84%E3%81%AB%E6%8C%87%E5%AE%9A%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%82%B7%E3%83%BC%E3%83%88%E3%81%AB%E3%81%AF%E3%80%81%E7%99%BA%E6%8C%AF%E3%81%AE%E3%83%94%E3%83%BC%E3%82%AF%E3%83%84%E3%83%BC%E3%83%94%E3%83%BC%E3%82%AF%E6%8C%AF%E5%B9%85%E3%81%8C%E6%A8%99%E6%BA%96%E5%80%A4%E3%81%A8%E3%81%97%E3%81%A60.6V%E3%81%A8%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A0%E3%81%91%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EVDD%E3%81%8C3.3%20V%E3%81%AE%E5%A0%B4%E5%90%88EXTAL48M%E3%80%81%E3%82%AF%E3%83%AD%E3%83%83%E3%82%AF%E3%81%8CVIH%2FVIL%E3%81%AE%E9%96%BE%E5%80%A4%E3%82%92%E6%BA%80%E3%81%9F%E3%81%97%E3%80%81%E3%81%8B%E3%81%A4VDD%20%2B%200.3%20V%E3%81%AE%E5%85%A5%E5%8A%9B%E5%88%B6%E9%99%90%E3%82%92%E8%B6%85%E3%81%88%E3%81%AA%E3%81%84%E9%99%90%E3%82%8A%E3%80%813.3%20V%E3%81%AE%E5%A4%96%E9%83%A8%E7%99%BA%E6%8C%AF%E5%99%A8%E3%81%A7%E9%A7%86%E5%8B%95%E5%8F%AF%E8%83%BD%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Voltage%20specification%20for%20externally%20provided%20clock%20signal%20(MCX%20A185%20VLH)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F194626%22%20target%3D%22_blank%22%3E%40wyss-11%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EVEC%E4%BB%95%E6%A7%98%E3%81%A8%E3%81%AF%E3%80%81%E5%A4%96%E9%83%A8%E7%99%BA%E6%8C%AF%E5%99%A8%E5%85%A5%E5%8A%9B%E3%81%8C%E6%9C%89%E5%8A%B9%E3%81%AA%E4%BD%8E%E7%8A%B6%E6%85%8B%E3%81%8A%E3%82%88%E3%81%B3%E9%AB%98%E7%8A%B6%E6%85%8B%E3%82%92%E8%AA%8D%E8%AD%98%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E6%9C%80%E5%B0%8F%E9%9B%BB%E5%9C%A7%E3%83%AC%E3%83%99%E3%83%AB%E3%82%92%E6%8C%87%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3EVDD%20%3D%203.3%20V%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%812.31%20V%E3%81%AF%E6%9C%89%E5%8A%B9%E3%81%AA%E3%83%8F%E3%82%A4%E3%83%AC%E3%83%99%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%E6%A4%9C%E5%87%BA%E3%81%95%E3%82%8C%E3%82%8B%E6%9C%80%E5%B0%8F%E9%9B%BB%E5%9C%A7%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
