Voltage specification for externally provided clock signal (MCX A185 VLH)
wyss-11
I can not find the max. voltage allowed at the EXTAL48M pin for the MCXA185VLH MCU in the datasheets.
I know from the LPCxxx families of microcontrollers that the oscillator input is very picky about this amplitude (0.85Vpp or similar).
Can I feed an externally generated 3.3V oscillator clock signal directly to the EXTAL48M pin?
Labels (2)
carlos_o
Hi @wyss-11
The VEC specification refers to the minimum voltage levels required by the external oscillator input to recognize valid low and high states.
When VDD = 3.3 V, 2.31 V is the minimum voltage that will be detected as a valid high level.
wyss-11
Thanks for your post.
Yes, the datasheet specifies Vec (Externally provided input clock amplitude) with max. voltage as VIH. But as VIH is 0.7xVDD, this would mean that with VDD=3.3V, Vec max. would be 2.31V only.
So either this datasheet specification is wrong, or Vec max. is really 2.31V in case of VDD=3.3V?
carlos_o
Hi @wyss-11
carlos_o
Hi @wyss-11
Thanks for your post!
MCXA18 does have an EXTAL48M input voltage definition, but it is specified indirectly through the standard input thresholds VIH/VIL relative to VDD, not as a separate fixed EXTAL48M voltage value.
The datasheet only stands the Peak-to-peak amplitude of oscillation as typical value of 0.6V.
When VDD is 3.3 V, EXTAL48M can be driven by a 3.3 V external oscillator as long as the clock meets the VIH/VIL thresholds and does not exceed the VDD + 0.3 V input limit.
%3CLINGO-SUB%20id%3D%22lingo-sub-2383149%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EVoltage%20specification%20for%20externally%20provided%20clock%20signal%20(MCX%20A185%20VLH)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383149%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20can%20not%20find%20the%20max.%20voltage%20allowed%20at%20the%20EXTAL48M%20pin%20for%20the%20MCXA185VLH%20MCU%20in%20the%20datasheets.%3C%2FP%3E%3CP%3EI%20know%20from%20the%20LPCxxx%20families%20of%20microcontrollers%20that%20the%20oscillator%20input%20is%20very%20picky%20about%20this%20amplitude%20(0.85Vpp%20or%20similar).%26nbsp%3B%3C%2FP%3E%3CP%3ECan%20I%20feed%20an%20externally%20generated%203.3V%20oscillator%20clock%20signal%20directly%20to%20the%20EXTAL48M%20pin%3F%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2383149%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EClock%7CTimers%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EMCXA%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Voltage%20specification%20for%20externally%20provided%20clock%20signal%20(MCX%20A185%20VLH)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThanks%20for%20your%20post.%26nbsp%3B%3C%2FP%3E%3CP%3EYes%2C%20the%20datasheet%20specifies%20Vec%20(Externally%20provided%20input%20clock%20amplitude)%20with%20max.%20voltage%20as%20VIH.%20But%20as%20VIH%20is%200.7xVDD%2C%20this%20would%20mean%20that%20with%20VDD%3D3.3V%2C%20Vec%20max.%20would%20be%202.31V%20only.%26nbsp%3B%3C%2FP%3E%3CP%3ESo%20either%20this%20datasheet%20specification%20is%20wrong%2C%20or%20Vec%20max.%20is%20really%202.31V%20in%20case%20of%20VDD%3D3.3V%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Voltage%20specification%20for%20externally%20provided%20clock%20signal%20(MCX%20A185%20VLH)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F194626%22%20target%3D%22_blank%22%3E%40wyss-11%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20post!%3C%2FP%3E%0A%3CP%3EMCXA18%20does%20have%20an%20EXTAL48M%20input%20voltage%20definition%2C%20but%20it%20is%20specified%20indirectly%20through%20the%20standard%20input%20thresholds%20VIH%2FVIL%20relative%20to%20VDD%2C%20not%20as%20a%20separate%20fixed%20EXTAL48M%20voltage%20value.%3C%2FP%3E%0A%3CP%3EThe%20datasheet%20only%20stands%20the%26nbsp%3BPeak-to-peak%20amplitude%20of%20oscillation%20as%20typical%20value%20of%200.6V.%3C%2FP%3E%0A%3CP%3EWhen%20VDD%20is%203.3%20V%2C%20EXTAL48M%20can%20be%20driven%20by%20a%203.3%20V%20external%20oscillator%20as%20long%20as%20the%20clock%20meets%20the%20VIH%2FVIL%20thresholds%20and%20does%20not%20exceed%20the%20VDD%20%2B%200.3%20V%20input%20limit.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Voltage%20specification%20for%20externally%20provided%20clock%20signal%20(MCX%20A185%20VLH)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F194626%22%20target%3D%22_blank%22%3E%40wyss-11%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThe%20VEC%20specification%20refers%20to%20the%20minimum%20voltage%20levels%20required%20by%20the%20external%20oscillator%20input%20to%20recognize%20valid%20low%20and%20high%20states.%3C%2FP%3E%0A%3CP%3EWhen%20VDD%20%3D%203.3%E2%80%AFV%2C%202.31%E2%80%AFV%20is%20the%20minimum%20voltage%20that%20will%20be%20detected%20as%20a%20valid%20high%20level.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
