Voltage specification for externally provided clock signal (MCX A185 VLH)
795 次查看
wyss-11
I can not find the max. voltage allowed at the EXTAL48M pin for the MCXA185VLH MCU in the datasheets.
I know from the LPCxxx families of microcontrollers that the oscillator input is very picky about this amplitude (0.85Vpp or similar).
Can I feed an externally generated 3.3V oscillator clock signal directly to the EXTAL48M pin?
标签 (2)
725 次查看
carlos_o
Hi @wyss-11
The VEC specification refers to the minimum voltage levels required by the external oscillator input to recognize valid low and high states.
When VDD = 3.3 V, 2.31 V is the minimum voltage that will be detected as a valid high level.
749 次查看
wyss-11
Thanks for your post.
Yes, the datasheet specifies Vec (Externally provided input clock amplitude) with max. voltage as VIH. But as VIH is 0.7xVDD, this would mean that with VDD=3.3V, Vec max. would be 2.31V only.
So either this datasheet specification is wrong, or Vec max. is really 2.31V in case of VDD=3.3V?
726 次查看
carlos_o
Hi @wyss-11
766 次查看
carlos_o
Hi @wyss-11
Thanks for your post!
MCXA18 does have an EXTAL48M input voltage definition, but it is specified indirectly through the standard input thresholds VIH/VIL relative to VDD, not as a separate fixed EXTAL48M voltage value.
The datasheet only stands the Peak-to-peak amplitude of oscillation as typical value of 0.6V.
When VDD is 3.3 V, EXTAL48M can be driven by a 3.3 V external oscillator as long as the clock meets the VIH/VIL thresholds and does not exceed the VDD + 0.3 V input limit.
%3CLINGO-SUB%20id%3D%22lingo-sub-2383149%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%A4%96%E9%83%A8%E6%97%B6%E9%92%9F%E4%BF%A1%E5%8F%B7%E7%94%B5%E5%8E%8B%E8%A7%84%E6%A0%BC%EF%BC%88MCX%20A185%20VLH%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383149%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E6%9C%80%E5%A4%A7%E5%80%BC%E3%80%82%E6%95%B0%E6%8D%AE%E6%89%8B%E5%86%8C%E4%B8%AD%E8%A7%84%E5%AE%9A%E7%9A%84%20MCXA185VLH%20MCU%20%E7%9A%84%20EXTAL48M%20%E5%BC%95%E8%84%9A%E5%85%81%E8%AE%B8%E7%9A%84%E7%94%B5%E5%8E%8B%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%BB%8E%20LPCxxx%20%E7%B3%BB%E5%88%97%E5%BE%AE%E6%8E%A7%E5%88%B6%E5%99%A8%E4%B8%AD%E4%BA%86%E8%A7%A3%E5%88%B0%EF%BC%8C%E6%8C%AF%E8%8D%A1%E5%99%A8%E8%BE%93%E5%85%A5%E5%AF%B9%E8%BF%99%E4%B8%AA%E5%B9%85%E5%BA%A6%EF%BC%880.85Vpp%20%E6%88%96%E7%B1%BB%E4%BC%BC%E5%80%BC%EF%BC%89%E9%9D%9E%E5%B8%B8%E6%8C%91%E5%89%94%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%B0%86%E5%A4%96%E9%83%A8%E4%BA%A7%E7%94%9F%E7%9A%84%203.3V%20%E6%8C%AF%E8%8D%A1%E5%99%A8%E6%97%B6%E9%92%9F%E4%BF%A1%E5%8F%B7%E7%9B%B4%E6%8E%A5%E8%BE%93%E5%85%A5%E5%88%B0%20EXTAL48M%20%E5%BC%95%E8%84%9A%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2383149%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%97%B6%E9%92%9F%7C%E8%AE%A1%E6%97%B6%E5%99%A8%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EMCXA%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Voltage%20specification%20for%20externally%20provided%20clock%20signal%20(MCX%20A185%20VLH)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383409%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%B8%96%E5%AD%90%E3%80%82%3C%2FP%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E6%95%B0%E6%8D%AE%E6%89%8B%E5%86%8C%E8%A7%84%E5%AE%9A%E4%BA%86%20Vec%EF%BC%88%E5%A4%96%E9%83%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E8%BE%93%E5%85%A5%E6%97%B6%E9%92%9F%E5%B9%85%E5%BA%A6%EF%BC%89%E7%9A%84%E6%9C%80%E5%A4%A7%E5%80%BC%E3%80%82%E7%94%B5%E5%8E%8B%E4%B8%BA%20VIH%E3%80%82%E4%BD%86%E7%94%B1%E4%BA%8E%20VIH%20%E6%98%AF%200.7xVDD%EF%BC%8C%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%E5%BD%93%20VDD%3D3.3V%20%E6%97%B6%EF%BC%8C%E6%9C%80%E5%A4%A7%E5%90%91%E9%87%8F%E3%80%82%E7%94%B5%E5%8E%8B%E4%BB%85%E4%B8%BA%202.31V%E3%80%82%3C%2FP%3E%3CP%3E%E6%89%80%E4%BB%A5%E8%A6%81%E4%B9%88%E8%BF%99%E4%BB%BD%E6%95%B0%E6%8D%AE%E6%89%8B%E5%86%8C%E7%9A%84%E8%A7%84%E6%A0%BC%E6%9C%89%E8%AF%AF%EF%BC%8C%E8%A6%81%E4%B9%88%E5%9C%A8VDD%3D3.3V%E7%9A%84%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8CVec%20max.%20%E5%AE%9E%E9%99%85%E4%B8%8A%E6%98%AF2.31V%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Voltage%20specification%20for%20externally%20provided%20clock%20signal%20(MCX%20A185%20VLH)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383296%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F194626%22%20target%3D%22_blank%22%3E%40wyss-11%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E5%B8%96%E5%AD%90%EF%BC%81%3C%2FP%3E%0A%3CP%3EMCXA18%20%E7%A1%AE%E5%AE%9E%E6%9C%89%20EXTAL48M%20%E8%BE%93%E5%85%A5%E7%94%B5%E5%8E%8B%E5%AE%9A%E4%B9%89%EF%BC%8C%E4%BD%86%E5%AE%83%E6%98%AF%E9%80%9A%E8%BF%87%E7%9B%B8%E5%AF%B9%E4%BA%8E%20VDD%20%E7%9A%84%E6%A0%87%E5%87%86%E8%BE%93%E5%85%A5%E9%98%88%E5%80%BC%20VIH%2FVIL%20%E9%97%B4%E6%8E%A5%E6%8C%87%E5%AE%9A%E7%9A%84%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E4%BD%9C%E4%B8%BA%E5%8D%95%E7%8B%AC%E7%9A%84%E5%9B%BA%E5%AE%9A%20EXTAL48M%20%E7%94%B5%E5%8E%8B%E5%80%BC%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%95%B0%E6%8D%AE%E6%89%8B%E5%86%8C%E4%BB%85%E5%B0%86%E6%8C%AF%E8%8D%A1%E5%B3%B0%E5%B3%B0%E5%80%BC%E5%B9%85%E5%BA%A6%E5%88%97%E4%B8%BA%E5%85%B8%E5%9E%8B%E5%80%BC%200.6V%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%BD%93%20VDD%20%E4%B8%BA%203.3%20V%20%E6%97%B6%EF%BC%8C%E5%8F%AA%E8%A6%81%E6%97%B6%E9%92%9F%E6%BB%A1%E8%B6%B3%20VIH%2FVIL%20%E9%98%88%E5%80%BC%E4%B8%94%E4%B8%8D%E8%B6%85%E8%BF%87%20VDD%20%2B%200.3%20V%20%E8%BE%93%E5%85%A5%E9%99%90%E5%88%B6%EF%BC%8CEXTAL48M%20%E5%B0%B1%E5%8F%AF%E4%BB%A5%E7%94%B1%203.3%20V%20%E5%A4%96%E9%83%A8%E6%8C%AF%E8%8D%A1%E5%99%A8%E9%A9%B1%E5%8A%A8%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2383558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Voltage%20specification%20for%20externally%20provided%20clock%20signal%20(MCX%20A185%20VLH)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2383558%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F194626%22%20target%3D%22_blank%22%3E%40wyss-11%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EVEC%20%E8%A7%84%E8%8C%83%E6%98%AF%E6%8C%87%E5%A4%96%E9%83%A8%E6%8C%AF%E8%8D%A1%E5%99%A8%E8%BE%93%E5%85%A5%E8%AF%86%E5%88%AB%E6%9C%89%E6%95%88%E4%BD%8E%E7%94%B5%E5%B9%B3%E5%92%8C%E9%AB%98%E7%94%B5%E5%B9%B3%E6%89%80%E9%9C%80%E7%9A%84%E6%9C%80%E5%B0%8F%E7%94%B5%E5%8E%8B%E7%AD%89%E7%BA%A7%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%BD%93%20VDD%20%3D%203.3%20V%20%E6%97%B6%EF%BC%8C2.31%20V%20%E6%98%AF%E8%83%BD%E8%A2%AB%E6%A3%80%E6%B5%8B%E5%88%B0%E7%9A%84%E6%9C%89%E6%95%88%E9%AB%98%E7%94%B5%E5%B9%B3%E7%9A%84%E6%9C%80%E5%B0%8F%E7%94%B5%E5%8E%8B%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
