Title: Arduino Bootloader HEX (Arch Mix) not working on i.MX RT1050 EVK (RT1052 MCU)
1,383 次查看
Harisha
is it possible to run ardunio bootloader in rt1050 evk to make it behave as arduino board
I am trying to use the Arduino bootloader provided for the Seeeduino Arch Mix (i.MX RT1052) on an NXP i.MX RT1050 EVK board, since both boards use the same MCU (RT1052).
Reference guide followed:
https://wiki.seeedstudio.com/Arch_Mix/#using-nxpbootutility-to-flash-arduino-bootloader ()
What I tried:
Converted RT1050 EVK to QSPI (IS25WP064A).
Flashed the prebuilt Arduino bootloader HEX file (from Arch Mix) into QSPI flash at address 0x60000000.
Followed the same procedure as mentioned in the above guide:
Connected in Serial Downloader mode
Used NXP MCUBootUtility
Selected FlexSPI NOR
Used “All-in-One Action” to flash
Flashing completes successfully.
Expected behavior:
After switching back to QSPI boot and resetting the board, the Arduino bootloader should run and USB (OTG) should enumerate as a CDC device. ()
Actual behavior:
USB is not detected
No COM port appears
Bootloader seems not running
My questions:
Is the Arch Mix Arduino bootloader HEX directly compatible with RT1050 EVK?
Even though both use RT1052, are there any board-specific differences (USB pins, clock config, PHY, etc.)?
Does the bootloader depend on Arch Mix-specific hardware configuration?
Do we need to rebuild or modify the bootloader for RT1050 EVK?
Any guidance would be very helpful.
Thanks!
标签 (1)
1 回复
1,364 次查看
mayliu1
Hi @Harisha ,
Thank you so much for your interest in our products and for using our community.
I couldn’t find any doc indicating that the prebuilt Arch Mix Arduino bootloader is intended to be reused on MIMXRT1050-EVKB board.
For the MIMXRT1050‑EVKB, NXP provides board‑specific doc for the supported boot options using HyperFlash and QSPI Flash. The boot flow depends on FlexSPI configuration  and boot image headers that are specific to the target board and flash device.
Therefore, for the MIMXRT1050‑EVKB, I suggest you can  starting from the official MCUXpresso SDK demo provided for this board, rather than using the Arch Mix bootloader HEX directly.
Best Regards
May Liu
%3CLINGO-SUB%20id%3D%22lingo-sub-2348107%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%A0%87%E9%A2%98%EF%BC%9AArduino%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%20HEX%EF%BC%88Arch%20Mix%EF%BC%89%E6%97%A0%E6%B3%95%E5%9C%A8%20i.MX%20RT1050%20EVK%EF%BC%88RT1052%20MCU%EF%BC%89%E4%B8%8A%E8%BF%90%E8%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2348107%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%89%E5%8F%AF%E8%83%BD%E5%9C%A8%20rt1050%20evk%20%E4%B8%AD%E8%BF%90%E8%A1%8C%20ardunio%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E4%BB%A5%E4%BD%BF%E5%85%B6%E8%A1%A8%E7%8E%B0%E5%BE%97%E5%83%8F%20arduino%20%E6%9D%BF%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%9C%A8%E6%81%A9%E6%99%BA%E6%B5%A6%20i.MX%20RT1050%20EVK%20%E6%9D%BF%E4%B8%8A%E4%BD%BF%E7%94%A8%E4%B8%BA%20Seeeduino%20Arch%20Mix%EF%BC%88i.MX%20RT1052%EF%BC%89%E6%8F%90%E4%BE%9B%E7%9A%84%20Arduino%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%9B%A0%E4%B8%BA%E4%B8%A4%E5%9D%97%E6%9D%BF%E4%BD%BF%E7%94%A8%E7%9B%B8%E5%90%8C%E7%9A%84%20MCU%EF%BC%88RT1052%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E5%8F%82%E8%80%83%E6%8C%87%E5%8D%97%E5%A6%82%E4%B8%8B%EF%BC%9A%3C%2FP%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwiki.seeedstudio.com%2FArch_Mix%2F%23using-nxpbootutility-to-flash-arduino-bootloader%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwiki.seeedstudio.com%2FArch_Mix%2F%23using-nxpbootutility-to-flash-arduino-bootloader%3C%2FA%3E()%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E5%B0%9D%E8%AF%95%3C%2FP%3E%3CP%3E%E5%B0%86%20RT1050%20EVK%20%E8%BD%AC%E6%8D%A2%E4%B8%BA%20QSPI%20(IS25WP064A)%E3%80%82%3CBR%20%2F%3E%E5%B0%86%E9%A2%84%E5%88%B6%E7%9A%84%20Arduino%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%20HEX%20%E6%96%87%E4%BB%B6%EF%BC%88%E6%9D%A5%E8%87%AA%20Arch%20Mix%EF%BC%89%E9%97%AA%E5%AD%98%E5%88%B0%20QSPI%20%E9%97%AA%E5%AD%98%E4%B8%AD%EF%BC%8C%E5%9C%B0%E5%9D%80%E4%B8%BA%200x60000000%E3%80%82%3CBR%20%2F%3E%E9%81%B5%E5%BE%AA%E4%BA%86%E4%B8%8E%E4%B8%8A%E8%BF%B0%E6%8C%87%E5%8D%97%E4%B8%AD%E6%8F%90%E5%88%B0%E7%9A%84%E7%9B%B8%E5%90%8C%E6%AD%A5%E9%AA%A4%EF%BC%9A%E5%9C%A8%E4%B8%B2%E8%A1%8C%E4%B8%8B%E8%BD%BD%E5%99%A8%E6%A8%A1%E5%BC%8F%E4%B8%8B%3CBR%20%2F%3E%E8%BF%9E%E6%8E%A5%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E6%81%A9%E6%99%BA%E6%B5%A6%20mcubootUtility%20%3CBR%20%2F%3E%20%E9%80%89%E5%AE%9A%20FlexSPI%20%E6%88%96%E9%9D%9E%20%3CBR%20%2F%3E%20%E4%BD%BF%E7%94%A8%20%E2%80%9C%E5%A4%9A%E5%90%88%E4%B8%80%E6%93%8D%E4%BD%9C%E2%80%9D%20%E8%BF%9B%E8%A1%8C%E9%97%AA%E5%AD%98%3C%2FP%3E%3CP%3E%E9%97%AA%E7%83%81%E6%88%90%E5%8A%9F%E5%AE%8C%E6%88%90%E3%80%82%3C%2FP%3E%3CP%3E%E9%A2%84%E6%9C%9F%E8%A1%8C%E4%B8%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%E5%88%87%E6%8D%A2%E5%9B%9EQSPI%E5%90%AF%E5%8A%A8%E5%B9%B6%E9%87%8D%E7%BD%AE%E4%B8%BB%E6%9D%BF%E5%90%8E%EF%BC%8CArduino%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%BA%94%E8%BF%90%E8%A1%8C%EF%BC%8CUSB%EF%BC%88OTG%EF%BC%89%E5%BA%94%E5%88%97%E4%B8%BE%E4%B8%BACDC%E8%AE%BE%E5%A4%87%E3%80%82()%3C%2FP%3E%3CP%3E%E5%AE%9E%E9%99%85%E8%A1%8C%E4%B8%BA%EF%BC%9A%3C%2FP%3E%3CP%3E%E6%9C%AA%E6%A3%80%E6%B5%8B%E5%88%B0%20USB%3CBR%20%2F%3E%E6%9C%AA%E5%87%BA%E7%8E%B0%20COM%20%E7%AB%AF%E5%8F%A3%3CBR%20%2F%3E%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E4%BC%BC%E4%B9%8E%E6%9C%AA%E8%BF%90%E8%A1%8C%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E9%97%AE%E9%A2%98%3C%2FP%3E%3CP%3EArch%20Mix%20Arduino%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%20HEX%20%E4%B8%8E%20RT1050%20EVK%20%E7%9B%B4%E6%8E%A5%E5%85%BC%E5%AE%B9%E5%90%97%EF%BC%9F%3CBR%20%2F%3E%E5%B0%BD%E7%AE%A1%E4%B8%A4%E8%80%85%E9%83%BD%E4%BD%BF%E7%94%A8%20RT1052%EF%BC%8C%E4%BD%86%E6%98%AF%E5%90%A6%E5%AD%98%E5%9C%A8%E6%9D%BF%E7%89%B9%E5%AE%9A%E7%9A%84%E5%8C%BA%E5%88%AB%EF%BC%88USB%20%E5%BC%95%E8%84%9A%E3%80%81%E6%97%B6%E9%92%9F%E9%85%8D%E7%BD%AE%E3%80%81PHY%20%E7%AD%89%EF%BC%89%EF%BC%9F%3CBR%20%2F%3E%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E6%98%AF%E5%90%A6%E4%BE%9D%E8%B5%96%E4%BA%8E%20Arch%20Mix%20%E7%89%B9%E5%AE%9A%E7%9A%84%E7%A1%AC%E4%BB%B6%E9%85%8D%E7%BD%AE%EF%BC%9F%3CBR%20%2F%3E%E6%88%91%E4%BB%AC%E9%9C%80%E8%A6%81%E9%87%8D%E5%BB%BA%E6%88%96%E4%BF%AE%E6%94%B9%20RT1050%20EVK%20%E7%9A%84%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E4%BB%BB%E4%BD%95%E6%8C%87%E5%AF%BC%E9%83%BD%E4%BC%9A%E9%9D%9E%E5%B8%B8%E6%9C%89%E5%B8%AE%E5%8A%A9%E3%80%82%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E6%82%A8%EF%BC%81%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2348107%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%90%AF%E5%8A%A8%20ROM%20%7C%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%20%7C%20%E9%97%AA%E5%AD%98%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2348365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Title%3A%20Arduino%20Bootloader%20HEX%20(Arch%20Mix)%20not%20working%20on%20i.MX%20RT1050%20EVK%20(RT1052%20MCU)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2348365%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253824%22%20target%3D%22_blank%22%3E%40Harisha%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E5%85%B3%E6%B3%A8%E6%88%91%E4%BB%AC%E7%9A%84%E4%BA%A7%E5%93%81%E5%B9%B6%E4%BD%BF%E7%94%A8%E6%88%91%E4%BB%AC%E7%9A%84%E7%A4%BE%E5%8C%BA%E3%80%82%3C%2FP%3E%0A%3CDIV%3E%0A%3CP%3E%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E4%BB%BB%E4%BD%95%3CSPAN%3E%E8%A1%A8%E6%98%8E%E9%A2%84%E5%BB%BA%E7%9A%84%20Arch%20Mix%20Arduino%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%E6%89%93%E7%AE%97%E5%9C%A8%20MIMXRT1050-EVKB%20%E6%9D%BF%E4%B8%8A%E9%87%8D%E5%A4%8D%E4%BD%BF%E7%94%A8%E7%9A%84%3C%2FSPAN%3E%E6%96%87%E6%A1%A3%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8EMIMXRT1050%E2%80%91EVKB%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E6%8F%90%E4%BE%9B%E4%B8%BB%E6%9D%BF%E4%B8%93%E7%94%A8%E6%96%87%E6%A1%A3%EF%BC%8C%E4%BB%8B%E7%BB%8D%E4%BD%BF%E7%94%A8HyperFlash%E5%92%8CQSPI%E9%97%AA%E5%AD%98%E6%94%AF%E6%8C%81%E7%9A%84%E5%90%AF%E5%8A%A8%E9%80%89%E9%A1%B9%E3%80%82%E5%90%AF%E5%8A%A8%E6%B5%81%E7%A8%8B%E5%8F%96%E5%86%B3%E4%BA%8E%E7%89%B9%E5%AE%9A%E4%BA%8E%E7%9B%AE%E6%A0%87%E6%9D%BF%E5%92%8C%E9%97%AA%E5%AD%98%E8%AE%BE%E5%A4%87%E7%9A%84%20FlexSPI%20%E9%85%8D%E7%BD%AE%E5%92%8C%E5%90%AF%E5%8A%A8%E6%98%A0%E5%83%8F%E6%A0%87%E5%A4%B4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%AF%B9%E4%BA%8E%20MIMXRT1050%E2%80%91EVKB%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%A0%E5%8F%AF%E4%BB%A5%E4%BB%8E%E4%B8%BA%E8%AF%A5%E4%B8%BB%E6%9D%BF%E6%8F%90%E4%BE%9B%E7%9A%84%E5%AE%98%E6%96%B9%20MCUXpresso%20SDK%20%E6%BC%94%E7%A4%BA%E7%89%88%E5%BC%80%E5%A7%8B%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E7%9B%B4%E6%8E%A5%E4%BD%BF%E7%94%A8%20Arch%20Mix%20%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%20HEX%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E5%88%98%E6%A2%85%3C%2FP%3E%0A%3C%2FDIV%3E%3C%2FLINGO-BODY%3E
