RT600+KEIL5+JLINK(FLM flash programming issue)
1,762件の閲覧回数
Jokerufo
HI,
I am developing audio product on RT685-AUD-EVK, i use KEIL5 as devl tool, there are some issues when i use arm algorithm FLM file to program flash, attachment is FLM i used, please help me to solve those issue, thanks.
1)MIMXRT685-AUD-EVK
2)Program LPC4322 to jlink MODE
3) JLINK CAN ACCESS RT586 chip
4)keil program flash incounter can't halt CPU
JLink Info: InitTarget() start
JLink Info:
JLink Info: J-Link script: i.MXRT6xx Cortex-M33 core J-Link script
JLink Info:
JLink Info: DAP-IDCODE:0x002A0000
JLink Info: InitTarget() end
JLink Info: Found SW-DP with ID 0x6BA02477
JLink Info: DPIDR: 0x6BA02477
JLink Info: CoreSight SoC-400 or earlier
JLink Info: Scanning AP map to find all available APs
JLink Info: AP[1]: Stopped AP scan as end of AP map has been reached
JLink Info: AP[0]: AHB-AP (IDR: 0x84770001)
JLink Info: Iterating through AP map to find AHB-AP to use
JLink Info: AP[0]: Core found
JLink Info: AP[0]: AHB-AP ROM base: 0xE00FE000
JLink Info: CPUID register: 0x410FD213. Implementer code: 0x41 (ARM)
JLink Info: Feature set: Mainline
JLink Info: Found Cortex-M33 r0p3, Little endian.
JLink Info: FPUnit: 8 code (BP) slots and 0 literal slots
JLink Info: Security extension: implemented
JLink Info: Secure debug: enabled
JLink Info: CoreSight components:
JLink Info: ROMTbl[0] @ E00FE000
JLink Info: [0][0]: E00FF000 CID B105100D PID 000BB4C9 ROM Table
JLink Info: ROMTbl[1] @ E00FF000
JLink Info: [1][0]: E000E000 CID B105900D PID 000BBD21 DEVARCH 47702A04 DEVTYPE 00 Cortex-M33
JLink Info: [1][1]: E0001000 CID B105900D PID 000BBD21 DEVARCH 47701A02 DEVTYPE 00 DWT
JLink Info: [1][2]: E0002000 CID B105900D PID 000BBD21 DEVARCH 47701A03 DEVTYPE 00 FPB
JLink Info: [1][3]: E0000000 CID B105900D PID 000BBD21 DEVARCH 47701A01 DEVTYPE 43 ITM
JLink Info: [1][5]: E0041000 CID B105900D PID 002BBD21 DEVARCH 47724A13 DEVTYPE 13 ETM
JLink Info: [1][6]: E0042000 CID B105900D PID 000BBD21 DEVARCH 47701A14 DEVTYPE 14 CSS600-CTI
JLink Info: [0][1]: E0040000 CID B105900D PID 000BBD21 DEVARCH 00000000 DEVTYPE 11 TPIU
ROMTableAddr = 0xE00FE000
JLink Info: ResetTarget() start
JLink Info: Reset external flash
JLink Info: Set watch point
JLink Info: Execute SYSRESETREQ via AIRCR
JLink Info: ResetTarget() end
JLink Info: CPU could not be halted
JLink Error: Failed to halt CPU.
Warning: Secure Cortex-M device stop can be delayed!
Error: Flash Download failed - Target DLL has been cancelled
Flash Load finished at 20:52:32
1,713件の閲覧回数
Gavin_Jia
Hi @Jokerufo ,
I tested with on board JLink and it works.
First, ensure that the FLM you selected is the two with the FlexSPI_B suffix. If this step is confirmed correct, put the board into serial download mode and use SEC or MCUBootUtility to erase the Flash before attempting reprogramming.
Gavin
%3CLINGO-SUB%20id%3D%22lingo-sub-2268777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERT600%2BKEIL5%2BJLINK(FLM%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AE%E5%95%8F%E9%A1%8C)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AF%20RT685-AUD-EVK%20%E3%81%A7%E3%82%AA%E3%83%BC%E3%83%87%E3%82%A3%E3%82%AA%E8%A3%BD%E5%93%81%E3%82%92%E9%96%8B%E7%99%BA%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E9%96%8B%E7%99%BA%E3%83%84%E3%83%BC%E3%83%AB%E3%81%A8%E3%81%97%E3%81%A6%20KEIL5%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8C%E3%80%81ARM%20%E3%82%A2%E3%83%AB%E3%82%B4%E3%83%AA%E3%82%BA%E3%83%A0%20FLM%20%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%E3%81%A8%E5%95%8F%E9%A1%8C%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E6%B7%BB%E4%BB%98%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB%E3%81%AF%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%9F%20FLM%20%E3%81%A7%E3%81%99%E3%80%82%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%AE%E8%A7%A3%E6%B1%BA%E3%81%AB%E3%81%94%E5%8D%94%E5%8A%9B%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E1)MIMXRT685-AUD-EVK%3C%2FP%3E%3CP%3E2)LPC4322%E3%82%92jlink%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%81%99%E3%82%8B%3C%2FP%3E%3CP%3E3)%20JLINK%E3%81%AFRT586%E3%83%81%E3%83%83%E3%83%97%E3%81%ABCAN%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%81%A7%E3%81%8D%E3%82%8B%3C%2FP%3E%3CP%3E4)Keil%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%A0%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%AB%E3%82%A6%E3%83%B3%E3%82%BF%E3%81%AFCPU%E3%82%92%E5%81%9C%E6%AD%A2CAN%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EJLink%20%E6%83%85%E5%A0%B1%3A%20InitTarget()%20%E9%96%8B%E5%A7%8B%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%3CBR%20%2F%3E%20JLink%20%E6%83%85%E5%A0%B1%3A%20J-Link%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3A%20i.MXRT6xx%20Cortex-M33%20%E3%82%B3%E3%82%A2%20J-Link%20%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%3CBR%20%2F%3E%20JLink%20%E6%83%85%E5%A0%B1%3A%20DAP-IDCODE%3A0x002A0000%3CBR%20%2F%3E%20JLink%20%E6%83%85%E5%A0%B1%3A%20InitTarget()%20%E7%B5%82%E4%BA%86%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20ID%200x6BA02477%20%E3%81%AE%20SW-DP%20%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20DPIDR%3A%200x6BA02477%3CBR%20%2F%3E%20JLink%20%E6%83%85%E5%A0%B1%3A%20CoreSight%20SoC-400%20%E4%BB%A5%E5%89%8D%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%81%97%E3%81%A6%E5%88%A9%E7%94%A8%E5%8F%AF%E8%83%BD%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%20AP%20%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CBR%20%2F%3EJLink%E6%83%85%E5%A0%B1%3A%20AP%5B1%5D%3A%20AP%E3%83%9E%E3%83%83%E3%83%97%E3%81%AE%E7%B5%82%E3%82%8F%E3%82%8A%E3%81%AB%E9%81%94%E3%81%97%E3%81%9F%E3%81%9F%E3%82%81%E3%80%81AP%E3%82%B9%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EJLink%E6%83%85%E5%A0%B1%3A%20AP%5B0%5D%3A%20AHB-AP%20(IDR%3A%200x84770001)%3CBR%20%2F%3E%20JLink%20%E6%83%85%E5%A0%B1%3A%20AP%20%E3%83%9E%E3%83%83%E3%83%97%E3%82%92%E5%8F%8D%E5%BE%A9%E5%87%A6%E7%90%86%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%20AHB-AP%20%E3%82%92%E6%A4%9C%E7%B4%A2%E3%81%97%E3%81%BE%E3%81%99%3CBR%20%2F%3EJLink%E6%83%85%E5%A0%B1%3A%20AP%5B0%5D%3A%20%E3%82%B3%E3%82%A2%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3EJLink%E6%83%85%E5%A0%B1%3A%20AP%5B0%5D%3A%20AHB-AP%20ROM%E3%83%99%E3%83%BC%E3%82%B9%3A%200xE00FE000%3CBR%20%2F%3E%20JLink%20%E6%83%85%E5%A0%B1%3A%20CPUID%20%E3%83%AC%E3%82%B8%E3%82%B9%E3%82%BF%3A%200x410FD213%E3%80%82%E5%AE%9F%E8%A3%85%E8%80%85%E3%82%B3%E3%83%BC%E3%83%89%3A%200x41%20(ARM)%3CBR%20%2F%3E%20JLink%20%E6%83%85%E5%A0%B1%3A%20%E6%A9%9F%E8%83%BD%E3%82%BB%E3%83%83%E3%83%88%3A%20%E3%83%A1%E3%82%A4%E3%83%B3%E3%83%A9%E3%82%A4%E3%83%B3%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20Cortex-M33%20r0p3%E3%80%81%E3%83%AA%E3%83%88%E3%83%AB%E3%82%A8%E3%83%B3%E3%83%87%E3%82%A3%E3%82%A2%E3%83%B3%E3%81%8C%E8%A6%8B%E3%81%A4%E3%81%8B%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20FPUnit%3A%208%20%E3%81%A4%E3%81%AE%E3%82%B3%E3%83%BC%E3%83%89%20(BP)%20%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%A8%200%20%E3%81%A4%E3%81%AE%E3%83%AA%E3%83%86%E3%83%A9%E3%83%AB%20%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%83%AA%E3%83%86%E3%82%A3%E6%8B%A1%E5%BC%B5%3A%20%E5%AE%9F%E8%A3%85%E6%B8%88%E3%81%BF%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%20%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%3A%20%E6%9C%89%E5%8A%B9%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20CoreSight%20%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%3A%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20ROMTbl%5B0%5D%20%40%20E00FE000%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20%5B0%5D%5B0%5D%3A%20E00FF000%20CID%20B105100D%20PID%20000BB4C9%20ROM%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20ROMTbl%5B1%5D%20%40%20E00FF000%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20%5B1%5D%5B0%5D%3A%20E000E000%20CID%20B105900D%20PID%20000BBD21%20DEVARCH%2047702A04%20DEVTYPE%2000%20Cortex-M33%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20%5B1%5D%5B1%5D%3A%20E0001000%20CID%20B105900D%20PID%20000BBD21%20DEVARCH%2047701A02%20DEVTYPE%2000%20DWT%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20%5B1%5D%5B2%5D%3A%20E0002000%20CID%20B105900D%20PID%20000BBD21%20DEVARCH%2047701A03%20DEVTYPE%2000%20FPB%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20%5B1%5D%5B3%5D%3A%20E0000000%20CID%20B105900D%20PID%20000BBD21%20DEVARCH%2047701A01%20DEVTYPE%2043%20ITM%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20%5B1%5D%5B5%5D%3A%20E0041000%20CID%20B105900D%20PID%20002BBD21%20DEVARCH%2047724A13%20DEVTYPE%2013%20ETM%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20%5B1%5D%5B6%5D%3A%20E0042000%20CID%20B105900D%20PID%20000BBD21%20DEVARCH%2047701A14%20DEVTYPE%2014%20CSS600-CTI%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20%5B0%5D%5B1%5D%3A%20E0040000%20CID%20B105900D%20PID%20000BBD21%20DEVARCH%2000000000%20DEVTYPE%2011%20TPIU%3CBR%20%2F%3EROM%E3%83%86%E3%83%BC%E3%83%96%E3%83%AB%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%20%3D%200xE00FE000%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20ResetTarget()%20%E3%81%AE%E9%96%8B%E5%A7%8B%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20%E5%A4%96%E9%83%A8%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20%E7%9B%A3%E8%A6%96%E3%83%9D%E3%82%A4%E3%83%B3%E3%83%88%E3%81%AE%E8%A8%AD%E5%AE%9A%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20AIRCR%20%E7%B5%8C%E7%94%B1%E3%81%A7%20SYSRESETREQ%20%E3%82%92%E5%AE%9F%E8%A1%8C%E3%81%99%E3%82%8B%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20ResetTarget()%20%E7%B5%82%E4%BA%86%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20CPU%20%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3EJLink%20%E3%82%A8%E3%83%A9%E3%83%BC%3A%20CPU%20%E3%81%AE%E5%81%9C%E6%AD%A2%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3CBR%20%2F%3EJLink%20%E6%83%85%E5%A0%B1%3A%20CPU%20%E3%82%92%E5%81%9C%E6%AD%A2%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%9B%E3%82%93%E3%81%A7%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E8%AD%A6%E5%91%8A%3A%20%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%20Cortex-M%20%E3%83%87%E3%83%90%E3%82%A4%E3%82%B9%E3%81%AE%E5%81%9C%E6%AD%A2%E3%81%8C%E9%81%85%E3%82%8C%E3%82%8B%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%82%A8%E3%83%A9%E3%83%BC%3A%20Flash%20%E3%81%AE%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%20-%20%E3%82%BF%E3%83%BC%E3%82%B2%E3%83%83%E3%83%88%20DLL%20%E3%81%8C%E3%82%AD%E3%83%A3%E3%83%B3%E3%82%BB%E3%83%AB%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3CBR%20%2F%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%83%AD%E3%83%BC%E3%83%89%E3%81%AF20%3A52%3A32%E3%81%AB%E7%B5%82%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2268777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E3%83%96%E3%83%BC%E3%83%88ROM%7C%E3%83%96%E3%83%BC%E3%83%88%7C%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2269058%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT600%2BKEIL5%2BJLINK(FLM%20flash%20programming%20issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2269058%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F225639%22%20target%3D%22_blank%22%3E%40Jokerufo%3C%2FA%3E%E3%81%95%E3%82%93%3C%2FP%3E%0A%3CP%3E%E6%90%AD%E8%BC%89%20JLink%20%E3%81%A7%E3%83%86%E3%82%B9%E3%83%88%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%BE%E3%81%9A%E3%80%81%E9%81%B8%E6%8A%9E%E3%81%97%E3%81%9F%20FLM%20%E3%81%8C%20FlexSPI_B%20%E3%82%B5%E3%83%95%E3%82%A3%E3%83%83%E3%82%AF%E3%82%B9%E3%82%92%E6%8C%81%E3%81%A4%202%20%E3%81%A4%E3%81%AE%20FLM%20%E3%81%A7%E3%81%82%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E6%89%8B%E9%A0%86%E3%81%8C%E6%AD%A3%E3%81%97%E3%81%84%E3%81%93%E3%81%A8%E3%81%8C%E7%A2%BA%E8%AA%8D%E3%81%95%E3%82%8C%E3%81%9F%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%82%B7%E3%83%AA%E3%82%A2%E3%83%AB%20%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%20%E3%83%A2%E3%83%BC%E3%83%89%E3%81%AB%E3%81%97%E3%81%A6%E3%80%81SEC%20%E3%81%BE%E3%81%9F%E3%81%AF%20MCUBootUtility%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E6%B6%88%E5%8E%BB%E3%81%97%E3%81%A6%E3%81%8B%E3%82%89%E3%80%81%E5%86%8D%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%82%88%E3%82%8D%E3%81%97%E3%81%8F%E3%81%8A%E9%A1%98%E3%81%84%E3%81%97%E3%81%BE%E3%81%99%E3%80%81%3CBR%20%2F%3E%E3%82%AE%E3%83%A3%E3%83%93%E3%83%B3%3C%2FP%3E%3C%2FLINGO-BODY%3E
