RT600+KEIL5+JLINK(FLM flash programming issue)
1,672 次查看
Jokerufo
HI,
I am developing audio product on RT685-AUD-EVK, i use KEIL5 as devl tool, there are some issues when i use arm algorithm FLM file to program flash, attachment is FLM i used, please help me to solve those issue, thanks.
1)MIMXRT685-AUD-EVK
2)Program LPC4322 to jlink MODE
3) JLINK CAN ACCESS RT586 chip
4)keil program flash incounter can't halt CPU
JLink Info: InitTarget() start
JLink Info:
JLink Info: J-Link script: i.MXRT6xx Cortex-M33 core J-Link script
JLink Info:
JLink Info: DAP-IDCODE:0x002A0000
JLink Info: InitTarget() end
JLink Info: Found SW-DP with ID 0x6BA02477
JLink Info: DPIDR: 0x6BA02477
JLink Info: CoreSight SoC-400 or earlier
JLink Info: Scanning AP map to find all available APs
JLink Info: AP[1]: Stopped AP scan as end of AP map has been reached
JLink Info: AP[0]: AHB-AP (IDR: 0x84770001)
JLink Info: Iterating through AP map to find AHB-AP to use
JLink Info: AP[0]: Core found
JLink Info: AP[0]: AHB-AP ROM base: 0xE00FE000
JLink Info: CPUID register: 0x410FD213. Implementer code: 0x41 (ARM)
JLink Info: Feature set: Mainline
JLink Info: Found Cortex-M33 r0p3, Little endian.
JLink Info: FPUnit: 8 code (BP) slots and 0 literal slots
JLink Info: Security extension: implemented
JLink Info: Secure debug: enabled
JLink Info: CoreSight components:
JLink Info: ROMTbl[0] @ E00FE000
JLink Info: [0][0]: E00FF000 CID B105100D PID 000BB4C9 ROM Table
JLink Info: ROMTbl[1] @ E00FF000
JLink Info: [1][0]: E000E000 CID B105900D PID 000BBD21 DEVARCH 47702A04 DEVTYPE 00 Cortex-M33
JLink Info: [1][1]: E0001000 CID B105900D PID 000BBD21 DEVARCH 47701A02 DEVTYPE 00 DWT
JLink Info: [1][2]: E0002000 CID B105900D PID 000BBD21 DEVARCH 47701A03 DEVTYPE 00 FPB
JLink Info: [1][3]: E0000000 CID B105900D PID 000BBD21 DEVARCH 47701A01 DEVTYPE 43 ITM
JLink Info: [1][5]: E0041000 CID B105900D PID 002BBD21 DEVARCH 47724A13 DEVTYPE 13 ETM
JLink Info: [1][6]: E0042000 CID B105900D PID 000BBD21 DEVARCH 47701A14 DEVTYPE 14 CSS600-CTI
JLink Info: [0][1]: E0040000 CID B105900D PID 000BBD21 DEVARCH 00000000 DEVTYPE 11 TPIU
ROMTableAddr = 0xE00FE000
JLink Info: ResetTarget() start
JLink Info: Reset external flash
JLink Info: Set watch point
JLink Info: Execute SYSRESETREQ via AIRCR
JLink Info: ResetTarget() end
JLink Info: CPU could not be halted
JLink Error: Failed to halt CPU.
Warning: Secure Cortex-M device stop can be delayed!
Error: Flash Download failed - Target DLL has been cancelled
Flash Load finished at 20:52:32
1,623 次查看
Gavin_Jia
Hi @Jokerufo ,
I tested with on board JLink and it works.
First, ensure that the FLM you selected is the two with the FlexSPI_B suffix. If this step is confirmed correct, put the board into serial download mode and use SEC or MCUBootUtility to erase the Flash before attempting reprogramming.
Gavin
%3CLINGO-SUB%20id%3D%22lingo-sub-2268777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERT600%2BKEIL5%2BJLINK%EF%BC%88FLM%20%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%E9%97%AE%E9%A2%98%EF%BC%89%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2268777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%20RT685-AUD-EVK%20%E4%B8%8A%E5%BC%80%E5%8F%91%E9%9F%B3%E9%A2%91%E4%BA%A7%E5%93%81%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%20KEIL5%20%E4%BD%9C%E4%B8%BA%E5%BC%80%E5%8F%91%E5%B7%A5%E5%85%B7%EF%BC%8C%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%20arm%20%E7%AE%97%E6%B3%95%20FLM%20%E6%96%87%E4%BB%B6%E7%BC%96%E7%A8%8B%20flash%20%E6%97%B6%E4%BC%9A%E5%87%BA%E7%8E%B0%E4%B8%80%E4%BA%9B%E9%97%AE%E9%A2%98%EF%BC%8C%E9%99%84%E4%BB%B6%E6%98%AF%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%20FLM%EF%BC%8C%E8%AF%B7%E5%B8%AE%E6%88%91%E8%A7%A3%E5%86%B3%E8%BF%99%E4%BA%9B%E9%97%AE%E9%A2%98%EF%BC%8C%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3CP%3E1)mimxrt685-aud-evk%3C%2FP%3E%3CP%3E2%EF%BC%89%E5%B0%86%20LPC4322%20%E7%BC%96%E7%A8%8B%E4%B8%BA%20jlink%20%E6%A8%A1%E5%BC%8F%3C%2FP%3E%3CP%3E3)%20JLINK%20CAN%20ACCESS%20RT586%20%E8%8A%AF%E7%89%87%3C%2FP%3E%3CP%3E4%EF%BC%89Keil%20%E7%A8%8B%E5%BA%8F%E9%97%AA%E5%AD%98%E8%AE%A1%E6%95%B0%E5%99%A8%E6%97%A0%E6%B3%95%E5%81%9C%E6%AD%A2%20CPU%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3EJLink%20Info%3A%20InitTarget()%20start%3CBR%20%2F%3EJLink%20Info%EF%BC%9A%3CBR%20%2F%3EJLink%20Info%EF%BC%9AJ-Link%20%E8%84%9A%E6%9C%AC%EF%BC%9Ai.MXRT6xx%20Cortex-M33%20%E5%86%85%E6%A0%B8%20J-Link%20%E8%84%9A%E6%9C%AC%3CBR%20%2F%3EJLink%20Info%EF%BC%9A%3CBR%20%2F%3EJLink%20Info%EF%BC%9ADAP-IDCODE%3A0x002A0000%3CBR%20%2F%3EJLink%20Info%3A%20InitTarget()%20end%3CBR%20%2F%3EJLink%20Info%EF%BC%9A%E6%89%BE%E5%88%B0%20ID%20%E4%B8%BA%200x6BA02477%20%E7%9A%84%20SW-DP%3CBR%20%2F%3EJLink%20Info%EF%BC%9ADPIDR%3A%200x6BA02477%3CBR%20%2F%3EJLink%20Info%EF%BC%9ACoreSight%20SoC-400%20%E6%88%96%E6%9B%B4%E6%97%A9%E7%89%88%E6%9C%AC%3CBR%20%2F%3EJLink%20Info%EF%BC%9A%E6%89%AB%E6%8F%8F%20AP%20%E5%9C%B0%E5%9B%BE%E4%BB%A5%E6%9F%A5%E6%89%BE%E6%89%80%E6%9C%89%E5%8F%AF%E7%94%A8%20AP%3CBR%20%2F%3EJLink%20Info%EF%BC%9AAP%5B1%5D%EF%BC%9AStopped%20AP%20scan%20as%20end%20of%20AP%20map%20has%20been%20reached%3CBR%20%2F%3EJLink%20Info%EF%BC%9AAP%5B0%5D%EF%BC%9AAHB-AP%20(IDR%3A%200x84770001)%3CBR%20%2F%3EJLink%20Info%3A%20Iterating%20through%20AP%20map%20to%20find%20AHB-AP%20to%20use%3CBR%20%2F%3EJLink%20Info%EF%BC%9AAP%5B0%5D%EF%BC%9A%E6%89%BE%E5%88%B0%E6%A0%B8%E5%BF%83%3CBR%20%2F%3EJLink%20Info%EF%BC%9AAP%5B0%5D%EF%BC%9AAHB-AP%20ROM%20base%EF%BC%9A0xE00FE000%3CBR%20%2F%3EJLink%20Info%EF%BC%9ACPUID%20%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%9A0x410FD213.%E5%AE%9E%E7%8E%B0%E8%80%85%E4%BB%A3%E7%A0%81%EF%BC%9A0x41%20(ARM)%20%3CBR%20%2F%3E%20jLink%20%E4%BF%A1%E6%81%AF%EF%BC%9A%E5%8A%9F%E8%83%BD%E9%9B%86%EF%BC%9A%E4%B8%BB%E7%BA%BF%20%3CBR%20%2F%3E%20jLink%20%E4%BF%A1%E6%81%AF%EF%BC%9A%E6%89%BE%E5%88%B0%E4%BA%86%20Cortex-M33%20r0p3%EF%BC%8C%E5%B0%8F%E7%AB%AF%E8%8A%82%E5%BA%8F%E3%80%82%3CBR%20%2F%3EjLink%20%E4%BF%A1%E6%81%AF%EF%BC%9AfpUnit%EF%BC%9A8%20%E4%B8%AA%E4%BB%A3%E7%A0%81%20(BP)%20%E6%8F%92%E6%A7%BD%E5%92%8C%200%20%E4%B8%AA%E6%96%87%E5%AD%97%E6%8F%92%E6%A7%BD%3CBR%20%2F%3E%20jLink%20%E4%BF%A1%E6%81%AF%EF%BC%9A%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E6%89%A9%E5%B1%95%EF%BC%9A%E5%B7%B2%E5%AE%9E%E7%8E%B0%20jLink%3CBR%20%2F%3E%20%E4%BF%A1%E6%81%AF%EF%BC%9A%E5%AE%89%E5%85%A8%E8%B0%83%E8%AF%95%EF%BC%9A%E5%90%AF%E7%94%A8%3CBR%20%2F%3E%20jLink%20%E4%BF%A1%E6%81%AF%EF%BC%9AcoreSight%20%E7%BB%84%E4%BB%B6%EF%BC%9AromTBL%3CBR%20%2F%3E%20%5B0%5D%20%40%20E00FE000%3CBR%20%2F%3E%20jLink%20%E4%BF%A1%E6%81%AF%EF%BC%9A%5B0%5D%EF%BC%9AE00FF000%20CID%20B105100D%20PID%20000BB4C9%20ROM%20%E8%A1%A8%3CBR%20%2F%3E%20jLink%20%E4%BF%A1%E6%81%AF%EF%BC%9Aromtbl%20%5B1%5D%20%40%20E00FF000%3CBR%20%2F%3E%20jLink%20%E4%BF%A1%E6%81%AF%EF%BC%9A%5B1%5D%20%5B0%5D%5D%3A%20E000E000%20CID%20B105900D%20PID%20000BBD21%20DEVARCH%2047702A04%20DEVTYPE%2000%20Cortex-M33%3CBR%20%2F%3E%20jLink%20%E4%BF%A1%E6%81%AF%EF%BC%9A%5B1%5D%20%5B1%5D%EF%BC%9AE0001000%20CID%20B105900D%20PID%20PID%20PID%20DEVARCH%20DEVTYPE%2000%20DWT%3CBR%20%2F%3E%20jLink%20%E4%BF%A1%E6%81%AF%EF%BC%9A%5B1%5D%20%5B2%5D%EF%BC%9A%20000BBD21%2047701A02%20E0002000%20B105900DPID%20000BBD21%20DEVARCH%2047701A03%20DEVTYPE%2000%20FPB%3CBR%20%2F%3E%20jLink%20%E4%BF%A1%E6%81%AF%EF%BC%9A%5B1%5D%20%5B3%5D%EF%BC%9AE0000000%20CID%20B105900D%20PID%20000BBD21%20DEVARCH%2047701A01%20DEVTYPE%2043%20ITM%3CBR%20%2F%3E%20jLink%20%E4%BF%A1%E6%81%AF%EF%BC%9A%5B1%5D%20%5B5%5D%EF%BC%9AE0041000%20CID%20B105900D%20PID%20002BBD21%20DEVARCH%2047724A13%20DEVTYPE%2013%20ETM%3CBR%20%2F%3E%20jLink%20%E4%BF%A1%E6%81%AF%EF%BC%9A%5B1%5D%20%5B6%5D%EF%BC%9A%E5%93%88%E5%93%88%E5%93%88%E5%93%88%E5%93%88%E5%93%88%E5%93%88%E5%93%88%E5%93%88%E5%93%88%E5%93%88%E5%93%88%E5%93%88%E5%93%88%E5%93%88%E5%93%88%E5%93%88%E5%93%88%E5%93%88%E5%93%88%E5%93%88%3CBR%20%2F%3E%2000000000%20DEVTYPE%2011%20TPIU%3CBR%20%2F%3E%20romtableAddr%20%3D%200xe00fe000%20jLink%3CBR%20%2F%3E%20%E4%BF%A1%E6%81%AF%EF%BC%9ARESETTarget%20()%20%E5%90%AF%E5%8A%A8%20jLink%20%E4%BF%A1%E6%81%AF%EF%BC%9ARESET%3CBR%20%2F%3E%20%E5%A4%96%E9%83%A8%E9%97%AA%E5%AD%98%20jLink%20%E4%BF%A1%E6%81%AF%EF%BC%9A%E8%AE%BE%E7%BD%AE%E8%A7%82%E5%AF%9F%E7%82%B9%20jLink%20E0042000%20B105900D%20000BBD21%2047701A14%20CSS600-CTI%20E0040000%20B105900D%20000BBD21%E4%BF%A1%E6%81%AF%EF%BC%9A%E9%80%9A%E8%BF%87%3CBR%20%2F%3E%20%3CBR%20%2F%3EAIRCR%20%E6%89%A7%E8%A1%8C%20SYSRESETREQ%3CBR%20%2F%3E%20%3CBR%20%2F%3EjLink%3CBR%20%2F%3E%20%E4%BF%A1%E6%81%AF%EF%BC%9ARESETTarget%20()%20end%20jLink%20%E4%BF%A1%E6%81%AF%EF%BC%9ACPU%3CBR%20%2F%3E%20%E6%97%A0%E6%B3%95%E5%81%9C%E6%AD%A2%20jLink%20%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E5%81%9C%E6%AD%A2%20CPU%20%E9%94%99%E8%AF%AF%EF%BC%9A%E6%97%A0%E6%B3%95%E5%81%9C%E6%AD%A2%20CPU%E3%80%82%3CBR%20%2F%3E%20jLink%20%E4%BF%A1%E6%81%AF%EF%BC%9ACPU%20%E6%97%A0%E6%B3%95%E6%9A%82%E5%81%9C%E8%AD%A6%20%E5%91%8A%EF%BC%9A%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%20Cortex-M%20%E8%AE%BE%E5%A4%87%E5%81%9C%E6%AD%A2%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%BB%B6%E8%BF%9F%EF%BC%81%3CBR%20%2F%3E%E9%94%99%E8%AF%AF%EF%BC%9A%E9%97%AA%E5%AD%98%E4%B8%8B%E8%BD%BD%E5%A4%B1%E8%B4%A5%20-%20%E7%9B%AE%E6%A0%87%20DLL%20%E5%B7%B2%E5%8F%96%E6%B6%88%3CBR%20%2F%3E%E9%97%AA%E5%AD%98%E5%8A%A0%E8%BD%BD%E4%BA%8E%2020%3A52%3A32%20%E5%AE%8C%E6%88%90%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2268777%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%90%AF%E5%8A%A8%20ROM%20%7C%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%20%7C%20%E9%97%AA%E5%AD%98%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2269058%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RT600%2BKEIL5%2BJLINK(FLM%20flash%20programming%20issue)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2269058%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F225639%22%20target%3D%22_blank%22%3E%40Jokerufo%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%9C%A8%E6%9C%BA%E4%B8%8A%E4%BD%BF%E7%94%A8jLink%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%EF%BC%8C%E5%AE%83%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%A6%96%E5%85%88%EF%BC%8C%E7%A1%AE%E4%BF%9D%E6%89%80%E9%80%89%E7%9A%84%20FLM%20%E6%98%AF%E5%90%8E%E7%BC%80%E5%90%8D%E4%B8%BA%20FlexSPI_B%20%E7%9A%84%20FLM%E3%80%82%E5%A6%82%E6%9E%9C%E7%A1%AE%E8%AE%A4%E6%AD%A4%E6%AD%A5%E9%AA%A4%E6%AD%A3%E7%A1%AE%EF%BC%8C%E8%AF%B7%E5%B0%86%E6%9D%BF%E7%BD%AE%E4%BA%8E%E4%B8%B2%E8%A1%8C%E4%B8%8B%E8%BD%BD%E6%A8%A1%E5%BC%8F%EF%BC%8C%E5%9C%A8%E5%B0%9D%E8%AF%95%E9%87%8D%E6%96%B0%E7%BC%96%E7%A8%8B%E4%B9%8B%E5%89%8D%E4%BD%BF%E7%94%A8%E9%AB%98%E6%95%88%E5%AF%86%E7%A0%81%E5%AD%A6%E6%A0%87%E5%87%86(SEC)%E6%88%96McubootUtility%E6%93%A6%E9%99%A4%E9%97%AA%E5%AD%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%3CBR%20%2F%3EGavin%3C%2FP%3E%3C%2FLINGO-BODY%3E
