MCXN547: how to enable iRTC subSecond function ?
3,568 次查看
jimmyli
Hi NXP,
      I find that MCXN547 has subsecond function register for iRTC, and I consider using this function to record millisecond.
      According to official SDK (SDK_2.x_FRDM-MCXN947), I import the iRTC driver example and add the code to test this function, but failed.
      Can you help to check and provide some tips ?
      Thanks;
1>subSecond register in MCXN reference manual
2>test code
based on example: frdmmcxn947_irtc_cm33_core0
hardware: FRDM-MCXN947
IRTC_EnableSubsecondCounter(RTC,true);
uint32_t subSecond_cnt = 0;
while(1){
subSecond_cnt = IRTC_GetSubsecondCount(RTC);
PRINTF("subSecond Counter is %d.\r\n",subSecond_cnt);
//intervals time
uint32_t i,j;
for(i=0;i<6534;i++)
for(j=0;j<6232;j++){
__NOP();
3>test result
    the parameter "subSecond_cnt" is still 0.
3,406 次查看
Harry_Zhang
Hi @jimmyli
I have tested again.
By default, the RTC Clock select
/* 16.384kHz clock is selected */
config->clockSelect = kIRTC_Clk16K;
So the count should less than 16384
You just need to change
RTC->CTRL |= RTC_CTRL_CLKOUT((uint16_t)kIRTC_ClkoutFine1Hz);
to
IRTC_ConfigClockOut(RTC, kIRTC_ClkoutCoarse1Hz);
It can work.
Harry
8 回复数
3,386 次查看
lucindaschatz
yes thanks
3,537 次查看
Harry_Zhang
Hi @jimmyli
The Subsecond counter  use these register, not RTC_TEST2.
If you want to use is,
Please refer to  chapter 56.3.2 Subsecond counter
You can try.
Harry
3,534 次查看
jimmyli
Hi Harry,
       Yes, you are right, the subsecond function has its own register.
       But, I called the static inline void IRTC_EnableSubsecondCounter(RTC_Type *base, bool enable) and static inline uint32_t IRTC_GetSubsecondCount(RTC_Type *base) APIs in fsl_irtc.h to enable and read the subsecond counter, but failed.
       Do you have any tips to help to enable this function ?
       Thanks very much.
3,517 次查看
Harry_Zhang
Hi @jimmyli
I just tested it on my end.
It can work.
According to the RM.
There are two important points to note.
1. You must independently enable the field by writing 1 to SUBSECOND_CTRL[SUB_SECOND_CNT_EN] after enabling RTC.CTRL[CLKOUT] (see chip-specific RTC_SUBSYSTEM for more information) to select the 1 Hz clock output.
2.In RTC.CTRL[CLKO_DIS]  you should select The selected clock is output to other peripherals. 0b
This is my test code.
    IRTC_GetDefaultConfig(&irtcConfig);
    irtcConfig.disableClockOutput = false;
    if (IRTC_Init(RTC, &irtcConfig) == kStatus_Fail)
        return 1;
    PRINTF("RTC Example START:\r\n");
    RTC->CTRL &= (uint16_t)(~RTC_CTRL_CLKOUT_MASK);
    IRTC_EnableSubsecondCounter(RTC, true);
    while(1){
    //intervals time
    uint32_t i,j;
    for(i=0;i<6534;i++)
    __NOP();
    for (;;)
Harry
3,513 次查看
jimmyli
Hi Harry,
      Thanks very much for your help!
      I have checked with your code, and subsecond can work now.
      But I have a question that when I convert subsecond counter to minisecond, the value seems wrong.
      Eg: 1>default clock source for subsecond counter is 32KHz;
           2>Minisecond Value = ( 1 / 32KHz ) * subsecond counter = 1/32000 x 53479 = 1.67 (s) > 1(s)
      Do I calculate it wrongly ?
3,407 次查看
Harry_Zhang
Hi @jimmyli
to
It can work.
Harry
3,395 次查看
jimmyli
Hi Harry,
      Got it.
      Thanks very much.
标记 (1)
3,423 次查看
Harry_Zhang
Hi @jimmyli
I think your calculation method is correct,
So i need to confirm with the internal team.
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2182747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCXN547%EF%BC%9A%E5%A6%82%E4%BD%95%E5%90%AF%E7%94%A8%20iRTC%20subSecond%20%E5%8A%9F%E8%83%BD%EF%BC%9F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2182747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%81%A9%E6%99%BA%E6%B5%A6%E3%80%81%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%E6%88%91%E5%8F%91%E7%8E%B0%20MCXN547%20%E6%9C%89%E7%94%A8%E4%BA%8E%20iRTC%20%E7%9A%84%E4%BA%9A%E7%A7%92%E5%8A%9F%E8%83%BD%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E6%88%91%E8%80%83%E8%99%91%E4%BD%BF%E7%94%A8%E8%AF%A5%E5%8A%9F%E8%83%BD%E8%AE%B0%E5%BD%95%E6%AF%AB%E7%A7%92%E3%80%82%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%E6%A0%B9%E6%8D%AE%E5%AE%98%E6%96%B9%20SDK%20(SDK_2.x_FRDM-MCXN947)%E3%80%81%E6%88%91%E5%AF%BC%E5%85%A5%E4%BA%86%20iRTC%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%A4%BA%E4%BE%8B%EF%BC%8C%E5%B9%B6%E6%B7%BB%E5%8A%A0%E4%BA%86%E4%BB%A3%E7%A0%81%E6%9D%A5%E6%B5%8B%E8%AF%95%E8%AF%A5%E5%8A%9F%E8%83%BD%EF%BC%8C%E4%BD%86%E5%A4%B1%E8%B4%A5%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%E6%82%A8%E8%83%BD%E5%B8%AE%E5%8A%A9%E6%A3%80%E6%9F%A5%E5%B9%B6%E6%8F%90%E4%BE%9B%E4%B8%80%E4%BA%9B%E6%8F%90%E7%A4%BA%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%E8%B0%A2%E8%B0%A2%EF%BC%9B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E1%20%26gt%3B%20MCXN%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E4%B8%AD%E7%9A%84%E4%BA%9A%E7%A7%92%E5%AF%84%E5%AD%98%E5%99%A8%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22jimmyli_0-1759989461232.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jimmyli_0-1759989461232.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360005iE066F39F17058C7F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22jimmyli_0-1759989461232.png%22%20alt%3D%22jimmyli_0-1759989461232.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E2%26gt%3B%E6%B5%8B%E8%AF%95%E4%BB%A3%E7%A0%81%3C%2FP%3E%3CP%3E%E5%9F%BA%E4%BA%8E%E7%A4%BA%E4%BE%8B%EF%BC%9A%3CFONT%20color%3D%22%23FF0000%22%3E%20frdmmcxn947_irtc_cm33_core0%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20color%3D%22%23000000%22%3E%E7%A1%AC%E4%BB%B6%EF%BC%9A%3CFONT%20color%3D%22%23FF0000%22%3EFRDM-MCXN947%3C%2FFONT%3E%3C%2FFONT%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CP%3E%3CSPAN%3EIRTC_EnableSubsecondCounter(RTC%2Ctrue)%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3EsubSecond_cnt%20%3D%200%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E8%80%8C%3C%2FSPAN%3E%3CSPAN%3E(1)%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EsubSecond_cnt%20%3D%20IRTC_GetSubsecondCount(RTC)%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EPRINTF(%3C%2FSPAN%3E%3CSPAN%3E%22subSecond%20Counter%20is%25d.%5Cr%5Cn%22%3C%2FSPAN%3E%3CSPAN%3E%2CsubSecond_cnt%EF%BC%89%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%2F%2F%E9%97%B4%E9%9A%94%E6%97%B6%E9%97%B4%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Euint32_t%3C%2FSPAN%3E%3CSPAN%3Ei%2Cj%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E4%B8%BA%3C%2FSPAN%3E%3CSPAN%3E(i%3D0%3Bi%26lt%3B6534%3Bi%2B%2B)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%AF%B9%E4%BA%8E%3C%2FSPAN%3E%3CSPAN%3E(j%3D0%3Bj%26lt%3B6232%3Bj%2B%2B)%7B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E__NOP()%EF%BC%9B%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%7D%3C%2FSPAN%3E%3C%2FP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22jimmyli_1-1759989578566.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jimmyli_1-1759989578566.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360006i5263BC5CA8F748CF%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22jimmyli_1-1759989578566.png%22%20alt%3D%22jimmyli_1-1759989578566.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3CBR%20%2F%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E3%26gt%3B%E6%B5%8B%E8%AF%95%E7%BB%93%E6%9E%9C%3C%2FP%3E%3CP%3E%20%20%20%20%22%3CSPAN%3E%20subSecond_cnt%22%20%3C%2FSPAN%3E%E5%8F%82%E6%95%B0%E4%BB%8D%E4%B8%BA%200%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2182747%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EMCX%20N%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2186834%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCXN547%3A%20how%20to%20enable%20iRTC%20subSecond%20function%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2186834%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%98%AF%E7%9A%84%EF%BC%8C%E8%B0%A2%E8%B0%A2%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2186700%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCXN547%3A%20how%20to%20enable%20iRTC%20subSecond%20function%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2186700%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%93%88%E9%87%8C%E3%80%81%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%E7%9F%A5%E9%81%93%E4%BA%86%3C%2FP%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2186427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCXN547%3A%20how%20to%20enable%20iRTC%20subSecond%20function%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2186427%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F69183%22%20target%3D%22_blank%22%3E%40jimmyli%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%86%8D%E6%AC%A1%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%EF%BC%8CRTC%20%E6%97%B6%E9%92%9F%E9%80%89%E6%8B%A9%20%3C%2FP%3E%0A%3CP%3E%2F*%20%E9%80%89%E6%8B%A9%2016.384kHz%20%E6%97%B6%E9%92%9F%20*%2F%3CBR%20%2F%3Econfig-%26gt%3BclockSelect%20%3D%20kIRTC_Clk16K%EF%BC%9B%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E8%AE%A1%E6%95%B0%E5%BA%94%E5%B0%8F%E4%BA%8E%2016384%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E5%8F%AA%E9%9C%80%E6%94%B9%E5%8F%98%20%3C%2FP%3E%0A%3CP%3ERTC-%26gt%3BCTRL%20%7C%3D%20RTC_CTRL_CLKOUT((uint16_t)kIRTC_ClkoutFine1Hz)%EF%BC%9B%3C%2FP%3E%0A%3CP%3E%E8%87%B3%20%3C%2FP%3E%0A%3CP%3EIRTC_ConfigClockOut(RTC%2C%20kIRTC_ClkoutCoarse1Hz)%EF%BC%9B%3C%2FP%3E%0A%3CP%3E%E5%AE%83%E8%83%BD%E5%8F%91%E6%8C%A5%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1760515151613.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1760515151613.png%22%20style%3D%22width%3A%20209px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360855i27C1A6C909E512DA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1760515151613.png%22%20alt%3D%22Harry_Zhang_0-1760515151613.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2185642%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCXN547%3A%20how%20to%20enable%20iRTC%20subSecond%20function%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2185642%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F69183%22%20target%3D%22_blank%22%3E%40jimmyli%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E8%AE%A4%E4%B8%BA%E4%BD%A0%E7%9A%84%E8%AE%A1%E7%AE%97%E6%96%B9%E6%B3%95%E6%98%AF%E6%AD%A3%E7%A1%AE%E7%9A%84%E3%80%81%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E9%9C%80%E8%A6%81%E4%B8%8E%E5%86%85%E9%83%A8%E5%9B%A2%E9%98%9F%E7%A1%AE%E8%AE%A4%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCXN547%3A%20how%20to%20enable%20iRTC%20subSecond%20function%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183755%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%93%88%E9%87%8C%E3%80%81%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E4%BD%A0%E4%BB%AC%E7%9A%84%E5%B8%AE%E5%8A%A9%EF%BC%81%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%E6%88%91%E7%94%A8%E6%82%A8%E7%9A%84%E4%BB%A3%E7%A0%81%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%A3%80%E6%9F%A5%EF%BC%8C%E7%8E%B0%E5%9C%A8%E5%AD%90%E7%A7%92%E5%8F%AF%E4%BB%A5%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E4%BA%86%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%20%20%20%20%20%20%E4%BD%86%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E5%BD%93%E6%88%91%E6%8A%8A%E4%BA%9A%E7%A7%92%E8%AE%A1%E6%95%B0%E5%99%A8%E8%BD%AC%E6%8D%A2%E6%88%90%E5%88%86%E7%A7%92%E8%AE%A1%E6%95%B0%E5%99%A8%E6%97%B6%EF%BC%8C%E6%95%B0%E5%80%BC%E4%BC%BC%E4%B9%8E%E4%B8%8D%E5%AF%B9%E3%80%82%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%E4%BE%8B%E5%A6%82%EF%BC%9A1%26gt%3B%E4%BA%9A%E7%A7%92%E8%AE%A1%E6%95%B0%E5%99%A8%E7%9A%84%E9%BB%98%E8%AE%A4%E6%97%B6%E9%92%9F%E6%BA%90%E4%B8%BA%2032KHz%EF%BC%9B%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%20%20%20%202%26gt%3B%E5%88%86%E7%A7%92%E5%80%BC%20%3D%20(%201%20%2F%2032KHz%20)%20*%20%E5%88%86%E7%A7%92%E8%AE%A1%E6%95%B0%E5%99%A8%20%3D%201%2F32000%20x%2053479%20%3D%201.67%20(s)%26gt%3B%201%20(s)%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%E6%98%AF%E6%88%91%E8%AE%A1%E7%AE%97%E9%94%99%E8%AF%AF%E5%90%97%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22jimmyli_0-1760086905182.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22jimmyli_0-1760086905182.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360232i3E57B86A351E478F%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22jimmyli_0-1760086905182.png%22%20alt%3D%22jimmyli_0-1760086905182.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCXN547%3A%20how%20to%20enable%20iRTC%20subSecond%20function%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F69183%22%20target%3D%22_blank%22%3E%40jimmyli%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%88%9A%E5%88%9A%E5%9C%A8%E6%88%91%E8%BF%99%E8%BE%B9%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%B5%8B%E8%AF%95%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%AE%83%E8%83%BD%E5%8F%91%E6%8C%A5%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%A0%B9%E6%8D%AE%20RM%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%9C%89%E4%B8%A4%E4%B8%AA%E8%A6%81%E7%82%B9%E9%9C%80%E8%A6%81%E6%B3%A8%E6%84%8F%E3%80%82%3C%2FP%3E%0A%3CP%3E1.%20%3CSTRONG%3E%E5%90%AF%E7%94%A8%20RTC.CTRL%20%5BCLKOUT%5D%EF%BC%88%E6%9C%89%E5%85%B3%E6%9B%B4%E5%A4%9A%E4%BF%A1%E6%81%AF%EF%BC%8C%E8%AF%B7%E5%8F%82%E9%98%85%E8%8A%AF%E7%89%87%E4%B8%93%E7%94%A8%3C%2FSTRONG%3E%20RTC_SUBSYSTEM%EF%BC%89%E5%90%8E%EF%BC%8C%E5%BF%85%E9%A1%BB%E9%80%9A%E8%BF%87%E5%90%91%20SUBSECOND_CTRL%20%5BSUB_SECOND_CNT_EN%5D%20%E5%86%99%E5%85%A5%201%20%E6%9D%A5%E7%8B%AC%E7%AB%8B%E5%90%AF%E7%94%A8%E8%AF%A5%E5%AD%97%E6%AE%B5%EF%BC%8C%E4%BB%A5%E9%80%89%E6%8B%A9%3CSTRONG%3E%201%20Hz%20%E7%9A%84%E6%97%B6%E9%92%9F%E8%BE%93%E5%87%BA%20%E3%80%82%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CP%3E2.%E5%9C%A8%20RTC.CTRL%5BCLKO_DIS%5D%E4%B8%AD%E5%BA%94%E9%80%89%E6%8B%A9%20%E6%89%80%E9%80%89%E6%97%B6%E9%92%9F%E5%B0%86%E8%BE%93%E5%87%BA%E5%88%B0%E5%85%B6%E4%BB%96%E5%A4%96%E8%AE%BE%E3%80%820b%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E6%98%AF%E6%88%91%E7%9A%84%E6%B5%8B%E8%AF%95%E4%BB%A3%E7%A0%81%E3%80%82%3C%2FP%3E%0A%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E%20%20%20%20IRTC_GetDefaultConfig(%26amp%3BirtcConfig)%3B%0A%20%20%20%20irtcConfig.disableClockOutput%20%3D%20false%3B%0A%20%20%20%20if%20(IRTC_Init(RTC%2C%20%26amp%3BirtcConfig)%20%3D%3D%20kStatus_Fail)%0A%20%20%20%20%7B%0A%20%20%20%20%20%20%20%20return%201%3B%0A%20%20%20%20%7D%0A%20%20%20%20%0A%20%20%20%20PRINTF(%22RTC%20Example%20START%3A%5Cr%5Cn%22)%3B%0A%0A%20%20%20%20RTC-%26gt%3BCTRL%20%26amp%3B%3D%20(uint16_t)(~RTC_CTRL_CLKOUT_MASK)%3B%0A%0A%20%20%20%20RTC-%26gt%3BCTRL%20%7C%3D%20RTC_CTRL_CLKOUT((uint16_t)kIRTC_ClkoutFine1Hz)%3B%0A%0A%20%20%20%20IRTC_EnableSubsecondCounter(RTC%2C%20true)%3B%0A%0A%20%20%20%20uint32_t%20subSecond_cnt%20%3D%200%3B%0A%0A%20%20%20%20while(1)%7B%0A%0A%20%20%20%20subSecond_cnt%20%3D%20IRTC_GetSubsecondCount(RTC)%3B%0A%0A%20%20%20%20PRINTF(%22subSecond%20Counter%20is%20%25d.%5Cr%5Cn%22%2CsubSecond_cnt)%3B%0A%0A%0A%20%20%20%20%2F%2Fintervals%20time%0A%0A%20%20%20%20uint32_t%20i%2Cj%3B%0A%0A%20%20%20%20for(i%3D0%3Bi%26lt%3B6534%3Bi%2B%2B)%0A%0A%20%20%20%20for(j%3D0%3Bj%26lt%3B6232%3Bj%2B%2B)%7B%0A%0A%20%20%20%20__NOP()%3B%0A%0A%20%20%20%20%7D%0A%20%20%20%20%7D%0A%20%20%20%20for%20(%3B%3B)%0A%20%20%20%20%7B%0A%20%20%20%20%7D%3C%2FCODE%3E%3C%2FPRE%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1760082383619.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1760082383619.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360213i8E2441CB485C0D8E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1760082383619.png%22%20alt%3D%22Harry_Zhang_0-1760082383619.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183479%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCXN547%3A%20how%20to%20enable%20iRTC%20subSecond%20function%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183479%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%E5%93%88%E9%87%8C%E3%80%81%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%E6%98%AF%E7%9A%84%EF%BC%8C%E4%BD%A0%E8%AF%B4%E5%BE%97%E5%AF%B9%EF%BC%8C%E5%AD%90%E7%A7%92%E5%87%BD%E6%95%B0%E6%9C%89%E8%87%AA%E5%B7%B1%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E6%88%91%E8%B0%83%E7%94%A8%E4%BA%86%3CFONT%20color%3D%22%23FF0000%22%3E%20fsl_irtc.h%3C%2FFONT%3E%3CSTRONG%3E%20%E4%B8%AD%E7%9A%84%20static%20inline%20void%20IRTC_EnableSubsecondCounter(RTC_Type%20*base%2C%20bool%20enable)%3C%2FSTRONG%3E%20%E5%92%8C%3CSTRONG%3E%20static%20inline%20uint32_t%20IRTC_GetSubsecondCount(RTC_Type%20*base)%3C%2FSTRONG%3E%20API%E3%80%82%E4%BB%A5%E5%90%AF%E7%94%A8%E5%92%8C%E8%AF%BB%E5%8F%96%E4%BA%9A%E7%A7%92%E8%AE%A1%E6%95%B0%E5%99%A8%EF%BC%8C%E4%BD%86%E5%A4%B1%E8%B4%A5%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%E6%82%A8%E6%9C%89%E4%BB%80%E4%B9%88%E5%B0%8F%E7%AA%8D%E9%97%A8%E5%8F%AF%E4%BB%A5%E5%B8%AE%E5%8A%A9%E5%90%AF%E7%94%A8%E6%AD%A4%E5%8A%9F%E8%83%BD%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%20%20%20%20%20%20%20%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2183463%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCXN547%3A%20how%20to%20enable%20iRTC%20subSecond%20function%20%3F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2183463%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F69183%22%20target%3D%22_blank%22%3E%40jimmyli%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%AC%A1%E7%A7%92%E8%AE%A1%E6%95%B0%E5%99%A8%E4%BD%BF%E7%94%A8%E8%BF%99%E4%BA%9B%E5%AF%84%E5%AD%98%E5%99%A8%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%20RTC_TEST2%E3%80%82%20%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1760064450831.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1760064450831.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360160iA963611669BD6EFB%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1760064450831.png%22%20alt%3D%22Harry_Zhang_0-1760064450831.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E6%82%A8%E6%83%B3%E4%BD%BF%E7%94%A8%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%8F%82%E8%A7%81%E7%AC%AC%2056.3.2%20%E7%AB%A0%E4%BA%9A%E7%A7%92%E8%AE%A1%E6%95%B0%E5%99%A8%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_1-1760064593090.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_1-1760064593090.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F360161i5720779C7A01A394%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_1-1760064593090.png%22%20alt%3D%22Harry_Zhang_1-1760064593090.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E4%BD%A0%E5%8F%AF%E4%BB%A5%E8%AF%95%E8%AF%95%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E
