MCXN236 eFuse / OTP information?
1,532 次查看
psmitty7373
Which document for the MCXN236 has information about the size, use, and addressing of the OTP bits?
Thanks!
1,506 次查看
Celeste_Liu
Hello @psmitty7373 ,
Thanks for your post.
According to the section "12.5 eFuse definitions " of MCXN236 reference manual, I believe it can be found in the MCX N23x Security Reference Manual.
The Security Reference Manual is confidential. You need to sign a NDA with our company and apply for the secure document on your own. The marketing department will decide whether to open it for your account.
Hope it can help you.
BRs,
Celeste
5 回复数
1,476 次查看
marek-trmac
Hi @psmitty7373 ,
you can also use MCUXpresso Secure Provisioning tool (https://nxp.com/mcuxpresso/secure) to edit the fuses in GUI tool (see OTP configuration window).
For full fuses description, you need to install restricted data package, that can be downloaded on the same page.
Marek
NOTE: If you find the answer useful, kindly click on [ACCEPT AS SOLUTION] button
1,471 次查看
psmitty7373
Good to know, thank you Marek.
1,489 次查看
psmitty7373
Thanks, Celeste.
1,507 次查看
Celeste_Liu
BRs,
Celeste
1,249 次查看
Slopegame
Thanks, Celeste! Very helpful info on accessing the MCXN236 security manual. Navigating NDAs can feel like playing Slope Game - constantly overcoming obstacles! Knowing it's through marketing is key. Perhaps a summary for non-NDA folks could be beneficial? Appreciate the direction!
