MCXC041 minimal schematic (32.768 RTC?)
dav1
Contributor V
like the simplicity of the new MCXC041
noted the evkit has a RTC crystal, I assume it is optional, but would like to understand in what scenarios it is needed. I'm mainly after the lowest possible power consumption with wake on gpio -> uart message. no strict timing requirements.
ZhangJennie
Hi dav1,
MCXC041 on-chip RTC precesion is not that high. It may be impacted by some factors like temperture, voltage fluctuation, etc.While external RTC can provide more stable and accturate clock.
So if user's application needs high precision RTC, we suggest using external RTC clock.
Hope this helps,
Jun Zhang
ZhangJennie
Hi dav1,
Hope this helps,
Jun Zhang
%3CLINGO-SUB%20id%3D%22lingo-sub-2033981%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCXC041%20minimal%20schematic%20(32.768%20RTC%3F)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2033981%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Elike%20the%20simplicity%20of%20the%20new%26nbsp%3B%3CSPAN%3EMCXC041%3C%2FSPAN%3E%3C%2FP%3E%3CP%3Enoted%20the%20evkit%20has%20a%20RTC%20crystal%2C%20I%20assume%20it%20is%20optional%2C%20but%20would%20like%20to%20understand%20in%20what%20scenarios%20it%20is%20needed.%20I'm%20mainly%20after%20the%20lowest%20possible%20power%20consumption%20with%20wake%20on%20gpio%20-%26gt%3B%20uart%20message.%20no%20strict%20timing%20requirements.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2033981%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EMCXC%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2034476%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3A%20MCXC041%20minimal%20schematic%20(32.768%20RTC%3F)%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2034476%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20dav1%2C%3C%2FP%3E%0A%3CP%3EMCXC041%20on-chip%20RTC%20precesion%20is%20not%20that%20high.%20It%20may%20be%20impacted%20by%20some%20factors%20like%20temperture%2C%20voltage%20fluctuation%2C%20etc.While%20external%20RTC%20can%20provide%20more%20stable%20and%20accturate%20clock.%3CBR%20%2F%3ESo%20if%20user's%20application%20needs%20high%20precision%20RTC%2C%20we%20suggest%20using%20external%20RTC%20clock.%3C%2FP%3E%0A%3CP%3EHope%20this%20helps%2C%3C%2FP%3E%0A%3CP%3EJun%20Zhang%3C%2FP%3E%3C%2FLINGO-BODY%3E
