MCUXpressoIDE with FRDM-MCXW23
1,179件の閲覧回数
stejen
it seems MCUXpressoIDE does not work correctly with FRDM-MCXW23.
I installed the correct SDK inside the IDE. However, on creating a new project only the "Project Template" category is selected, which leads to compiling errors in a new project.
For FRDM-MCXN947, all needed components to compile a fresh projects are selected out of the box.
タグ(1)
3 返答(返信)
1,090件の閲覧回数
stejen
Hi @Harry_Zhang,
thank you for reaching out to me.
Here my situation and how to reproduce:
I have installed MCUXpresso IDE 25.6 with all updates. I can confirm this on both Linux and macOS
I currently have 2 SDKs installed directly via the IDE:
SDK_2.x_FRDM-MCXN947 25.09.00
SDK_2.x_FRDM-MCXW23 25.03.00
Those SDKs were downloaded by the IDE as "latest"
Then I created a new project for FRDM-MCXW23 - as well directly via the IDE.
Here the error message on compiling the fresh project:
13:27:31 **** Build of configuration Debug for project MCXW236B_Project ****
make -r -j11 all
Building file: ../source/MCXW236B_Project.c
Building file: ../board/board.c
Building file: ../source/semihost_hardfault.c
Building file: ../board/clock_config.c
Building file: ../board/peripherals.c
Building file: ../board/pin_mux.c
Invoking: MCU C Compiler
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXW236BIHNAR -DCPU_MCXW236BIHNAR_cm33 -DSDK_DEBUGCONSOLE=1 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -D__MCUXPRESSO -DDEBUG -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board" -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/source" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../source/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"source/MCXW236B_Project.d" -MT"source/MCXW236B_Project.o" -MT"source/MCXW236B_Project.d" -o "source/MCXW236B_Project.o" "../source/MCXW236B_Project.c"
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXW236BIHNAR -DCPU_MCXW236BIHNAR_cm33 -DSDK_DEBUGCONSOLE=1 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -D__MCUXPRESSO -DDEBUG -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board" -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/source" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../board/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"board/board.d" -MT"board/board.o" -MT"board/board.d" -o "board/board.o" "../board/board.c"
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXW236BIHNAR -DCPU_MCXW236BIHNAR_cm33 -DSDK_DEBUGCONSOLE=1 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -D__MCUXPRESSO -DDEBUG -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board" -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/source" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../source/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"source/semihost_hardfault.d" -MT"source/semihost_hardfault.o" -MT"source/semihost_hardfault.d" -o "source/semihost_hardfault.o" "../source/semihost_hardfault.c"
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXW236BIHNAR -DCPU_MCXW236BIHNAR_cm33 -DSDK_DEBUGCONSOLE=1 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -D__MCUXPRESSO -DDEBUG -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board" -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/source" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../board/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"board/peripherals.d" -MT"board/peripherals.o" -MT"board/peripherals.d" -o "board/peripherals.o" "../board/peripherals.c"
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXW236BIHNAR -DCPU_MCXW236BIHNAR_cm33 -DSDK_DEBUGCONSOLE=1 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -D__MCUXPRESSO -DDEBUG -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board" -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/source" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../board/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"board/clock_config.d" -MT"board/clock_config.o" -MT"board/clock_config.d" -o "board/clock_config.o" "../board/clock_config.c"
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXW236BIHNAR -DCPU_MCXW236BIHNAR_cm33 -DSDK_DEBUGCONSOLE=1 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -D__MCUXPRESSO -DDEBUG -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board" -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/source" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../board/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"board/pin_mux.d" -MT"board/pin_mux.o" -MT"board/pin_mux.d" -o "board/pin_mux.o" "../board/pin_mux.c"
../board/board.c:7:10: fatal error: fsl_common.h: No such file or directory
    7 | #include "fsl_common.h"
compilation terminated.
../board/clock_config.c:7:10: fatal error: fsl_power.h: No such file or directory
    7 | #include "fsl_power.h"
In file included from ../board/peripherals.c:56:
../board/peripherals.h:18:10: fatal error: fsl_common.h: No such file or directory
   18 | #include "fsl_common.h"
../board/pin_mux.c:48:10: fatal error: fsl_common.h: No such file or directory
   48 | #include "fsl_common.h"
make[1]: *** [board/subdir.mk:29: board/clock_config.o] Error 1
make[1]: *** Waiting for unfinished jobs....
make[1]: *** [board/subdir.mk:29: board/peripherals.o] Error 1
make[1]: *** [board/subdir.mk:29: board/board.o] Error 1
make[1]: *** [board/subdir.mk:29: board/pin_mux.o] Error 1
In file included from ../source/MCXW236B_Project.c:13:
/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board/board.h:10:10: fatal error: fsl_common.h: No such file or directory
   10 | #include "fsl_common.h"
make[1]: *** [source/subdir.mk:23: source/MCXW236B_Project.o] Error 1
Finished building: ../source/semihost_hardfault.c
make: *** [makefile:36: all] Error 2
"make -r -j11 all" terminated with exit code 2. Build might be incomplete.
13:27:31 Build Failed. 12 errors, 0 warnings. (took 580ms)
There is something that was pondering me. When creating a new project for FRDM-MCXN947, everything worked out of the box. Please note the differences between the pre-selected components for both boards in the new project wizard:
The template for the MCXN947 has more components preselected. The MCXW23 template seems to missing essential components to start out of the box.
I was able to somehow click together some components to make it work, but it would be better to fix the project template to work out of the box. 
1,001件の閲覧回数
Harry_Zhang
Hi @stejen
Thanks for your information.
I can reproduce this issue.
I will report it to our IDE team.
I think you can import the Hello World example as a starting point.
Harry
1,095件の閲覧回数
Harry_Zhang
Hi @stejen
May I ask what the compilation error is?
Can you share your project?
I downloaded the latest version of the SDK(SDK_25_12_00_FRDM-MCXW23) and it can be successfully compiled.
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2295435%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-MCXW23%20%E3%82%92%E6%90%AD%E8%BC%89%E3%81%97%E3%81%9F%20MCUXpressoIDE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295435%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%3C%2FP%3E%3CP%3EMCUXpressoIDE%E3%81%AFFRDM-MCXW23%E3%81%A7%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%8F%E5%8B%95%E4%BD%9C%E3%81%97%E3%81%AA%E3%81%84%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EIDE%20%E5%86%85%E3%81%AB%E6%AD%A3%E3%81%97%E3%81%84%20SDK%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%81%9F%E3%81%A0%E3%81%97%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%A8%E3%81%8D%E3%81%AB%E3%80%8C%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20%E3%83%86%E3%83%B3%E3%83%97%E3%83%AC%E3%83%BC%E3%83%88%E3%80%8D%E3%82%AB%E3%83%86%E3%82%B4%E3%83%AA%E3%81%AE%E3%81%BF%E3%81%8C%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A7%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%20%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3EFRDM-MCXN947%20%E3%81%AE%E5%A0%B4%E5%90%88%E3%80%81%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%8C%E3%81%99%E3%81%90%E3%81%AB%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2295435%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E9%96%8B%E7%99%BA%E3%83%9C%E3%83%BC%E3%83%89%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2295955%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCUXpressoIDE%20with%20FRDM-MCXW23%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295955%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251666%22%20target%3D%22_blank%22%3E%40stejen%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%A8%E3%81%AF%E4%BD%95%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E6%9C%80%E6%96%B0%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%81%AE%20SDK%20(SDK_25_12_00_FRDM-MCXW23)%20%E3%82%92%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%97%E3%80%81%E6%AD%A3%E5%B8%B8%E3%81%AB%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2296005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCUXpressoIDE%20with%20FRDM-MCXW23%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2296005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%20%E3%80%81%3C%2FP%3E%3CP%3E%E3%81%94%E9%80%A3%E7%B5%A1%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%A7%81%E3%81%AE%E7%8A%B6%E6%B3%81%E3%81%A8%E5%86%8D%E7%8F%BE%E6%96%B9%E6%B3%95%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3CBR%20%2F%3E%E3%81%99%E3%81%B9%E3%81%A6%E3%81%AE%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%82%92%E5%90%AB%E3%82%80%20MCUXpresso%20IDE%2025.6%20%E3%82%92%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82Linux%E3%81%A8macOS%E3%81%AE%E4%B8%A1%E6%96%B9%E3%81%A7%E3%81%93%E3%82%8C%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E7%8F%BE%E5%9C%A8%E3%80%81IDE%20%E7%B5%8C%E7%94%B1%E3%81%A7%E7%9B%B4%E6%8E%A5%202%20%E3%81%A4%E3%81%AE%20SDKs%20%E3%81%8C%E3%82%A4%E3%83%B3%E3%82%B9%E3%83%88%E3%83%BC%E3%83%AB%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3ESDK_2.x_FRDM-MCXN947%2025.09.00%3CBR%20%2F%3ESDK_2.x_FRDM-MCXW232000%E5%B9%B43%E6%9C%8825%E6%97%A5%3C%2FP%3E%3CP%3E%E3%81%93%E3%82%8C%E3%82%89%E3%81%AESDK%E3%81%AFIDE%E3%81%AB%E3%82%88%E3%81%A3%E3%81%A6%E3%80%8C%E6%9C%80%E6%96%B0%E3%80%8D%E3%81%A8%E3%81%97%E3%81%A6%E3%83%80%E3%82%A6%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FP%3E%3CP%3E%E6%AC%A1%E3%81%AB%E3%80%81IDE%20%E7%B5%8C%E7%94%B1%E3%81%A7%E7%9B%B4%E6%8E%A5%E3%80%81FRDM-MCXW23%20%E7%94%A8%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E3%82%B3%E3%83%B3%E3%83%91%E3%82%A4%E3%83%AB%E3%81%99%E3%82%8B%E9%9A%9B%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%20%E3%83%A1%E3%83%83%E3%82%BB%E3%83%BC%E3%82%B8%E3%81%AF%E6%AC%A1%E3%81%AE%E3%81%A8%E3%81%8A%E3%82%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E13%3A27%3A31%20****%20Build%20of%20configuration%20Debug%20for%20project%20MCXW236B_Project%20****%0Amake%20-r%20-j11%20all%0ABuilding%20file%3A%20..%2Fsource%2FMCXW236B_Project.c%0ABuilding%20file%3A%20..%2Fboard%2Fboard.c%0ABuilding%20file%3A%20..%2Fsource%2Fsemihost_hardfault.c%0ABuilding%20file%3A%20..%2Fboard%2Fclock_config.c%0ABuilding%20file%3A%20..%2Fboard%2Fperipherals.c%0ABuilding%20file%3A%20..%2Fboard%2Fpin_mux.c%0AInvoking%3A%20MCU%20C%20Compiler%0Aarm-none-eabi-gcc%20-D__REDLIB__%20-DCPU_MCXW236BIHNAR%20-DCPU_MCXW236BIHNAR_cm33%20-DSDK_DEBUGCONSOLE%3D1%20-DCR_INTEGER_PRINTF%20-DPRINTF_FLOAT_ENABLE%3D0%20-D__MCUXPRESSO%20-DDEBUG%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%22%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fsource%22%20-O0%20-fno-common%20-g3%20-gdwarf-4%20-Wall%20-c%20-ffunction-sections%20-fdata-sections%20-fno-builtin%20-fmerge-constants%20-fmacro-prefix-map%3D%22..%2Fsource%2F%22%3D%20-mcpu%3Dcortex-m33%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-mthumb%20-D__REDLIB__%20-fstack-usage%20-specs%3Dredlib.specs%20-MMD%20-MP%20-MF%22source%2FMCXW236B_Project.d%22%20-MT%22source%2FMCXW236B_Project.o%22%20-MT%22source%2FMCXW236B_Project.d%22%20-o%20%22source%2FMCXW236B_Project.o%22%20%22..%2Fsource%2FMCXW236B_Project.c%22%0AInvoking%3A%20MCU%20C%20Compiler%0AInvoking%3A%20MCU%20C%20Compiler%0Aarm-none-eabi-gcc%20-D__REDLIB__%20-DCPU_MCXW236BIHNAR%20-DCPU_MCXW236BIHNAR_cm33%20-DSDK_DEBUGCONSOLE%3D1%20-DCR_INTEGER_PRINTF%20-DPRINTF_FLOAT_ENABLE%3D0%20-D__MCUXPRESSO%20-DDEBUG%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%22%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fsource%22%20-O0%20-fno-common%20-g3%20-gdwarf-4%20-Wall%20-c%20-ffunction-sections%20-fdata-sections%20-fno-builtin%20-fmerge-constants%20-fmacro-prefix-map%3D%22..%2Fboard%2F%22%3D%20-mcpu%3Dcortex-m33%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-mthumb%20-D__REDLIB__%20-fstack-usage%20-specs%3Dredlib.specs%20-MMD%20-MP%20-MF%22board%2Fboard.d%22%20-MT%22board%2Fboard.o%22%20-MT%22board%2Fboard.d%22%20-o%20%22board%2Fboard.o%22%20%22..%2Fboard%2Fboard.c%22%0Aarm-none-eabi-gcc%20-D__REDLIB__%20-DCPU_MCXW236BIHNAR%20-DCPU_MCXW236BIHNAR_cm33%20-DSDK_DEBUGCONSOLE%3D1%20-DCR_INTEGER_PRINTF%20-DPRINTF_FLOAT_ENABLE%3D0%20-D__MCUXPRESSO%20-DDEBUG%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%22%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fsource%22%20-O0%20-fno-common%20-g3%20-gdwarf-4%20-Wall%20-c%20-ffunction-sections%20-fdata-sections%20-fno-builtin%20-fmerge-constants%20-fmacro-prefix-map%3D%22..%2Fsource%2F%22%3D%20-mcpu%3Dcortex-m33%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-mthumb%20-D__REDLIB__%20-fstack-usage%20-specs%3Dredlib.specs%20-MMD%20-MP%20-MF%22source%2Fsemihost_hardfault.d%22%20-MT%22source%2Fsemihost_hardfault.o%22%20-MT%22source%2Fsemihost_hardfault.d%22%20-o%20%22source%2Fsemihost_hardfault.o%22%20%22..%2Fsource%2Fsemihost_hardfault.c%22%0AInvoking%3A%20MCU%20C%20Compiler%0AInvoking%3A%20MCU%20C%20Compiler%0Aarm-none-eabi-gcc%20-D__REDLIB__%20-DCPU_MCXW236BIHNAR%20-DCPU_MCXW236BIHNAR_cm33%20-DSDK_DEBUGCONSOLE%3D1%20-DCR_INTEGER_PRINTF%20-DPRINTF_FLOAT_ENABLE%3D0%20-D__MCUXPRESSO%20-DDEBUG%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%22%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fsource%22%20-O0%20-fno-common%20-g3%20-gdwarf-4%20-Wall%20-c%20-ffunction-sections%20-fdata-sections%20-fno-builtin%20-fmerge-constants%20-fmacro-prefix-map%3D%22..%2Fboard%2F%22%3D%20-mcpu%3Dcortex-m33%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-mthumb%20-D__REDLIB__%20-fstack-usage%20-specs%3Dredlib.specs%20-MMD%20-MP%20-MF%22board%2Fperipherals.d%22%20-MT%22board%2Fperipherals.o%22%20-MT%22board%2Fperipherals.d%22%20-o%20%22board%2Fperipherals.o%22%20%22..%2Fboard%2Fperipherals.c%22%0Aarm-none-eabi-gcc%20-D__REDLIB__%20-DCPU_MCXW236BIHNAR%20-DCPU_MCXW236BIHNAR_cm33%20-DSDK_DEBUGCONSOLE%3D1%20-DCR_INTEGER_PRINTF%20-DPRINTF_FLOAT_ENABLE%3D0%20-D__MCUXPRESSO%20-DDEBUG%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%22%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fsource%22%20-O0%20-fno-common%20-g3%20-gdwarf-4%20-Wall%20-c%20-ffunction-sections%20-fdata-sections%20-fno-builtin%20-fmerge-constants%20-fmacro-prefix-map%3D%22..%2Fboard%2F%22%3D%20-mcpu%3Dcortex-m33%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-mthumb%20-D__REDLIB__%20-fstack-usage%20-specs%3Dredlib.specs%20-MMD%20-MP%20-MF%22board%2Fclock_config.d%22%20-MT%22board%2Fclock_config.o%22%20-MT%22board%2Fclock_config.d%22%20-o%20%22board%2Fclock_config.o%22%20%22..%2Fboard%2Fclock_config.c%22%0AInvoking%3A%20MCU%20C%20Compiler%0Aarm-none-eabi-gcc%20-D__REDLIB__%20-DCPU_MCXW236BIHNAR%20-DCPU_MCXW236BIHNAR_cm33%20-DSDK_DEBUGCONSOLE%3D1%20-DCR_INTEGER_PRINTF%20-DPRINTF_FLOAT_ENABLE%3D0%20-D__MCUXPRESSO%20-DDEBUG%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%22%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fsource%22%20-O0%20-fno-common%20-g3%20-gdwarf-4%20-Wall%20-c%20-ffunction-sections%20-fdata-sections%20-fno-builtin%20-fmerge-constants%20-fmacro-prefix-map%3D%22..%2Fboard%2F%22%3D%20-mcpu%3Dcortex-m33%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-mthumb%20-D__REDLIB__%20-fstack-usage%20-specs%3Dredlib.specs%20-MMD%20-MP%20-MF%22board%2Fpin_mux.d%22%20-MT%22board%2Fpin_mux.o%22%20-MT%22board%2Fpin_mux.d%22%20-o%20%22board%2Fpin_mux.o%22%20%22..%2Fboard%2Fpin_mux.c%22%0A..%2Fboard%2Fboard.c%3A7%3A10%3A%20fatal%20error%3A%20fsl_common.h%3A%20No%20such%20file%20or%20directory%0A%20%20%20%207%20%7C%20%23include%20%22fsl_common.h%22%0A%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%5E~~~~~~~~~~~~~%0Acompilation%20terminated.%0A..%2Fboard%2Fclock_config.c%3A7%3A10%3A%20fatal%20error%3A%20fsl_power.h%3A%20No%20such%20file%20or%20directory%0A%20%20%20%207%20%7C%20%23include%20%22fsl_power.h%22%0A%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%5E~~~~~~~~~~~~%0Acompilation%20terminated.%0AIn%20file%20included%20from%20..%2Fboard%2Fperipherals.c%3A56%3A%0A..%2Fboard%2Fperipherals.h%3A18%3A10%3A%20fatal%20error%3A%20fsl_common.h%3A%20No%20such%20file%20or%20directory%0A%20%20%2018%20%7C%20%23include%20%22fsl_common.h%22%0A%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%5E~~~~~~~~~~~~~%0Acompilation%20terminated.%0A..%2Fboard%2Fpin_mux.c%3A48%3A10%3A%20fatal%20error%3A%20fsl_common.h%3A%20No%20such%20file%20or%20directory%0A%20%20%2048%20%7C%20%23include%20%22fsl_common.h%22%0A%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%5E~~~~~~~~~~~~~%0Acompilation%20terminated.%0Amake%5B1%5D%3A%20***%20%5Bboard%2Fsubdir.mk%3A29%3A%20board%2Fclock_config.o%5D%20Error%201%0Amake%5B1%5D%3A%20***%20Waiting%20for%20unfinished%20jobs....%0Amake%5B1%5D%3A%20***%20%5Bboard%2Fsubdir.mk%3A29%3A%20board%2Fperipherals.o%5D%20Error%201%0Amake%5B1%5D%3A%20***%20%5Bboard%2Fsubdir.mk%3A29%3A%20board%2Fboard.o%5D%20Error%201%0Amake%5B1%5D%3A%20***%20%5Bboard%2Fsubdir.mk%3A29%3A%20board%2Fpin_mux.o%5D%20Error%201%0AIn%20file%20included%20from%20..%2Fsource%2FMCXW236B_Project.c%3A13%3A%0A%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%2Fboard.h%3A10%3A10%3A%20fatal%20error%3A%20fsl_common.h%3A%20No%20such%20file%20or%20directory%0A%20%20%2010%20%7C%20%23include%20%22fsl_common.h%22%0A%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%5E~~~~~~~~~~~~~%0Acompilation%20terminated.%0Amake%5B1%5D%3A%20***%20%5Bsource%2Fsubdir.mk%3A23%3A%20source%2FMCXW236B_Project.o%5D%20Error%201%0AFinished%20building%3A%20..%2Fsource%2Fsemihost_hardfault.c%0A%20%0Amake%3A%20***%20%5Bmakefile%3A36%3A%20all%5D%20Error%202%0A%22make%20-r%20-j11%20all%22%20terminated%20with%20exit%20code%202.%20Build%20might%20be%20incomplete.%0A%0A13%3A27%3A31%20Build%20Failed.%2012%20errors%2C%200%20warnings.%20(took%20580ms)%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E6%B0%97%E3%81%AB%E3%81%AA%E3%81%A3%E3%81%A6%E3%81%84%E3%81%9F%E3%81%93%E3%81%A8%E3%81%8C%E3%81%82%E3%82%8A%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82FRDM-MCXN947%20%E3%81%AE%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%82%92%E4%BD%9C%E6%88%90%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%81%99%E3%81%B9%E3%81%A6%E3%81%8C%E3%81%99%E3%81%90%E3%81%AB%E6%A9%9F%E8%83%BD%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E6%96%B0%E3%81%97%E3%81%84%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20%E3%82%A6%E3%82%A3%E3%82%B6%E3%83%BC%E3%83%89%E3%81%A7%E4%B8%A1%E6%96%B9%E3%81%AE%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AB%E5%AF%BE%E3%81%97%E3%81%A6%E4%BA%8B%E5%89%8D%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%AE%E9%81%95%E3%81%84%E3%81%AB%E6%B3%A8%E6%84%8F%E3%81%97%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22frdm-mcxw23.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22frdm-mcxw23.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22frdm-mcxw23.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373361i8C5B23C482BB0BAA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22frdm-mcxw23.png%22%20alt%3D%22frdm-mcxw23.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22frdm-mcxn947.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22frdm-mcxn947.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22frdm-mcxn947.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373362iBC0B0C3B621B9E8D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22frdm-mcxn947.png%22%20alt%3D%22frdm-mcxn947.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EMCXN947%20%E3%81%AE%E3%83%86%E3%83%B3%E3%83%97%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AB%E3%81%AF%E3%80%81%E3%81%95%E3%82%89%E3%81%AB%E5%A4%9A%E3%81%8F%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%8C%E4%BA%8B%E5%89%8D%E9%81%B8%E6%8A%9E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82MCXW23%20%E3%83%86%E3%83%B3%E3%83%97%E3%83%AC%E3%83%BC%E3%83%88%E3%81%AB%E3%81%AF%E3%80%81%E3%81%99%E3%81%90%E3%81%AB%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E5%BF%85%E8%A6%81%E3%81%AA%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%81%8C%E6%AC%A0%E3%81%91%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%95%E3%81%A8%E3%81%8B%E3%81%84%E3%81%8F%E3%81%A4%E3%81%8B%E3%81%AE%E3%82%B3%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%8D%E3%83%B3%E3%83%88%E3%82%92%E3%82%AF%E3%83%AA%E3%83%83%E3%82%AF%E3%81%97%E3%81%A6%E5%8B%95%E4%BD%9C%E3%81%95%E3%81%9B%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%97%E3%81%9F%E3%81%8C%E3%80%81%E3%81%99%E3%81%90%E3%81%AB%E5%8B%95%E4%BD%9C%E3%81%99%E3%82%8B%E3%82%88%E3%81%86%E3%81%AB%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%20%E3%83%86%E3%83%B3%E3%83%97%E3%83%AC%E3%83%BC%E3%83%88%E3%82%92%E4%BF%AE%E6%AD%A3%E3%81%97%E3%81%9F%E3%81%BB%E3%81%86%E3%81%8C%E3%82%88%E3%81%84%E3%81%A7%E3%81%97%E3%82%87%E3%81%86%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2297144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCUXpressoIDE%20with%20FRDM-MCXW23%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2297144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251666%22%20target%3D%22_blank%22%3E%40stejen%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%83%85%E5%A0%B1%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%8D%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E5%86%8D%E7%8F%BE%E3%81%A7%E3%81%8D%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%BC%8A%E7%A4%BE%E3%81%AE%20IDE%20%E3%83%81%E3%83%BC%E3%83%A0%E3%81%AB%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%87%BA%E7%99%BA%E7%82%B9%E3%81%A8%E3%81%97%E3%81%A6%20Hello%20World%20%E3%81%AE%E4%BE%8B%E3%82%92%E3%82%A4%E3%83%B3%E3%83%9D%E3%83%BC%E3%83%88%E3%81%A7%E3%81%8D%E3%82%8B%E3%81%A8%E6%80%9D%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1768983696079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1768983696079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373649i6479EC26DBE1130E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1768983696079.png%22%20alt%3D%22Harry_Zhang_0-1768983696079.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%83%8F%E3%83%AA%E3%83%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E
