MCUXpressoIDE with FRDM-MCXW23
1,198 次查看
stejen
it seems MCUXpressoIDE does not work correctly with FRDM-MCXW23.
I installed the correct SDK inside the IDE. However, on creating a new project only the "Project Template" category is selected, which leads to compiling errors in a new project.
For FRDM-MCXN947, all needed components to compile a fresh projects are selected out of the box.
标记 (1)
1,109 次查看
stejen
Hi @Harry_Zhang,
thank you for reaching out to me.
Here my situation and how to reproduce:
I have installed MCUXpresso IDE 25.6 with all updates. I can confirm this on both Linux and macOS
I currently have 2 SDKs installed directly via the IDE:
SDK_2.x_FRDM-MCXN947 25.09.00
SDK_2.x_FRDM-MCXW23 25.03.00
Those SDKs were downloaded by the IDE as "latest"
Then I created a new project for FRDM-MCXW23 - as well directly via the IDE.
Here the error message on compiling the fresh project:
13:27:31 **** Build of configuration Debug for project MCXW236B_Project ****
make -r -j11 all
Building file: ../source/MCXW236B_Project.c
Building file: ../board/board.c
Building file: ../source/semihost_hardfault.c
Building file: ../board/clock_config.c
Building file: ../board/peripherals.c
Building file: ../board/pin_mux.c
Invoking: MCU C Compiler
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXW236BIHNAR -DCPU_MCXW236BIHNAR_cm33 -DSDK_DEBUGCONSOLE=1 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -D__MCUXPRESSO -DDEBUG -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board" -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/source" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../source/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"source/MCXW236B_Project.d" -MT"source/MCXW236B_Project.o" -MT"source/MCXW236B_Project.d" -o "source/MCXW236B_Project.o" "../source/MCXW236B_Project.c"
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXW236BIHNAR -DCPU_MCXW236BIHNAR_cm33 -DSDK_DEBUGCONSOLE=1 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -D__MCUXPRESSO -DDEBUG -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board" -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/source" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../board/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"board/board.d" -MT"board/board.o" -MT"board/board.d" -o "board/board.o" "../board/board.c"
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXW236BIHNAR -DCPU_MCXW236BIHNAR_cm33 -DSDK_DEBUGCONSOLE=1 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -D__MCUXPRESSO -DDEBUG -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board" -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/source" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../source/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"source/semihost_hardfault.d" -MT"source/semihost_hardfault.o" -MT"source/semihost_hardfault.d" -o "source/semihost_hardfault.o" "../source/semihost_hardfault.c"
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXW236BIHNAR -DCPU_MCXW236BIHNAR_cm33 -DSDK_DEBUGCONSOLE=1 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -D__MCUXPRESSO -DDEBUG -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board" -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/source" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../board/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"board/peripherals.d" -MT"board/peripherals.o" -MT"board/peripherals.d" -o "board/peripherals.o" "../board/peripherals.c"
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXW236BIHNAR -DCPU_MCXW236BIHNAR_cm33 -DSDK_DEBUGCONSOLE=1 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -D__MCUXPRESSO -DDEBUG -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board" -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/source" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../board/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"board/clock_config.d" -MT"board/clock_config.o" -MT"board/clock_config.d" -o "board/clock_config.o" "../board/clock_config.c"
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXW236BIHNAR -DCPU_MCXW236BIHNAR_cm33 -DSDK_DEBUGCONSOLE=1 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -D__MCUXPRESSO -DDEBUG -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board" -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/source" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../board/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"board/pin_mux.d" -MT"board/pin_mux.o" -MT"board/pin_mux.d" -o "board/pin_mux.o" "../board/pin_mux.c"
../board/board.c:7:10: fatal error: fsl_common.h: No such file or directory
    7 | #include "fsl_common.h"
compilation terminated.
../board/clock_config.c:7:10: fatal error: fsl_power.h: No such file or directory
    7 | #include "fsl_power.h"
In file included from ../board/peripherals.c:56:
../board/peripherals.h:18:10: fatal error: fsl_common.h: No such file or directory
   18 | #include "fsl_common.h"
../board/pin_mux.c:48:10: fatal error: fsl_common.h: No such file or directory
   48 | #include "fsl_common.h"
make[1]: *** [board/subdir.mk:29: board/clock_config.o] Error 1
make[1]: *** Waiting for unfinished jobs....
make[1]: *** [board/subdir.mk:29: board/peripherals.o] Error 1
make[1]: *** [board/subdir.mk:29: board/board.o] Error 1
make[1]: *** [board/subdir.mk:29: board/pin_mux.o] Error 1
In file included from ../source/MCXW236B_Project.c:13:
/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board/board.h:10:10: fatal error: fsl_common.h: No such file or directory
   10 | #include "fsl_common.h"
make[1]: *** [source/subdir.mk:23: source/MCXW236B_Project.o] Error 1
Finished building: ../source/semihost_hardfault.c
make: *** [makefile:36: all] Error 2
"make -r -j11 all" terminated with exit code 2. Build might be incomplete.
13:27:31 Build Failed. 12 errors, 0 warnings. (took 580ms)
There is something that was pondering me. When creating a new project for FRDM-MCXN947, everything worked out of the box. Please note the differences between the pre-selected components for both boards in the new project wizard:
The template for the MCXN947 has more components preselected. The MCXW23 template seems to missing essential components to start out of the box.
I was able to somehow click together some components to make it work, but it would be better to fix the project template to work out of the box. 
1,020 次查看
Harry_Zhang
Hi @stejen
Thanks for your information.
I can reproduce this issue.
I will report it to our IDE team.
I think you can import the Hello World example as a starting point.
Harry
1,114 次查看
Harry_Zhang
Hi @stejen
May I ask what the compilation error is?
Can you share your project?
I downloaded the latest version of the SDK(SDK_25_12_00_FRDM-MCXW23) and it can be successfully compiled.
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2295435%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%B8%A6%E6%9C%89%20FRDM-MCXW23%20%E7%9A%84%20MCUXpressoIDE%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295435%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%3CP%3EMCUXpressoIDE%20%E4%BC%BC%E4%B9%8E%E6%97%A0%E6%B3%95%E4%B8%8E%20FRDM-MCXW23%20%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%9C%A8%E9%9B%86%E6%88%90%E5%BC%80%E5%8F%91%E7%8E%AF%E5%A2%83%E4%B8%AD%E5%AE%89%E8%A3%85%E4%BA%86%E6%AD%A3%E7%A1%AE%E7%9A%84%20SDK%E3%80%82%E7%84%B6%E8%80%8C%EF%BC%8C%E5%9C%A8%E5%88%9B%E5%BB%BA%E6%96%B0%E9%A1%B9%E7%9B%AE%E6%97%B6%EF%BC%8C%E5%8F%AA%E9%80%89%E6%8B%A9%E4%BA%86%22Project%20Template%22%20%E7%B1%BB%E5%88%AB%EF%BC%8C%E8%BF%99%E4%BC%9A%E5%AF%BC%E8%87%B4%E6%96%B0%E9%A1%B9%E7%9B%AE%E7%BC%96%E8%AF%91%E5%87%BA%E9%94%99%E3%80%82%3C%2FP%3E%3CP%3E%E5%AF%B9%E4%BA%8E%20FRDM-MCXN947%EF%BC%8C%E7%BC%96%E8%AF%91%E6%96%B0%E9%A1%B9%E7%9B%AE%E6%89%80%E9%9C%80%E7%9A%84%E6%89%80%E6%9C%89%E5%85%83%E5%99%A8%E4%BB%B6%E9%83%BD%E6%98%AF%E5%BC%80%E7%AE%B1%E5%8D%B3%E7%94%A8%E7%9A%84%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2295435%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%BC%80%E5%8F%91%E6%9D%BF%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2295955%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCUXpressoIDE%20with%20FRDM-MCXW23%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295955%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251666%22%20target%3D%22_blank%22%3E%40stejen%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E9%97%AE%E6%98%AF%E4%BB%80%E4%B9%88%E7%BC%96%E8%AF%91%E9%94%99%E8%AF%AF%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%82%A8%E8%83%BD%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%8B%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%B8%8B%E8%BD%BD%E4%BA%86%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E7%9A%84%20SDK%EF%BC%88SDK_25_12_00_FRDM-MCXW23%EF%BC%89%EF%BC%8C%E5%8F%AF%E4%BB%A5%E6%88%90%E5%8A%9F%E7%BC%96%E8%AF%91%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2296005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCUXpressoIDE%20with%20FRDM-MCXW23%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2296005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%EF%BC%8C%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%E3%80%81%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E4%B8%8E%E6%88%91%E8%81%94%E7%B3%BB%E3%80%82%3C%2FP%3E%3CP%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%88%91%E7%9A%84%E6%83%85%E5%86%B5%E5%92%8C%E9%87%8D%E7%8E%B0%E6%96%B9%E6%B3%95%EF%BC%9A%3CBR%20%2F%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%AE%89%E8%A3%85%E4%BA%86%20MCUXpresso%20IDE%2025.6%EF%BC%8C%E5%B9%B6%E8%BF%9B%E8%A1%8C%E4%BA%86%E6%89%80%E6%9C%89%E6%9B%B4%E6%96%B0%E3%80%82%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%20Linux%20%E5%92%8C%20macOS%20%E4%B8%8A%E7%A1%AE%E8%AE%A4%E8%BF%99%E4%B8%80%E7%82%B9%3C%2FP%3E%3CP%3E%E7%9B%AE%E5%89%8D%EF%BC%8C%E6%88%91%E9%80%9A%E8%BF%87%E9%9B%86%E6%88%90%E5%BC%80%E5%8F%91%E7%8E%AF%E5%A2%83%E7%9B%B4%E6%8E%A5%E5%AE%89%E8%A3%85%E4%BA%86%202%20%E4%B8%AA%20SDK%EF%BC%9A%3C%2FP%3E%3CP%3ESDK_2.x_FRDM-MCXN947%2025.09.00%3CBR%20%2F%3ESDK_2.x_FRDM-MCXW2325.03.00%3C%2FP%3E%3CP%3E%E8%BF%99%E4%BA%9B%20SDK%20%E8%A2%AB%E9%9B%86%E6%88%90%E5%BC%80%E5%8F%91%E7%8E%AF%E5%A2%83%E4%B8%8B%E8%BD%BD%E4%B8%BA%22%E6%9C%80%E6%96%B0%E7%89%88%E6%9C%AC%E3%80%82%22%3C%2FP%3E%3CP%3E%E7%84%B6%E5%90%8E%EF%BC%8C%E6%88%91%E7%9B%B4%E6%8E%A5%E9%80%9A%E8%BF%87%E9%9B%86%E6%88%90%E5%BC%80%E5%8F%91%E7%8E%AF%E5%A2%83%E4%B8%BA%20FRDM-MCXW23%20%E5%88%9B%E5%BB%BA%E4%BA%86%E4%B8%80%E4%B8%AA%E6%96%B0%E9%A1%B9%E7%9B%AE%E3%80%82%3C%2FP%3E%3CP%3E%E4%B8%8B%E9%9D%A2%E6%98%AF%E7%BC%96%E8%AF%91%E6%96%B0%E9%A1%B9%E7%9B%AE%E6%97%B6%E7%9A%84%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%20translate%3D%22no%22%3E13%3A27%3A31%20****%20Build%20of%20configuration%20Debug%20for%20project%20MCXW236B_Project%20****%0Amake%20-r%20-j11%20all%0ABuilding%20file%3A%20..%2Fsource%2FMCXW236B_Project.c%0ABuilding%20file%3A%20..%2Fboard%2Fboard.c%0ABuilding%20file%3A%20..%2Fsource%2Fsemihost_hardfault.c%0ABuilding%20file%3A%20..%2Fboard%2Fclock_config.c%0ABuilding%20file%3A%20..%2Fboard%2Fperipherals.c%0ABuilding%20file%3A%20..%2Fboard%2Fpin_mux.c%0AInvoking%3A%20MCU%20C%20Compiler%0Aarm-none-eabi-gcc%20-D__REDLIB__%20-DCPU_MCXW236BIHNAR%20-DCPU_MCXW236BIHNAR_cm33%20-DSDK_DEBUGCONSOLE%3D1%20-DCR_INTEGER_PRINTF%20-DPRINTF_FLOAT_ENABLE%3D0%20-D__MCUXPRESSO%20-DDEBUG%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%22%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fsource%22%20-O0%20-fno-common%20-g3%20-gdwarf-4%20-Wall%20-c%20-ffunction-sections%20-fdata-sections%20-fno-builtin%20-fmerge-constants%20-fmacro-prefix-map%3D%22..%2Fsource%2F%22%3D%20-mcpu%3Dcortex-m33%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-mthumb%20-D__REDLIB__%20-fstack-usage%20-specs%3Dredlib.specs%20-MMD%20-MP%20-MF%22source%2FMCXW236B_Project.d%22%20-MT%22source%2FMCXW236B_Project.o%22%20-MT%22source%2FMCXW236B_Project.d%22%20-o%20%22source%2FMCXW236B_Project.o%22%20%22..%2Fsource%2FMCXW236B_Project.c%22%0AInvoking%3A%20MCU%20C%20Compiler%0AInvoking%3A%20MCU%20C%20Compiler%0Aarm-none-eabi-gcc%20-D__REDLIB__%20-DCPU_MCXW236BIHNAR%20-DCPU_MCXW236BIHNAR_cm33%20-DSDK_DEBUGCONSOLE%3D1%20-DCR_INTEGER_PRINTF%20-DPRINTF_FLOAT_ENABLE%3D0%20-D__MCUXPRESSO%20-DDEBUG%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%22%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fsource%22%20-O0%20-fno-common%20-g3%20-gdwarf-4%20-Wall%20-c%20-ffunction-sections%20-fdata-sections%20-fno-builtin%20-fmerge-constants%20-fmacro-prefix-map%3D%22..%2Fboard%2F%22%3D%20-mcpu%3Dcortex-m33%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-mthumb%20-D__REDLIB__%20-fstack-usage%20-specs%3Dredlib.specs%20-MMD%20-MP%20-MF%22board%2Fboard.d%22%20-MT%22board%2Fboard.o%22%20-MT%22board%2Fboard.d%22%20-o%20%22board%2Fboard.o%22%20%22..%2Fboard%2Fboard.c%22%0Aarm-none-eabi-gcc%20-D__REDLIB__%20-DCPU_MCXW236BIHNAR%20-DCPU_MCXW236BIHNAR_cm33%20-DSDK_DEBUGCONSOLE%3D1%20-DCR_INTEGER_PRINTF%20-DPRINTF_FLOAT_ENABLE%3D0%20-D__MCUXPRESSO%20-DDEBUG%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%22%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fsource%22%20-O0%20-fno-common%20-g3%20-gdwarf-4%20-Wall%20-c%20-ffunction-sections%20-fdata-sections%20-fno-builtin%20-fmerge-constants%20-fmacro-prefix-map%3D%22..%2Fsource%2F%22%3D%20-mcpu%3Dcortex-m33%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-mthumb%20-D__REDLIB__%20-fstack-usage%20-specs%3Dredlib.specs%20-MMD%20-MP%20-MF%22source%2Fsemihost_hardfault.d%22%20-MT%22source%2Fsemihost_hardfault.o%22%20-MT%22source%2Fsemihost_hardfault.d%22%20-o%20%22source%2Fsemihost_hardfault.o%22%20%22..%2Fsource%2Fsemihost_hardfault.c%22%0AInvoking%3A%20MCU%20C%20Compiler%0AInvoking%3A%20MCU%20C%20Compiler%0Aarm-none-eabi-gcc%20-D__REDLIB__%20-DCPU_MCXW236BIHNAR%20-DCPU_MCXW236BIHNAR_cm33%20-DSDK_DEBUGCONSOLE%3D1%20-DCR_INTEGER_PRINTF%20-DPRINTF_FLOAT_ENABLE%3D0%20-D__MCUXPRESSO%20-DDEBUG%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%22%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fsource%22%20-O0%20-fno-common%20-g3%20-gdwarf-4%20-Wall%20-c%20-ffunction-sections%20-fdata-sections%20-fno-builtin%20-fmerge-constants%20-fmacro-prefix-map%3D%22..%2Fboard%2F%22%3D%20-mcpu%3Dcortex-m33%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-mthumb%20-D__REDLIB__%20-fstack-usage%20-specs%3Dredlib.specs%20-MMD%20-MP%20-MF%22board%2Fperipherals.d%22%20-MT%22board%2Fperipherals.o%22%20-MT%22board%2Fperipherals.d%22%20-o%20%22board%2Fperipherals.o%22%20%22..%2Fboard%2Fperipherals.c%22%0Aarm-none-eabi-gcc%20-D__REDLIB__%20-DCPU_MCXW236BIHNAR%20-DCPU_MCXW236BIHNAR_cm33%20-DSDK_DEBUGCONSOLE%3D1%20-DCR_INTEGER_PRINTF%20-DPRINTF_FLOAT_ENABLE%3D0%20-D__MCUXPRESSO%20-DDEBUG%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%22%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fsource%22%20-O0%20-fno-common%20-g3%20-gdwarf-4%20-Wall%20-c%20-ffunction-sections%20-fdata-sections%20-fno-builtin%20-fmerge-constants%20-fmacro-prefix-map%3D%22..%2Fboard%2F%22%3D%20-mcpu%3Dcortex-m33%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-mthumb%20-D__REDLIB__%20-fstack-usage%20-specs%3Dredlib.specs%20-MMD%20-MP%20-MF%22board%2Fclock_config.d%22%20-MT%22board%2Fclock_config.o%22%20-MT%22board%2Fclock_config.d%22%20-o%20%22board%2Fclock_config.o%22%20%22..%2Fboard%2Fclock_config.c%22%0AInvoking%3A%20MCU%20C%20Compiler%0Aarm-none-eabi-gcc%20-D__REDLIB__%20-DCPU_MCXW236BIHNAR%20-DCPU_MCXW236BIHNAR_cm33%20-DSDK_DEBUGCONSOLE%3D1%20-DCR_INTEGER_PRINTF%20-DPRINTF_FLOAT_ENABLE%3D0%20-D__MCUXPRESSO%20-DDEBUG%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%22%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fsource%22%20-O0%20-fno-common%20-g3%20-gdwarf-4%20-Wall%20-c%20-ffunction-sections%20-fdata-sections%20-fno-builtin%20-fmerge-constants%20-fmacro-prefix-map%3D%22..%2Fboard%2F%22%3D%20-mcpu%3Dcortex-m33%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-mthumb%20-D__REDLIB__%20-fstack-usage%20-specs%3Dredlib.specs%20-MMD%20-MP%20-MF%22board%2Fpin_mux.d%22%20-MT%22board%2Fpin_mux.o%22%20-MT%22board%2Fpin_mux.d%22%20-o%20%22board%2Fpin_mux.o%22%20%22..%2Fboard%2Fpin_mux.c%22%0A..%2Fboard%2Fboard.c%3A7%3A10%3A%20fatal%20error%3A%20fsl_common.h%3A%20No%20such%20file%20or%20directory%0A%20%20%20%207%20%7C%20%23include%20%22fsl_common.h%22%0A%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%5E~~~~~~~~~~~~~%0Acompilation%20terminated.%0A..%2Fboard%2Fclock_config.c%3A7%3A10%3A%20fatal%20error%3A%20fsl_power.h%3A%20No%20such%20file%20or%20directory%0A%20%20%20%207%20%7C%20%23include%20%22fsl_power.h%22%0A%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%5E~~~~~~~~~~~~%0Acompilation%20terminated.%0AIn%20file%20included%20from%20..%2Fboard%2Fperipherals.c%3A56%3A%0A..%2Fboard%2Fperipherals.h%3A18%3A10%3A%20fatal%20error%3A%20fsl_common.h%3A%20No%20such%20file%20or%20directory%0A%20%20%2018%20%7C%20%23include%20%22fsl_common.h%22%0A%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%5E~~~~~~~~~~~~~%0Acompilation%20terminated.%0A..%2Fboard%2Fpin_mux.c%3A48%3A10%3A%20fatal%20error%3A%20fsl_common.h%3A%20No%20such%20file%20or%20directory%0A%20%20%2048%20%7C%20%23include%20%22fsl_common.h%22%0A%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%5E~~~~~~~~~~~~~%0Acompilation%20terminated.%0Amake%5B1%5D%3A%20***%20%5Bboard%2Fsubdir.mk%3A29%3A%20board%2Fclock_config.o%5D%20Error%201%0Amake%5B1%5D%3A%20***%20Waiting%20for%20unfinished%20jobs....%0Amake%5B1%5D%3A%20***%20%5Bboard%2Fsubdir.mk%3A29%3A%20board%2Fperipherals.o%5D%20Error%201%0Amake%5B1%5D%3A%20***%20%5Bboard%2Fsubdir.mk%3A29%3A%20board%2Fboard.o%5D%20Error%201%0Amake%5B1%5D%3A%20***%20%5Bboard%2Fsubdir.mk%3A29%3A%20board%2Fpin_mux.o%5D%20Error%201%0AIn%20file%20included%20from%20..%2Fsource%2FMCXW236B_Project.c%3A13%3A%0A%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%2Fboard.h%3A10%3A10%3A%20fatal%20error%3A%20fsl_common.h%3A%20No%20such%20file%20or%20directory%0A%20%20%2010%20%7C%20%23include%20%22fsl_common.h%22%0A%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%5E~~~~~~~~~~~~~%0Acompilation%20terminated.%0Amake%5B1%5D%3A%20***%20%5Bsource%2Fsubdir.mk%3A23%3A%20source%2FMCXW236B_Project.o%5D%20Error%201%0AFinished%20building%3A%20..%2Fsource%2Fsemihost_hardfault.c%0A%20%0Amake%3A%20***%20%5Bmakefile%3A36%3A%20all%5D%20Error%202%0A%22make%20-r%20-j11%20all%22%20terminated%20with%20exit%20code%202.%20Build%20might%20be%20incomplete.%0A%0A13%3A27%3A31%20Build%20Failed.%2012%20errors%2C%200%20warnings.%20(took%20580ms)%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%E6%88%91%E4%B8%80%E7%9B%B4%E5%9C%A8%E6%80%9D%E8%80%83%E4%B8%80%E4%BB%B6%E4%BA%8B%E3%80%82%E5%9C%A8%E4%B8%BA%20FRDM-MCXN947%20%E5%88%9B%E5%BB%BA%E4%B8%80%E4%B8%AA%E6%96%B0%E9%A1%B9%E7%9B%AE%E6%97%B6%EF%BC%8C%E4%B8%80%E5%88%87%E6%AD%A3%E5%B8%B8%E3%80%82%E8%AF%B7%E6%B3%A8%E6%84%8F%E6%96%B0%E9%A1%B9%E7%9B%AE%E5%90%91%E5%AF%BC%E4%B8%AD%E4%B8%BA%E4%B8%A4%E4%B8%AA%E6%9D%BF%E9%A2%84%E5%85%88%E9%80%89%E6%8B%A9%E7%9A%84%E5%85%83%E5%99%A8%E4%BB%B6%E4%B9%8B%E9%97%B4%E7%9A%84%E5%8C%BA%E5%88%AB%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22frdm-mcxw23.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22frdm-mcxw23.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22frdm-mcxw23.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373361i8C5B23C482BB0BAA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22frdm-mcxw23.png%22%20alt%3D%22frdm-mcxw23.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22frdm-mcxn947.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22frdm-mcxn947.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22frdm-mcxn947.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373362iBC0B0C3B621B9E8D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22frdm-mcxn947.png%22%20alt%3D%22frdm-mcxn947.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EMCXN947%20%E7%9A%84%E6%A8%A1%E6%9D%BF%E9%A2%84%E5%85%88%E9%80%89%E6%8B%A9%E4%BA%86%E6%9B%B4%E5%A4%9A%E5%85%83%E5%99%A8%E4%BB%B6%E3%80%82MCXW23%20%E6%A8%A1%E6%9D%BF%E4%BC%BC%E4%B9%8E%E7%BC%BA%E5%B0%91%E5%BC%80%E7%AE%B1%E5%8D%B3%E7%94%A8%E7%9A%84%E5%9F%BA%E6%9C%AC%E5%85%83%E5%99%A8%E4%BB%B6%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E8%83%BD%E5%A4%9F%E4%BB%A5%E6%9F%90%E7%A7%8D%E6%96%B9%E5%BC%8F%E5%B0%86%E4%B8%80%E4%BA%9B%E5%85%83%E5%99%A8%E4%BB%B6%E7%BB%84%E5%90%88%E5%9C%A8%E4%B8%80%E8%B5%B7%E4%BD%BF%E5%85%B6%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E4%BD%86%E6%98%AF%E6%9C%80%E5%A5%BD%E4%BF%AE%E5%A4%8D%E9%A1%B9%E7%9B%AE%E6%A8%A1%E6%9D%BF%E4%BB%A5%E4%BD%BF%E5%85%B6%E5%BC%80%E7%AE%B1%E5%8D%B3%E7%94%A8%E3%80%82%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2297144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCUXpressoIDE%20with%20FRDM-MCXW23%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2297144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251666%22%20target%3D%22_blank%22%3E%40stejen%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E4%BE%9B%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E9%87%8D%E7%8E%B0%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BC%9A%E5%90%91%20IDE%20%E5%9B%A2%E9%98%9F%E6%8A%A5%E5%91%8A%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%83%B3%E4%BD%A0%E5%8F%AF%E4%BB%A5%E4%BB%8E%20Hello%20World%20%E7%A4%BA%E4%BE%8B%E5%BC%80%E5%A7%8B%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1768983696079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1768983696079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373649i6479EC26DBE1130E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1768983696079.png%22%20alt%3D%22Harry_Zhang_0-1768983696079.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E5%88%A9%3C%2FP%3E%3C%2FLINGO-BODY%3E
