MCUXpressoIDE with FRDM-MCXW23
stejen
it seems MCUXpressoIDE does not work correctly with FRDM-MCXW23.
I installed the correct SDK inside the IDE. However, on creating a new project only the "Project Template" category is selected, which leads to compiling errors in a new project.
For FRDM-MCXN947, all needed components to compile a fresh projects are selected out of the box.
stejen
Hi @Harry_Zhang,
thank you for reaching out to me.
Here my situation and how to reproduce:
I have installed MCUXpresso IDE 25.6 with all updates. I can confirm this on both Linux and macOS
I currently have 2 SDKs installed directly via the IDE:
SDK_2.x_FRDM-MCXN947 25.09.00
SDK_2.x_FRDM-MCXW23 25.03.00
Those SDKs were downloaded by the IDE as "latest"
Then I created a new project for FRDM-MCXW23 - as well directly via the IDE.
Here the error message on compiling the fresh project:
13:27:31 **** Build of configuration Debug for project MCXW236B_Project ****
make -r -j11 all
Building file: ../source/MCXW236B_Project.c
Building file: ../board/board.c
Building file: ../source/semihost_hardfault.c
Building file: ../board/clock_config.c
Building file: ../board/peripherals.c
Building file: ../board/pin_mux.c
Invoking: MCU C Compiler
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXW236BIHNAR -DCPU_MCXW236BIHNAR_cm33 -DSDK_DEBUGCONSOLE=1 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -D__MCUXPRESSO -DDEBUG -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board" -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/source" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../source/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"source/MCXW236B_Project.d" -MT"source/MCXW236B_Project.o" -MT"source/MCXW236B_Project.d" -o "source/MCXW236B_Project.o" "../source/MCXW236B_Project.c"
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXW236BIHNAR -DCPU_MCXW236BIHNAR_cm33 -DSDK_DEBUGCONSOLE=1 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -D__MCUXPRESSO -DDEBUG -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board" -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/source" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../board/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"board/board.d" -MT"board/board.o" -MT"board/board.d" -o "board/board.o" "../board/board.c"
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXW236BIHNAR -DCPU_MCXW236BIHNAR_cm33 -DSDK_DEBUGCONSOLE=1 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -D__MCUXPRESSO -DDEBUG -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board" -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/source" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../source/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"source/semihost_hardfault.d" -MT"source/semihost_hardfault.o" -MT"source/semihost_hardfault.d" -o "source/semihost_hardfault.o" "../source/semihost_hardfault.c"
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXW236BIHNAR -DCPU_MCXW236BIHNAR_cm33 -DSDK_DEBUGCONSOLE=1 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -D__MCUXPRESSO -DDEBUG -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board" -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/source" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../board/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"board/peripherals.d" -MT"board/peripherals.o" -MT"board/peripherals.d" -o "board/peripherals.o" "../board/peripherals.c"
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXW236BIHNAR -DCPU_MCXW236BIHNAR_cm33 -DSDK_DEBUGCONSOLE=1 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -D__MCUXPRESSO -DDEBUG -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board" -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/source" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../board/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"board/clock_config.d" -MT"board/clock_config.o" -MT"board/clock_config.d" -o "board/clock_config.o" "../board/clock_config.c"
arm-none-eabi-gcc -D__REDLIB__ -DCPU_MCXW236BIHNAR -DCPU_MCXW236BIHNAR_cm33 -DSDK_DEBUGCONSOLE=1 -DCR_INTEGER_PRINTF -DPRINTF_FLOAT_ENABLE=0 -D__MCUXPRESSO -DDEBUG -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board" -I"/Users/usernam/MCUXpressoIDE/MCXW236B_Project/source" -O0 -fno-common -g3 -gdwarf-4 -Wall -c -ffunction-sections -fdata-sections -fno-builtin -fmerge-constants -fmacro-prefix-map="../board/"= -mcpu=cortex-m33 -mfpu=fpv5-sp-d16 -mfloat-abi=hard -mthumb -D__REDLIB__ -fstack-usage -specs=redlib.specs -MMD -MP -MF"board/pin_mux.d" -MT"board/pin_mux.o" -MT"board/pin_mux.d" -o "board/pin_mux.o" "../board/pin_mux.c"
../board/board.c:7:10: fatal error: fsl_common.h: No such file or directory
    7 | #include "fsl_common.h"
compilation terminated.
../board/clock_config.c:7:10: fatal error: fsl_power.h: No such file or directory
    7 | #include "fsl_power.h"
In file included from ../board/peripherals.c:56:
../board/peripherals.h:18:10: fatal error: fsl_common.h: No such file or directory
   18 | #include "fsl_common.h"
../board/pin_mux.c:48:10: fatal error: fsl_common.h: No such file or directory
   48 | #include "fsl_common.h"
make[1]: *** [board/subdir.mk:29: board/clock_config.o] Error 1
make[1]: *** Waiting for unfinished jobs....
make[1]: *** [board/subdir.mk:29: board/peripherals.o] Error 1
make[1]: *** [board/subdir.mk:29: board/board.o] Error 1
make[1]: *** [board/subdir.mk:29: board/pin_mux.o] Error 1
In file included from ../source/MCXW236B_Project.c:13:
/Users/usernam/MCUXpressoIDE/MCXW236B_Project/board/board.h:10:10: fatal error: fsl_common.h: No such file or directory
   10 | #include "fsl_common.h"
make[1]: *** [source/subdir.mk:23: source/MCXW236B_Project.o] Error 1
Finished building: ../source/semihost_hardfault.c
make: *** [makefile:36: all] Error 2
"make -r -j11 all" terminated with exit code 2. Build might be incomplete.
13:27:31 Build Failed. 12 errors, 0 warnings. (took 580ms)
There is something that was pondering me. When creating a new project for FRDM-MCXN947, everything worked out of the box. Please note the differences between the pre-selected components for both boards in the new project wizard:
The template for the MCXN947 has more components preselected. The MCXW23 template seems to missing essential components to start out of the box.
I was able to somehow click together some components to make it work, but it would be better to fix the project template to work out of the box. 
Harry_Zhang
Hi @stejen
Thanks for your information.
I can reproduce this issue.
I will report it to our IDE team.
I think you can import the Hello World example as a starting point.
Harry
Harry_Zhang
Hi @stejen
May I ask what the compilation error is?
Can you share your project?
I downloaded the latest version of the SDK(SDK_25_12_00_FRDM-MCXW23) and it can be successfully compiled.
Harry
%3CLINGO-SUB%20id%3D%22lingo-sub-2295435%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCUXpressoIDE%20with%20FRDM-MCXW23%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295435%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%2C%3C%2FP%3E%3CP%3Eit%20seems%20MCUXpressoIDE%20does%20not%20work%20correctly%20with%20FRDM-MCXW23.%3C%2FP%3E%3CP%3EI%20installed%20the%20correct%20SDK%20inside%20the%20IDE.%20However%2C%20on%20creating%20a%20new%20project%20only%20the%20%22Project%20Template%22%20category%20is%20selected%2C%20which%20leads%20to%20compiling%20errors%20in%20a%20new%20project.%3C%2FP%3E%3CP%3EFor%20FRDM-MCXN947%2C%20all%20needed%20components%20to%20compile%20a%20fresh%20projects%20are%20selected%20out%20of%20the%20box.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2295435%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EDevelopment%20Board%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2295955%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCUXpressoIDE%20with%20FRDM-MCXW23%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2295955%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251666%22%20target%3D%22_blank%22%3E%40stejen%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EMay%20I%20ask%20what%20the%20compilation%20error%20is%3F%3C%2FP%3E%0A%3CP%3ECan%20you%20share%20your%20project%3F%3C%2FP%3E%0A%3CP%3EI%20downloaded%20the%20latest%20version%20of%20the%20SDK(SDK_25_12_00_FRDM-MCXW23)%20and%20it%20can%20be%20successfully%20compiled.%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EHarry%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2296005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCUXpressoIDE%20with%20FRDM-MCXW23%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2296005%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F229957%22%20target%3D%22_blank%22%3E%40Harry_Zhang%3C%2FA%3E%2C%3C%2FP%3E%3CP%3Ethank%20you%20for%20reaching%20out%20to%20me.%3C%2FP%3E%3CP%3EHere%20my%20situation%20and%20how%20to%20reproduce%3A%3CBR%20%2F%3EI%20have%20installed%20MCUXpresso%20IDE%2025.6%20with%20all%20updates.%20I%20can%20confirm%20this%20on%20both%20Linux%20and%20macOS%3C%2FP%3E%3CP%3EI%20currently%20have%202%20SDKs%20installed%20directly%20via%20the%20IDE%3A%3C%2FP%3E%3CP%3ESDK_2.x_FRDM-MCXN947%2025.09.00%3CBR%20%2F%3ESDK_2.x_FRDM-MCXW23%2025.03.00%3C%2FP%3E%3CP%3EThose%20SDKs%20were%20downloaded%20by%20the%20IDE%20as%20%22latest%22%3C%2FP%3E%3CP%3EThen%20I%20created%20a%20new%20project%20for%20FRDM-MCXW23%20-%20as%20well%20directly%20via%20the%20IDE.%3C%2FP%3E%3CP%3EHere%20the%20error%20message%20on%20compiling%20the%20fresh%20project%3A%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-markup%22%3E%3CCODE%3E13%3A27%3A31%20****%20Build%20of%20configuration%20Debug%20for%20project%20MCXW236B_Project%20****%0Amake%20-r%20-j11%20all%0ABuilding%20file%3A%20..%2Fsource%2FMCXW236B_Project.c%0ABuilding%20file%3A%20..%2Fboard%2Fboard.c%0ABuilding%20file%3A%20..%2Fsource%2Fsemihost_hardfault.c%0ABuilding%20file%3A%20..%2Fboard%2Fclock_config.c%0ABuilding%20file%3A%20..%2Fboard%2Fperipherals.c%0ABuilding%20file%3A%20..%2Fboard%2Fpin_mux.c%0AInvoking%3A%20MCU%20C%20Compiler%0Aarm-none-eabi-gcc%20-D__REDLIB__%20-DCPU_MCXW236BIHNAR%20-DCPU_MCXW236BIHNAR_cm33%20-DSDK_DEBUGCONSOLE%3D1%20-DCR_INTEGER_PRINTF%20-DPRINTF_FLOAT_ENABLE%3D0%20-D__MCUXPRESSO%20-DDEBUG%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%22%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fsource%22%20-O0%20-fno-common%20-g3%20-gdwarf-4%20-Wall%20-c%20-ffunction-sections%20-fdata-sections%20-fno-builtin%20-fmerge-constants%20-fmacro-prefix-map%3D%22..%2Fsource%2F%22%3D%20-mcpu%3Dcortex-m33%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-mthumb%20-D__REDLIB__%20-fstack-usage%20-specs%3Dredlib.specs%20-MMD%20-MP%20-MF%22source%2FMCXW236B_Project.d%22%20-MT%22source%2FMCXW236B_Project.o%22%20-MT%22source%2FMCXW236B_Project.d%22%20-o%20%22source%2FMCXW236B_Project.o%22%20%22..%2Fsource%2FMCXW236B_Project.c%22%0AInvoking%3A%20MCU%20C%20Compiler%0AInvoking%3A%20MCU%20C%20Compiler%0Aarm-none-eabi-gcc%20-D__REDLIB__%20-DCPU_MCXW236BIHNAR%20-DCPU_MCXW236BIHNAR_cm33%20-DSDK_DEBUGCONSOLE%3D1%20-DCR_INTEGER_PRINTF%20-DPRINTF_FLOAT_ENABLE%3D0%20-D__MCUXPRESSO%20-DDEBUG%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%22%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fsource%22%20-O0%20-fno-common%20-g3%20-gdwarf-4%20-Wall%20-c%20-ffunction-sections%20-fdata-sections%20-fno-builtin%20-fmerge-constants%20-fmacro-prefix-map%3D%22..%2Fboard%2F%22%3D%20-mcpu%3Dcortex-m33%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-mthumb%20-D__REDLIB__%20-fstack-usage%20-specs%3Dredlib.specs%20-MMD%20-MP%20-MF%22board%2Fboard.d%22%20-MT%22board%2Fboard.o%22%20-MT%22board%2Fboard.d%22%20-o%20%22board%2Fboard.o%22%20%22..%2Fboard%2Fboard.c%22%0Aarm-none-eabi-gcc%20-D__REDLIB__%20-DCPU_MCXW236BIHNAR%20-DCPU_MCXW236BIHNAR_cm33%20-DSDK_DEBUGCONSOLE%3D1%20-DCR_INTEGER_PRINTF%20-DPRINTF_FLOAT_ENABLE%3D0%20-D__MCUXPRESSO%20-DDEBUG%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%22%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fsource%22%20-O0%20-fno-common%20-g3%20-gdwarf-4%20-Wall%20-c%20-ffunction-sections%20-fdata-sections%20-fno-builtin%20-fmerge-constants%20-fmacro-prefix-map%3D%22..%2Fsource%2F%22%3D%20-mcpu%3Dcortex-m33%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-mthumb%20-D__REDLIB__%20-fstack-usage%20-specs%3Dredlib.specs%20-MMD%20-MP%20-MF%22source%2Fsemihost_hardfault.d%22%20-MT%22source%2Fsemihost_hardfault.o%22%20-MT%22source%2Fsemihost_hardfault.d%22%20-o%20%22source%2Fsemihost_hardfault.o%22%20%22..%2Fsource%2Fsemihost_hardfault.c%22%0AInvoking%3A%20MCU%20C%20Compiler%0AInvoking%3A%20MCU%20C%20Compiler%0Aarm-none-eabi-gcc%20-D__REDLIB__%20-DCPU_MCXW236BIHNAR%20-DCPU_MCXW236BIHNAR_cm33%20-DSDK_DEBUGCONSOLE%3D1%20-DCR_INTEGER_PRINTF%20-DPRINTF_FLOAT_ENABLE%3D0%20-D__MCUXPRESSO%20-DDEBUG%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%22%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fsource%22%20-O0%20-fno-common%20-g3%20-gdwarf-4%20-Wall%20-c%20-ffunction-sections%20-fdata-sections%20-fno-builtin%20-fmerge-constants%20-fmacro-prefix-map%3D%22..%2Fboard%2F%22%3D%20-mcpu%3Dcortex-m33%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-mthumb%20-D__REDLIB__%20-fstack-usage%20-specs%3Dredlib.specs%20-MMD%20-MP%20-MF%22board%2Fperipherals.d%22%20-MT%22board%2Fperipherals.o%22%20-MT%22board%2Fperipherals.d%22%20-o%20%22board%2Fperipherals.o%22%20%22..%2Fboard%2Fperipherals.c%22%0Aarm-none-eabi-gcc%20-D__REDLIB__%20-DCPU_MCXW236BIHNAR%20-DCPU_MCXW236BIHNAR_cm33%20-DSDK_DEBUGCONSOLE%3D1%20-DCR_INTEGER_PRINTF%20-DPRINTF_FLOAT_ENABLE%3D0%20-D__MCUXPRESSO%20-DDEBUG%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%22%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fsource%22%20-O0%20-fno-common%20-g3%20-gdwarf-4%20-Wall%20-c%20-ffunction-sections%20-fdata-sections%20-fno-builtin%20-fmerge-constants%20-fmacro-prefix-map%3D%22..%2Fboard%2F%22%3D%20-mcpu%3Dcortex-m33%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-mthumb%20-D__REDLIB__%20-fstack-usage%20-specs%3Dredlib.specs%20-MMD%20-MP%20-MF%22board%2Fclock_config.d%22%20-MT%22board%2Fclock_config.o%22%20-MT%22board%2Fclock_config.d%22%20-o%20%22board%2Fclock_config.o%22%20%22..%2Fboard%2Fclock_config.c%22%0AInvoking%3A%20MCU%20C%20Compiler%0Aarm-none-eabi-gcc%20-D__REDLIB__%20-DCPU_MCXW236BIHNAR%20-DCPU_MCXW236BIHNAR_cm33%20-DSDK_DEBUGCONSOLE%3D1%20-DCR_INTEGER_PRINTF%20-DPRINTF_FLOAT_ENABLE%3D0%20-D__MCUXPRESSO%20-DDEBUG%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%22%20-I%22%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fsource%22%20-O0%20-fno-common%20-g3%20-gdwarf-4%20-Wall%20-c%20-ffunction-sections%20-fdata-sections%20-fno-builtin%20-fmerge-constants%20-fmacro-prefix-map%3D%22..%2Fboard%2F%22%3D%20-mcpu%3Dcortex-m33%20-mfpu%3Dfpv5-sp-d16%20-mfloat-abi%3Dhard%20-mthumb%20-D__REDLIB__%20-fstack-usage%20-specs%3Dredlib.specs%20-MMD%20-MP%20-MF%22board%2Fpin_mux.d%22%20-MT%22board%2Fpin_mux.o%22%20-MT%22board%2Fpin_mux.d%22%20-o%20%22board%2Fpin_mux.o%22%20%22..%2Fboard%2Fpin_mux.c%22%0A..%2Fboard%2Fboard.c%3A7%3A10%3A%20fatal%20error%3A%20fsl_common.h%3A%20No%20such%20file%20or%20directory%0A%20%20%20%207%20%7C%20%23include%20%22fsl_common.h%22%0A%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%5E~~~~~~~~~~~~~%0Acompilation%20terminated.%0A..%2Fboard%2Fclock_config.c%3A7%3A10%3A%20fatal%20error%3A%20fsl_power.h%3A%20No%20such%20file%20or%20directory%0A%20%20%20%207%20%7C%20%23include%20%22fsl_power.h%22%0A%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%5E~~~~~~~~~~~~%0Acompilation%20terminated.%0AIn%20file%20included%20from%20..%2Fboard%2Fperipherals.c%3A56%3A%0A..%2Fboard%2Fperipherals.h%3A18%3A10%3A%20fatal%20error%3A%20fsl_common.h%3A%20No%20such%20file%20or%20directory%0A%20%20%2018%20%7C%20%23include%20%22fsl_common.h%22%0A%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%5E~~~~~~~~~~~~~%0Acompilation%20terminated.%0A..%2Fboard%2Fpin_mux.c%3A48%3A10%3A%20fatal%20error%3A%20fsl_common.h%3A%20No%20such%20file%20or%20directory%0A%20%20%2048%20%7C%20%23include%20%22fsl_common.h%22%0A%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%5E~~~~~~~~~~~~~%0Acompilation%20terminated.%0Amake%5B1%5D%3A%20***%20%5Bboard%2Fsubdir.mk%3A29%3A%20board%2Fclock_config.o%5D%20Error%201%0Amake%5B1%5D%3A%20***%20Waiting%20for%20unfinished%20jobs....%0Amake%5B1%5D%3A%20***%20%5Bboard%2Fsubdir.mk%3A29%3A%20board%2Fperipherals.o%5D%20Error%201%0Amake%5B1%5D%3A%20***%20%5Bboard%2Fsubdir.mk%3A29%3A%20board%2Fboard.o%5D%20Error%201%0Amake%5B1%5D%3A%20***%20%5Bboard%2Fsubdir.mk%3A29%3A%20board%2Fpin_mux.o%5D%20Error%201%0AIn%20file%20included%20from%20..%2Fsource%2FMCXW236B_Project.c%3A13%3A%0A%2FUsers%2Fusernam%2FMCUXpressoIDE%2FMCXW236B_Project%2Fboard%2Fboard.h%3A10%3A10%3A%20fatal%20error%3A%20fsl_common.h%3A%20No%20such%20file%20or%20directory%0A%20%20%2010%20%7C%20%23include%20%22fsl_common.h%22%0A%20%20%20%20%20%20%7C%20%20%20%20%20%20%20%20%20%20%5E~~~~~~~~~~~~~%0Acompilation%20terminated.%0Amake%5B1%5D%3A%20***%20%5Bsource%2Fsubdir.mk%3A23%3A%20source%2FMCXW236B_Project.o%5D%20Error%201%0AFinished%20building%3A%20..%2Fsource%2Fsemihost_hardfault.c%0A%20%0Amake%3A%20***%20%5Bmakefile%3A36%3A%20all%5D%20Error%202%0A%22make%20-r%20-j11%20all%22%20terminated%20with%20exit%20code%202.%20Build%20might%20be%20incomplete.%0A%0A13%3A27%3A31%20Build%20Failed.%2012%20errors%2C%200%20warnings.%20(took%20580ms)%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3EThere%20is%20something%20that%20was%20pondering%20me.%20When%20creating%20a%20new%20project%20for%20FRDM-MCXN947%2C%20everything%20worked%20out%20of%20the%20box.%20Please%20note%20the%20differences%20between%20the%20pre-selected%20components%20for%20both%20boards%20in%20the%20new%20project%20wizard%3A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22frdm-mcxw23.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22frdm-mcxw23.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22frdm-mcxw23.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373361i8C5B23C482BB0BAA%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22frdm-mcxw23.png%22%20alt%3D%22frdm-mcxw23.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E2%80%83%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22frdm-mcxn947.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22frdm-mcxn947.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22frdm-mcxn947.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373362iBC0B0C3B621B9E8D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22frdm-mcxn947.png%22%20alt%3D%22frdm-mcxn947.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3EThe%20template%20for%20the%20MCXN947%20has%20more%20components%20preselected.%20The%20MCXW23%20template%20seems%20to%20missing%20essential%20components%20to%20start%20out%20of%20the%20box.%3C%2FP%3E%3CP%3EI%20was%20able%20to%20somehow%20click%20together%20some%20components%20to%20make%20it%20work%2C%20but%20it%20would%20be%20better%20to%20fix%20the%20project%20template%20to%20work%20out%20of%20the%20box.%E2%80%83%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2297144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCUXpressoIDE%20with%20FRDM-MCXW23%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2297144%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251666%22%20target%3D%22_blank%22%3E%40stejen%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThanks%20for%20your%20information.%3C%2FP%3E%0A%3CP%3EI%20can%20reproduce%20this%20issue.%3C%2FP%3E%0A%3CP%3EI%20will%20report%20it%20to%20our%20IDE%20team.%3C%2FP%3E%0A%3CP%3EI%20think%20you%20can%20import%20the%20Hello%20World%20example%20as%20a%20starting%20point.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Harry_Zhang_0-1768983696079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Harry_Zhang_0-1768983696079.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F373649i6479EC26DBE1130E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Harry_Zhang_0-1768983696079.png%22%20alt%3D%22Harry_Zhang_0-1768983696079.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3EHarry%3C%2FP%3E%3C%2FLINGO-BODY%3E
