MCF5480 boot debug error
1,907 次查看
manonroad
i repaired a MCF5480 board,while booting,i meet some UART error. i want to know,if this error caused by hardware damage?
4 回复数
1,777 次查看
manonroad
Thanks for your reply.This error occured  between MCF5480 and a DSP chip .They communicated through UART3,While system init, RTS and CTS signals reported error.This snap picture's messages obtained from the debug UART Port. Did this error caused by a hardware fault?
1,771 次查看
Bio_TICFSL
Yes, Change the configuration in the DSP.
1,746 次查看
manonroad
The MCF5480 and DSP worked correctly everbefore.I didn't change anything about hardware or  software.  While  VFP software displayed  "Dual Port RAM Uninitialized".
   As you mean,how to change DSP's program?
1,791 次查看
Bio_TICFSL
The error "RTS 200100 was not 0" in ColdFire processors indicates a critical communication failure between the debugger and the chip. This code is often tied to "invalid parameters" or a synchronization mismatch during the flash programming or erase process.
Key Causes and Solutions
  • Debugger Driver Incompatibility: This is the most common cause. Using older versions of CodeWarrior on modern operating systems (Windows 10/11) often causes driver conflicts with the P&E Multilink interface.
    • Solution: Install the latest P&E Micro drivers or run your development environment in a Windows XP/7 Virtual Machine.
  • Target Initialization Issues: The target initialization file (often a .tcl or .cfg script) might contain incorrect parameters for the flash base address, bank size, or clock settings (PLL).
    • Solution: Verify that the flash base address and memory map in your project settings match your specific ColdFire model Enable "Verify Target Memory Writes" in the Target Configuration to check if the algorithm downloads correctly.
  • USB Port Speed Issues: High-speed USB 3.0 ports can sometimes be too fast for older BDM/JTAG debuggers, leading to timing errors.
    • Solution: Connect the debugger through a powered USB 2.0 hub or try a different USB port on your machine.
  • Hardware Interference: Improper hardware connections or interference on the BDM lines can trigger communication losses.
    • Solution: Check for cold solder joints on the BDM header and ensure you are not using an excessively long ribbon cable.
Debugging Steps
  1. Check for duplicate processes: Open Task Manager and ensure there isn't another instance of pegdbserver_console or the debugger running.
  2. Verify the Hardware ID: Ensure the hardware selected in the NXP Community or IDE matches the physical chip on your board (e.g., ColdFire V1 vs V2).
  3. Power Cycle: Completely power down both the target board and the debugger to reset the communication interface.
%3CLINGO-SUB%20id%3D%22lingo-sub-2346695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCF5480%20%E5%90%AF%E5%8A%A8%E8%B0%83%E8%AF%95%E9%94%99%E8%AF%AF%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2346695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BF%AE%E5%A4%8D%E4%BA%86%20MCF5480%20%E6%9D%BF%EF%BC%8C%E5%9C%A8%E5%90%AF%E5%8A%A8%E6%97%B6%EF%BC%8C%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%B8%80%E4%BA%9B%20UART%20%E9%94%99%E8%AF%AF%E3%80%82%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%EF%BC%8C%E8%BF%99%E4%B8%AA%E9%94%99%E8%AF%AF%E6%98%AF%E5%90%A6%E6%98%AF%E7%94%B1%E7%A1%AC%E4%BB%B6%E6%8D%9F%E5%9D%8F%E5%BC%95%E8%B5%B7%E7%9A%84%EF%BC%9F%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381513i1475F92018BD69A6%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F381512i2DEA59159B870BCF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20alt%3D%22%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3E%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE%202026-04-08%20121449.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2346695%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E5%90%AF%E5%8A%A8%20ROM%20%7C%20%E5%90%AF%E5%8A%A8%E9%85%8D%E7%BD%AE%20%7C%20%E9%97%AA%E5%AD%98%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCF5480%20boot%20debug%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350537%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EMCF5480%20%E5%92%8C%20DSP%20%E4%B9%8B%E5%89%8D%E4%B8%80%E7%9B%B4%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%EF%BC%8C%E6%88%91%E6%B2%A1%E6%9C%89%E6%9B%B4%E6%94%B9%E4%BB%BB%E4%BD%95%E7%A1%AC%E4%BB%B6%E6%88%96%E8%BD%AF%E4%BB%B6%E3%80%82%20%E8%80%8C%20VFP%20%E8%BD%AF%E4%BB%B6%E6%98%BE%E7%A4%BA%22%20%E5%8F%8C%3CSPAN%3E%E7%AB%AF%E5%8F%A3%20RAM%20%E6%9C%AA%E5%88%9D%E5%A7%8B%E5%8C%96%3C%2FSPAN%3E%22%20%E3%80%82%3C%2FP%3E%3CP%3E%20%20%20%E6%82%A8%E7%9A%84%E6%84%8F%E6%80%9D%E6%98%AF%EF%BC%8C%E5%A6%82%E4%BD%95%E6%9B%B4%E6%94%B9%20DSP%20%E7%9A%84%E7%A8%8B%E5%BA%8F%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCF5480%20boot%20debug%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350237%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CP%3E%E6%98%AF%EF%BC%8C%E6%9B%B4%E6%94%B9%20DSP%20%E4%B8%AD%E7%9A%84%E9%85%8D%E7%BD%AE%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E6%AD%A4%E8%87%B4%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350230%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCF5480%20boot%20debug%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350230%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%9B%9E%E5%A4%8D%E3%80%82%E8%AF%A5%E9%94%99%E8%AF%AF%E5%8F%91%E7%94%9F%E5%9C%A8%20MCF5480%20%E5%92%8C%E4%B8%80%E4%B8%AA%20DSP%20%E8%8A%AF%E7%89%87%E4%B9%8B%E9%97%B4%EF%BC%8C%E5%AE%83%E4%BB%AC%E9%80%9A%E8%BF%87%20UART3%20%E9%80%9A%E4%BF%A1%EF%BC%8C%E5%BD%93%E7%B3%BB%E7%BB%9F%E5%90%AF%E5%8A%A8%E6%97%B6%EF%BC%8CRTS%20%E5%92%8C%20CTS%20%E4%BF%A1%E5%8F%B7%E6%8A%A5%E9%94%99%E3%80%82%E8%AF%A5%E9%94%99%E8%AF%AF%E6%98%AF%E7%94%B1%E7%A1%AC%E4%BB%B6%E6%95%85%E9%9A%9C%E5%BC%95%E8%B5%B7%E7%9A%84%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2350197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MCF5480%20boot%20debug%20error%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2350197%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3C%2FP%3E%0A%3CDIV%20class%3D%22Y3BBE%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIAhAA%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E5%9C%A8%20ColdFire%20%E5%A4%84%E7%90%86%E5%99%A8%E4%B8%AD%EF%BC%8C%E9%94%99%E8%AF%AF%22RTS%20200100%20was%20not%200%22%20%E8%A1%A8%E6%98%8E%E8%B0%83%E8%AF%95%E5%99%A8%E4%B8%8E%E8%8A%AF%E7%89%87%E4%B9%8B%E9%97%B4%E5%8F%91%E7%94%9F%E4%BA%86%E4%B8%A5%E9%87%8D%E7%9A%84%E9%80%9A%E4%BF%A1%E6%95%85%E9%9A%9C%E3%80%82%E8%AF%A5%E4%BB%A3%E7%A0%81%E9%80%9A%E5%B8%B8%E4%B8%8E%22%E6%97%A0%E6%95%88%E5%8F%82%E6%95%B0%22%20%E6%88%96%E9%97%AA%E5%AD%98%E7%BC%96%E7%A8%8B%E6%88%96%E6%93%A6%E9%99%A4%E8%BF%87%E7%A8%8B%E4%B8%AD%E7%9A%84%E5%90%8C%E6%AD%A5%E4%B8%8D%E5%8C%B9%E9%85%8D%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22K4nz9c_m%2CK4nz9c_n%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DK4nz9c_l%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E6%9C%89%E5%85%B3%E3%80%82%3C%2FDIV%3E%0A%3CDIV%20class%3D%22Fsg96%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22otQkpb%22%20role%3D%22heading%22%20data-sae%3D%22%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%20data-animation-nesting%3D%22%22%20aria-level%3D%223%22%3E%E4%B8%BB%E8%A6%81%E5%8E%9F%E5%9B%A0%E5%92%8C%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%3C%2FDIV%3E%0A%3CUL%20class%3D%22KsbFXc%20U6u95%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIAxAA%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E8%B0%83%E8%AF%95%E5%99%A8%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E4%B8%8D%E5%85%BC%E5%AE%B9%EF%BC%9A%E8%BF%99%E6%98%AF%E6%9C%80%E5%B8%B8%E8%A7%81%E7%9A%84%E5%8E%9F%E5%9B%A0%E3%80%82%E5%9C%A8%E7%8E%B0%E4%BB%A3%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%EF%BC%88Windows%2010%2F11%EF%BC%89%E4%B8%8A%E4%BD%BF%E7%94%A8%E6%97%A7%E7%89%88%E6%9C%AC%E7%9A%84%20CodeWarrior%20%E7%BB%8F%E5%B8%B8%E4%BC%9A%E5%AF%BC%E8%87%B4%E4%B8%8E%3CA%20class%3D%22H23r4e%22%20href%3D%22https%3A%2F%2Fwww.pemicro.com%2Fsupport%2Findex.cfm%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20data-sb%3D%22%2Furl%3Fsa%3Di%26amp%3Bsource%3Dweb%26amp%3Brct%3Dj%26amp%3Burl%3Dhttps%3A%2F%2Fwww.pemicro.com%2Fsupport%2Findex.cfm%26amp%3Bved%3D2ahUKEwiv6YfVguuTAxXZg2oFHYDEFygQy_kOegYIAQgDEAE%26amp%3Bopi%3D89978449%26amp%3Bcd%26amp%3Bpsig%3DAOvVaw2gAIC1XNa4xs7m04Q4K7N6%26amp%3Bust%3D1776176351380000%22%20data-hveid%3D%22CAEIAxAB%22%20target%3D%22_blank%22%3E%20P%26amp%3B%20E%20Multilink%20%E6%8E%A5%E5%8F%A3%3C%2FA%3E%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22K4nz9c_y%2CK4nz9c_z%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DK4nz9c_x%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E7%9A%84%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%86%B2%E7%AA%81%E3%80%82%3C%2FSPAN%3E%0A%3CUL%20class%3D%22KsbFXc%20U6u95%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIAxAE%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9A%E5%AE%89%E8%A3%85%E6%9C%80%E6%96%B0%E7%9A%84%3CA%20class%3D%22H23r4e%22%20href%3D%22https%3A%2F%2Fwww.pemicro.com%2Fsupport%2Fdownload_processor.cfm%3Ftype%3D5%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20data-sb%3D%22%2Furl%3Fsa%3Di%26amp%3Bsource%3Dweb%26amp%3Brct%3Dj%26amp%3Burl%3Dhttps%3A%2F%2Fwww.pemicro.com%2Fsupport%2Fdownload_processor.cfm%3Ftype%253D5%26amp%3Bved%3D2ahUKEwiv6YfVguuTAxXZg2oFHYDEFygQy_kOegYIAQgDEAU%26amp%3Bopi%3D89978449%26amp%3Bcd%26amp%3Bpsig%3DAOvVaw2gAIC1XNa4xs7m04Q4K7N6%26amp%3Bust%3D1776176351380000%22%20data-hveid%3D%22CAEIAxAF%22%20target%3D%22_blank%22%3E%20P%26amp%3B%20E%20Micro%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%3C%2FA%3E%20%EF%BC%8C%E6%88%96%E5%9C%A8%20Windows%20XP%2F7%20%E8%99%9A%E6%8B%9F%E6%9C%BA%E4%B8%AD%E8%BF%90%E8%A1%8C%E5%BC%80%E5%8F%91%E7%8E%AF%E5%A2%83%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIAxAG%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E7%9B%AE%E6%A0%87%E5%88%9D%E5%A7%8B%E5%8C%96%E9%97%AE%E9%A2%98%EF%BC%9A%E7%9B%AE%E6%A0%87%E5%88%9D%E5%A7%8B%E5%8C%96%E6%96%87%E4%BB%B6%EF%BC%88%E9%80%9A%E5%B8%B8%E6%98%AF%3CCODE%20class%3D%22KDcb0c%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E.tcl%3C%2FCODE%3E%E6%88%96%3CCODE%20class%3D%22KDcb0c%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E.cfg%3C%2FCODE%3E%E8%84%9A%E6%9C%AC%EF%BC%89%E5%8F%AF%E8%83%BD%E5%8C%85%E5%90%AB%E4%B8%8D%E6%AD%A3%E7%A1%AE%E7%9A%84%E9%97%AA%E5%AD%98%E5%9F%BA%E5%9C%B0%E5%9D%80%E3%80%81%E5%AD%98%E5%82%A8%E4%BD%93%E5%A4%A7%E5%B0%8F%E6%88%96%E6%97%B6%E9%92%9F%E8%AE%BE%E7%BD%AE%EF%BC%88PLL%EF%BC%89%E5%8F%82%E6%95%B0%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22K4nz9c_1c%2CK4nz9c_1d%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DK4nz9c_1b%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%0A%3CUL%20class%3D%22KsbFXc%20U6u95%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIAxAJ%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9A%E9%AA%8C%E8%AF%81%E9%A1%B9%E7%9B%AE%E8%AE%BE%E7%BD%AE%E4%B8%AD%E7%9A%84%E9%97%AA%E5%AD%98%E5%9F%BA%E5%9C%B0%E5%9D%80%E5%92%8C%E5%86%85%E5%AD%98%E6%98%A0%E5%B0%84%E6%98%AF%E5%90%A6%E4%B8%8E%E7%89%B9%E5%AE%9A%E7%9A%84%20ColdFire%20%E5%9E%8B%E5%8F%B7%E7%9B%B8%E5%8C%B9%E9%85%8D%20%E5%9C%A8%E7%9B%AE%E6%A0%87%E9%85%8D%E7%BD%AE%E4%B8%AD%E5%90%AF%E7%94%A8%22Verify%20Target%20Memory%20Writes%22%20%EF%BC%8C%E6%A3%80%E6%9F%A5%E7%AE%97%E6%B3%95%E4%B8%8B%E8%BD%BD%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22K4nz9c_1l%2CK4nz9c_1m%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DK4nz9c_1k%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIAxAM%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3EUSB%20%E7%AB%AF%E5%8F%A3%E9%80%9F%E5%BA%A6%E9%97%AE%E9%A2%98%EF%BC%9A%E5%AF%B9%E4%BA%8E%E8%80%81%E5%BC%8F%20BDM%2FJTAG%20%E8%B0%83%E8%AF%95%E5%99%A8%E8%80%8C%E8%A8%80%EF%BC%8C%E9%AB%98%E9%80%9F%20USB%203.0%20%E7%AB%AF%E5%8F%A3%E6%9C%89%E6%97%B6%E9%80%9F%E5%BA%A6%E8%BF%87%E5%BF%AB%EF%BC%8C%E5%AF%BC%E8%87%B4%E5%AE%9A%E6%97%B6%E9%94%99%E8%AF%AF%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22K4nz9c_1s%2CK4nz9c_1t%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DK4nz9c_1r%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%0A%3CUL%20class%3D%22KsbFXc%20U6u95%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIAxAP%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E8%A7%A3%E5%86%B3%E5%8A%9E%E6%B3%95%EF%BC%9A%E9%80%9A%E8%BF%87%E4%BE%9B%E7%94%B5%E7%9A%84%20USB%202.0%20%E9%9B%86%E7%BA%BF%E5%99%A8%E8%BF%9E%E6%8E%A5%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%8C%E6%88%96%E5%B0%9D%E8%AF%95%E4%BD%BF%E7%94%A8%E6%9C%BA%E5%99%A8%E4%B8%8A%E7%9A%84%E5%85%B6%E4%BB%96%20USB%20%E7%AB%AF%E5%8F%A3%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIAxAQ%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E7%A1%AC%E4%BB%B6%E5%B9%B2%E6%89%B0%EF%BC%9A%E4%B8%8D%E6%AD%A3%E7%A1%AE%E7%9A%84%E7%A1%AC%E4%BB%B6%E8%BF%9E%E6%8E%A5%E6%88%96%20BDM%20%E7%BA%BF%E8%B7%AF%E4%B8%8A%E7%9A%84%E5%B9%B2%E6%89%B0%E5%8F%AF%E8%83%BD%E4%BC%9A%E5%BC%95%E5%8F%91%E9%80%9A%E4%BF%A1%E4%B8%A2%E5%A4%B1%20%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22K4nz9c_24%2CK4nz9c_25%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DK4nz9c_23%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E.%3C%2FSPAN%3E%0A%3CUL%20class%3D%22KsbFXc%20U6u95%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIAxAT%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%A1%88%EF%BC%9A%E6%A3%80%E6%9F%A5%20BDM%20%E9%92%88%E5%BA%A7%E4%B8%8A%E6%98%AF%E5%90%A6%E6%9C%89%E5%86%B7%E7%84%8A%E7%82%B9%EF%BC%8C%E5%B9%B6%E7%A1%AE%E4%BF%9D%E6%B2%A1%E6%9C%89%E4%BD%BF%E7%94%A8%E8%BF%87%E9%95%BF%E7%9A%84%E5%B8%A6%E7%8A%B6%E7%94%B5%E7%BC%86%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3C%2FLI%3E%0A%3C%2FUL%3E%0A%3CDIV%20class%3D%22Fsg96%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%26nbsp%3B%3C%2FDIV%3E%0A%3CDIV%20class%3D%22otQkpb%22%20role%3D%22heading%22%20data-sae%3D%22%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%20data-animation-nesting%3D%22%22%20aria-level%3D%223%22%3E%E8%B0%83%E8%AF%95%E6%AD%A5%E9%AA%A4%3C%2FDIV%3E%0A%3COL%20class%3D%22IaGLZe%20VimKh%22%20data-processed%3D%22true%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIBBAA%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E6%A3%80%E6%9F%A5%E8%BF%9B%E7%A8%8B%E6%98%AF%E5%90%A6%E9%87%8D%E5%A4%8D%EF%BC%9A%E6%89%93%E5%BC%80%E4%BB%BB%E5%8A%A1%E7%AE%A1%E7%90%86%E5%99%A8%EF%BC%8C%E7%A1%AE%E4%BF%9D%E6%B2%A1%E6%9C%89%E5%8F%A6%E4%B8%80%E4%B8%AA%3CCODE%20class%3D%22KDcb0c%22%20dir%3D%22ltr%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3Epegdbserver_console%3C%2FCODE%3E%E6%88%96%E8%B0%83%E8%AF%95%E5%99%A8%E5%AE%9E%E4%BE%8B%E5%9C%A8%E8%BF%90%E8%A1%8C%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22K4nz9c_2p%2CK4nz9c_2q%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DK4nz9c_2o%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIBBAD%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E9%AA%8C%E8%AF%81%E7%A1%AC%E4%BB%B6%20ID%EF%BC%9A%E7%A1%AE%E4%BF%9D%E5%9C%A8%3CA%20class%3D%22H23r4e%22%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2F%22%20data-sb%3D%22%2Furl%3Fsa%3Di%26amp%3Bsource%3Dweb%26amp%3Brct%3Dj%26amp%3Burl%3Dhttps%3A%2F%2Fcommunity.nxp.com%2F%26amp%3Bved%3D2ahUKEwiv6YfVguuTAxXZg2oFHYDEFygQy_kOegYIAQgEEAQ%26amp%3Bopi%3D89978449%26amp%3Bcd%26amp%3Bpsig%3DAOvVaw2gAIC1XNa4xs7m04Q4K7N6%26amp%3Bust%3D1776176351380000%22%20data-hveid%3D%22CAEIBBAE%22%20target%3D%22_blank%22%3E%E6%81%A9%E6%99%BA%E6%B5%A6%E7%A4%BE%E5%8C%BA%3C%2FA%3E%E6%88%96%20IDE%20%E4%B8%AD%E9%80%89%E6%8B%A9%E7%9A%84%E7%A1%AC%E4%BB%B6%E4%B8%8E%E6%9D%BF%E4%B8%8A%E7%9A%84%E7%89%A9%E7%90%86%E8%8A%AF%E7%89%87%E7%9B%B8%E5%8C%B9%E9%85%8D%EF%BC%88%E4%BE%8B%E5%A6%82%EF%BC%8CColdFire%20V1%20%E4%B8%8E%20V2%EF%BC%89%3CSPAN%20class%3D%22uJ19be%20notranslate%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-wiz-uids%3D%22K4nz9c_2x%2CK4nz9c_2y%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22vKEkVd%22%20data-sae%3D%22%22%20data-wiz-attrbind%3D%22class%3DK4nz9c_2w%2FTKHnVd%22%20data-animation-atomic%3D%22%22%3E%3CSPAN%20aria-hidden%3D%22true%22%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3CLI%20class%3D%22dF3vjf%22%20data-sae%3D%22%22%20data-complete%3D%22true%22%20data-hveid%3D%22CAEIBBAH%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%3E%3CSPAN%20class%3D%22T286Pc%22%20aria-owns%3D%22action-menu-parent-container%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E7%94%B5%E6%BA%90%E9%87%8D%E5%90%AF%EF%BC%9A%E5%AE%8C%E5%85%A8%E6%8E%89%E7%94%B5%E7%9B%AE%E6%A0%87%E6%9D%BF%E5%92%8C%E8%B0%83%E8%AF%95%E5%99%A8%EF%BC%8C%E4%BB%A5RESET%E9%80%9A%E4%BF%A1%E6%8E%A5%E5%8F%A3%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%0A%3C%2FOL%3E%0A%3CP%3E%3CSPAN%20class%3D%22T286Pc%22%20aria-owns%3D%22action-menu-parent-container%22%20data-complete%3D%22true%22%20data-sfc-cb%3D%22%22%20data-sfc-root%3D%22c%22%20data-sfc-cp%3D%22%22%3E%E6%AD%A4%E8%87%B4%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
