MC33771c TPL communication
1,180 次查看
Miral
The communication works correctly with the MC33771B using a specific implementation and BCC library. I can successfully send commands and receive valid response frames.
However, when I use the same communication code and only replace the BCC library/configuration for the MC33771C, I receive only the echo frame and no valid response from the device.
The SPI/TPL timing, frame format, and hardware connections remain the same. The wake-up sequence and INIT sequence are also implemented.
Has anyone experienced this issue with MC33771C?
bcc_status_t BCC_MCU_TransferTpl(uint8_t drvInstance, uint8_t transBuf[], uint8_t recvBuf[], uint16_t recvTrCnt)
uint16_t recvSize;
if(recvTrCnt > 0)
recvSize = (recvTrCnt - 1) * 6U;
else recvSize = 6U;
HAL_SPI_DeInit(&hspi2);
HAL_Delay(2);
HAL_SPI_Init(&hspi2);
memset(recvBuf, 0, sizeof(&recvBuf));
HAL_GPIO_WritePin(CS_TX_GPIO_Port, CS_TX_Pin, GPIO_PIN_RESET); HAL_SPI_Receive_IT(&hspi2, recvBuf, 6);
rxflag = 0;
if(HAL_SPI_Transmit_IT(&hspi1, transBuf, 6) != HAL_OK)
{ HAL_GPIO_WritePin(CS_TX_GPIO_Port, CS_TX_Pin, GPIO_PIN_SET);
return BCC_STATUS_PARAM_RANGE;
BCC_MCU_WaitUs(5);
if(spi2_rx_done == 1)
HAL_SPI_Receive_IT(&hspi2, recvBuf, recvSize);
spi2_rx_done = 0;
return BCC_STATUS_SUCCESS;
int MC33771_Init(void)
HAL_GPIO_WritePin(EN_GPIO_Port, EN_Pin, GPIO_PIN_RESET);
HAL_Delay(1);
HAL_GPIO_WritePin(EN_GPIO_Port, EN_Pin, GPIO_PIN_SET);
HAL_Delay(10);
g_bccConfig.drvInstance = 0;
g_bccConfig.commMode = BCC_MODE_TPL;
g_bccConfig.devicesCnt = 1;
g_bccConfig.device[0] = BCC_DEVICE_MC33771C;
g_bccConfig.cellCnt[0] = 14;
status = BCC_Init(&g_bccConfig);
if(status != BCC_STATUS_SUCCESS)
return (int)status;
void HAL_SPI_RxCpltCallback(SPI_HandleTypeDef *hspi)
if(hspi->Instance == SPI2)
spi2_rx_done = 1;
static void MX_SPI1_Init(void)
hspi1.Instance = SPI1;
hspi1.Init.Mode = SPI_MODE_MASTER;
hspi1.Init.Direction = SPI_DIRECTION_2LINES;
hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi1.Init.CLKPhase = SPI_PHASE_2EDGE;
hspi1.Init.NSS = SPI_NSS_SOFT;
hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_8;
hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi1.Init.NSSPMode = SPI_NSS_PULSE_ENABLE;
if(HAL_SPI_Init(&hspi1) != HAL_OK)
Error_Handler();
static void MX_SPI2_Init(void)
hspi2.Instance = SPI2;
hspi2.Init.Mode = SPI_MODE_SLAVE;
hspi2.Init.Direction = SPI_DIRECTION_2LINES_RXONLY;
hspi2.Init.DataSize = SPI_DATASIZE_8BIT;
hspi2.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi2.Init.CLKPhase = SPI_PHASE_2EDGE;
hspi2.Init.NSS = SPI_NSS_HARD_INPUT;
hspi2.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi2.Init.TIMode = SPI_TIMODE_DISABLE;
hspi2.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi2.Init.NSSPMode = SPI_NSS_PULSE_DISABLE;
if(HAL_SPI_Init(&hspi2) != HAL_OK)
Error_Handler();
1,132 次查看
JozefKozon
Dear Miral,
I need to contact Software engineer for your issue. Please share following information about your project. They always require the information.
Customer: AARTRONIX INNOVATIONS
End Customer: ? (can be also AARTRONIX INNOVATIONS)
End Application: ?
Country: India
Annual Volume: ?
With Best Regards,
Jozef
1,128 次查看
Miral
End Customer: AAROHI EMBEDDED SYSTEM PVT LTD
End Application: UPS Battery backup
Country: India
Annual Volume:1000
1,016 次查看
JozefKozon
Dear Miral,
please see below an answer from the application engineer. Please share a scope as requested.
DESCRIPTION
It would really help if the customer could get a scope trace or Saleae output of the transmissions to really see what is going on.  Note that the MC33771B is TPL1 (40-bit) and MC33771C is TPL2 (48-bit).  Also, the customer can reference the MC33771C SDK attached.
With Best Regards,
Jozef
%3CLINGO-SUB%20id%3D%22lingo-sub-2369103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMC33771c%20TPL%20%E9%80%9A%E4%BF%A1%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2369103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%BF%E7%94%A8%E7%89%B9%E5%AE%9A%E7%9A%84%E5%AE%9E%E7%8E%B0%E6%96%B9%E5%BC%8F%E5%92%8C%20BCC%20%E5%BA%93%EF%BC%8C%E5%8F%AF%E4%BB%A5%E4%B8%8E%20MC33771B%20%E6%AD%A3%E5%B8%B8%E9%80%9A%E4%BF%A1%E3%80%82%E6%88%91%E5%8F%AF%E4%BB%A5%E6%88%90%E5%8A%9F%E5%8F%91%E9%80%81%E5%91%BD%E4%BB%A4%E5%B9%B6%E6%8E%A5%E6%94%B6%E6%9C%89%E6%95%88%E7%9A%84%E5%93%8D%E5%BA%94%E5%B8%A7%E3%80%82%3C%2FP%3E%3CP%3E%E4%BD%86%E6%98%AF%EF%BC%8C%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%E7%9B%B8%E5%90%8C%E7%9A%84%E9%80%9A%E4%BF%A1%E4%BB%A3%E7%A0%81%E5%B9%B6%E4%BB%85%E6%9B%BF%E6%8D%A2%20MC33771C%20%E7%9A%84%20BCC%20%E5%BA%93%2F%E9%85%8D%E7%BD%AE%E6%97%B6%EF%BC%8C%E6%88%91%E5%8F%AA%E4%BC%9A%E6%94%B6%E5%88%B0%E5%9B%9E%E5%A3%B0%E5%B8%A7%E8%80%8C%E6%B2%A1%E6%9C%89%E6%9D%A5%E8%87%AA%E8%AE%BE%E5%A4%87%E7%9A%84%E6%9C%89%E6%95%88%E5%93%8D%E5%BA%94%E3%80%82%3C%2FP%3E%3CP%3ESPI%2FTPL%20%E6%97%B6%E5%BA%8F%E3%80%81%E5%B8%A7%E6%A0%BC%E5%BC%8F%E5%92%8C%E7%A1%AC%E4%BB%B6%E8%BF%9E%E6%8E%A5%E4%BF%9D%E6%8C%81%E4%B8%8D%E5%8F%98%E3%80%82%E6%AD%A4%E5%A4%96%EF%BC%8C%E8%BF%98%E5%AE%9E%E7%8E%B0%E4%BA%86%E5%94%A4%E9%86%92%E5%BA%8F%E5%88%97%E5%92%8C%20INIT%20%E5%BA%8F%E5%88%97%E3%80%82%3C%2FP%3E%3CP%3E%E6%9C%89%E4%BA%BA%E5%9C%A8%E4%BD%BF%E7%94%A8%20MC33771C%20%E6%97%B6%E9%81%87%E5%88%B0%E8%BF%87%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%3CBR%20%2F%3Ebcc_status_t%20BCC_MCU_TransferTpl(uint8_t%20drvInstance%2C%20uint8_t%20transBuf%5B%5D%2C%20uint8_t%20recvBuf%5B%5D%2C%20uint16_t%20recvTrCnt)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3Euint16_t%20recvSize%EF%BC%9B%3C%2FP%3E%3CP%3Eif(recvTrCnt%26gt%3B%200)%3C%2FP%3E%3CP%3ErecvSize%20%3D%20(recvTrCnt%20-%201)%20*%206U%EF%BC%9B%3C%2FP%3E%3CP%3E%E5%90%A6%E5%88%99%20recvSize%20%3D%206U%EF%BC%9B%3C%2FP%3E%3CP%3EHAL_SPI_DeInit(%26amp%3Bhspi2)%EF%BC%9B%3C%2FP%3E%3CP%3EHAL_Delay(2)%EF%BC%9B%3C%2FP%3E%3CP%3EHAL_SPI_Init(%26amp%3Bhspi2)%EF%BC%9B%3C%2FP%3E%3CP%3Ememset(recvBuf%2C%200%2C%20sizeof(%26amp%3BrecvBuf))%EF%BC%9B%3C%2FP%3E%3CP%3EHAL_GPIO_WritePin(CS_TX_GPIO_Port%2C%20CS_TX_Pin%2C%20GPIO_PIN_RESET)%3B%20HAL_SPI_Receive_IT(%26amp%3Bhspi2%2C%20recvBuf%2C%206)%EF%BC%9B%3C%2FP%3E%3CP%3Erxflag%20%3D%200%EF%BC%9B%3C%2FP%3E%3CP%3Eif(HAL_SPI_Transmit_IT(%26amp%3Bhspi1%2C%20transBuf%2C%206)%20!%3D%20HAL_OK)%3C%2FP%3E%3CP%3E%7B%20HAL_GPIO_WritePin(CS_TX_GPIO_Port%2C%20CS_TX_Pin%2C%20GPIO_PIN_SET)%EF%BC%9B%3C%2FP%3E%3CP%3E%E8%BF%94%E5%9B%9E%20BCC_STATUS_PARAM_RANGE%EF%BC%9B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3EBCC_MCU_WaitUs(5)%EF%BC%9B%3C%2FP%3E%3CP%3Eif(spi2_rx_done%20%3D%3D%201)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3EHAL_SPI_Receive_IT(%26amp%3Bhspi2%2C%20recvBuf%2C%20recvSize)%EF%BC%9B%3C%2FP%3E%3CP%3Espi2_rx_done%20%3D%200%EF%BC%9B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3EHAL_GPIO_WritePin(CS_TX_GPIO_Port%2C%20CS_TX_Pin%2C%20GPIO_PIN_SET)%EF%BC%9B%3C%2FP%3E%3CP%3E%E8%BF%94%E5%9B%9E%20BCC_STATUS_SUCCESS%EF%BC%9B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3Eint%20MC33771_Init(void)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3EHAL_GPIO_WritePin(EN_GPIO_Port%2C%20EN_Pin%2C%20GPIO_PIN_RESET)%EF%BC%9B%3C%2FP%3E%3CP%3EHAL_Delay(1)%EF%BC%9B%3C%2FP%3E%3CP%3EHAL_GPIO_WritePin(EN_GPIO_Port%2C%20EN_Pin%2C%20GPIO_PIN_SET)%EF%BC%9B%3C%2FP%3E%3CP%3EHAL_Delay(10)%EF%BC%9B%3C%2FP%3E%3CP%3Eg_bccConfig.drvInstance%20%3D%200%EF%BC%9B%3C%2FP%3E%3CP%3Eg_bccConfig.commMode%20%3D%20BCC_MODE_TPL%EF%BC%9B%3C%2FP%3E%3CP%3Eg_bccConfig.devicesCnt%20%3D%201%EF%BC%9B%3C%2FP%3E%3CP%3Eg_bccConfig.%E8%AE%BE%E5%A4%87%3CSPAN%20class%3D%22%22%3E%5B0%5D%3C%2FSPAN%3E%3D%20bcc_device_mc33771c%EF%BC%9B%3C%2FP%3E%3CP%3Eg_bccConfig.cellCnt%3CSPAN%20class%3D%22%22%3E%5B0%5D%3C%2FSPAN%3E%3D%2014%3B%3C%2FP%3E%3CP%3Estatus%20%3D%20BCC_Init(%26amp%3Bg_bccConfig)%EF%BC%9B%3C%2FP%3E%3CP%3Eif(status%20!%3D%20BCC_STATUS_SUCCESS)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3E%E8%BF%94%E5%9B%9E%20(int)status%EF%BC%9B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3Evoid%20HAL_SPI_RxCpltCallback(SPI_HandleTypeDef%20*hspi)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3Eif(hspi-%26gt%3BInstance%20%3D%3D%20SPI2)%3C%2FP%3E%3CP%3Espi2_rx_done%20%3D%201%EF%BC%9B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3Estatic%20void%20MX_SPI1_Init(void)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3Ehspi1.Instance%20%3D%20SPI1%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi1.Init.Mode%20%3D%20SPI_MODE_MASTER%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi1.Init.Direction%20%3D%20SPI_DIRECTION_2LINES%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi1.Init.DataSize%20%3D%20SPI_DATASIZE_8BIT%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi1.Init.CLKPolarity%20%3D%20SPI_POLARITY_LOW%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi1.Init.CLKPhase%20%3D%20SPI_PHASE_2EDGE%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi1.Init.NSS%20%3D%20SPI_NSS_SOFT%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi1.Init.BaudRatePrescaler%20%3D%20SPI_BAUDRATEPRESCALER_8%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi1.Init.FirstBit%20%3D%20SPI_FIRSTBIT_MSB%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi1.Init.TIMode%20%3D%20SPI_TIMODE_DISABLE%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi1.Init.CRCCalculation%20%3D%20SPI_CRCCALCULATION_DISABLE%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi1.Init.NSSPMode%20%3D%20SPI_NSS_PULSE_ENABLE%EF%BC%9B%3C%2FP%3E%3CP%3Eif(HAL_SPI_Init(%26amp%3Bhspi1)%20!%3D%20HAL_OK)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3EError_Handler()%EF%BC%9B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3Estatic%20void%20MX_SPI2_Init(void)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3Ehspi2.Instance%20%3D%20SPI2%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi2.Init.Mode%20%3D%20SPI_MODE_SLAVE%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi2.Init.Direction%20%3D%20SPI_DIRECTION_2LINES_RXONLY%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi2.Init.DataSize%20%3D%20SPI_DATASIZE_8BIT%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi2.Init.CLKPolarity%20%3D%20SPI_POLARITY_LOW%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi2.Init.CLKPhase%20%3D%20SPI_PHASE_2EDGE%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi2.Init.NSS%20%3D%20SPI_NSS_HARD_INPUT%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi2.Init.FirstBit%20%3D%20SPI_FIRSTBIT_MSB%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi2.Init.TIMode%20%3D%20SPI_TIMODE_DISABLE%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi2.Init.CRCCalculation%20%3D%20SPI_CRCCALCULATION_DISABLE%EF%BC%9B%3C%2FP%3E%3CP%3Ehspi2.Init.NSSPMode%20%3D%20SPI_NSS_PULSE_DISABLE%EF%BC%9B%3C%2FP%3E%3CP%3Eif(HAL_SPI_Init(%26amp%3Bhspi2)%20!%3D%20HAL_OK)%3C%2FP%3E%3CP%3E%7B%3C%2FP%3E%3CP%3EError_Handler()%EF%BC%9B%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3CP%3E%7D%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2369103%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E7%94%B5%E8%B7%AF%E6%9D%BF%E8%AE%BE%E8%AE%A1%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2370557%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MC33771c%20TPL%20communication%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2370557%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%E7%B1%B3%E6%8B%89%E5%B0%94%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E7%9C%8B%E4%B8%8B%E9%9D%A2%E5%BA%94%E7%94%A8%E5%B7%A5%E7%A8%8B%E5%B8%88%E7%9A%84%E5%9B%9E%E7%AD%94%E3%80%82%E8%AF%B7%E6%8C%89%E8%A6%81%E6%B1%82%E5%85%B1%E4%BA%AB%E4%B8%80%E4%B8%AA%E8%8C%83%E5%9B%B4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B4%E6%98%8E%3C%2FP%3E%0A%3CP%3E%3CFONT%20color%3D%22%230000FF%22%3E%3CSPAN%3E%E5%A6%82%E6%9E%9C%E5%AE%A2%E6%88%B7%E8%83%BD%E8%8E%B7%E5%BE%97%E4%BC%A0%E8%BE%93%E7%9A%84%E7%A4%BA%E6%B3%A2%E5%99%A8%E8%B7%9F%E8%B8%AA%E6%88%96%20Saleae%20%E8%BE%93%E5%87%BA%EF%BC%8C%E5%B0%B1%E8%83%BD%E7%9C%9F%E6%AD%A3%E4%BA%86%E8%A7%A3%E6%83%85%E5%86%B5%E3%80%82%20%E8%AF%B7%E6%B3%A8%E6%84%8F%EF%BC%8CMC33771B%20%E6%98%AF%20TPL1%EF%BC%8840%20%E4%BD%8D%EF%BC%89%EF%BC%8CMC33771C%20%E6%98%AF%20TPL2%EF%BC%8848%20%E4%BD%8D%EF%BC%89%E3%80%82%20%E6%AD%A4%E5%A4%96%EF%BC%8C%E5%AE%A2%E6%88%B7%E5%8F%AF%E4%BB%A5%E5%8F%82%E8%80%83%E9%9A%8F%E9%99%84%E7%9A%84%20MC33771C%20%E8%BD%AF%E4%BB%B6%E5%BC%80%E5%8F%91%E5%B7%A5%E5%85%B7%E5%8C%85%E3%80%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%3C%2FP%3E%0A%3CP%3E%E7%BA%A6%E7%91%9F%E5%A4%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2369482%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MC33771c%20TPL%20communication%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2369482%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E5%AE%A2%E6%88%B7%EF%BC%9AAARTRONIX%20%E5%88%9B%E6%96%B0%E5%85%AC%E5%8F%B8%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%9C%80%E7%BB%88%E5%AE%A2%E6%88%B7%EF%BC%9AAAROHI%20%E5%B5%8C%E5%85%A5%E5%BC%8F%E7%B3%BB%E7%BB%9F%E7%A7%81%E4%BA%BA%E6%9C%89%E9%99%90%E5%85%AC%E5%8F%B8%20%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%BB%88%E7%AB%AF%E5%BA%94%E7%94%A8%EF%BC%9AUPS%20%E5%A4%87%E7%94%A8%E7%94%B5%E6%B1%A0%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%9B%BD%E5%AE%B6%EF%BC%9A%20%E5%8D%B0%E5%BA%A6%E5%8D%B0%E5%BA%A6%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E5%B9%B4%E4%BA%A7%E9%87%8F%EF%BC%9A1000%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2369464%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20MC33771c%20TPL%20communication%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2369464%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%E7%B1%B3%E6%8B%89%E5%B0%94%3C%2FP%3E%0A%3CP%3E%E6%88%91%E9%9C%80%E8%A6%81%E8%81%94%E7%B3%BB%E8%BD%AF%E4%BB%B6%E5%B7%A5%E7%A8%8B%E5%B8%88%E6%9D%A5%E8%A7%A3%E5%86%B3%E6%82%A8%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%E8%AF%B7%E5%88%86%E4%BA%AB%E4%BB%A5%E4%B8%8B%E6%9C%89%E5%85%B3%E8%B4%B5%E9%A1%B9%E7%9B%AE%E7%9A%84%E4%BF%A1%E6%81%AF%E3%80%82%E4%BB%96%E4%BB%AC%E6%80%BB%E6%98%AF%E9%9C%80%E8%A6%81%E4%BF%A1%E6%81%AF%E3%80%82%20%3C%2FP%3E%0A%3CP%20class%3D%22x_elementToProof%22%3E%3CFONT%20color%3D%22%230000FF%22%3E%3CSPAN%20data-olk-copy-source%3D%22MessageBody%22%3E%E5%AE%A2%E6%88%B7%EF%BC%9AAARTRONIX%20%E5%88%9B%E6%96%B0%E5%85%AC%E5%8F%B8%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%20class%3D%22x_elementToProof%22%3E%3CFONT%20color%3D%22%230000FF%22%3E%3CSPAN%3E%E6%9C%80%E7%BB%88%E5%AE%A2%E6%88%B7%EF%BC%9A%3F(%E4%B9%9F%E5%8F%AF%E4%BB%A5%E6%98%AF%20AARTRONIX%20INNOVATIONS)%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%20class%3D%22x_elementToProof%22%3E%3CFONT%20color%3D%22%230000FF%22%3E%3CSPAN%3E%E6%9C%80%E7%BB%88%E5%BA%94%E7%94%A8%EF%BC%9A%20%3F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%20class%3D%22x_elementToProof%22%3E%3CFONT%20color%3D%22%230000FF%22%3E%3CSPAN%3E%E5%9B%BD%E5%AE%B6%EF%BC%9A%20%E5%8D%B0%E5%BA%A6%E5%8D%B0%E5%BA%A6%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%20class%3D%22x_elementToProof%22%3E%3CFONT%20color%3D%22%230000FF%22%3E%3CSPAN%3E%E5%B9%B4%E4%BA%A7%E9%87%8F%EF%BC%9A%3F%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%0A%3CP%3E%E8%87%B4%E4%BB%A5%E6%9C%80%E5%B4%87%E9%AB%98%E7%9A%84%E6%95%AC%E6%84%8F%3C%2FP%3E%0A%3CP%3E%E7%BA%A6%E7%91%9F%E5%A4%AB%3C%2FP%3E%3C%2FLINGO-BODY%3E
