Low-voltage detect: Datasheet vs. Reference Manual
907 次查看
Weber1
Hi community,
I'm trying to implement the Low-Voltage Detection (LVD) feature of a MCXA156 controller. The Datasheet defines the VLVDH_VDD threshold = 2.619V (typ) and also the VLVDL_VDD threshold = 1.651V (typ). The VLVDH threshold is exactly what I want. But only the VLVDis configured by default (plus having the bad behavior of intermittently flipping the reset signal few times when detecting LVD, as I can see using a scope - hystresis too low!)
Furthermore, the Reference Manual says: "The voltage threshold at which the LVD reset asserts is programmable", and the VD_SYS_CFG register is described aby "...configures the low-voltage trip point..." Fine, so far.
The problem now is that the VD_SYS_CFG register only has the following bits documented in the RM:
  • LOCK
  • HVDIE - HVD interrupt enable
  • HVDRE - HVD reset enable
  • LVDIE - LVD interrupt enable
  • LVDRE - LVD reset enable
None of these is usable to set the threshold.
Question: How should I configure the LVD threshold?
Weber
标签 (3)
标记 (3)
681 次查看
luis_maravilla
Dear Weber,
I apologize for the late response; In Reference Manual Chapter 25.7.17 VD_SYS_CFG configuration, the 8 bit show as reserved is "LVSEL", this should be open to users, we are working on modification for RM.
Before Writing to this field, you must write 0 to LOCK.
If you want to change LVSEL, you must do this after disabling the LVD reset and interrupt. Otherwise, SPC could generate an LVD due to the LVSEL change.
Configuration for LVSEL:
0b-Normal
1b-Safe
In SDK examples for MCXA156, you can see in file fsl_spc.h the spc_low_voltage_level_select function.
Since you want to use the High Range LVD threshold, you need to use [ksPC_LowVoltageHighRange] entering Normal level [0b] in spc_low_voltage_level_select
Let me know if that work for you.
Best Regards, Luis
901 次查看
Weber1
Let me add that in the RM there is the LOCK bit of VD_SYS_CFG, which is commented by "Allows writing to the LVDRE, HVDRE, and LVSEL fields". But there is no LVSEL bit anywhere defined.
Furthermore, there is a SDK function "SPC_SetSystemVDDLowVoltageLevel" which refers to SPC_VD_SYS_CFG_LVSEL (bit 8), where the related code is commented out. Very strange...
Any suggestions?
%3CLINGO-SUB%20id%3D%22lingo-sub-2327038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%BD%8E%E7%94%B5%E5%8E%8B%E6%A3%80%E6%B5%8B%EF%BC%9A%E6%95%B0%E6%8D%AE%E8%A1%A8%E4%B8%8E%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2327038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%3C%2FP%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E5%AE%9E%E7%8E%B0%20MCXA156%20%E6%8E%A7%E5%88%B6%E5%99%A8%E7%9A%84%E4%BD%8E%E5%8E%8B%E6%A3%80%E6%B5%8B%20(LVD)%20%E5%8A%9F%E8%83%BD%E3%80%82%E6%95%B0%E6%8D%AE%E6%89%8B%E5%86%8C%E3%80%8B%E5%AE%9A%E4%B9%89%20VLVDH_VDD%20%E9%98%88%E5%80%BC%E4%B8%BA%202.619V%EF%BC%88%E5%85%B8%E5%9E%8B%E5%80%BC%EF%BC%89%EF%BC%8CVLVDL_VDD%20%E9%98%88%E5%80%BC%E4%B8%BA%201.651V%EF%BC%88%E5%85%B8%E5%9E%8B%E5%80%BC%EF%BC%89%E3%80%82%3CSTRONG%3EVLVDH%3C%2FSTRONG%3E%E4%B8%B4%E7%95%8C%E5%80%BC%E6%AD%A3%E6%98%AF%E6%88%91%E6%83%B3%E8%A6%81%E7%9A%84%E3%80%82%E4%BD%86%E6%98%AF%E9%BB%98%E8%AE%A4%E6%83%85%E5%86%B5%E4%B8%8B%E5%8F%AA%E9%85%8D%E7%BD%AE%E4%BA%86%20VLVD%20%3CSTRONG%3EL%3C%2FSTRONG%3E%EF%BC%88%E8%80%8C%E4%B8%94%E5%9C%A8%E6%A3%80%E6%B5%8B%20%E4%BD%8E%E5%8E%8B%E6%A3%80%E6%B5%8B%20%E6%97%B6%E4%BC%9A%E5%87%BA%E7%8E%B0%E5%87%A0%E6%AC%A1%E9%97%B4%E6%AD%87%E6%80%A7%E7%BF%BB%E8%BD%AC%20RESET%20%E4%BF%A1%E5%8F%B7%E7%9A%84%E4%B8%8D%E8%89%AF%E8%A1%8C%E4%B8%BA%EF%BC%8C%E6%AD%A3%E5%A6%82%E6%88%91%E4%BD%BF%E7%94%A8%E7%A4%BA%E6%B3%A2%E5%99%A8%E7%9C%8B%E5%88%B0%E7%9A%84%E9%82%A3%E6%A0%B7%20%E2%80%94%E2%80%94%20%E8%BF%9F%E6%BB%9E%E5%A4%AA%E4%BD%8E%E4%BA%86%EF%BC%81%EF%BC%89%3C%2FP%3E%3CP%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E8%AF%B4%EF%BC%9A%22%20%E4%BD%8E%E5%8E%8B%E6%A3%80%E6%B5%8B%20RESET%20%E6%89%80%E5%A4%84%E7%9A%84%E7%94%B5%E5%8E%8B%E9%98%88%E5%80%BC%E6%98%AF%E5%8F%AF%E7%BC%96%E7%A8%8B%E7%9A%84%20%22%EF%BC%8C%E8%80%8C%20VD_SYS_CFG%20%E5%AF%84%E5%AD%98%E5%99%A8%E7%9A%84%E6%8F%8F%E8%BF%B0%E6%98%AF%20%22...%20%E9%85%8D%E7%BD%AE%E4%BD%8E%E5%8E%8B%E8%A7%A6%E5%8F%91%E7%82%B9...%22%20%E5%88%B0%E7%9B%AE%E5%89%8D%E4%B8%BA%E6%AD%A2%E8%BF%98%E4%B8%8D%E9%94%99%E3%80%82%3C%2FP%3E%3CP%3E%E7%8E%B0%E5%9C%A8%E7%9A%84%E9%97%AE%E9%A2%98%E6%98%AF%EF%BC%8CVD_SYS_CFG%20%E5%AF%84%E5%AD%98%E5%99%A8%E5%8F%AA%E6%9C%89%20RM%20%E4%B8%AD%E8%AE%B0%E5%BD%95%E7%9A%84%E4%BB%A5%E4%B8%8B%E4%BD%8D%EF%BC%9A%3C%2FP%3E%3CUL%3E%3CLI%3ELOCK%3C%2FLI%3E%3CLI%3EHVDIE%20-%20%E5%90%AF%E7%94%A8%20HVD%20%E4%B8%AD%E6%96%AD%3C%2FLI%3E%3CLI%3EHVDRE-%E5%90%AF%E7%94%A8%20HVD%20RESET%3C%2FLI%3E%3CLI%3ELVDIE-%E4%BD%8E%E5%8E%8B%E6%A3%80%E6%B5%8B%20%E4%B8%AD%E6%96%AD%E5%90%AF%E7%94%A8%3C%2FLI%3E%3CLI%3E%E4%BD%8E%E5%8E%8B%E6%A3%80%E6%B5%8BRE-%E5%90%AF%E7%94%A8%20%E4%BD%8E%E5%8E%8B%E6%A3%80%E6%B5%8B%20RESET%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%E8%BF%99%E4%BA%9B%E9%83%BD%E4%B8%8D%E8%83%BD%E7%94%A8%E6%9D%A5%E8%AE%BE%E7%BD%AE%E9%98%88%E5%80%BC%E3%80%82%20%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%EF%BC%9A%E6%88%91%E5%BA%94%E8%AF%A5%E5%A6%82%E4%BD%95%E9%85%8D%E7%BD%AE%E4%BD%8E%E5%8E%8B%E6%A3%80%E6%B5%8B%E9%98%88%E5%80%BC%EF%BC%9F%3C%2FP%3E%3CP%3E%E9%A1%BA%E7%A5%9D%E5%95%86%E7%A5%BA%EF%BC%81%3C%2FP%3E%3CP%3E%E9%9F%A6%E4%BC%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2327038%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E6%A0%B8%E5%BF%83%E4%B8%8E%E5%86%85%E5%AD%98%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EMCXA%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3E%E7%94%B5%E6%BA%90%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2327057%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Low-voltage%20detect%3A%20Datasheet%20vs.%20Reference%20Manual%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2327057%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AE%A9%E6%88%91%E8%A1%A5%E5%85%85%E4%B8%80%E7%82%B9%EF%BC%8C%E5%9C%A8%20RM%20%E4%B8%AD%EF%BC%8CVD_SYS_CFG%20%E7%9A%84%20LOCK%20%E4%BD%8D%E6%B3%A8%E9%87%8A%E4%B8%BA%22%E5%85%81%E8%AE%B8%E5%86%99%E5%85%A5%20LVDRE%E3%80%81HVDRE%20%E5%92%8C%20LVSEL%20%E5%AD%97%E6%AE%B5%22%20%E3%80%82%E4%BD%86%E6%B2%A1%E6%9C%89%E5%9C%A8%E4%BB%BB%E4%BD%95%E5%9C%B0%E6%96%B9%E5%AE%9A%E4%B9%89%20LVSEL%20%E4%BD%8D%E3%80%82%3CBR%20%2F%3E%E6%AD%A4%E5%A4%96%EF%BC%8C%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%20SDK%20%E5%87%BD%E6%95%B0%22SPC_SetSystemVDDLowVoltageLevel%22%20%EF%BC%8C%E5%AE%83%E6%8C%87%E5%90%91%20SPC_VD_SYS_CFG_LVSEL%EF%BC%88%E7%AC%AC%208%20%E4%BD%8D%EF%BC%89%EF%BC%8C%E5%85%B6%E4%B8%AD%3CLI-EMOJI%20id%3D%22lia_smiling-face-with-sunglasses%22%20title%3D%22%3Asmiling_face_with_sunglasses%3A%22%3E%3C%2FLI-EMOJI%3E%E7%9B%B8%E5%85%B3%E4%BB%A3%E7%A0%81%E5%B7%B2%E6%B3%A8%E9%87%8A%E3%80%82%E9%9D%9E%E5%B8%B8%E5%A5%87%E6%80%AA...%3C%2FP%3E%3CP%3E%E6%82%A8%E6%9C%89%E4%BB%80%E4%B9%88%E5%BB%BA%E8%AE%AE%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2335399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Low-voltage%20detect%3A%20Datasheet%20vs.%20Reference%20Manual%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2335399%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BA%B2%E7%88%B1%E7%9A%84%E9%9F%A6%E4%BC%AF%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%E8%BF%9F%E5%88%B0%E7%9A%84%E5%9B%9E%E5%A4%8D%EF%BC%8C%E6%88%91%E6%B7%B1%E8%A1%A8%E6%AD%89%E6%84%8F%EF%BC%9B%E5%8F%82%E8%A7%81%E3%80%8A%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E3%80%8B%E7%AC%AC%2025.7.17%20%E7%AB%A0VD_SYS_CFG%20%E9%85%8D%E7%BD%AE%E4%B8%AD%EF%BC%8C%E6%98%BE%E7%A4%BA%E4%B8%BA%E4%BF%9D%E7%95%99%E7%9A%84%208%20%E4%BD%8D%E6%98%AF%22LVSEL%22%20%EF%BC%8C%E8%BF%99%E5%BA%94%E8%AF%A5%E5%AF%B9%E7%94%A8%E6%88%B7%E5%BC%80%E6%94%BE%EF%BC%8C%E6%88%91%E4%BB%AC%E6%AD%A3%E5%9C%A8%E4%B8%BA%20RM%20%E8%BF%9B%E8%A1%8C%E4%BF%AE%E6%94%B9%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%9C%A8%E5%86%99%E5%85%A5%E8%AF%A5%E5%AD%97%E6%AE%B5%E4%B9%8B%E5%89%8D%EF%BC%8C%E5%BF%85%E9%A1%BB%E5%B0%86%20LOCK%20%E5%86%99%E4%B8%BA%200%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%A6%82%E6%9E%9C%E8%A6%81%E6%9B%B4%E6%94%B9%20LVSEL%EF%BC%8C%E5%88%99%E5%BF%85%E9%A1%BB%E5%9C%A8%E7%A6%81%E7%94%A8%20LVD%20RESET%20%E5%92%8C%E4%B8%AD%E6%96%AD%E5%90%8E%E6%89%A7%E8%A1%8C%E6%AD%A4%E6%93%8D%E4%BD%9C%E3%80%82%E5%90%A6%E5%88%99%EF%BC%8C%E7%94%B1%E4%BA%8E%20LVSEL%20%E7%9A%84%E5%8F%98%E5%8C%96%EF%BC%8CSPC%20%E5%8F%AF%E8%83%BD%E4%BC%9A%E7%94%9F%E6%88%90%E4%BD%8E%E5%8E%8B%E6%A3%80%E6%B5%8B%E3%80%82%3C%2FP%3E%0A%3CP%3ELVSEL%20%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%9A%3C%2FP%3E%0A%3CP%3E0b-%E6%AD%A3%E5%B8%B8%3C%2FP%3E%0A%3CP%3E1b-%E5%AE%89%E5%85%A8%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E5%9C%A8%20MCXA156%20%E7%9A%84%20SDK%20%E7%A4%BA%E4%BE%8B%E4%B8%AD%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E5%9C%A8%E6%96%87%E4%BB%B6%20%3CEM%3E%3CSTRONG%3Efsl_spc.h%3C%2FSTRONG%3E%3C%2FEM%3E%E4%B8%AD%E7%9A%84%20%3CEM%3E%3CSTRONG%3Espc_low_voltage_level_select%3C%2FSTRONG%3E%3C%2FEM%3E%E5%87%BD%E6%95%B0%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E7%94%B1%E4%BA%8E%E8%A6%81%E4%BD%BF%E7%94%A8%E9%AB%98%E8%8C%83%E5%9B%B4%20%E4%BD%8E%E5%8E%8B%E6%A3%80%E6%B5%8B%20%E9%98%88%E5%80%BC%EF%BC%8C%E5%9B%A0%E6%AD%A4%E9%9C%80%E8%A6%81%E4%BD%BF%E7%94%A8%20%5B%3CEM%3E%3CSTRONG%3EksPC_LowVoltageHighRange%3C%2FSTRONG%3E%3C%2FEM%3E%5D%20entering%20Normal%20level%20%5B0b%5D%20in%20%3CSTRONG%3E%3CEM%3Espc_low_voltage_level_select%3C%2FEM%3E%3C%2FSTRONG%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E8%AE%A9%E6%88%91%E7%9F%A5%E9%81%93%E8%BF%99%E6%98%AF%E5%90%A6%E9%80%82%E5%90%88%E4%BD%A0%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%9C%80%E8%AF%9A%E6%8C%9A%E7%9A%84%E9%97%AE%E5%80%99%EF%BC%8C%E8%B7%AF%E6%98%93%E6%96%AF%3C%2FP%3E%3C%2FLINGO-BODY%3E
