LSTM machine learning model whether support NXP MCXN947 or not
850 次查看
BillWen
Hi everyone:
I have a question for LSTM machine learning model whether support NXP MCXN947 or not
I check the document "How to Integrate Customer ML Model to NPU on MCX N94", the following is the table for "The operators supported by the NPU"
I want to double confirm is LSTM model not support MCXN947?
The other thing is I try to put the LSTM model into MCXN947 by "frdmmcxn947_tflm_cifar10" project, the following is the error message. Is it cause by the same reason?
Is there anyone have some experience can answer me about this? I really need some help, thanks.
Thanks a lot
Best Regards, BillWen
标签 (2)
标记 (2)
781 次查看
Joey_z
hi,BillWen
Thank you for your interest in NXP Semiconductor products and the opportunity to serve you, I will gladly help you with this.
I already answered it in your other question.
Wish it helps you.
Xu Zhang
