LPI2C glitch filter width discrepancy
286 次查看
jcallon
I am using an MCXN947 on the latest released SDK (version 26.09).
When I was configuring the LPI2C peripheral in MCUxpresso, I noticed lpi2c_master_config_t and lpi2c_slave_config_t had different data type widths to store their glitch filter length.
This meant the same length I was using on my slave configuration was being truncated for my master configuration of the same peripheral.
fsl_lpi2c.h
typedef struct _lpi2c_master_config
    uint8_t sdaGlitchFilterWidth_ns;     /*!< Width in nanoseconds of glitch filter on SDA pin. Set to 0 to disable. */
    uint8_t sclGlitchFilterWidth_ns;     /*!< Width in nanoseconds of glitch filter on SCL pin. Set to 0 to disable. */
} lpi2c_master_config_t;
typedef struct _lpi2c_slave_config
    uint32_t sdaGlitchFilterWidth_ns; /*!< Width in nanoseconds of the digital filter on the SDA signal. Set to 0 to
                                         disable. */
    uint32_t sclGlitchFilterWidth_ns; /*!< Width in nanoseconds of the digital filter on the SCL signal. Set to 0 to
                                         disable. */
} lpi2c_slave_config_t;
MCFGR2.FILDSDA and MCFGR2.FILTSDL, the registers that pull from these values, appear to be fixed 4 bits in the reference manual.
My reference manual is MCXNX4XRM Rev. 6, 2025-03-05, so it may be a bit outdated. I was having trouble finding any new releases of it. If there is a new release, I'd be very happy to be pointed to it.
fsl_lpi2c.cc
void LPI2C_MasterInit(...) {
    cycles = LPI2C_GetCyclesForWidth(sourceClock_Hz, masterConfig->sdaGlitchFilterWidth_ns, 0U,
                                     (LPI2C_MCFGR2_FILTSDA_MASK >> LPI2C_MCFGR2_FILTSDA_SHIFT), 0U);
    cycles = LPI2C_GetCyclesForWidth(sourceClock_Hz, masterConfig->sclGlitchFilterWidth_ns, 0U,
                                     (LPI2C_MCFGR2_FILTSCL_MASK >> LPI2C_MCFGR2_FILTSCL_SHIFT), 0U);
I was wondering, why is there this discrepancy between the master and slave configuration?
Thank you for your time,
JC
259 次查看
Harry_Zhang
Hi @jcallon
Thank you for reporting this. After reviewing the LPI2C register definitions and driver implementation, this appears to be an SDK driver issue.
The FILTSDA and FILTSCL fields are 4 bits wide for both controller and target configurations, and LPI2C_GetCyclesForWidth() already accepts a uint32_t nanosecond value and limits the resulting cycle count to the supported register range. Therefore, using uint8_t for the glitch filter width in lpi2c_master_config_t unnecessarily limits the input to 255 ns, whereas lpi2c_slave_config_t uses uint32_t.
I will report this inconsistency to the SDK team for confirmation and correction. Thank you for bringing it to our attention.
Harry
259 次查看
Harry_Zhang
Hi @jcallon
Harry
282 次查看
jcallon
Correction, the slave code updates SCFGR2.FILTSDA and SCFGR2.FILTSCL.
Although, in the code, the masks and offsets for MCFGR2 and SCFGR2 appear to be the same.
#define LPI2C_MCFGR2_FILTSCL_MASK (0xF0000U)
#define LPI2C_MCFGR2_FILTSCL_SHIFT (16U)
/*! FILTSCL - Glitch Filter SCL */
#define LPI2C_MCFGR2_FILTSCL(x) (((uint32_t)(((uint32_t)(x)) << LPI2C_MCFGR2_FILTSCL_SHIFT)) & LPI2C_MCFGR2_FILTSCL_MASK)
#define LPI2C_SCFGR2_FILTSCL_MASK (0xF0000U)
#define LPI2C_SCFGR2_FILTSCL_SHIFT (16U)
#define LPI2C_SCFGR2_FILTSCL(x) (((uint32_t)(((uint32_t)(x)) << LPI2C_SCFGR2_FILTSCL_SHIFT)) & LPI2C_SCFGR2_FILTSCL_MASK)
%3CLINGO-SUB%20id%3D%22lingo-sub-2422413%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELPI2C%E6%95%85%E9%9A%9C%E6%BB%A4%E6%B3%A2%E5%99%A8%E5%AE%BD%E5%BA%A6%E5%B7%AE%E5%BC%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2422413%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20MCXN947%EF%BC%8C%E6%90%AD%E8%BD%BD%E7%9A%84%E6%98%AF%E6%9C%80%E6%96%B0%E5%8F%91%E5%B8%83%E7%9A%84%20SDK%EF%BC%88%E7%89%88%E6%9C%AC%2026.09%EF%BC%89%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%20MCUxpresso%20%E4%B8%AD%E9%85%8D%E7%BD%AE%20LPI2C%20%E5%A4%96%E8%AE%BE%E6%97%B6%EF%BC%8C%E6%88%91%E6%B3%A8%E6%84%8F%E5%88%B0%20lpi2c_master_config_t%20%E5%92%8C%20lpi2c_slave_config_t%20%E7%9A%84%E6%95%B0%E6%8D%AE%E7%B1%BB%E5%9E%8B%E5%AE%BD%E5%BA%A6%E4%B8%8D%E5%90%8C%EF%BC%8C%E7%94%A8%E4%BA%8E%E5%AD%98%E5%82%A8%E5%AE%83%E4%BB%AC%E7%9A%84%E6%AF%9B%E5%88%BA%E6%BB%A4%E6%B3%A2%E5%99%A8%E9%95%BF%E5%BA%A6%E3%80%82%3CBR%20%2F%3E%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%EF%BC%8C%E6%88%91%E5%9C%A8%E4%BB%8E%E8%AE%BE%E5%A4%87%E9%85%8D%E7%BD%AE%E4%B8%AD%E4%BD%BF%E7%94%A8%E7%9A%84%E7%9B%B8%E5%90%8C%E9%95%BF%E5%BA%A6%EF%BC%8C%E5%9C%A8%E5%90%8C%E4%B8%80%E4%B8%AA%E5%A4%96%E8%AE%BE%E7%9A%84%E4%B8%BB%E8%AE%BE%E5%A4%87%E9%85%8D%E7%BD%AE%E4%B8%AD%E4%BC%9A%E8%A2%AB%E6%88%AA%E6%96%AD%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3Efsl_lpi2c.h%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Etypedef%20struct%20_lpi2c_master_config%0A%7B%0A...%0A%20%20%20%20uint8_t%20sdaGlitchFilterWidth_ns%3B%20%20%20%20%20%2F*!%26lt%3B%20Width%20in%20nanoseconds%20of%20glitch%20filter%20on%20SDA%20pin.%20Set%20to%200%20to%20disable.%20*%2F%0A%20%20%20%20uint8_t%20sclGlitchFilterWidth_ns%3B%20%20%20%20%20%2F*!%26lt%3B%20Width%20in%20nanoseconds%20of%20glitch%20filter%20on%20SCL%20pin.%20Set%20to%200%20to%20disable.%20*%2F%0A...%0A%7D%20lpi2c_master_config_t%3B%0A%0A...%0A%0Atypedef%20struct%20_lpi2c_slave_config%0A%7B%0A...%0A%20%20%20%20uint32_t%20sdaGlitchFilterWidth_ns%3B%20%2F*!%26lt%3B%20Width%20in%20nanoseconds%20of%20the%20digital%20filter%20on%20the%20SDA%20signal.%20Set%20to%200%20to%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20disable.%20*%2F%0A%20%20%20%20uint32_t%20sclGlitchFilterWidth_ns%3B%20%2F*!%26lt%3B%20Width%20in%20nanoseconds%20of%20the%20digital%20filter%20on%20the%20SCL%20signal.%20Set%20to%200%20to%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20disable.%20*%2F%0A...%0A%7D%20lpi2c_slave_config_t%3B%3C%2FCODE%3E%3C%2FPRE%3E%3CP%3E%3CBR%20%2F%3E%E6%A0%B9%E6%8D%AE%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%EF%BC%8CMCFGR2.FILDSDA%20%E5%92%8C%20MCFGR2.FILTSDL%20%E8%BF%99%E4%B8%A4%E4%B8%AA%E5%AF%84%E5%AD%98%E5%99%A8%E4%BC%9A%E8%AF%BB%E5%8F%96%E8%BF%99%E4%BA%9B%E5%80%BC%EF%BC%8C%E5%AE%83%E4%BB%AC%E4%BC%BC%E4%B9%8E%E6%98%AF%E5%9B%BA%E5%AE%9A%E7%9A%84%204%20%E4%BD%8D%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E7%9A%84%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%E6%98%AF%20MCXNX4XRM%20Rev.6%E3%80%812025-03-05%EF%BC%8C%E6%89%80%E4%BB%A5%E5%8F%AF%E8%83%BD%E6%9C%89%E7%82%B9%E8%BF%87%E6%97%B6%E4%BA%86%E3%80%82%E6%88%91%E4%B8%80%E7%9B%B4%E6%89%BE%E4%B8%8D%E5%88%B0%E5%AE%83%E7%9A%84%E6%96%B0%E7%89%88%E6%9C%AC%E3%80%82%E5%A6%82%E6%9E%9C%E6%9C%89%E6%96%B0%E7%89%88%E6%9C%AC%E5%8F%91%E5%B8%83%EF%BC%8C%E8%AF%B7%E5%91%8A%E8%AF%89%E6%88%91%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3Efsl_lpi2c.cc%3C%2FP%3E%3CPRE%20class%3D%22lia-code-sample%20language-c%22%3E%3CCODE%20translate%3D%22no%22%3Evoid%20LPI2C_MasterInit(...)%20%7B%0A...%0A%20%20%20%20cycles%20%3D%20LPI2C_GetCyclesForWidth(sourceClock_Hz%2C%20masterConfig-%26gt%3BsdaGlitchFilterWidth_ns%2C%200U%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20(LPI2C_MCFGR2_FILTSDA_MASK%20%26gt%3B%26gt%3B%20LPI2C_MCFGR2_FILTSDA_SHIFT)%2C%200U)%3B%0A...%0A%20%20%20%20cycles%20%3D%20LPI2C_GetCyclesForWidth(sourceClock_Hz%2C%20masterConfig-%26gt%3BsclGlitchFilterWidth_ns%2C%200U%2C%0A%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20%20(LPI2C_MCFGR2_FILTSCL_MASK%20%26gt%3B%26gt%3B%20LPI2C_MCFGR2_FILTSCL_SHIFT)%2C%200U)%3B%0A...%0A%7D%3C%2FCODE%3E%3C%2FPRE%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%EF%BC%8C%E4%B8%BA%E4%BB%80%E4%B9%88%E4%B8%BB%E8%AE%BE%E5%A4%87%E5%92%8C%E4%BB%8E%E8%AE%BE%E5%A4%87%E9%85%8D%E7%BD%AE%E4%B9%8B%E9%97%B4%E5%AD%98%E5%9C%A8%E8%BF%99%E7%A7%8D%E5%B7%AE%E5%BC%82%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8A%BD%E5%87%BA%E6%97%B6%E9%97%B4%E3%80%82%3CBR%20%2F%3E%E6%9D%B0%E8%A5%BF%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2422413%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E9%80%9A%E4%BF%A1%E4%B8%8E%E6%8E%A7%E5%88%B6%EF%BC%88I3C%20%7C%20I2C%20%7C%20SPI%20%7C%20FlexCAN%20%7C%20%E4%BB%A5%E5%A4%AA%E7%BD%91%20%7C%20FlexIO%EF%BC%89%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2422414%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LPI2C%20glitch%20filter%20width%20discrepancy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2422414%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%9B%B4%E6%AD%A3%EF%BC%8C%E4%BB%8E%E4%BB%A3%E7%A0%81%E6%9B%B4%E6%96%B0%20SCFGR2.FILTSDA%20%E5%92%8C%20SCFGR2.FILTSCL%E3%80%82%3CBR%20%2F%3E%E8%99%BD%E7%84%B6%E5%9C%A8%E4%BB%A3%E7%A0%81%E4%B8%AD%EF%BC%8CMCFGR2%20%E5%92%8C%20SCFGR2%20%E7%9A%84%E6%8E%A9%E7%A0%81%E5%92%8C%E5%81%8F%E7%A7%BB%E9%87%8F%E7%9C%8B%E8%B5%B7%E6%9D%A5%E6%98%AF%E7%9B%B8%E5%90%8C%E7%9A%84%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%23define%20LPI2C_MCFGR2_FILTSCL_MASK%20(0xF0000U)%3CBR%20%2F%3E%20%23define%20LPI2C_MCFGR2_FILTSCL_SHIFT%20(16U)%3CBR%20%2F%3E%20%2F*!%20FILTSCL%20-%20%E6%95%85%E9%9A%9C%E6%BB%A4%E6%B3%A2%E5%99%A8%20SCL%20*%2F%3CBR%20%2F%3E%20%23define%20LPI2C_MCFGR2_FILTSCL(x)%20(((uint32_t)(((uint32_t)(x))%20%26lt%3B%26lt%3B%20LPI2C_MCFGR2_FILTSCL_SHIFT))%20%26amp%3B%20LPI2C_MCFGR2_FILTSCL_MASK)%3CBR%20%2F%3E%3CBR%20%2F%3E%20%23define%20LPI2C_SCFGR2_FILTSCL_MASK%20(0xF0000U)%3CBR%20%2F%3E%20%23define%20LPI2C_SCFGR2_FILTSCL_SHIFT%20(16U)%3CBR%20%2F%3E%20%2F*!%20FILTSCL%20-%20%E6%95%85%E9%9A%9C%E6%BB%A4%E6%B3%A2%E5%99%A8%20SCL%20*%2F%3CBR%20%2F%3E%20%23define%20LPI2C_SCFGR2_FILTSCL(x)%20(((uint32_t)(((uint32_t)(x))%20%26lt%3B%26lt%3B%20LPI2C_SCFGR2_FILTSCL_SHIFT))%20%26amp%3B%20LPI2C_SCFGR2_FILTSCL_MASK)%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2422668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9A%20LPI2C%20glitch%20filter%20width%20discrepancy%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2422668%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%97%A8%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F248166%22%20target%3D%22_blank%22%3E%40jcallon%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E4%B8%BE%E6%8A%A5%E3%80%82%E5%9C%A8%E5%AE%A1%E6%9F%A5%E4%BA%86%20LPI2C%20%E5%AF%84%E5%AD%98%E5%99%A8%E5%AE%9A%E4%B9%89%E5%92%8C%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E5%AE%9E%E7%8E%B0%E4%B9%8B%E5%90%8E%EF%BC%8C%E8%BF%99%E4%BC%BC%E4%B9%8E%E6%98%AF%20SDK%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%AF%B9%E4%BA%8E%E6%8E%A7%E5%88%B6%E5%99%A8%E5%92%8C%E7%9B%AE%E6%A0%87%E9%85%8D%E7%BD%AE%EF%BC%8CFILTSDA%20%E5%92%8C%20FILTSCL%20%E5%AD%97%E6%AE%B5%E5%9D%87%E4%B8%BA%204%20%E4%BD%8D%E5%AE%BD%EF%BC%8CLPI2C_GetCyclesForWidth()%20%E5%B7%B2%E7%BB%8F%E6%8E%A5%E5%8F%97%20uint32_t%20%E7%BA%B3%E7%A7%92%E5%80%BC%EF%BC%8C%E5%B9%B6%E5%B0%86%E7%94%9F%E6%88%90%E7%9A%84%E5%91%A8%E6%9C%9F%E8%AE%A1%E6%95%B0%E9%99%90%E5%88%B6%E5%9C%A8%E6%94%AF%E6%8C%81%E7%9A%84%E5%AF%84%E5%AD%98%E5%99%A8%E8%8C%83%E5%9B%B4%E5%86%85%E3%80%82%E5%9B%A0%E6%AD%A4%EF%BC%8C%E5%9C%A8%20lpi2c_master_config_t%20%E4%B8%AD%E4%BD%BF%E7%94%A8%20uint8_t%20%E4%BD%9C%E4%B8%BA%E6%AF%9B%E5%88%BA%E6%BB%A4%E6%B3%A2%E5%99%A8%E5%AE%BD%E5%BA%A6%E4%BC%9A%E4%B8%8D%E5%BF%85%E8%A6%81%E5%9C%B0%E5%B0%86%E8%BE%93%E5%85%A5%E9%99%90%E5%88%B6%E4%B8%BA%20255%20ns%EF%BC%8C%E8%80%8C%20lpi2c_slave_config_t%20%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20uint32_t%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E4%BC%9A%E5%B0%86%E6%AD%A4%E4%B8%8D%E4%B8%80%E8%87%B4%E4%B9%8B%E5%A4%84%E6%8A%A5%E5%91%8A%E7%BB%99SDK%E5%9B%A2%E9%98%9F%EF%BC%8C%E4%BB%A5%E4%BE%BF%E4%BB%96%E4%BB%AC%E7%A1%AE%E8%AE%A4%E5%92%8C%E6%9B%B4%E6%AD%A3%E3%80%82%E6%84%9F%E8%B0%A2%E6%82%A8%E6%8F%90%E9%86%92%E6%88%91%E4%BB%AC%E6%B3%A8%E6%84%8F%E6%AD%A4%E4%BA%8B%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E5%93%88%E9%87%8C%3C%2FP%3E%3C%2FLINGO-BODY%3E
