GUI Guider (LVGL v9 simulator) FreeMASTER binding: Meter with Image Needle disappears GG_METER h
1,161 次查看
ryan_hong_wtmec
Hi all,
I’d like to share an issue and workaround for GUI Guider + LVGL v9 simulator with FreeMASTER binding.
Environment: GUI Guider 9.2 / 1.10.0 GA, LVGL v9 simulator (lvgl-simulator or lv_web_emscripten),
FreeMASTER JSON-RPC WebSocket (ws://localhost:41000), Windows 10/11.
Problem: When a FreeMASTER variable is bound to a Meter/Scale widget using an Image Needle,
the needle disappears or does not update correctly. The same variable bound to a Label updates
normally (e.g., 40–60), so the incoming value is valid.
Workaround/Fix: Patch the simulator code (or the template) here:
C:\nxp\GUI-Guider-1.10.0-GA\environment\template\project\v9\lvgl-simulator\gg_external_data\freemaster\freemaster_client.c
Update the GG_METER case to safely handle image needles vs line needles (and add NULL guards):
case GG_METER:
for (int i = 0; i < user_parm->arrayLen; i++)
meter_needle *nd = (meter_needle *)user_parm->childObjArray[i];
int v = atoi(dataArray[i]);
if (nd && nd->needle_obj)
if (lv_obj_check_type(nd->needle_obj, &lv_image_class))
lv_scale_set_image_needle_value(user_parm->parentObj, nd->needle_obj, v);
else
lv_scale_set_line_needle_value(user_parm->parentObj, nd->needle_obj, nd->needle_length, v);
break;
Question: Is this a known issue? If not, could this fix be integrated into future GUI Guider releases/templates?
Thanks.
1 回复
1,136 次查看
Celeste_Liu
Hello @ryan_hong_wtmec ,
Thank you for sharing. I will report this to the internal team and wait for their further confirmation.
Thank you for again your contribution in the NXP community.
Celeste
%3CLINGO-SUB%20id%3D%22lingo-sub-2267842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EGUI%20Guider%EF%BC%88LVGL%20v9%20%E6%A8%A1%E6%8B%9F%E5%99%A8%EF%BC%89FreeMASTER%20%E7%BB%91%E5%AE%9A%EF%BC%9A%E5%B8%A6%E6%9C%89%E5%9B%BE%E5%83%8F%E9%92%88%E7%9A%84%E4%BB%AA%E8%A1%A8%E6%B6%88%E5%A4%B1%20GG_METER%20h%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2267842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%A4%A7%E5%AE%B6%E5%A5%BD%EF%BC%8C%3CBR%20%2F%3E%EF%BC%8C%E6%88%91%E6%83%B3%E4%B8%8E%E5%A4%A7%E5%AE%B6%E5%88%86%E4%BA%AB%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E4%BB%A5%E5%8F%8A%E4%BD%BF%E7%94%A8%20FreeMASTER%20%E7%BB%91%E5%AE%9A%E7%9A%84%20GUI%20Guider%20%2B%20LVGL%20v9%20%E6%A8%A1%E6%8B%9F%E5%99%A8%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E3%80%82%3C%2FP%3E%3CP%3E%E7%8E%AF%E5%A2%83GUI%20Guider%209.2%20%2F%201.10.0GA%E3%80%81LVGL%20v9%20%E6%A8%A1%E6%8B%9F%E5%99%A8%20(lvgl-simulator%20%E6%88%96%20lv_web_emscripten)%E3%80%81%3CBR%20%2F%3EFreeMASTER%20JSON-RPC%20WebSocket%20(ws%3A%2F%2Flocalhost%3A41000)%E3%80%81Windows%2010%2F11%E3%80%82%3C%2FP%3E%3CP%3E%E9%97%AE%E9%A2%98%EF%BC%9A%E5%BD%93%20FreeMASTER%20%E5%8F%98%E9%87%8F%E4%B8%8E%E4%BD%BF%E7%94%A8%E5%9B%BE%E5%83%8F%E9%92%88%E7%9A%84%E4%BB%AA%E8%A1%A8%2F%E5%88%BB%E5%BA%A6%E9%83%A8%E4%BB%B6%E7%BB%91%E5%AE%9A%E6%97%B6%EF%BC%8C%3CBR%20%2F%3E%EF%BC%8C%E9%92%88%E4%BC%9A%E6%B6%88%E5%A4%B1%E6%88%96%E4%B8%8D%E8%83%BD%E6%AD%A3%E7%A1%AE%E6%9B%B4%E6%96%B0%E3%80%82%E4%B8%8E%E6%A0%87%E7%AD%BE%E7%BB%91%E5%AE%9A%E7%9A%84%E5%90%8C%E4%B8%80%E5%8F%98%E9%87%8F%E4%BC%9A%E6%AD%A3%E5%B8%B8%E6%9B%B4%E6%96%B0%3CBR%20%2F%3E%EF%BC%88%E5%A6%82%2040-60%EF%BC%89%EF%BC%8C%E5%9B%A0%E6%AD%A4%E8%BE%93%E5%85%A5%E7%9A%84%E5%80%BC%E6%98%AF%E6%9C%89%E6%95%88%E7%9A%84%E3%80%82%3C%2FP%3E%3CP%3E%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%2F%E8%A1%A5%E4%B8%81%EF%BC%9A%E5%9C%A8%E6%AD%A4%E5%A4%84%E4%BF%AE%E8%A1%A5%E6%A8%A1%E6%8B%9F%E5%99%A8%E4%BB%A3%E7%A0%81%EF%BC%88%E6%88%96%E6%A8%A1%E6%9D%BF%EF%BC%89%EF%BC%9A%3CBR%20%2F%3EC%3A%5Cnxp%5CGUI-Guider-1.10.0-GA%5Cenvironment%5Ctemplate%5Cproject%5Cv9%5Clvgl-simulator%5Cgg_external_data%5Cfreemaster%5Cfreemaster_client.c%3C%2FP%3E%3CP%3E%E6%9B%B4%E6%96%B0%20GG_METER%20%E6%A1%88%E4%BE%8B%EF%BC%8C%E4%BB%A5%E4%BE%BF%E5%AE%89%E5%85%A8%E5%9C%B0%E5%A4%84%E7%90%86%E5%9B%BE%E5%83%8F%E9%92%88%E5%92%8C%E7%BA%BF%E9%92%88%EF%BC%88%E5%B9%B6%E6%B7%BB%E5%8A%A0%20NULL%20%E4%BF%9D%E6%8A%A4%EF%BC%89%EF%BC%9A%3C%2FP%3E%3CP%3Ecase%20GG_METER%EF%BC%9A%3CBR%20%2F%3E%7B%3CBR%20%2F%3Efor%20(int%20i%20%3D%200%3B%20i%26lt%3B%20user_parm-%26gt%3BarrayLen%3B%20i%2B%2B)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Emeter_needle%20*nd%20%3D%20(meter_needle%20*)user_parm-%26gt%3BchildObjArray%5Bi%5D%3B%3CBR%20%2F%3Eint%20v%20%3D%20atoi(dataArray%5Bi%5D)%EF%BC%9B%3C%2FP%3E%3CP%3Eif%20(nd%26amp%3B%26amp%3B%20nd-%26gt%3Bneedle_obj)%3CBR%20%2F%3E%7B%3CBR%20%2F%3Eif%20(lv_obj_check_type(nd-%26gt%3Bneedle_obj%2C%26amp%3Blv_image_class))%3CBR%20%2F%3Elv_scale_set_image_needle_value(user_parm-%26gt%3BparentObj%2C%20nd-%26gt%3Bneedle_obj%2C%20v)%EF%BC%9B%3CBR%20%2F%3Eelse%3CBR%20%2F%3Elv_scale_set_line_needle_value(user_parm-%26gt%3BparentObj%2C%20nd-%26gt%3Bneedle_obj%2C%20nd-%26gt%3Bneedle_length%2C%20v)%3B%3CBR%20%2F%3E%7D%3CBR%20%2F%3E%7D%3CBR%20%2F%3Ebreak%3B%3CBR%20%2F%3E%7D%3C%2FP%3E%3CP%3E%3CBR%20%2F%3E%E9%97%AE%E9%A2%98%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E5%B7%B2%E7%9F%A5%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%E5%A6%82%E6%9E%9C%E4%B8%8D%E6%98%AF%EF%BC%8C%E8%BF%99%E4%B8%AA%E4%BF%AE%E5%A4%8D%E7%A8%8B%E5%BA%8F%E8%83%BD%E5%90%A6%E9%9B%86%E6%88%90%E5%88%B0%E6%9C%AA%E6%9D%A5%E7%9A%84%20GUI%20Guider%20%E7%89%88%E6%9C%AC%2F%E6%A8%A1%E6%9D%BF%E4%B8%AD%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2267842%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E9%80%9A%E4%BF%A1%26amp%3B%20%E6%8E%A7%E5%88%B6%EF%BC%88I3C%20%7C%20I2C%20%7C%20SPI%20%7C%20FlexCAN%20%7C%20%E4%BB%A5%E5%A4%AA%E7%BD%91%20%7C%20FlexIO%EF%BC%89%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2267914%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20GUI%20Guider%20(LVGL%20v9%20simulator)%20FreeMASTER%20binding%3A%20Meter%20with%20Image%20Needle%20disappears%20%20GG_METER%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2267914%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F258268%22%20target%3D%22_blank%22%3E%40ryan_hong_wtmec%3C%2FA%3E%E3%80%81%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%88%86%E4%BA%AB%E3%80%82%E6%88%91%E4%BC%9A%E5%90%91%E5%86%85%E9%83%A8%E5%9B%A2%E9%98%9F%E6%8A%A5%E5%91%8A%E6%AD%A4%E4%BA%8B%EF%BC%8C%E7%AD%89%E5%BE%85%E4%BB%96%E4%BB%AC%E7%9A%84%E8%BF%9B%E4%B8%80%E6%AD%A5%E7%A1%AE%E8%AE%A4%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E5%86%8D%E6%AC%A1%E4%B8%BA%E6%81%A9%E6%99%BA%E6%B5%A6%E7%A4%BE%E5%8C%BA%E5%81%9A%E5%87%BA%E8%B4%A1%E7%8C%AE%E3%80%82%3C%2FP%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E8%A5%BF%E8%8E%B1%E6%96%AF%E7%89%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E
