Flash write access with AHB
vanessa_dis
Hi, I would like to know if flash write access is supported by mimxrt1050 controller and NOR flash QSPI. I read that only in hyperflash was available this but i would like to confirm this.
Thank you.
Labels (2)
Sam_Gao
@vanessa_dis
The MIMXRT1050's FlexSPI controller fully supports read, write, and erase operations for QSPI NOR flash; using it on the EVK board simply requires hardware modifications to switch from the default HyperFlash chip.
https://www.nxp.com/docs/en/application-note/AN12108.pdf How to Enable Boot from QSPI Flash
vanessa_dis
Hi Sam, Currently I have it with IP operations working, but can NOR Flash QSPI supports flash write using AHB?
Sam_Gao
Did you ask details for HAB (High Assurance Boot)?
https://spsdk.readthedocs.io/en/stable/images/hab.html
Please refer to below AN with secure acess (Sorry, I can't send it directly, please apply for access or contact with local Sales/FAEs).
AN12681 How to use HAB secure boot in i.MX RT10xx [AN979510]
vanessa_dis
I am refearing AHB Advanced High-performance Bus
Sam_Gao
@vanessa_dis
I got your point.
Yes, the FlexSPI controller on the i.MX RT1050 and RT1060 series fully supports write access to external QSPI NOR flash using the AHB bus. The capability is not exclusive to HyperFlash.
The FlexSPI controller is designed with a flexible architecture to support various external memory types, including Serial NOR Flash (which covers QSPI), HyperFlash, and HyperRAM . The controller provides memory-mapped read and write access through the AHB bus for any of these supported devices .
https://www.nxp.com/docs/en/nxp/application-notes/AN12239.pdf
%3CLINGO-SUB%20id%3D%22lingo-sub-2207145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFlash%20write%20access%20with%20AHB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2207145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20I%20would%20like%20to%20know%20if%20flash%20write%20access%20is%20supported%20by%20mimxrt1050%20controller%20and%20NOR%20flash%20QSPI.%20I%20read%20that%20only%20in%20hyperflash%20was%20available%20this%20but%20i%20would%20like%20to%20confirm%20this.%3C%2FP%3E%3CP%3EThank%20you.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2207145%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EBoot%20ROM%7CBooting%20%7C%20Flash%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ECore%20and%20Memory%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2213216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Flash%20write%20access%20with%20AHB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2213216%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%20Sam%2C%20Currently%20I%20have%20it%20with%20IP%20operations%20working%2C%20but%20can%20NOR%20Flash%20QSPI%20supports%20flash%20write%20using%20AHB%3F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2207448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Flash%20write%20access%20with%20AHB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2207448%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F187080%22%20target%3D%22_blank%22%3E%40vanessa_dis%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EThe%20MIMXRT1050's%20FlexSPI%20controller%20fully%20supports%20read%2C%20write%2C%20and%20erase%20operations%20for%20QSPI%20NOR%20flash%3B%20using%20it%20on%20the%20EVK%20board%20simply%20requires%20hardware%20modifications%20to%20switch%20from%20the%20default%20HyperFlash%20chip.%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12108.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN12108.pdf%3C%2FA%3E%26nbsp%3BHow%20to%20Enable%20Boot%20from%20QSPI%20Flash%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2247801%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Flash%20write%20access%20with%20AHB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2247801%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%3CBR%20%2F%3E%3CBR%20%2F%3EI%20am%20refearing%20AHB%26nbsp%3B%3CEM%3EAdvanced%20High-performance%20Bus%3C%2FEM%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2248119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Flash%20write%20access%20with%20AHB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2248119%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F187080%22%20target%3D%22_blank%22%3E%40vanessa_dis%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EI%20got%20your%20point.%3C%2FP%3E%0A%3CP%20class%3D%22%22%3EYes%2C%20the%20FlexSPI%20controller%20on%20the%20i.MX%20RT1050%20and%20RT1060%20series%20fully%20supports%20write%20access%20to%20external%20QSPI%20NOR%20flash%20using%20the%20AHB%20bus.%20The%20capability%20is%20not%20exclusive%20to%20HyperFlash.%3C%2FP%3E%0A%3CP%20class%3D%22%22%3EThe%20FlexSPI%20controller%20is%20designed%20with%20a%20flexible%20architecture%20to%20support%20various%20external%20memory%20types%2C%20including%20Serial%20NOR%20Flash%20(which%20covers%20QSPI)%2C%20HyperFlash%2C%20and%20HyperRAM%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E.%20The%20controller%20provides%20memory-mapped%20read%20and%20write%20access%20through%20the%20AHB%20bus%20for%20any%20of%20these%20supported%20devices%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E.%3C%2FP%3E%0A%3CP%20class%3D%22%22%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fnxp%2Fapplication-notes%2FAN12239.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fnxp%2Fapplication-notes%2FAN12239.pdf%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sam_Gao_0-1764056082334.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sam_Gao_0-1764056082334.png%22%20style%3D%22width%3A%20341px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sam_Gao_0-1764056082334.png%22%20style%3D%22width%3A%20341px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F367097i3E3E20E0B0270F4D%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sam_Gao_0-1764056082334.png%22%20alt%3D%22Sam_Gao_0-1764056082334.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESam_Gao_0-1764056082334.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2246839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Flash%20write%20access%20with%20AHB%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2246839%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EDid%20you%20ask%20details%20for%20HAB%20(%3CSPAN%3EHigh%20Assurance%20Boot%3C%2FSPAN%3E)%3F%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fspsdk.readthedocs.io%2Fen%2Fstable%2Fimages%2Fhab.html%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fspsdk.readthedocs.io%2Fen%2Fstable%2Fimages%2Fhab.html%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CP%3EPlease%20refer%20to%20below%20AN%20with%20secure%20acess%20(Sorry%2C%20I%20can't%20send%20it%20directly%2C%20please%20apply%20for%20access%20or%20contact%20with%20local%20Sales%2FFAEs).%3C%2FP%3E%0A%3CP%3E%3CA%20id%3D%22relatedDocsClickPDF_3%22%20class%3D%22dtmcustomrulelink%22%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fwebapp%2Fsd%2Fcollateral%2F1707943504236748981110%3Fversion%3D1.0%22%20target%3D%22_blank%22%20rel%3D%22noopener%20nofollow%20noreferrer%22%20data-dtmaction%3D%22Documentation%20Section%20-%20Results%20Link%20Click%22%20data-dtmsubaction%3D%22AN12681%20How%20to%20use%20HAB%20secure%20boot%20in%20i.MX%20RT10xx%20-%20Secure%20Files%20-%20Application%20Note%20-%20English%22%20data-dtmconfidentialitylevel%3D%22Restricted%22%20data-dtmsecureapplist%3D%22DOCSTORE%22%20data-dtmsearchresulttitle%3D%22AN12681%20How%20to%20use%20HAB%20secure%20boot%20in%20i.MX%20RT10xx%22%20data-cl-id%3D%22548489468%22%3E%3CSPAN%3EAN12681%20How%20to%20use%20HAB%20secure%20boot%20in%20i.MX%20RT10xx%3C%2FSPAN%3E%3CSPAN%3E%26nbsp%3B%3C%2FSPAN%3E%3C%2FA%3E%3CSPAN%20class%3D%22code-id%22%3E%5BAN979510%5D%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22Sam_Gao_0-1763971556120.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22Sam_Gao_0-1763971556120.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F366944i963FD25E2094F714%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22Sam_Gao_0-1763971556120.png%22%20alt%3D%22Sam_Gao_0-1763971556120.png%22%20%2F%3E%3Cspan%20class%3D%22lia-inline-image-caption%22%20onclick%3D%22event.preventDefault()%3B%22%3ESam_Gao_0-1763971556120.png%3C%2Fspan%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
