FRDM-MCXE31B
FRDM-MCXE31B
330件の閲覧回数
Lokeshgowdas
I'm trying to debug/flash a FRDM-MCXE31B board and consistently hit a RAM initialization failure during the connect sequence, before any application code loads. I've ruled out wiring, cables, USB ports, jumpers, and probe firmware — details below.
Setup:
  • Board: FRDM-MCXE31B
  • M C U: MCXE31B
  • Tested with: M C U X Presso IDE v25.6 (Windows) and standalone Link-server v26.6.137 (Ubuntu Linux) — same failure on both
  • MCU-Link onboard probe firmware: updated to v3.172 (confirmed matching, no version mismatch reported)
  • Connect script: MCXE31x_connect.scp
What works:
  • SWD physical connection succeeds
  • Debug authentication/unlock succeeds ("application debug already enabled")
  • Chip identification succeeds — reads back correct part number:
SIUL2:MIDR1 @ 0x40290004 = 0x6BA02477
MCU Part Number is 0x000003A0
Where it fails — every attempt, both OSes:
... RAM init via eDMA: address=0x20400000 size=0x00028000
Error: Wire Ack Fault - target connected? [repeats ~46 times]
Error: RAM initialization failed (timeout)!
This leads to: Failed on connect: Ep(01). Target marked as not debuggable.
Context I found that may be relevant: I understand from the S32K3 reference manual (same architecture family) that ECC-protected RAM on these parts must be initialized via a 64-bit master write before any 32-bit access is valid after power-on-reset — so I assume this eDMA step in the connect script is performing that mandatory initialization automatically. It appears to be this automated step itself that's timing out, not a wiring/connection issue, since chip identification (steps before this) succeeds cleanly every time.
Question: Has anyone else hit this specific failure on FRDM-MCXE31B? Is there a known workaround, updated connect script, or a way to skip/adjust the automatic RAM-init step? Happy to provide full verbose logs (Link-server -l 5) if useful.
312件の閲覧回数
carlos_o
Hi @Lokeshgowdas
Thank you for your post!
Is this happening only in one project?
I see that your project is using Zephyr, could you please share which version are you using?
Please share the logs to review it.
%3CLINGO-SUB%20id%3D%22lingo-sub-2408846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-MCXE31B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3EFRDM-MCXE31B%E3%83%9C%E3%83%BC%E3%83%89%E3%81%AE%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%82%84%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E3%82%92%E8%A9%A6%E3%81%BF%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E6%8E%A5%E7%B6%9A%E3%82%B7%E3%83%BC%E3%82%B1%E3%83%B3%E3%82%B9%E4%B8%AD%E3%81%AB%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%B3%E3%83%BC%E3%83%89%E3%81%8C%E8%AA%AD%E3%81%BF%E8%BE%BC%E3%81%BE%E3%82%8C%E3%82%8B%E5%89%8D%E3%81%AB%E4%B8%80%E8%B2%AB%E3%81%97%E3%81%A6RAM%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%AE%E5%A4%B1%E6%95%97%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%E9%85%8D%E7%B7%9A%E3%80%81%E3%82%B1%E3%83%BC%E3%83%96%E3%83%AB%E3%80%81USB%E3%83%9D%E3%83%BC%E3%83%88%E3%80%81%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%91%E3%83%BC%E3%80%81%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%81%AE%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%81%AF%E3%80%81%E5%95%8F%E9%A1%8C%E3%81%AA%E3%81%84%E3%81%A8%E5%88%A4%E6%96%AD%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E8%A9%B3%E7%B4%B0%E3%81%AF%E4%B8%8B%E8%A8%98%E3%82%92%E3%81%94%E8%A6%A7%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%A8%AD%E5%AE%9A%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E5%9F%BA%E6%9D%BF%3A%20FRDM-MCXE31B%3C%2FLI%3E%3CLI%3EMCU%3A%20MCXE31B%3C%2FLI%3E%3CLI%3E%E3%83%86%E3%82%B9%E3%83%88%E5%AF%BE%E8%B1%A1%3AM%20C%20U%20X%20Presso%20IDE%20v25.6(Windows)%E3%81%8A%E3%82%88%E3%81%B3%E3%82%B9%E3%82%BF%E3%83%B3%E3%83%89%E3%82%A2%E3%83%AD%E3%83%B3%E3%81%AELink-server%20v26.6.137(Ubuntu%20Linux)%E2%80%94%20%E4%B8%A1%E6%96%B9%E3%81%A8%E3%82%82%E5%90%8C%E3%81%98%E6%95%85%E9%9A%9C%E3%81%A7%E3%81%99%3C%2FLI%3E%3CLI%3EMCU-Link%E3%82%AA%E3%83%B3%E3%83%9C%E3%83%BC%E3%83%89%E3%83%97%E3%83%AD%E3%83%BC%E3%83%96%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%3Av3.172%E3%81%AB%E6%9B%B4%E6%96%B0(%E3%83%9E%E3%83%83%E3%83%81%E3%83%B3%E3%82%B0%E7%A2%BA%E8%AA%8D%E3%80%81%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E4%B8%8D%E4%B8%80%E8%87%B4%E3%81%AA%E3%81%97)%3C%2FLI%3E%3CLI%3E%E6%8E%A5%E7%B6%9A%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%3A%20MCXE31x_connect.scp%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E%E5%8A%B9%E6%9E%9C%E7%9A%84%E3%81%AA%E6%96%B9%E6%B3%95%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3ESWD%E3%81%AE%E7%89%A9%E7%90%86%E7%9A%84%E6%8E%A5%E7%B6%9A%E3%81%8C%E6%88%90%E5%8A%9F%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FLI%3E%3CLI%3E%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E8%AA%8D%E8%A8%BC%2F%E3%82%A2%E3%83%B3%E3%83%AD%E3%83%83%E3%82%AF%E6%88%90%E5%8A%9F(%E3%80%8C%E3%82%A2%E3%83%97%E3%83%AA%E3%82%B1%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%8C%E3%81%99%E3%81%A7%E3%81%AB%E6%9C%89%E5%8A%B9%E3%80%8D)%E3%80%82%3C%2FLI%3E%3CLI%3E%E3%83%81%E3%83%83%E3%83%97%E8%AD%98%E5%88%A5%E6%88%90%E5%8A%9F%20%E2%80%94%20%E6%AD%A3%E3%81%97%E3%81%84%E9%83%A8%E5%93%81%E7%95%AA%E5%8F%B7%E3%82%92%E8%AA%AD%E3%81%BF%E8%BF%94%E3%81%97%E3%81%BE%E3%81%99%3A%3C%2FLI%3E%3C%2FUL%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CPRE%20translate%3D%22no%22%3ESIUL2%3AMIDR1%20%40%200x40290004%20%3D%200x6BA02477%0AMCU%20Part%20Number%20is%200x000003A0%3C%2FPRE%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%3CSTRONG%3E%E5%A4%B1%E6%95%97%E3%81%99%E3%82%8B%E7%82%B9%20%E2%80%95%20%E4%B8%A1%E6%96%B9%E3%81%AEOS%E3%81%A7%E3%80%81%E3%81%82%E3%82%89%E3%82%86%E3%82%8B%E8%A9%A6%E3%81%BF%E3%81%AB%E3%81%8A%E3%81%84%E3%81%A6%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CPRE%20translate%3D%22no%22%3E...%20RAM%20init%20via%20eDMA%3A%20address%3D0x20400000%20size%3D0x00028000%0AError%3A%20Wire%20Ack%20Fault%20-%20target%20connected%3F%20%5Brepeats%20~46%20times%5D%0AError%3A%20RAM%20initialization%20failed%20(timeout)!%3C%2FPRE%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E3%81%93%E3%82%8C%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%E6%AC%A1%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%8C%E7%99%BA%E7%94%9F%E3%81%97%E3%81%BE%E3%81%99%3A%20%E6%8E%A5%E7%B6%9A%E3%81%AB%E5%A4%B1%E6%95%97%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3A%20Ep(01)%E3%80%82%E5%AF%BE%E8%B1%A1%E3%81%8C%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E4%B8%8D%E5%8F%AF%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E9%96%A2%E9%80%A3%E3%81%8B%E3%82%82%E3%81%97%E3%82%8C%E3%81%AA%E3%81%84%E3%82%B3%E3%83%B3%E3%83%86%E3%82%AD%E3%82%B9%E3%83%88%E6%83%85%E5%A0%B1%3A%3C%2FSTRONG%3E%20S32K3%E3%81%AE%E3%83%AA%E3%83%95%E3%82%A1%E3%83%AC%E3%83%B3%E3%82%B9%E3%83%BB%E3%83%9E%E3%83%8B%E3%83%A5%E3%82%A2%E3%83%AB(%E5%90%8C%E3%81%98%E3%82%A2%E3%83%BC%E3%82%AD%E3%83%86%E3%82%AF%E3%83%81%E3%83%A3%E3%83%95%E3%82%A1%E3%83%9F%E3%83%AA)%E3%81%AB%E3%82%88%E3%82%8B%E3%81%A8%E3%80%81%E3%81%93%E3%82%8C%E3%82%89%E3%81%AE%E9%83%A8%E5%93%81%E3%81%AEECC%E4%BF%9D%E8%AD%B7%E6%B8%88%E3%81%BFRAM%E3%81%AF%E3%80%81%E9%9B%BB%E6%BA%90%E3%82%AA%E3%83%B3%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E5%BE%8C%E3%81%AB32%E3%83%93%E3%83%83%E3%83%88%E3%82%A2%E3%82%AF%E3%82%BB%E3%82%B9%E3%82%92%E6%9C%89%E5%8A%B9%E3%81%AB%E3%81%99%E3%82%8B%E5%89%8D%E3%81%AB64%E3%83%93%E3%83%83%E3%83%88%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%83%A9%E3%82%A4%E3%83%88%E3%81%A7%E5%88%9D%E6%9C%9F%E5%8C%96%E3%81%97%E3%81%AA%E3%81%91%E3%82%8C%E3%81%B0%E3%81%AA%E3%82%89%E3%81%AA%E3%81%84%E3%81%A8%E7%90%86%E8%A7%A3%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%97%E3%81%9F%E3%81%8C%E3%81%A3%E3%81%A6%E3%80%81connect%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%81%AEeDMA%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%81%8C%E3%81%9D%E3%81%AE%E5%BF%85%E9%A0%88%E3%81%AE%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%92%E8%87%AA%E5%8B%95%E7%9A%84%E3%81%AB%E8%A1%8C%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%A8%E6%8E%A8%E6%B8%AC%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%E3%81%93%E3%81%AE%E8%87%AA%E5%8B%95%E5%8C%96%E3%81%95%E3%82%8C%E3%81%9F%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E8%87%AA%E4%BD%93%E3%81%8C%E3%82%BF%E3%82%A4%E3%83%A0%E3%82%A2%E3%82%A6%E3%83%88%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%80%81%E9%85%8D%E7%B7%9A%E3%82%84%E6%8E%A5%E7%B6%9A%E3%81%AE%E5%95%8F%E9%A1%8C%E3%81%A7%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%E3%80%82%E3%83%81%E3%83%83%E3%83%97%E8%AD%98%E5%88%A5(%E3%81%93%E3%82%8C%E4%BB%A5%E5%89%8D%E3%81%AE%E3%82%B9%E3%83%86%E3%83%83%E3%83%97)%E3%81%AF%E6%AF%8E%E5%9B%9E%E3%81%8D%E3%82%8C%E3%81%84%E3%81%AB%E6%88%90%E5%8A%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%B3%AA%E5%95%8F%EF%BC%9A%3C%2FSTRONG%3E%20FRDM-MCXE31B%E3%81%A7%E3%81%93%E3%81%AE%E7%89%B9%E5%AE%9A%E3%81%AE%E3%82%A8%E3%83%A9%E3%83%BC%E3%81%AB%E9%81%AD%E9%81%87%E3%81%97%E3%81%9F%E6%96%B9%E3%81%AF%E4%BB%96%E3%81%AB%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E6%97%A2%E7%9F%A5%E3%81%AE%E5%9B%9E%E9%81%BF%E7%AD%96%E3%80%81%E6%9B%B4%E6%96%B0%E3%81%95%E3%82%8C%E3%81%9F%E6%8E%A5%E7%B6%9A%E3%82%B9%E3%82%AF%E3%83%AA%E3%83%97%E3%83%88%E3%80%81%E3%81%BE%E3%81%9F%E3%81%AF%E8%87%AA%E5%8B%95RAM%E5%88%9D%E6%9C%9F%E5%8C%96%E3%82%B9%E3%83%86%E3%83%83%E3%83%97%E3%82%92%E3%82%B9%E3%82%AD%E3%83%83%E3%83%97%2F%E8%AA%BF%E6%95%B4%E3%81%99%E3%82%8B%E6%96%B9%E6%B3%95%E3%81%AF%E3%81%82%E3%82%8A%E3%81%BE%E3%81%99%E3%81%8B%EF%BC%9F%E5%BF%85%E8%A6%81%E3%81%A7%E3%81%82%E3%82%8C%E3%81%B0%E3%80%81%E8%A9%B3%E7%B4%B0%E3%81%AA%E3%83%AD%E3%82%B0%EF%BC%88Link-server%20-l%205%EF%BC%89%E3%82%92%E6%8F%90%E4%BE%9B%E3%81%84%E3%81%9F%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2408846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E9%80%9A%E4%BF%A1%E3%83%BB%E5%88%B6%E5%BE%A1(I3C%20%7CI2C%20%7CSPI%20%7CFlexCAN%20%7C%E3%82%A4%E3%83%BC%E3%82%B5%E3%83%8D%E3%83%83%E3%83%88%20%7CFlexIO)%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MCXE31B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F265994%22%20target%3D%22_blank%22%3E%40Lokeshgowdas%E3%81%95%E3%82%93%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%8A%95%E7%A8%BF%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%81%94%E3%81%96%E3%81%84%E3%81%BE%E3%81%99%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E3%81%93%E3%82%8C%E3%81%AF%E7%89%B9%E5%AE%9A%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%A0%E3%81%91%E3%81%A7%E7%99%BA%E7%94%9F%E3%81%97%E3%81%A6%E3%81%84%E3%82%8B%E7%8F%BE%E8%B1%A1%E3%81%A7%E3%81%99%E3%81%8B%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E3%81%82%E3%81%AA%E3%81%9F%E3%81%AE%E3%83%97%E3%83%AD%E3%82%B8%E3%82%A7%E3%82%AF%E3%83%88%E3%81%AFZephyr%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%82%88%E3%81%86%E3%81%A7%E3%81%99%E3%81%8C%E3%80%81%E3%81%A9%E3%81%AE%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%E3%82%92%E4%BD%BF%E3%81%A3%E3%81%A6%E3%81%84%E3%82%8B%E3%81%AE%E3%81%8B%E6%95%99%E3%81%88%E3%81%A6%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FP%3E%0A%3CP%3E%E3%83%AD%E3%82%B0%E3%82%92%E5%85%B1%E6%9C%89%E3%81%97%E3%81%A6%E7%A2%BA%E8%AA%8D%E3%81%95%E3%81%9B%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
