FRDM-MCXE31B
FRDM-MCXE31B
225 次查看
Lokeshgowdas
I'm trying to debug/flash a FRDM-MCXE31B board and consistently hit a RAM initialization failure during the connect sequence, before any application code loads. I've ruled out wiring, cables, USB ports, jumpers, and probe firmware — details below.
Setup:
  • Board: FRDM-MCXE31B
  • M C U: MCXE31B
  • Tested with: M C U X Presso IDE v25.6 (Windows) and standalone Link-server v26.6.137 (Ubuntu Linux) — same failure on both
  • MCU-Link onboard probe firmware: updated to v3.172 (confirmed matching, no version mismatch reported)
  • Connect script: MCXE31x_connect.scp
What works:
  • SWD physical connection succeeds
  • Debug authentication/unlock succeeds ("application debug already enabled")
  • Chip identification succeeds — reads back correct part number:
SIUL2:MIDR1 @ 0x40290004 = 0x6BA02477
MCU Part Number is 0x000003A0
Where it fails — every attempt, both OSes:
... RAM init via eDMA: address=0x20400000 size=0x00028000
Error: Wire Ack Fault - target connected? [repeats ~46 times]
Error: RAM initialization failed (timeout)!
This leads to: Failed on connect: Ep(01). Target marked as not debuggable.
Context I found that may be relevant: I understand from the S32K3 reference manual (same architecture family) that ECC-protected RAM on these parts must be initialized via a 64-bit master write before any 32-bit access is valid after power-on-reset — so I assume this eDMA step in the connect script is performing that mandatory initialization automatically. It appears to be this automated step itself that's timing out, not a wiring/connection issue, since chip identification (steps before this) succeeds cleanly every time.
Question: Has anyone else hit this specific failure on FRDM-MCXE31B? Is there a known workaround, updated connect script, or a way to skip/adjust the automatic RAM-init step? Happy to provide full verbose logs (Link-server -l 5) if useful.
207 次查看
carlos_o
Hi @Lokeshgowdas
Thank you for your post!
Is this happening only in one project?
I see that your project is using Zephyr, could you please share which version are you using?
Please share the logs to review it.
%3CLINGO-SUB%20id%3D%22lingo-sub-2408846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EFRDM-MCXE31B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E5%B0%9D%E8%AF%95%E8%B0%83%E8%AF%95%2F%E7%83%A7%E5%BD%95%20FRDM-MCXE31B%20%E6%9D%BF%EF%BC%8C%E4%BD%86%E5%9C%A8%E8%BF%9E%E6%8E%A5%E5%BA%8F%E5%88%97%E6%9C%9F%E9%97%B4%EF%BC%8C%E5%9C%A8%E4%BB%BB%E4%BD%95%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E4%BB%A3%E7%A0%81%E5%8A%A0%E8%BD%BD%E4%B9%8B%E5%89%8D%EF%BC%8C%E6%80%BB%E6%98%AF%E9%81%87%E5%88%B0%20RAM%20%E5%88%9D%E5%A7%8B%E5%8C%96%E5%A4%B1%E8%B4%A5%E7%9A%84%E6%83%85%E5%86%B5%E3%80%82%E6%88%91%E5%B7%B2%E7%BB%8F%E6%8E%92%E9%99%A4%E4%BA%86%E7%BA%BF%E8%B7%AF%E3%80%81%E7%94%B5%E7%BC%86%E3%80%81USB%20%E7%AB%AF%E5%8F%A3%E3%80%81%E8%B7%B3%E7%BA%BF%E5%92%8C%E6%8E%A2%E9%92%88%E5%9B%BA%E4%BB%B6%E7%9A%84%E9%97%AE%E9%A2%98%E2%80%94%E2%80%94%E8%AF%A6%E6%83%85%E5%A6%82%E4%B8%8B%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E8%AE%BE%E7%BD%AE%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%E7%94%B5%E8%B7%AF%E6%9D%BF%EF%BC%9AFRDM-MCXE31B%3C%2FLI%3E%3CLI%3EM%20C%20U%EF%BC%9AMCXE31B%3C%2FLI%3E%3CLI%3E%E6%B5%8B%E8%AF%95%E7%8E%AF%E5%A2%83%EF%BC%9AM%20C%20U%20X%20Presso%20IDE%20v25.6%EF%BC%88Windows%EF%BC%89%E5%92%8C%E7%8B%AC%E7%AB%8B%E7%BB%84%E7%BD%91%20(SA)%20Link-server%20v26.6.137%EF%BC%88Ubuntu%20Linux%EF%BC%89%E2%80%94%E2%80%94%E4%B8%A4%E7%A7%8D%E7%B3%BB%E7%BB%9F%E9%83%BD%E5%87%BA%E7%8E%B0%E5%90%8C%E6%A0%B7%E7%9A%84%E6%95%85%E9%9A%9C%3C%2FLI%3E%3CLI%3EMCU-Link%20%E6%9D%BF%E8%BD%BD%E6%8E%A2%E9%92%88%E5%9B%BA%E4%BB%B6%EF%BC%9A%E5%B7%B2%E6%9B%B4%E6%96%B0%E8%87%B3%20v3.172%EF%BC%88%E5%B7%B2%E7%A1%AE%E8%AE%A4%E5%8C%B9%E9%85%8D%EF%BC%8C%E6%9C%AA%E6%8A%A5%E5%91%8A%E7%89%88%E6%9C%AC%E4%B8%8D%E5%8C%B9%E9%85%8D%EF%BC%89%3C%2FLI%3E%3CLI%3E%E8%BF%9E%E6%8E%A5%E8%84%9A%E6%9C%AC%EF%BC%9AMCXE31x_connect.scp%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSTRONG%3E%E6%9C%89%E6%95%88%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CUL%3E%3CLI%3ESWD%E7%89%A9%E7%90%86%E8%BF%9E%E6%8E%A5%E6%88%90%E5%8A%9F%E3%80%82%3C%2FLI%3E%3CLI%3E%E8%B0%83%E8%AF%95%E8%BA%AB%E4%BB%BD%E9%AA%8C%E8%AF%81%2F%E8%A7%A3%E9%94%81%E6%88%90%E5%8A%9F%EF%BC%88%E2%80%9C%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E8%B0%83%E8%AF%95%E5%B7%B2%E5%90%AF%E7%94%A8%E2%80%9D%EF%BC%89%3C%2FLI%3E%3CLI%3E%E8%8A%AF%E7%89%87%E8%AF%86%E5%88%AB%E6%88%90%E5%8A%9F%E2%80%94%E2%80%94%E8%AF%BB%E5%8F%96%E5%88%B0%E6%AD%A3%E7%A1%AE%E7%9A%84%E9%9B%B6%E4%BB%B6%E7%BC%96%E5%8F%B7%EF%BC%9A%3C%2FLI%3E%3C%2FUL%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CPRE%20translate%3D%22no%22%3ESIUL2%3AMIDR1%20%40%200x40290004%20%3D%200x6BA02477%0AMCU%20Part%20Number%20is%200x000003A0%3C%2FPRE%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%3CSTRONG%3E%E5%A4%B1%E8%B4%A5%E4%B9%8B%E5%A4%84%E2%80%94%E2%80%94%E6%AF%8F%E6%AC%A1%E5%B0%9D%E8%AF%95%EF%BC%8C%E4%B8%A4%E4%B8%AA%E6%93%8D%E4%BD%9C%E7%B3%BB%E7%BB%9F%E9%83%BD%E5%A4%B1%E8%B4%A5%EF%BC%9A%3C%2FSTRONG%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%3CDIV%3E%26nbsp%3B%3C%2FDIV%3E%3C%2FDIV%3E%3CDIV%3E%3CPRE%20translate%3D%22no%22%3E...%20RAM%20init%20via%20eDMA%3A%20address%3D0x20400000%20size%3D0x00028000%0AError%3A%20Wire%20Ack%20Fault%20-%20target%20connected%3F%20%5Brepeats%20~46%20times%5D%0AError%3A%20RAM%20initialization%20failed%20(timeout)!%3C%2FPRE%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E8%BF%99%E5%AF%BC%E8%87%B4%EF%BC%9A%E8%BF%9E%E6%8E%A5%E5%A4%B1%E8%B4%A5%EF%BC%9AEp(01)%E3%80%82%E7%9B%AE%E6%A0%87%E8%A2%AB%E6%A0%87%E8%AE%B0%E4%B8%BA%E4%B8%8D%E5%8F%AF%E8%B0%83%E8%AF%95%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E6%88%91%E5%8F%91%E7%8E%B0%E4%BB%A5%E4%B8%8B%E6%83%85%E5%86%B5%E5%8F%AF%E8%83%BD%E4%B8%8E%E6%AD%A4%E7%9B%B8%E5%85%B3%EF%BC%9A%3C%2FSTRONG%3E%E6%88%91%E4%BB%8E%20S32K3%20%E5%8F%82%E8%80%83%E6%89%8B%E5%86%8C%EF%BC%88%E5%90%8C%E4%B8%80%E6%9E%B6%E6%9E%84%E7%B3%BB%E5%88%97%EF%BC%89%E4%BA%86%E8%A7%A3%E5%88%B0%EF%BC%8C%E8%BF%99%E4%BA%9B%E9%83%A8%E4%BB%B6%E4%B8%8A%E7%9A%84%20ECC%20%E4%BF%9D%E6%8A%A4%20RAM%20%E5%BF%85%E9%A1%BB%E5%85%88%E9%80%9A%E8%BF%87%2064%20%E4%BD%8D%E4%B8%BB%E5%86%99%E5%85%A5%E8%BF%9B%E8%A1%8C%E5%88%9D%E5%A7%8B%E5%8C%96%EF%BC%8C%E7%84%B6%E5%90%8E%E6%89%8D%E8%83%BD%E5%9C%A8%E4%B8%8A%E7%94%B5%E5%A4%8D%E4%BD%8D%E5%90%8E%E8%BF%9B%E8%A1%8C%E4%BB%BB%E4%BD%95%2032%20%E4%BD%8D%E8%AE%BF%E9%97%AE%E2%80%94%E2%80%94%E5%9B%A0%E6%AD%A4%E6%88%91%E5%81%87%E8%AE%BE%E8%BF%9E%E6%8E%A5%E8%84%9A%E6%9C%AC%E4%B8%AD%E7%9A%84%20eDMA%20%E6%AD%A5%E9%AA%A4%E4%BC%9A%E8%87%AA%E5%8A%A8%E6%89%A7%E8%A1%8C%E6%AD%A4%E5%BC%BA%E5%88%B6%E5%88%9D%E5%A7%8B%E5%8C%96%E3%80%82%E4%BC%BC%E4%B9%8E%E6%98%AF%E8%BF%99%E4%B8%AA%E8%87%AA%E5%8A%A8%E5%8C%96%E6%AD%A5%E9%AA%A4%E6%9C%AC%E8%BA%AB%E8%B6%85%E6%97%B6%E4%BA%86%EF%BC%8C%E8%80%8C%E4%B8%8D%E6%98%AF%E7%BA%BF%E8%B7%AF%2F%E8%BF%9E%E6%8E%A5%E9%97%AE%E9%A2%98%EF%BC%8C%E5%9B%A0%E4%B8%BA%E8%8A%AF%E7%89%87%E8%AF%86%E5%88%AB%EF%BC%88%E4%B9%8B%E5%89%8D%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%89%E6%AF%8F%E6%AC%A1%E9%83%BD%E8%83%BD%E9%A1%BA%E5%88%A9%E5%AE%8C%E6%88%90%E3%80%82%3C%2FP%3E%3CP%3E%3CSTRONG%3E%E9%97%AE%EF%BC%9A%3C%2FSTRONG%3E%E8%BF%98%E6%9C%89%E5%85%B6%E4%BB%96%E4%BA%BA%E9%81%87%E5%88%B0%E8%BF%87%20FRDM-MCXE31B%20%E7%9A%84%E8%BF%99%E7%A7%8D%E7%89%B9%E5%AE%9A%E6%95%85%E9%9A%9C%E5%90%97%EF%BC%9F%E6%98%AF%E5%90%A6%E6%9C%89%E5%B7%B2%E7%9F%A5%E7%9A%84%E8%A7%A3%E5%86%B3%E6%96%B9%E6%B3%95%E3%80%81%E6%9B%B4%E6%96%B0%E7%9A%84%E8%BF%9E%E6%8E%A5%E8%84%9A%E6%9C%AC%EF%BC%8C%E6%88%96%E8%80%85%E5%8F%AF%E4%BB%A5%E8%B7%B3%E8%BF%87%2F%E8%B0%83%E6%95%B4%E8%87%AA%E5%8A%A8%20RAM%20%E5%88%9D%E5%A7%8B%E5%8C%96%E6%AD%A5%E9%AA%A4%E7%9A%84%E6%96%B9%E6%B3%95%EF%BC%9F%E5%A6%82%E6%9E%9C%E9%9C%80%E8%A6%81%EF%BC%8C%E6%88%91%E5%BE%88%E4%B9%90%E6%84%8F%E6%8F%90%E4%BE%9B%E5%AE%8C%E6%95%B4%E7%9A%84%E8%AF%A6%E7%BB%86%E6%97%A5%E5%BF%97%EF%BC%88Link-server%20-l%205%EF%BC%89%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2408846%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3E%E9%80%9A%E4%BF%A1%E4%B8%8E%E6%8E%A7%E5%88%B6%EF%BC%88I3C%20%7C%20I2C%20%7C%20SPI%20%7C%20FlexCAN%20%7C%20%E4%BB%A5%E5%A4%AA%E7%BD%91%20%7C%20FlexIO%EF%BC%89%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2408991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20FRDM-MCXE31B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2408991%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F265994%22%20target%3D%22_blank%22%3E%40Lokeshgowdas%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E5%B8%96%E5%AD%90%EF%BC%81%3C%2FP%3E%0A%3CP%3E%E8%BF%99%E7%A7%8D%E6%83%85%E5%86%B5%E5%8F%AA%E5%8F%91%E7%94%9F%E5%9C%A8%E4%B8%80%E4%B8%AA%E9%A1%B9%E7%9B%AE%E4%B8%AD%E5%90%97%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E6%88%91%E7%9C%8B%E5%88%B0%E6%82%A8%E7%9A%84%E9%A1%B9%E7%9B%AE%E4%BD%BF%E7%94%A8%E4%BA%86%20Zephyr%EF%BC%8C%E8%AF%B7%E9%97%AE%E6%82%A8%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%EF%BC%9F%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E6%8F%90%E4%BE%9B%E6%97%A5%E5%BF%97%E6%96%87%E4%BB%B6%E4%BB%A5%E4%BE%BF%E6%88%91%E4%BB%AC%E8%BF%9B%E8%A1%8C%E6%9F%A5%E7%9C%8B%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
