Dual Core Debugging RT1186
Mastrmat
Hi, I'm trying to debug the M7 core of an RT1186 using a SEGGER J-Link. However, I'm having a lot of trouble attaching correctly after starting the M33 core. Could you help me with the json.launch configuration? I've attached what I currently have.
      "type": "mcuxpresso-debug",
      "name": "Dbg (M7) with JLink",
      "request": "launch",
      "cwd": "${workspaceFolder}",
      "executable": {
        "elf": ""
      "probeSerialNumber": "59101260",
      "isAttach": true,
      "skipBuildBeforeDebug": false,
      "gdbInitCommands": [
        "set remotetimeout 600",
        "set debug-file-directory",
        "set non-stop off"
      "gdbServerConfigs": {
        "linkserver": {},
        "segger": {
          "device": "MIMXRT1186XXX8_M7",
          "interface": "SWD",
          "gdbServerPath": "c:\\Program Files\\SEGGER\\JLink_V930\\JLinkGDBServerCL.exe",
          "gdbServerArgs": [
            "-select",
            "usb=59101260",
            "-device",
            "-if",
            "swd",
            "-speed",
            "4000",
            "-port",
            "2393",
            "-swoport",
            "2394",
            "-scriptfile",
            "c:\\NXP\\mcuxsdk\\mcuxsdk\\examples\\_boards\\frdmimxrt1186\\jlinkscript\\frdmimxrt1186_cm7.jlinkscript",
            "-single run"
          "scriptfile": "c:\\NXP\\mcuxsdk\\mcuxsdk\\examples\\_boards\\frdmimxrt1186\\jlinkscript\\frdmimxrt1186_cm7.jlinkscript",
          "speed": "4000",
          "gdbServerLaunchTimeout": 5000,
          "gdbServerExtraArgs": [],
          "gdbPort": 2393,
          "swoPort": 2394,
          "resetAfterLoad": true
        "pemicro": {}
      "showDevDebugOutput": "raw",
      "probeType": "SEGGER",
      "toolchainPath": "C:\\Users\\mastrmat\\.mcuxpressotools\\arm-gnu-toolchain-14.2.rel1-mingw-w64-x86_64-arm-none-eabi",
      "svdPath": "c:\\NXP\\MIMXRT1186_cm7.xml",
      "preLaunchCommands": [],
      "postLaunchCommands": [],
      "executableLoadTypePriority": "auto",
      "domain": "multicore_manager_secondary_core",
      "stopAtSymbol": "main",
      "extraLoadFiles": [
        "c:\\repo\\sidel_tmp\\flexspi_nor_debug\\multicore_manager_secondary_core\\multicore_manager_secondary_core_cm7.elf"
      "extraSymbolFiles": []
mayliu1
Hi @Mastrmat ,
Thank you so much for your interest in our products and for using our community.
Regarding your question, I think that for the M7 attach session, the main change is to place the CM7 ELF in executable.elf instead of extraLoadFiles. executable.elf provides the program and debug information for the session, whereas extraLoadFiles is intended for additional files to be loaded and does not load their debug symbols.
Please try the simplified configuration below and let me know the result.
Due to NXP policy, I cannot share the source code. Instead, I have attached a key figure for reference.
Please start the M33 debug session first and allow it to start the M7 core. Then attach to the M7 using this configuration. For this setup, the secondary-core debug session should use attach mode. I have removed the duplicate server arguments and other optional settings for the initial test.
If the issue persists, please send the first error reported in the J-Link GDB Server log.
Wish it helps you
Best Regards
May Liu
%3CLINGO-SUB%20id%3D%22lingo-sub-2422554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDual%20Core%20Debugging%20RT1186%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2422554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%2C%20I'm%20trying%20to%20debug%20the%20M7%20core%20of%20an%20RT1186%20using%20a%20SEGGER%20J-Link.%20However%2C%20I'm%20having%20a%20lot%20of%20trouble%20attaching%20correctly%20after%20starting%20the%20M33%20core.%20Could%20you%20help%20me%20with%20the%20json.launch%20configuration%3F%20I've%20attached%20what%20I%20currently%20have.%3C%2FP%3E%3CBR%20%2F%3E%3CDIV%3E%3CDIV%3E%3CSPAN%3E%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22type%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22mcuxpresso-debug%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22name%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22Dbg%20(M7)%20with%20JLink%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22request%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22launch%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22cwd%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22%24%7BworkspaceFolder%7D%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22executable%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22elf%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22probeSerialNumber%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%2259101260%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22isAttach%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3Etrue%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22skipBuildBeforeDebug%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3Efalse%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22gdbInitCommands%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%5B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22set%20remotetimeout%20600%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22set%20debug-file-directory%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22set%20non-stop%20off%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%5D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22gdbServerConfigs%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22linkserver%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%7B%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22segger%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%7B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22device%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22MIMXRT1186XXX8_M7%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22interface%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22SWD%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22gdbServerPath%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22c%3A%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3EProgram%20Files%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3ESEGGER%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3EJLink_V930%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3EJLinkGDBServerCL.exe%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22gdbServerArgs%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%5B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22-select%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22usb%3D59101260%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22-device%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22MIMXRT1186XXX8_M7%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22-if%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22swd%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22-speed%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%224000%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22-port%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%222393%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22-swoport%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%222394%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22-scriptfile%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22c%3A%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3ENXP%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3Emcuxsdk%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3Emcuxsdk%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3Eexamples%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3E_boards%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3Efrdmimxrt1186%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3Ejlinkscript%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3Efrdmimxrt1186_cm7.jlinkscript%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22-single%20run%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%5D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22scriptfile%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22c%3A%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3ENXP%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3Emcuxsdk%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3Emcuxsdk%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3Eexamples%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3E_boards%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3Efrdmimxrt1186%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3Ejlinkscript%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3Efrdmimxrt1186_cm7.jlinkscript%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22speed%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%224000%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22gdbServerLaunchTimeout%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E5000%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22gdbServerExtraArgs%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%5B%5D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22gdbPort%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E2393%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22swoPort%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E2394%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22resetAfterLoad%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3Etrue%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22pemicro%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%7B%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%7D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22showDevDebugOutput%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22raw%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22probeType%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22SEGGER%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22toolchainPath%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22C%3A%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3EUsers%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3Emastrmat%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3E.mcuxpressotools%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3Earm-gnu-toolchain-14.2.rel1-mingw-w64-x86_64-arm-none-eabi%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22svdPath%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22c%3A%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3ENXP%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3EMIMXRT1186_cm7.xml%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22preLaunchCommands%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%5B%5D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22postLaunchCommands%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%5B%5D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22executableLoadTypePriority%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22auto%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22domain%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22multicore_manager_secondary_core%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22stopAtSymbol%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%3C%2FSPAN%3E%3CSPAN%3E%22main%22%3C%2FSPAN%3E%3CSPAN%3E%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22extraLoadFiles%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%5B%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22c%3A%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3Erepo%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3Esidel_tmp%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3Eflexspi_nor_debug%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3Emulticore_manager_secondary_core%3C%2FSPAN%3E%3CSPAN%3E%5C%5C%3C%2FSPAN%3E%3CSPAN%3Emulticore_manager_secondary_core_cm7.elf%22%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%5D%2C%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%26nbsp%3B%20%3C%2FSPAN%3E%3CSPAN%3E%22extraSymbolFiles%22%3C%2FSPAN%3E%3CSPAN%3E%3A%20%5B%5D%3C%2FSPAN%3E%3C%2FDIV%3E%3CDIV%3E%3CSPAN%3E%26nbsp%3B%20%26nbsp%3B%20%7D%3C%2FSPAN%3E%3C%2FDIV%3E%3C%2FDIV%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2422554%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EBoot%20ROM%7CBooting%20%7C%20Flash%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2422903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Dual%20Core%20Debugging%20RT1186%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2422903%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F267524%22%20target%3D%22_blank%22%3E%40Mastrmat%3C%2FA%3E%26nbsp%3B%EF%BC%8C%3C%2FP%3E%0A%3CP%3EThank%20you%20so%20much%20for%20your%20interest%20in%20our%20products%20and%20for%20using%20our%20community.%3C%2FP%3E%0A%3CP%3ERegarding%20your%20question%2C%20I%20think%20that%26nbsp%3Bfor%26nbsp%3Bthe%20M7%20attach%20session%2C%20the%20main%20change%20is%20to%20place%20the%20CM7%20ELF%20in%20executable.elf%20instead%20of%20extraLoadFiles.%20executable.elf%20provides%20the%20program%20and%20debug%20information%20for%20the%20session%2C%20whereas%20extraLoadFiles%20is%20intended%20for%20additional%20files%20to%20be%20loaded%20and%20does%20not%20load%20their%20debug%20symbols.%3C%2FP%3E%0A%3CP%20data-pm-slice%3D%221%201%20%5B%5D%22%3EPlease%20try%20the%20simplified%20configuration%20below%20and%20let%20me%20know%20the%20result.%3C%2FP%3E%0A%3CP%3EDue%20to%20NXP%20policy%2C%20I%20cannot%20share%20the%20source%20code.%20Instead%2C%20I%20have%20attached%20a%20key%20figure%20for%20reference.%3C%2FP%3E%0A%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22mayliu1_0-1792656632293.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22mayliu1_0-1792656632293.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F398347i6631E81AA9364754%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22mayliu1_0-1792656632293.png%22%20alt%3D%22mayliu1_0-1792656632293.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%20data-pm-slice%3D%221%201%20%5B%5D%22%3EPlease%20start%20the%20M33%20debug%20session%20first%20and%20allow%20it%20to%20start%20the%20M7%20core.%20Then%20attach%20to%20the%20M7%20using%20this%20configuration.%20For%20this%20setup%2C%20the%20secondary-core%20debug%20session%20should%20use%20attach%20mode.%20I%20have%20removed%20the%20duplicate%20server%20arguments%20and%20other%20optional%20settings%20for%20the%20initial%20test.%3C%2FP%3E%0A%3CP%3EIf%20the%20issue%20persists%2C%20please%20send%20the%20first%20error%20reported%20in%20the%20J-Link%20GDB%20Server%20log.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EWish%20it%20helps%20you%3C%2FP%3E%0A%3CP%3EBest%20Regards%3C%2FP%3E%0A%3CP%3EMay%20Liu%3C%2FP%3E%3C%2FLINGO-BODY%3E
