DFI Error. Please check DDR configuration. Error while flashing imx8ulp evk.
MadKEm
I am trying to flash the board on Linux using the command : "sudo uuu -b emmc imx-boot-imx8ulp-lpddr4-evk-sd.bin-flash_singleboot" the load bar gets to 100% but stucks and on the serial port of the first core it gives an error mentioned on the topic.
Manuel_Salas
Hello @MadKEm
Could you pelase share what BSP are you trying to flash?
Also, if possible share the part number you are using.
Finally, the UUU version.
Salas.
%3CLINGO-SUB%20id%3D%22lingo-sub-2149274%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EDFI%20Error.%20Please%20check%20DDR%20configuration.%20Error%20while%20flashing%20imx8ulp%20evk.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2149274%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EI%20am%20trying%20to%20flash%20the%20board%20on%20Linux%20using%20the%20command%20%3A%20%22sudo%20uuu%20-b%20emmc%20imx-boot-imx8ulp-lpddr4-evk-sd.bin-flash_singleboot%22%20the%20load%20bar%20gets%20to%20100%25%20but%20stucks%20and%20on%20the%20serial%20port%20of%20the%20first%20core%20it%20gives%20an%20error%20mentioned%20on%20the%20topic.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2149274%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EBoot%20ROM%7CBooting%20%7C%20Flash%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3ECore%20and%20Memory%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EDevelopment%20Board%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EUSB%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2153843%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20DFI%20Error.%20Please%20check%20DDR%20configuration.%20Error%20while%20flashing%20imx8ulp%20evk.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2153843%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253610%22%20target%3D%22_blank%22%3E%40MadKEm%3C%2FA%3E%26nbsp%3B%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3ECould%20you%20pelase%20share%20what%20BSP%20are%20you%20trying%20to%20flash%3F%3C%2FP%3E%0A%3CP%3EAlso%2C%20if%20possible%20share%20the%20part%20number%20you%20are%20using.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EFinally%2C%20the%20UUU%20version.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBest%20regards%2C%3C%2FP%3E%0A%3CP%3ESalas.%3C%2FP%3E%3C%2FLINGO-BODY%3E
