Bootloader reports "Image in the secondary slot is not valid" in MCXE31B
923件の閲覧回数
blessyvinolin
I am working on the NXP MCXE31B and using the MCUboot mcuboot_opensource example as the bootloader.
My goal is to implement OTA firmware updates by flashing the secondary slot via SPI using LPSPI in slave mode.
OTA Flow
  1. The secondary firmware image is generated using the imgtool utility.
  2. The image is transmitted from the SPI master in 256-byte chunks.
  3. On the receiver side, the firmware receives the SPI data and writes it into the secondary slot using mflash_drv_page_program().
  4. After the transfer is completed, the bootloader API boot_set_pending() is called to mark the image for swap.
Bootloader Behavior
After resetting the board, the bootloader prints the following log:
Bootloader Version 2.2.0
Image index: 0, Swap type: test
Image is invalid, erasing...
Image in the secondary slot is not valid!
Bootloader chainload address offset: 0x500000
Reset_Handler address offset: 0x500400
Jumping to the image
Image Header Verification
To verify the received image, I printed the MCUboot image header on the receiver side:
--- MCUboot Image Header Check ---
Magic:   0x96F3B83D (Expected: 0x96F3B83D)
Version: 1.0.5+0
SPI Transfer Log
During SPI transfer, the firmware receives and writes the image successfully. The progress log shows the entire secondary slot being written:
Progress: 16384 / 786432 bytes
Progress: 786432 / 786432 bytes
Data transfer finished (786432 bytes).
After writing the data, the trailer is written and the image is marked as pending:
writing magic; fa_id=1 off=0xbfff0 (0x6bfff0)
writing swap_info; fa_id=1 off=0xbffd8 (0x6bffd8), swap_type=0x2 image_num=0x0
Success! Image marked. Resetting to trigger swap...
Flash Layout
Primary slot   : 0x500000
Secondary slot : 0x600000
SPI Transfer Configuration
#define TRANSFER_SIZE 256
Issue
Even though:
  • The image header magic is correct
  • The image is generated using imgtool
  • The entire secondary slot is written successfully
  • The image is marked pending
The bootloader still reports that the secondary image is invalid.
Possible Causes Considered
I am currently investigating the following possibilities:
  • Incorrect image signing parameters
  • Mismatch between image size and slot size
  • Missing padding (--pad) during imgtool signing
  • Alignment issues with flash writes
  • Flash programming constraints when writing via mflash_drv_page_program()
  • Corruption of the MCUboot trailer area
Request
I would appreciate any suggestions or guidance on why MCUboot might reject the secondary image in this scenario and what additional checks I should perform to debug this issue.
タグ(3)
782件の閲覧回数
Hello @blessyvinolin
For using the mcuboot_opensource example, I highly recommend that you use MCUXpresso Secure Provisioning too.
Follow the steps described in
Secure Provisioning Tool User Guide 25.12 -> 7.5 MCUboot workflow .
Thank you.
Alice
%3CLINGO-SUB%20id%3D%22lingo-sub-2331508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMCXE31B%E3%81%A7%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%8C%E3%80%8C%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%AE%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%99%E3%80%8D%E3%81%A8%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%BE%E3%81%99%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2331508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E7%A7%81%E3%81%AF%3C%2FSPAN%3E%3CSTRONG%3E%20NXP%20MCXE31B%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%8A%E3%82%8A%3C%2FSTRONG%3E%3CSPAN%3E%20%E3%80%81%20%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%3C%2FSPAN%3E%3CSTRONG%3E%20MCUboot%E3%81%AE%3C%2FSTRONG%3E%3CSTRONG%3E%20mcuboot_opensource%3C%2FSTRONG%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3CSPAN%3E%E3%82%B5%E3%83%B3%E3%83%97%E3%83%AB%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E7%A7%81%E3%81%AE%E7%9B%AE%E6%A8%99%E3%81%AF%E3%80%81%3C%2FSPAN%3E%3CSTRONG%3E%E3%82%B9%E3%83%AC%E3%83%BC%E3%83%96%E3%83%A2%E3%83%BC%E3%83%89%E3%81%A7LPSPI%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6SPI%E7%B5%8C%E7%94%B1%E3%81%A7%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%AB%3C%2FSTRONG%3E%3CSPAN%3E%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%82%80%E3%81%93%E3%81%A8%E3%81%AB%E3%82%88%E3%82%8A%E3%80%81%3C%2FSPAN%3E%20%3CSTRONG%3EOTA%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A2%E3%83%83%E3%83%97%E3%83%87%E3%83%BC%E3%83%88%E3%82%92%3C%2FSTRONG%3E%E5%AE%9F%E8%A3%85%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%A7%E3%81%99%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId-2029116703%22%20id%3D%22toc-hId-2029146519%22%20id%3D%22toc-hId-2029146519%22%3E%3CSTRONG%3EOTA%E3%83%95%E3%83%AD%E3%83%BC%3C%2FSTRONG%3E%3C%2FH3%3E%3COL%3E%3CLI%3E%3CSPAN%3E%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AF%E3%80%81%3C%2FSPAN%3E%20%3CSTRONG%3Eimgtool%3C%2FSTRONG%3E%3CSPAN%3E%E3%83%A6%E3%83%BC%E3%83%86%E3%82%A3%E3%83%AA%E3%83%86%E3%82%A3%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E7%94%BB%E5%83%8F%E3%81%AFSPI%E3%83%9E%E3%82%B9%E3%82%BF%E3%83%BC%E3%81%8B%E3%82%89%3C%2FSPAN%3E%3CSTRONG%3E256%E3%83%90%E3%82%A4%E3%83%88%E3%81%AE%E3%83%81%E3%83%A3%E3%83%B3%E3%82%AF%E5%8D%98%E4%BD%8D%3C%2FSTRONG%3E%E3%81%A7%E9%80%81%E4%BF%A1%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E3%83%AC%E3%82%B7%E3%83%BC%E3%83%90%E5%81%B4%E3%81%A7%E3%81%AF%E3%80%81%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%8CSPI%E3%83%87%E3%83%BC%E3%82%BF%E3%82%92%E5%8F%97%E4%BF%A1%E3%81%97%E3%80%81%20mflash_drv_page_program()%3C%2FSPAN%3E%3CSPAN%3E%20%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%3C%2FSPAN%3E%3CSTRONG%3E%20%3C%2FSTRONG%3E%3CSPAN%3E%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%20%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%99%3C%2FSPAN%3E%3CSPAN%3E%20%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E8%BB%A2%E9%80%81%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%99%E3%82%8B%E3%81%A8%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BCAPI%E3%81%AE%3C%2FSPAN%3E%3CSPAN%3Eboot_set_pending()%3C%2FSPAN%3E%3CSPAN%3E%E3%81%8C%E5%91%BC%E3%81%B3%E5%87%BA%E3%81%95%E3%82%8C%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E3%82%B9%E3%83%AF%E3%83%83%E3%83%97%E5%AF%BE%E8%B1%A1%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FOL%3E%3CH3%20id%3D%22toc-hId-221662240%22%20id%3D%22toc-hId-221692056%22%20id%3D%22toc-hId-221692056%22%3E%3CSTRONG%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AE%E5%8B%95%E4%BD%9C%3C%2FSTRONG%3E%3C%2FH3%3E%3CP%3E%3CSPAN%3E%E3%83%9C%E3%83%BC%E3%83%89%E3%82%92%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AF%E6%AC%A1%E3%81%AE%E3%83%AD%E3%82%B0%E3%82%92%E5%87%BA%E5%8A%9B%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%20%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%202.2.0%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E7%94%BB%E5%83%8F%E3%82%A4%E3%83%B3%E3%83%87%E3%83%83%E3%82%AF%E3%82%B9%3A%200%E3%80%81%E3%82%B9%E3%83%AF%E3%83%83%E3%83%97%E3%82%BF%E3%82%A4%E3%83%97%3A%20%E3%83%86%E3%82%B9%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E7%94%BB%E5%83%8F%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%99%E3%80%82%E5%89%8A%E9%99%A4%E3%81%97%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%81%AE%E7%94%BB%E5%83%8F%E3%81%AF%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%99%EF%BC%81%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%83%81%E3%82%A7%E3%83%BC%E3%83%B3%E3%83%AD%E3%83%BC%E3%83%89%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3A%200x500000%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EReset_Handler%20%E3%82%A2%E3%83%89%E3%83%AC%E3%82%B9%E3%82%AA%E3%83%95%E3%82%BB%E3%83%83%E3%83%88%3A%200x500400%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E7%94%BB%E5%83%8F%E3%81%B8%E3%82%B8%E3%83%A3%E3%83%B3%E3%83%97%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CH3%20id%3D%22toc-hId--1585792223%22%20id%3D%22toc-hId--1585762407%22%20id%3D%22toc-hId--1585762407%22%3E%3CSTRONG%3E%E7%94%BB%E5%83%8F%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%AE%E6%A4%9C%E8%A8%BC%3C%2FSTRONG%3E%3C%2FH3%3E%3CP%3E%3CSPAN%3E%E5%8F%97%E4%BF%A1%E3%81%97%E3%81%9F%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E7%A2%BA%E8%AA%8D%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%80%81%E3%83%AC%E3%82%B7%E3%83%BC%E3%83%90%E3%81%A7MCUboot%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%AE%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%82%92%E5%8D%B0%E5%88%B7%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E---%20MCUboot%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%20---%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%83%9E%E3%82%B8%E3%83%83%E3%82%AF%E3%83%8A%E3%83%B3%E3%83%90%E3%83%BC%3A%200x96F3B83D%20(%E6%9C%9F%E5%BE%85%E5%80%A4%3A%200x96F3B83D)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%B5%E3%82%A4%E3%82%BA%EF%BC%9A20436%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%83%90%E3%83%BC%E3%82%B8%E3%83%A7%E3%83%B3%3A%201.0.5%2B0%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CH3%20id%3D%22toc-hId-901720610%22%20id%3D%22toc-hId-901750426%22%20id%3D%22toc-hId-901750426%22%3E%3CSTRONG%3ESPI%E8%BB%A2%E9%80%81%E3%83%AD%E3%82%B0%3C%2FSTRONG%3E%3C%2FH3%3E%3CP%3E%3CSPAN%3ESPI%E8%BB%A2%E9%80%81%E4%B8%AD%E3%80%81%E3%83%95%E3%82%A1%E3%83%BC%E3%83%A0%E3%82%A6%E3%82%A7%E3%82%A2%E3%81%AF%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%AD%A3%E5%B8%B8%E3%81%AB%E5%8F%97%E4%BF%A1%E3%81%97%E3%80%81%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E9%80%B2%E8%A1%8C%E7%8A%B6%E6%B3%81%E3%83%AD%E3%82%B0%E3%81%AB%E3%81%AF%E3%80%81%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E5%85%A8%E4%BD%93%E3%81%8C%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E3%81%93%E3%81%A8%E3%81%8C%E7%A4%BA%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%80%B2%E8%A1%8C%E7%8A%B6%E6%B3%81%3A%2016384%20%2F%20786432%20%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E...%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E9%80%B2%E8%A1%8C%E9%87%8F%3A786432%20%2F%20786432%E3%83%90%E3%82%A4%E3%83%88%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%83%87%E3%83%BC%E3%82%BF%E8%BB%A2%E9%80%81%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%EF%BC%88786432%E3%83%90%E3%82%A4%E3%83%88%EF%BC%89%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E3%83%87%E3%83%BC%E3%82%BF%E3%81%AE%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E5%BE%8C%E3%80%81%E4%BA%88%E5%91%8A%E7%B7%A8%E3%81%8C%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BE%E3%82%8C%E3%80%81%E7%94%BB%E5%83%8F%E3%81%AF%E4%BF%9D%E7%95%99%E4%B8%AD%E3%81%A8%E3%81%97%E3%81%A6%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%BE%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E9%AD%94%E6%B3%95%3B%20fa_id%3D1%20off%3D0xbfff0%20(0x6bfff0)%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3Eswap_info%20%E3%82%92%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E4%B8%AD%E3%80%82fa_id%3D1%20off%3D0xbffd8%20(0x6bffd8)%E3%80%81swap_type%3D0x2%20image_num%3D0x0%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%3E%E6%88%90%E5%8A%9F%EF%BC%81%E7%94%BB%E5%83%8F%E3%81%8C%E3%83%9E%E3%83%BC%E3%82%AF%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%E3%80%82%E3%83%AA%E3%82%BB%E3%83%83%E3%83%88%E3%81%97%E3%81%A6%E3%82%B9%E3%83%AF%E3%83%83%E3%83%97%E3%82%92%E3%83%88%E3%83%AA%E3%82%AC%E3%83%BC%E3%81%97%E3%81%BE%E3%81%99...%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CH3%20id%3D%22toc-hId--905733853%22%20id%3D%22toc-hId--905704037%22%20id%3D%22toc-hId--905704037%22%3E%3CSTRONG%3EFlash%E3%83%AC%E3%82%A4%E3%82%A2%E3%82%A6%E3%83%88%3C%2FSTRONG%3E%3C%2FH3%3E%3CP%3E%3CSPAN%3E%E3%83%97%E3%83%A9%E3%82%A4%E3%83%9E%E3%83%AA%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%EF%BC%9A0x500000%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3E%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%BC%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%EF%BC%9A0x600000%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CH3%20id%3D%22toc-hId-1581778980%22%20id%3D%22toc-hId-1581808796%22%20id%3D%22toc-hId-1581808796%22%3E%3CSTRONG%3ESPI%E8%BB%A2%E9%80%81%E6%A7%8B%E6%88%90%3C%2FSTRONG%3E%3C%2FH3%3E%3CP%3E%3CSPAN%3E%23define%20TRANSFER_SIZE%20256%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CH3%20id%3D%22toc-hId--225675483%22%20id%3D%22toc-hId--225645667%22%20id%3D%22toc-hId--225645667%22%3E%3CSTRONG%3E%E5%95%8F%E9%A1%8C%3C%2FSTRONG%3E%3C%2FH3%3E%3CP%3E%3CSPAN%3E%E3%81%9D%E3%82%8C%E3%81%A7%E3%82%82%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSPAN%3E%20%3C%2FSPAN%3E%3CSTRONG%3E%E7%94%BB%E5%83%8F%E3%83%98%E3%83%83%E3%83%80%E3%83%BC%E3%81%AE%E9%AD%94%E6%B3%95%E3%81%AF%E6%AD%A3%E3%81%97%E3%81%84%E3%81%A7%E3%81%99%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E7%94%BB%E5%83%8F%E3%81%AF%3C%2FSPAN%3E%3CSTRONG%3Eimgtool%3C%2FSTRONG%3E%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%97%E3%81%A6%E7%94%9F%E6%88%90%E3%81%95%E3%82%8C%E3%81%BE%E3%81%97%E3%81%9F%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%83%BC%3C%2FSPAN%3E%3CSTRONG%3E%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E5%85%A8%E4%BD%93%E3%81%AB%E6%AD%A3%E5%B8%B8%E3%81%AB%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%81%8C%E5%AE%8C%E4%BA%86%E3%81%97%E3%81%BE%E3%81%97%E3%81%9F%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%E7%94%BB%E5%83%8F%E3%81%AF%3C%2FSPAN%3E%3CSTRONG%3E%E4%BF%9D%E7%95%99%E4%B8%AD%E3%81%A8%E3%83%9E%E3%83%BC%E3%82%AF%3C%2FSTRONG%3E%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FLI%3E%3C%2FUL%3E%3CP%3E%3CSPAN%3E%E3%83%96%E3%83%BC%E3%83%88%E3%83%AD%E3%83%BC%E3%83%80%E3%83%BC%E3%81%AF%E4%BE%9D%E7%84%B6%E3%81%A8%E3%81%97%E3%81%A6%3C%2FSPAN%3E%3CSTRONG%3E%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%81%8C%E7%84%A1%E5%8A%B9%E3%81%A7%E3%81%82%E3%82%8B%3C%2FSTRONG%3E%E3%81%A8%E5%A0%B1%E5%91%8A%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3CSPAN%3E%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CH3%20id%3D%22toc-hId--2033129946%22%20id%3D%22toc-hId--2033100130%22%20id%3D%22toc-hId--2033100130%22%3E%3CSTRONG%3E%E8%80%83%E3%81%88%E3%82%89%E3%82%8C%E3%82%8B%E5%8E%9F%E5%9B%A0%3C%2FSTRONG%3E%3C%2FH3%3E%3CP%3E%3CSPAN%3E%E7%8F%BE%E5%9C%A8%E3%80%81%E4%BB%A5%E4%B8%8B%E3%81%AE%E5%8F%AF%E8%83%BD%E6%80%A7%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E8%AA%BF%E6%9F%BB%E4%B8%AD%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3CUL%3E%3CLI%3E%3CSTRONG%3E%E7%94%BB%E5%83%8F%E7%BD%B2%E5%90%8D%E3%83%91%E3%83%A9%E3%83%A1%E3%83%BC%E3%82%BF%E3%81%8C%3C%2FSTRONG%3E%3CSPAN%3E%20%E6%AD%A3%E3%81%97%E3%81%8F%E3%81%82%E3%82%8A%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%E7%94%BB%E5%83%8F%E3%82%B5%E3%82%A4%E3%82%BA%E3%81%A8%E3%82%B9%E3%83%AD%E3%83%83%E3%83%88%E3%82%B5%E3%82%A4%E3%82%BA%3C%2FSTRONG%3E%3CSPAN%3E%20%E3%81%8C%E4%B8%80%E8%87%B4%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%9B%E3%82%93%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3E%3C%2FSPAN%3E%3CSTRONG%3Eimgtool%E7%BD%B2%E5%90%8D%E4%B8%AD%E3%81%AB%20%E3%83%91%E3%83%87%E3%82%A3%E3%83%B3%E3%82%B0%EF%BC%88%3C%2FSTRONG%3E%3CSTRONG%3E%20--pad%3C%2FSTRONG%3E%3CSTRONG%3E%20%EF%BC%89%20%E3%81%8C%E6%AC%A0%E8%90%BD%E3%81%97%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%3C%2FSTRONG%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3E%3C%2FSTRONG%3E%3CSPAN%3E%E3%83%95%E3%83%A9%E3%83%83%E3%82%B7%E3%83%A5%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E6%99%82%E3%81%AE%20%E3%82%A2%E3%83%A9%E3%82%A4%E3%83%A1%E3%83%B3%E3%83%88%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSPAN%3Emflash_drv_page_program()%3C%2FSPAN%3E%3CSPAN%3E%E3%82%92%E4%BB%8B%E3%81%97%E3%81%A6%E6%9B%B8%E3%81%8D%E8%BE%BC%E3%81%BF%E3%82%92%E8%A1%8C%E3%81%86%E9%9A%9B%E3%81%AE%20Flash%20%E3%83%97%E3%83%AD%E3%82%B0%E3%83%A9%E3%83%9F%E3%83%B3%E3%82%B0%E3%81%AE%E5%88%B6%E7%B4%84%3C%2FSPAN%3E%3C%2FLI%3E%3CLI%3E%3CSTRONG%3EMCUboot%E3%83%88%E3%83%AC%E3%83%BC%E3%83%A9%E3%83%BC%E3%82%A8%E3%83%AA%E3%82%A2%3C%2FSTRONG%3E%3CSPAN%3E%20%E3%81%AE%E7%A0%B4%E6%90%8D%3C%2FSPAN%3E%3C%2FLI%3E%3C%2FUL%3E%3CH3%20id%3D%22toc-hId-454382887%22%20id%3D%22toc-hId-454412703%22%20id%3D%22toc-hId-454412703%22%3E%3CSTRONG%3E%E8%A6%81%E6%B1%82%3C%2FSTRONG%3E%3C%2FH3%3E%3CP%3E%3CSTRONG%3E%E3%81%93%E3%81%AE%E7%8A%B6%E6%B3%81%E3%81%A7MCUboot%E3%81%8C%E3%82%BB%E3%82%AB%E3%83%B3%E3%83%80%E3%83%AA%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%8B%92%E5%90%A6%E3%81%99%E3%82%8B%E7%90%86%E7%94%B1%3C%2FSTRONG%3E%3CSPAN%3E%20%E3%80%81%E3%81%8A%E3%82%88%E3%81%B3%E3%81%93%E3%81%AE%E5%95%8F%E9%A1%8C%E3%82%92%E3%83%87%E3%83%90%E3%83%83%E3%82%B0%E3%81%99%E3%82%8B%E3%81%9F%E3%82%81%E3%81%AB%E8%BF%BD%E5%8A%A0%E3%81%A7%E3%81%A9%E3%81%AE%E3%82%88%E3%81%86%E3%81%AA%E3%83%81%E3%82%A7%E3%83%83%E3%82%AF%E3%82%92%E8%A1%8C%E3%81%86%E3%81%B9%E3%81%8D%E3%81%8B%3C%2FSPAN%3E%3CSPAN%3E%20%E3%81%AB%E3%81%A4%E3%81%84%E3%81%A6%E3%80%81%E3%81%94%E6%8F%90%E6%A1%88%E3%82%84%E3%81%94%E5%8A%A9%E8%A8%80%E3%82%92%E3%81%84%E3%81%9F%E3%81%A0%E3%81%91%E3%82%8C%E3%81%B0%E5%B9%B8%E3%81%84%E3%81%A7%E3%81%99%20%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-2331508%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CLINGO-LABEL%3EFRDM%E3%83%88%E3%83%AC%E3%83%BC%E3%83%8B%E3%83%B3%E3%82%B0%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2334014%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Bootloader%20reports%20%22Image%20in%20the%20secondary%20slot%20is%20not%20valid%22%20in%20MCXE31B%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2334014%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%E3%80%81%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F259760%22%20target%3D%22_blank%22%3E%40blessyvinolin%20%E3%81%95%E3%82%93%E3%80%82%3C%2FA%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CDIV%3E%3CCODE%20translate%3D%22no%22%3Emcuboot_opensource%3C%2FCODE%3E%E4%BE%8B%E3%82%92%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%81%AF%E3%80%81MCUXpresso%20Secure%20Provisioning%E3%82%82%E4%BD%B5%E7%94%A8%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%82%92%E5%BC%B7%E3%81%8F%E3%81%8A%E5%8B%A7%E3%82%81%E3%81%97%E3%81%BE%E3%81%99%E3%80%82%3C%2FDIV%3E%0A%3CDIV%3E%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Fmcuxpresso-software-and-tools-%2Fmcuxpresso-secure-provisioning-tool%3AMCUXPRESSO-SECURE-PROVISIONING%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3Ehttps%3A%2F%2Fwww.nxp.com%2Fdesign%2Fdesign-center%2Fsoftware%2Fdevelopment-software%2Fmcuxpresso-software-and-tools-%2Fmcuxpresso-secure-provisioning-tool%3AMCUXPRESSO-SECURE-PROVISIONING%3C%2FA%3E%3C%2FDIV%3E%0A%3CDIV%3E%E8%A8%98%E8%BC%89%E3%81%95%E3%82%8C%E3%81%A6%E3%81%84%E3%82%8B%E6%89%8B%E9%A0%86%E3%81%AB%E5%BE%93%E3%81%A3%E3%81%A6%E3%81%8F%E3%81%A0%E3%81%95%E3%81%84%3C%2FDIV%3E%0A%3CP%3E%E3%82%BB%E3%82%AD%E3%83%A5%E3%82%A2%E3%83%97%E3%83%AD%E3%83%93%E3%82%B8%E3%83%A7%E3%83%8B%E3%83%B3%E3%82%B0%E3%83%84%E3%83%BC%E3%83%AB%E3%83%A6%E3%83%BC%E3%82%B6%E3%83%BC%E3%82%AC%E3%82%A4%E3%83%89%2025.12%20-%26gt%3B%207.5%20MCUboot%E3%83%AF%E3%83%BC%E3%82%AF%E3%83%95%E3%83%AD%E3%83%BC%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%E3%81%82%E3%82%8A%E3%81%8C%E3%81%A8%E3%81%86%E3%80%82%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EBR%3C%2FP%3E%0A%3CP%3E%E3%82%A2%E3%83%AA%E3%82%B9%3C%2FP%3E%3C%2FLINGO-BODY%3E
