RPMsg example question
1,214 次查看
dougbaker
I am using a IMX8 with a A53 and a M7.  The M7 code is built with VSCode and MCUXpresso environment.  The M7 runs Free RTOS and I have the M7 running example projects.  I have the example “multicoe_examples/rpmsg-lite-str-echo-rtos-remote”  running but I have some questions about it.
On a fresh boot, it generally works when I can sent messages from the A53 to the M7.  If I restart jut the M7 CPU, the messages do not The messages only work after a full reset including the A53.  When rebooting justthe m7 core, the M7 fails on the following call: rpmsg_lite_is_link_up(my_rpmsg);
Is there a example or recommended way to implement 2 endpoints between the A53 and the M7?  How should two endpoints between the two cores be implemented?
Am I asking this question in the right forum?
Doug
5 回复数
1,136 次查看
dougbaker
echo start > /sys/class/remoteproc/remoteproc0/state^C
1,137 次查看
dougbaker
1,147 次查看
Zhiming_Liu
Hi @dougbaker
How did you load the M7? Using Linux remoteproc sysfs or U-Boot commands?
Zhiming
1,102 次查看
dougbaker
Using Linux remoteproc.
1,101 次查看
dougbaker
In order to better isolate the messaging problems I am seeing, I went back to the original example code, confirmed that it worked correctly, and then began making small modifications. After those minor changes, I started seeing the same type of failures again.
The modification I made was:
#define USE_MEMORY_TEST (0)
#if USE_MEMORY_TEST
#define DUMMYBUF_SIZE 1024 // failed = 1024
static char dummy_buf[DUMMYBUF_SIZE];
#endif
I put this at the top of the void app_task(void *param)
#if USE_MEMORY_TEST
dummy_buf[DUMMYBUF_SIZE-1] = 1;
PRINTF("\r\nAdded DummyBuf size = %d...%d\r\n",
DUMMYBUF_SIZE, dummy_buf[DUMMYBUF_SIZE-1]);
#endif
After adding this code, I started seeing problems when stopping and restarting the M7 application.
With the code above enabled, messaging works correctly after a full reboot/power-up. However, if I stop and then restart the M7 application, the messaging fails and does not recover unless I perform a full system reset/reboot (either with the hardware reset switch or using shutdown -r now).
To stop/start the M7 CPU, I am using:
• echo stop > /sys/class/remoteproc/remoteproc0/state
• echo start > /sys/class/remoteproc/remoteproc0/state
Doug
%3CLINGO-SUB%20id%3D%22lingo-sub-2377616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERPMsg%20%E7%A4%BA%E4%BE%8B%E9%97%AE%E9%A2%98%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2377616%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E4%BD%BF%E7%94%A8%E7%9A%84%E6%98%AF%20IMX8%20%E4%B8%8E%20A53%20%E5%92%8C%20M7%E3%80%82%20M7%20%E4%BB%A3%E7%A0%81%E4%BD%BF%E7%94%A8%20VSCode%20%E5%92%8C%20MCUXpresso%20%E7%8E%AF%E5%A2%83%E6%9E%84%E5%BB%BA%E3%80%82M7%20%E8%BF%90%E8%A1%8C%E8%87%AA%E7%94%B1%20RTOS%EF%BC%8C%E6%88%91%E8%AE%A9%20M7%20%E8%BF%90%E8%A1%8C%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%E3%80%82%20%E6%88%91%E6%AD%A3%E5%9C%A8%E8%BF%90%E8%A1%8C%E7%A4%BA%E4%BE%8B%20%22multicoe_examples%2Frpmsg-lite-str-echo-rtos-remote%22%EF%BC%8C%E4%BD%86%E6%88%91%E6%9C%89%E4%B8%80%E4%BA%9B%E7%96%91%E9%97%AE%E3%80%82%3C%2FP%3E%3CP%3E%E5%9C%A8%E5%85%A8%E6%96%B0%E5%90%AF%E5%8A%A8%E6%97%B6%EF%BC%8C%E5%AE%83%E9%80%9A%E5%B8%B8%E5%9C%A8%E6%88%91%E5%8F%AF%E4%BB%A5%E4%BB%8E%20A53%20%E5%90%91%20M7%20%E5%8F%91%E9%80%81%E6%B6%88%E6%81%AF%E6%97%B6%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E5%A6%82%E6%9E%9C%E6%88%91%E5%8F%AA%E9%87%8D%E5%90%AFM7%20CPU%EF%BC%8C%E5%88%99%E6%B6%88%E6%81%AF%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E6%B6%88%E6%81%AF%E5%8F%AA%E6%9C%89%E5%9C%A8%E5%8C%85%E6%8B%ACA53%E5%9C%A8%E5%86%85%E7%9A%84%E5%AE%8C%E5%85%A8RESET%E5%90%8E%E6%89%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%E4%BB%85%E9%87%8D%E5%90%AF%20m7%20%E5%86%85%E6%A0%B8%E6%97%B6%EF%BC%8CM7%20%E5%9C%A8%E8%B0%83%E7%94%A8%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%E6%97%B6%E5%A4%B1%E8%B4%A5%EF%BC%9A%3CSTRONG%3Erpmsg_lite_is_link_up%3C%2FSTRONG%3E(my_rpmsg)%EF%BC%9B%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%9C%89%E6%B2%A1%E6%9C%89%E5%9C%A8%20A53%20%E5%92%8C%20M7%20%E4%B9%8B%E9%97%B4%E5%AE%9E%E7%8E%B0%E4%B8%A4%E4%B8%AA%E7%AB%AF%E7%82%B9%E7%9A%84%E7%A4%BA%E4%BE%8B%E6%88%96%E6%8E%A8%E8%8D%90%E6%96%B9%E6%B3%95%EF%BC%9F%20%20%E5%A6%82%E4%BD%95%E5%9C%A8%E4%B8%A4%E4%B8%AA%E5%86%85%E6%A0%B8%E4%B9%8B%E9%97%B4%E5%AE%9E%E7%8E%B0%E4%B8%A4%E4%B8%AA%E7%AB%AF%E7%82%B9%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E5%9C%A8%E6%AD%A3%E7%A1%AE%E7%9A%84%E8%AE%BA%E5%9D%9B%E4%B8%8A%E6%8F%90%E9%97%AE%E4%BA%86%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E9%81%93%E6%A0%BC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2378359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RPMsg%20example%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378359%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3Eecho%20start%26gt%3B%20%2Fsys%2Fclass%2Fremoteproc%2Fremoteproc0%2Fstate%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2377995%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RPMsg%20example%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2377995%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F136710%22%20target%3D%22_blank%22%3E%40%E8%B1%86%E8%B4%9D%E5%84%BF%3C%2FA%3E%20%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%A0%E6%98%AF%E5%A6%82%E4%BD%95%E8%A3%85%E8%BD%BD%20M7%20%E7%9A%84%EF%BC%9F%E4%BD%BF%E7%94%A8%20Linux%20remoteproc%20sysfs%20%E8%BF%98%E6%98%AF%20U-Boot%20%E5%91%BD%E4%BB%A4%EF%BC%9F%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%87%B4%E6%95%AC%EF%BC%8C%3CBR%20%2F%3EZhiming%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2378364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RPMsg%20example%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2378364%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eecho%20start%26gt%3B%20%2Fsys%2Fclass%2Fremoteproc%2Fremoteproc0%2Fstate%5EC%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2379164%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20RPMsg%20example%20question%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2379164%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E4%B8%BA%E4%BA%86%E6%9B%B4%E5%A5%BD%E5%9C%B0%E9%9A%94%E7%A6%BB%E6%88%91%E6%89%80%E7%9C%8B%E5%88%B0%E7%9A%84%E6%B6%88%E6%81%AF%E4%BC%A0%E9%80%92%E9%97%AE%E9%A2%98%EF%BC%8C%E6%88%91%E5%9B%9E%E5%88%B0%E4%BA%86%E6%9C%80%E5%88%9D%E7%9A%84%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%EF%BC%8C%E7%A1%AE%E8%AE%A4%E5%85%B6%E5%B7%A5%E4%BD%9C%E6%AD%A3%E5%B8%B8%EF%BC%8C%E7%84%B6%E5%90%8E%E5%BC%80%E5%A7%8B%E5%81%9A%E4%B8%80%E4%BA%9B%E5%B0%8F%E7%9A%84%E4%BF%AE%E6%94%B9%E3%80%82%E8%BF%99%E4%BA%9B%E5%B0%8F%E6%94%B9%E5%8A%A8%E4%B9%8B%E5%90%8E%EF%BC%8C%E6%88%91%E5%8F%88%E5%BC%80%E5%A7%8B%E7%9C%8B%E5%88%B0%E5%90%8C%E6%A0%B7%E7%B1%BB%E5%9E%8B%E7%9A%84%E6%95%85%E9%9A%9C%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E5%81%9A%E7%9A%84%E4%BF%AE%E6%94%B9%E6%98%AF%3CBR%20%2F%3E%3CBR%20%2F%3E%23define%20USE_MEMORY_TEST%20(0)%3CBR%20%2F%3E%23if%20USE_MEMORY_TEST%3CBR%20%2F%3E%23define%20DUMMYBUF_SIZE%201024%20%2F%2F%20failed%20%3D%201024%3CBR%20%2F%3Estatic%20char%20dummy_buf%5BDUMMYBUF_SIZE%5D%EF%BC%9B%3CBR%20%2F%3E%23endif%3CBR%20%2F%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%88%91%E6%8A%8A%E5%AE%83%E6%94%BE%E5%9C%A8%20void%20app_task(void%20*param)%20%E7%9A%84%E9%A1%B6%E9%83%A8%3CBR%20%2F%3E%3CBR%20%2F%3E%23if%20USE_MEMORY_TEST%3CBR%20%2F%3Edummy_buf%5BDUMMYBUF_SIZE-1%5D%20%3D%201%EF%BC%9B%3CBR%20%2F%3EPRINTF(%22%5Cr%5CnAdded%20DummyBuf%20size%20%3D%25d...%25d%5Cr%5Cn%22%2C%3CBR%20%2F%3EDUMMYBUF_SIZE%2C%20dummy_buf%5BDUMMYBUF_SIZE-1%5D)%3B%3CBR%20%2F%3E%23endif%3CBR%20%2F%3E%3CBR%20%2F%3E%E6%B7%BB%E5%8A%A0%E8%BF%99%E6%AE%B5%E4%BB%A3%E7%A0%81%E5%90%8E%EF%BC%8C%E6%88%91%E5%BC%80%E5%A7%8B%E5%9C%A8%E5%81%9C%E6%AD%A2%E5%92%8C%E9%87%8D%E5%90%AF%20M7%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%E6%97%B6%E5%8F%91%E7%8E%B0%E9%97%AE%E9%A2%98%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E5%90%AF%E7%94%A8%E4%B8%8A%E8%BF%B0%E4%BB%A3%E7%A0%81%E5%90%8E%EF%BC%8C%E5%9C%A8%E5%AE%8C%E5%85%A8%E9%87%8D%E5%90%AF%2F%E4%B8%8A%E7%94%B5%E5%90%8E%EF%BC%8C%E4%BF%A1%E6%81%AF%E4%BC%A0%E9%80%81%E5%B0%B1%E8%83%BD%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E3%80%82%E4%BD%86%E6%98%AF%EF%BC%8C%E5%A6%82%E6%9E%9C%E6%88%91%E5%81%9C%E6%AD%A2%E7%84%B6%E5%90%8E%E9%87%8D%E6%96%B0%E5%90%AF%E5%8A%A8%20M7%20%E5%BA%94%E7%94%A8%E7%A8%8B%E5%BA%8F%EF%BC%8C%E5%88%99%E6%B6%88%E6%81%AF%E4%BC%9A%E5%A4%B1%E8%B4%A5%E5%B9%B6%E4%B8%94%E6%97%A0%E6%B3%95%E6%81%A2%E5%A4%8D%EF%BC%8C%E9%99%A4%E9%9D%9E%E6%88%91%E6%89%A7%E8%A1%8C%E4%BA%86%E5%AE%8C%E6%95%B4%E7%9A%84%E7%B3%BB%E7%BB%9F%20RESET%2F%E9%87%8D%E5%90%AF%EF%BC%88%E4%BD%BF%E7%94%A8%E7%A1%AC%E4%BB%B6%20RESET%20%E5%BC%80%E5%85%B3%E6%88%96%E7%8E%B0%E5%9C%A8%E4%BD%BF%E7%94%A8%20shutdown-r%EF%BC%89%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%A6%81%E5%81%9C%E6%AD%A2%2F%E5%90%AF%E5%8A%A8%20M7%20CPU%EF%BC%8C%E6%88%91%E4%BD%BF%E7%94%A8%EF%BC%9A%3CBR%20%2F%3E-%20echo%20stop%26gt%3B%20%2Fsys%2Fclass%2Fremoteproc%2Fremoteproc0%2Fstate%3CBR%20%2F%3E-%20echo%20start%26gt%3B%20%2Fsys%2Fclass%2Fremoteproc%2Fremoteproc0%2Fstate%3CBR%20%2F%3E%3CBR%20%2F%3EDoug%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
