Maxium array entries fetch in VSCODE extension
jslota13245
Hello Everyone
I would like to ask about a feature from IDE which i don't know how to enable in VS-code.
The problem I have, is when there is a large array, if I hover over it with cursor, then the debugger will try to fetch every element of this array. Unsurprisingly it freezes VS-Code as debugger is reading all of that data, usually a restart of VS-Code is required.
IDE handles it nicely by showing you only 1000 entries, and provides a way to extend that view if needed.
Is there a way to enable this feature in the NXP for VS-Code extension?
Jakub
EdwinHz
Hi @jslota13245,
Currently, we do not provide a way to enable a similar behavior on MCUXpresso for VSCode. But this is mainly because it's a limitation on VSCode, rather than on the MCUXpresso extension: Debugger Freezes When Inspecting Large Array · Issue #13897 · microsoft/vscode-cpptools
If this is a limiting issue for your application development, I recommend going into the VSCode settings and disabling hover evaluation altogether, and instead rely on watch expressions or the Memory Inspector to view the data.
BR,
Edwin.
EdwinHz
Hi @jslota13245,
BR,
Edwin.
jslota13245
Thank you for the response!
%3CLINGO-SUB%20id%3D%22lingo-sub-2355260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EMaxium%20array%20entries%20fetch%20in%20VSCODE%20extension%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2355260%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHello%20Everyone%20%3CLI-EMOJI%20id%3D%22lia_slightly-smiling-face%22%20title%3D%22%3Aslightly_smiling_face%3A%22%3E%3C%2FLI-EMOJI%3E%3CBR%20%2F%3E%3CBR%20%2F%3EI%20would%20like%20to%20ask%20about%20a%20feature%20from%20IDE%20which%20i%20don't%20know%20how%20to%20enable%20in%20VS-code.%3CBR%20%2F%3E%3CBR%20%2F%3EThe%20problem%20I%20have%2C%20is%20when%20there%20is%20a%20large%20array%2C%20if%20I%20hover%20over%20it%20with%20cursor%2C%20then%20the%20debugger%20will%20try%20to%20fetch%20every%20element%20of%20this%20array.%20Unsurprisingly%20it%20freezes%20VS-Code%20as%20debugger%20is%20reading%20all%20of%20that%20data%2C%20usually%20a%20restart%20of%20VS-Code%20is%20required.%3CBR%20%2F%3E%3CBR%20%2F%3EIDE%20handles%20it%20nicely%20by%20showing%20you%20only%201000%20entries%2C%20and%20provides%20a%20way%20to%20extend%20that%20view%20if%20needed.%3CBR%20%2F%3E%3CBR%20%2F%3EIs%20there%20a%20way%20to%20enable%20this%20feature%20in%20the%20NXP%20for%20VS-Code%20extension%3F%3CBR%20%2F%3E%3CBR%20%2F%3EBest%20Regards%2C%3CBR%20%2F%3EJakub%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2356075%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Maxium%20array%20entries%20fetch%20in%20VSCODE%20extension%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356075%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EThank%20you%20for%20the%20response!%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2356014%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Maxium%20array%20entries%20fetch%20in%20VSCODE%20extension%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2356014%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F251438%22%20target%3D%22_blank%22%3E%40jslota13245%3C%2FA%3E%2C%3C%2FP%3E%0A%3CP%3ECurrently%2C%20we%20do%20not%20provide%20a%20way%20to%20enable%20a%20similar%20behavior%20on%20MCUXpresso%20for%20VSCode.%20But%20this%20is%20mainly%20because%20it's%20a%20limitation%20on%20VSCode%2C%20rather%20than%20on%20the%20MCUXpresso%20extension%3A%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fgithub.com%2Fmicrosoft%2Fvscode-cpptools%2Fissues%2F13897%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EDebugger%20Freezes%20When%20Inspecting%20Large%20Array%20%C2%B7%20Issue%20%2313897%20%C2%B7%20microsoft%2Fvscode-cpptools%3C%2FA%3E%3C%2FP%3E%0A%3CP%3EIf%20this%20is%20a%20limiting%20issue%20for%20your%20application%20development%2C%20I%20recommend%20going%20into%20the%20VSCode%20settings%20and%20disabling%20hover%20evaluation%20altogether%2C%20and%20instead%20rely%20on%20watch%20expressions%20or%20the%20Memory%20Inspector%20to%20view%20the%20data.%3C%2FP%3E%0A%3CP%3EBR%2C%3CBR%20%2F%3EEdwin.%3C%2FP%3E%3C%2FLINGO-BODY%3E
