How to configure current project flexram without effect other project
2,420 次查看
flyrobot
I configure the flexram by edit the "__repo__\devices\MIMXRT1062\gcc\startup_MIMXRT1062.S" file.
But this way has a problem, it will effect all the project using the same SDK repository.
Is there any better way to configure the flexram ?
2,398 次查看
Omar_Anguiano
Hello
I hope you are well.
Please refer to this document: Reallocating the FlexRAM - NXP Community
Omar
2,389 次查看
flyrobot
Hi Omar,
I already reallocated the flexram in the Reset_Handler in the startup_MIMXRT1062.S file.
The problem is in the vscode, all the project is refer to the same __repo__ , which means all of them will change the flexram because they are using the same startup_MIMXRT1062.S file.
2,303 次查看
Omar_Anguiano
Thank you for clarifying this. Unfortunately, you will need to have different repositories for each project if a different startup is needed. This since it will affect the project linked to that repository.
Omar
