Errors running MCUXpresso Installer
3,236 次查看
mrichardson
So, I have installed MCUXpresso for VS Code and now can't seem to run the installer.  I get the error below.
If I press the download button, I get the following error:
I am currently running MCUXpresso for VS Code v1.0.68 on Ubuntu 22.04.  I am running the Snap distributed version of VS Code version 1.81.0.
Anyone have any thoughts on how to fix this?
3,207 次查看
RaRo
Hello @mrichardson,
Could you please click on Up to date and check for updates?
[MCUXpresso Installer v1.0 for VS Code]
If this does not solve the issue, could you please try uninstalling the MCUXpresso Installer and install it from here: Dependency Installation · nxp-mcuxpresso/vscode-for-mcux Wiki · GitHub for Ubuntu environment.
Let us know if the issue still persists.
Best regards, Raul.
3,080 次查看
mrichardson
Thanks Raul.  I will try uninstalling.  The second image is the message I get when I try the check for updates.
3,074 次查看
RaRo
Hello @mrichardson,
Thanks for the clarification about the second image. Let us know if reinstalling the installer solved the issue.
Best regards, Raul.
