Support for Micron MT25QL02GCBB QSPI NOR flash
mns
Hi all,
We are preparing bringup of a custom board based on i.MX RT1170. The MCU is populated with a Micron MT25QL02GCBB QSPI NOR flash, through the secondary FlexSPI interface, secondary pin group.
We noticed that Micron_MT25QLxxxA is supported by SPT. AFAICS from the datasheet, the stack is the difference - the higher capacity is realized through 4 dies rather than 1. Question is whether it makes a difference and we can simply select the MT25QLxxxA for SPT flashing?
marek-trmac
Hi @mns ,
all FlexSPI NOR memory configurations in SEC tool are just templates. After applying the configuration from a template, you can tweak all the parameters and adjust for your needs. The configuration dialog also contains "Test" button allowing immediately test the selected parameters.
Marek
NOTE: If you find the answer useful, kindly click on [ACCEPT AS SOLUTION] button
marek-trmac
Hi @mns ,
Marek
mns
Got it, thx...
%3CLINGO-SUB%20id%3D%22lingo-sub-2162316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ESupport%20for%20Micron%20MT25QL02GCBB%20QSPI%20NOR%20flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2162316%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3EHi%20all%2C%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EWe%20are%20preparing%20bringup%20of%20a%20custom%20board%20based%20on%20i.MX%20RT1170.%20The%20MCU%20is%20populated%20with%20a%20Micron%20MT25QL02GCBB%20QSPI%20NOR%20flash%2C%20through%20the%20secondary%20FlexSPI%20interface%2C%20secondary%20pin%20group.%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EWe%20noticed%20that%26nbsp%3BMicron_MT25QLxxxA%20is%20supported%20by%20SPT.%20AFAICS%20from%20the%20datasheet%2C%20the%20stack%20is%20the%20difference%20-%20the%20higher%20capacity%20is%20realized%20through%204%20dies%20rather%20than%201.%20Question%20is%20whether%20it%20makes%20a%20difference%20and%20we%20can%20simply%20select%20the%26nbsp%3BMT25QLxxxA%20for%20SPT%20flashing%3F%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%3CSPAN%3EThanks%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2162577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Support%20for%20Micron%20MT25QL02GCBB%20QSPI%20NOR%20flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2162577%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EGot%20it%2C%20thx...%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2162570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Support%20for%20Micron%20MT25QL02GCBB%20QSPI%20NOR%20flash%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2162570%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3EHi%26nbsp%3B%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F253983%22%20target%3D%22_blank%22%3E%40mns%3C%2FA%3E%26nbsp%3B%2C%3C%2FP%3E%0A%3CP%3Eall%20FlexSPI%20NOR%20memory%20configurations%20in%20SEC%20tool%20are%20just%20templates.%20After%20applying%20the%20configuration%20from%20a%20template%2C%20you%20can%20tweak%20all%20the%20parameters%20and%20adjust%20for%20your%20needs.%20The%20configuration%20dialog%20also%20contains%20%22Test%22%20button%20allowing%20immediately%20test%20the%20selected%20parameters.%26nbsp%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E
