IMXRT1052 XIP Encryption Issue
2,108件の閲覧回数
acallamp
May I ask the expert: RT1052+XIP encryption method? If I want to use the UID of the chip as the key without burning the fuse, which solution should I choose to encrypt and generate the image? Because I am worried that after burning the fuse, the chip cannot be reused. May I ask if there are any good methods for encryption. It is also beneficial for the factory to facilitate mass production.
2,084件の閲覧回数
marek-trmac
"Encrypted mode with UID" => "BEE with OTPMK". The mode is available only for signed images, so it will require to burn fuses for signing.
You can always review, which fuses will be burnt in:
1) OTP Configuration dialog (use filter "Required")
2) Prior the write script is executed, the GUI tool first check the fuses in the processor and then displays all irreversible changes.
After the fuses burnt, the chip still can be used with the same keys. Fuse bit burnt to 1 cannot be reverted to 0 anymore.
You need to decide, whether you need same flash content for all products. If yes, you need same key for all products and you must use user key. Using UID/OTPMK means each product uses different key, so flash content is different.
Marek
NOTE: If you find the answer useful, kindly click on [ACCEPT AS SOLUTION] button
2,084件の閲覧回数
marek-trmac
Marek
2,075件の閲覧回数
acallamp
HI:
Does MFGTOOL only support USB and have production software that supports UART?
%3CLINGO-SUB%20id%3D%22lingo-sub-2004673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EIMXRT1052%20XIP%20%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2004673%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E5%B0%82%E9%96%80%E5%AE%B6%E3%81%AB%E8%81%9E%E3%81%84%E3%81%A6%E3%82%82%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3ART1052%20%2B%20XIP%E6%9A%97%E5%8F%B7%E5%8C%96%E6%96%B9%E5%BC%8F%3F%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%82%92%E7%87%83%E3%82%84%E3%81%95%E3%81%9A%E3%81%AB%E3%83%81%E3%83%83%E3%83%97%E3%81%AEUID%E3%82%92%E3%82%AD%E3%83%BC%E3%81%A8%E3%81%97%E3%81%A6%E4%BD%BF%E7%94%A8%E3%81%99%E3%82%8B%E5%A0%B4%E5%90%88%E3%80%81%E3%82%A4%E3%83%A1%E3%83%BC%E3%82%B8%E3%82%92%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%97%E3%81%A6%E7%94%9F%E6%88%90%E3%81%99%E3%82%8B%E3%81%AB%E3%81%AF%E3%81%A9%E3%81%AE%E3%82%BD%E3%83%AA%E3%83%A5%E3%83%BC%E3%82%B7%E3%83%A7%E3%83%B3%E3%82%92%E9%81%B8%E6%8A%9E%E3%81%99%E3%82%8C%E3%81%B0%E3%82%88%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%3F%E3%83%92%E3%83%A5%E3%83%BC%E3%82%BA%E3%82%92%E7%87%83%E3%82%84%E3%81%97%E3%81%9F%E5%BE%8C%E3%80%81%E3%83%81%E3%83%83%E3%83%97%E3%81%8C%E5%86%8D%E5%88%A9%E7%94%A8%E3%81%A7%E3%81%8D%E3%81%AA%E3%81%8F%E3%81%AA%E3%82%8B%E3%81%AE%E3%81%8C%E5%BF%83%E9%85%8D%E3%81%A0%E3%81%8B%E3%82%89%E3%81%A7%E3%81%99%E3%80%82%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%AE%E3%81%9F%E3%82%81%E3%81%AE%E8%89%AF%E3%81%84%E6%96%B9%E6%B3%95%E3%81%8C%E3%81%82%E3%82%8B%E3%81%8B%E3%81%A9%E3%81%86%E3%81%8B%E5%B0%8B%E3%81%AD%E3%81%A6%E3%82%82%E3%81%84%E3%81%84%E3%81%A7%E3%81%99%E3%81%8B%E3%80%82%E3%81%BE%E3%81%9F%E3%80%81%E5%B7%A5%E5%A0%B4%E3%81%AB%E3%81%A8%E3%81%A3%E3%81%A6%E3%82%82%E5%A4%A7%E9%87%8F%E7%94%9F%E7%94%A3%E3%82%92%E4%BF%83%E9%80%B2%E3%81%99%E3%82%8B%E3%81%93%E3%81%A8%E3%81%AF%E6%9C%89%E7%9B%8A%E3%81%A7%E3%81%99%E3%80%82%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2004904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ERe%3AIMXRT1052%20XIP%E6%9A%97%E5%8F%B7%E5%8C%96%E3%81%AE%E5%95%8F%E9%A1%8C%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2004904%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E3%81%93%E3%82%93%E3%81%AB%E3%81%A1%E3%81%AF%EF%BC%9A%3CBR%20%2F%3EMFGTOOL%E3%81%AFUSB%E3%81%AE%E3%81%BF%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%97%E3%80%81UART%E3%82%92%E3%82%B5%E3%83%9D%E3%83%BC%E3%83%88%E3%81%99%E3%82%8B%E8%A3%BD%E5%93%81%E3%82%BD%E3%83%95%E3%83%88%E3%82%A6%E3%82%A7%E3%82%A2%E3%82%92%E6%8C%81%E3%81%A3%E3%81%A6%E3%81%84%E3%81%BE%E3%81%99%E3%81%8B%3F%3C%2FLINGO-BODY%3E
