iomuxc_gpr_mode_t enumeration incorrect?
kaztros
Hello.  I'm trying to use the SDK for MIMXRT1052.
It looks like this definition is wrong (SDK version 2.15):
typedef enum _iomuxc_gpr_mode
kIOMUXC_GPR_GlobalInterruptRequest = IOMUXC_GPR_GPR1_GINT_MASK,
kIOMUXC_GPR_ENET1RefClkMode = IOMUXC_GPR_GPR1_ENET_TX_CLK_SEL_MASK,
kIOMUXC_GPR_ENET1TxClkOutputDir = IOMUXC_GPR_GPR1_ENET_REF_CLK_DIR_MASK,
kIOMUXC_GPR_SAI1MClkOutputDir = IOMUXC_GPR_GPR1_SAI1_MCLK_DIR_MASK,
kIOMUXC_GPR_SAI2MClkOutputDir = IOMUXC_GPR_GPR1_SAI2_MCLK_DIR_MASK,
kIOMUXC_GPR_SAI3MClkOutputDir = IOMUXC_GPR_GPR1_SAI3_MCLK_DIR_MASK,
kIOMUXC_GPR_ExcMonitorSlavErrResponse = IOMUXC_GPR_GPR1_EXC_MON_MASK,
kIOMUXC_GPR_AHBClockEnable = (int)IOMUXC_GPR_GPR1_CM7_FORCE_HCLK_EN_MASK,
} iomuxc_gpr_mode_t;
Whereas these two lines ought to read:
kIOMUXC_GPR_ENET1RefClkDir = IOMUXC_GPR_GPR1_ENET_REF_CLK_DIR_MASK,
kIOMUXC_GPR_ENET1TxClkMode = IOMUXC_GPR_GPR1_ENET_TX_CLK_SEL_MASK,
Probably?  I'm not sure, and would like confirmation.
Harry_Zhang
Hi @kaztros
I just checked the MIMXRT1052 SDK and found that the iomuxc_gpr_mode_t enumeration you mentioned is incorrect.
Thank you for the information.
And I will report this issue to our SDK team.
Hang
