Update DMA source buffer before software trigger
3,939 次查看
r_poelstra
I've configured a USART TX DMA channel (using the graphical config tool) that I trigger from software when bytes are available to be transmitted using:
DMA_DoChannelSoftwareTrigger(DMA0_DMA_BASEADDR, DMA0_LOG_UART_DMA_CHANNEL);
This works fine, but only with a fixed number of bytes each trigger.
How can I update the DMA channel so it knows how many bytes it should transfer?
Thanks in advance.
Kind regards,
Remco Poelstra
3,914 次查看
Hello Remco Poelstra,
Yes, the DMA only can transfer fixed number of bits.
And a ring buffer DMA maybe suit for you , there is demo"lpcxpresso845max_usart_transfer_rb_dma" under SDK, you can have a look.
Alice
4 回复数
3,889 次查看
r_poelstra
Thanks for the reply.
I'll look into the ring buffer example. It might indeed be what I need.
Kind regards,
Remco Poelstra
3,915 次查看
Alice
3,922 次查看
r_poelstra
I'm using LPC844.
Kind regards,
Remco Poelstra
3,925 次查看
ZhangJennie
Please let us know your chip part number, thus we can assign right engineer for your issue.
Jun Zhang
