Same enum names but different values in fsl_clock.h
1,579 次查看
moab
We are using SDK_2.6.0_LPCXpresso54618and SDK_2.6.0_LPC54605J256 in our project.
I have faced an issue when I was making a customized uart driver.
I need to Get clock frequency, so I need to use
/*! @brief Clock name used to get clock frequency. */
typedef enum _clock_name
and I  aslo need to enable and disable clock, so I need to use
/*! @brief Clock gate name used for CLOCK_EnableClock/CLOCK_DisableClock. */
typedef enum _clock_ip_name
I need to use both these enums in one file. But this is not possible because they have the same name!!  but different values!!
example: kCLOCK_Flexcomm0 in the following enums
kCLOCK_IpInvalid = 0U,
kCLOCK_Rom = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 1),
kCLOCK_Sram1 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 3),
kCLOCK_Sram2 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 4),
kCLOCK_Sram3 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 5),
kCLOCK_Flash = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 7),
kCLOCK_Fmc = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 8),
kCLOCK_Eeprom = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 9),
kCLOCK_Spifi = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 10),
kCLOCK_InputMux = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 11),
kCLOCK_Iocon = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 13),
kCLOCK_Gpio0 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 14),
kCLOCK_Gpio1 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 15),
kCLOCK_Gpio2 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 16),
kCLOCK_Gpio3 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 17),
kCLOCK_Pint = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 18),
kCLOCK_Gint = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 19),
kCLOCK_Dma = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 20),
kCLOCK_Crc = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 21),
kCLOCK_Wwdt = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 22),
kCLOCK_Rtc = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 23),
kCLOCK_Adc0 = CLK_GATE_DEFINE(AHB_CLK_CTRL0, 27),
kCLOCK_Mrt = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 0),
kCLOCK_Rit = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 1),
kCLOCK_Sct0 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 2),
kCLOCK_Mcan0 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 7),
kCLOCK_Mcan1 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 8),
kCLOCK_Utick = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 10),
kCLOCK_FlexComm0 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 11),
kCLOCK_FlexComm1 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 12),
kCLOCK_FlexComm2 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 13),
kCLOCK_FlexComm3 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 14),
kCLOCK_FlexComm4 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 15),
kCLOCK_FlexComm5 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 16),
kCLOCK_FlexComm6 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 17),
kCLOCK_FlexComm7 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 18),
kCLOCK_MinUart0 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 11),
kCLOCK_MinUart1 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 12),
kCLOCK_MinUart2 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 13),
kCLOCK_MinUart3 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 14),
kCLOCK_MinUart4 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 15),
kCLOCK_MinUart5 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 16),
kCLOCK_MinUart6 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 17),
kCLOCK_MinUart7 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 18),
kCLOCK_LSpi0 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 11),
kCLOCK_LSpi1 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 12),
kCLOCK_LSpi2 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 13),
kCLOCK_LSpi3 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 14),
kCLOCK_LSpi4 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 15),
kCLOCK_LSpi5 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 16),
kCLOCK_LSpi6 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 17),
kCLOCK_LSpi7 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 18),
kCLOCK_BI2c0 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 11),
kCLOCK_BI2c1 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 12),
kCLOCK_BI2c2 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 13),
kCLOCK_BI2c3 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 14),
kCLOCK_BI2c4 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 15),
kCLOCK_BI2c5 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 16),
kCLOCK_BI2c6 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 17),
kCLOCK_BI2c7 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 18),
kCLOCK_FlexI2s0 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 11),
kCLOCK_FlexI2s1 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 12),
kCLOCK_FlexI2s2 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 13),
kCLOCK_FlexI2s3 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 14),
kCLOCK_FlexI2s4 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 15),
kCLOCK_FlexI2s5 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 16),
kCLOCK_FlexI2s6 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 17),
kCLOCK_FlexI2s7 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 18),
kCLOCK_DMic = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 19),
kCLOCK_Ct32b2 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 22),
kCLOCK_Usbd0 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 25),
kCLOCK_Ct32b0 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 26),
kCLOCK_Ct32b1 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 27),
kCLOCK_BodyBias0 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 29),
kCLOCK_EzhArchB0 = CLK_GATE_DEFINE(AHB_CLK_CTRL1, 31),
kCLOCK_Lcd = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 2),
kCLOCK_Sdio = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 3),
kCLOCK_Usbh1 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 4),
kCLOCK_Usbd1 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 5),
kCLOCK_UsbRam1 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 6),
kCLOCK_Emc = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 7),
kCLOCK_Eth = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 8),
kCLOCK_Gpio4 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 9),
kCLOCK_Gpio5 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 10),
kCLOCK_Aes = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 11),
kCLOCK_Otp = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 12),
kCLOCK_Rng = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 13),
kCLOCK_FlexComm8 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 14),
kCLOCK_FlexComm9 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 15),
kCLOCK_MinUart8 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 14),
kCLOCK_MinUart9 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 15),
kCLOCK_LSpi8 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 14),
kCLOCK_LSpi9 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 15),
kCLOCK_BI2c8 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 14),
kCLOCK_BI2c9 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 15),
kCLOCK_FlexI2s8 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 14),
kCLOCK_FlexI2s9 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 15),
kCLOCK_Usbhmr0 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 16),
kCLOCK_Usbhsl0 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 17),
kCLOCK_Sha0 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 18),
kCLOCK_SmartCard0 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 19),
kCLOCK_SmartCard1 = CLK_GATE_DEFINE(AHB_CLK_CTRL2, 20),
kCLOCK_Ct32b3 = CLK_GATE_DEFINE(ASYNC_CLK_CTRL0, 13),
kCLOCK_Ct32b4 = CLK_GATE_DEFINE(ASYNC_CLK_CTRL0, 14)
} clock_ip_name_t;
kCLOCK_CoreSysClk, /*!< Core/system clock (aka MAIN_CLK) */
kCLOCK_BusClk, /*!< Bus clock (AHB clock) */
kCLOCK_ClockOut, /*!< CLOCKOUT */
kCLOCK_FroHf, /*!< FRO48/96 */
kCLOCK_SpiFi, /*!< SPIFI */
kCLOCK_Adc, /*!< ADC */
kCLOCK_Usb0, /*!< USB0 */
kCLOCK_Usb1, /*!< USB1 */
kCLOCK_UsbPll, /*!< USB1 PLL */
kCLOCK_Mclk, /*!< MCLK */
kCLOCK_Sct, /*!< SCT */
kCLOCK_SDio, /*!< SDIO */
kCLOCK_EMC, /*!< EMC */
kCLOCK_LCD, /*!< LCD */
kCLOCK_MCAN0, /*!< MCAN0 */
kCLOCK_MCAN1, /*!< MCAN1 */
kCLOCK_Fro12M, /*!< FRO12M */
kCLOCK_ExtClk, /*!< External Clock */
kCLOCK_PllOut, /*!< PLL Output */
kCLOCK_UsbClk, /*!< USB input */
kCLOCK_WdtOsc, /*!< Watchdog Oscillator */
kCLOCK_Frg, /*!< Frg Clock */
kCLOCK_Dmic, /*!< Digital Mic clock */
kCLOCK_AsyncApbClk, /*!< Async APB clock */
kCLOCK_FlexI2S, /*!< FlexI2S clock */
kCLOCK_Flexcomm0, /*!< Flexcomm0Clock */
kCLOCK_Flexcomm1, /*!< Flexcomm1Clock */
kCLOCK_Flexcomm2, /*!< Flexcomm2Clock */
kCLOCK_Flexcomm3, /*!< Flexcomm3Clock */
kCLOCK_Flexcomm4, /*!< Flexcomm4Clock */
kCLOCK_Flexcomm5, /*!< Flexcomm5Clock */
kCLOCK_Flexcomm6, /*!< Flexcomm6Clock */
kCLOCK_Flexcomm7, /*!< Flexcomm7Clock */
kCLOCK_Flexcomm8, /*!< Flexcomm8Clock */
kCLOCK_Flexcomm9, /*!< Flexcomm9Clock */
} clock_name_t;
Any suggestions on this issue?
Br
Mo
1,360 次查看
Sabina_Bruce
Hi Mo,
Both enums are actually in the same header file. So you can use both of them in your program.
The example you comment, kCLOCK_Flexcomm0 has the value of 25 in clock_name_t, and kCLOCK_FlexComm0 has the value of 267 in clock_ip_name_t. The difference is in the lowercase c and the uppercase C. Depending on what you need, you must choose the correct one, according to the argument type in each function.
Sabina
1,360 次查看
moab
I didn't notice the difference between 'c' and 'C'. thanks for your reply. My driver works fine now.
1,360 次查看
Sabina_Bruce
Not a problem. Have a great day!
