SDK for MIMXRT1170-EVK
mahmoudsaati
hello i was unable to find SDK for MIMXRT1170-EVK, the latest one i found was for RT1064, is it compatible? if no where i can find SDK for RT1170
thank you
victorjimenez
The RT1170 is still in pre-production, hence the SDK is not released yet. The RT1064-EVK SDK is not compatible by any means with the RT1170.
If you want more information about the RT1170 you will need to contact your local distributor.
Victor
fmabrouk
I am looking for the schematics of this dev board. Is it available online?
Any time frame about when the drivers/library for this dev board will be released?
