Questions regarding the examples of keyboard2mouse.
281 次查看
inse1979
When I run the keyboard2mouse example on the LPC55S69-EVK with the default settings, it works perfectly.
However, its current operation seems to be:
PC <--> LPCIP3511HS <--> LPC55S69 <--> OHCI <--> Keyboard
But I want to modify the operation mode to:
PC <--> LPCIP3511FS<-->LPC55s69<--> IP3516HS <--> Keyboard
So I tried the following modification:
usb_host_config.h:
#define USB_HOST_CONFIG_OHCI 0U
#define USB_HOST_CONFIG_IP3516HS 1U
usb_device_config.h
#define USB_DEVICE_CONFIG_LPCIP3511FS 1U
#define USB_DEVICE_CONFIG_LPCIP3511HS 0U
I encountered the following error message:
arm-none-eabi/bin/ld.exe: region `USB_RAM' overflowed by 3840 bytes
Memory region Used Size Region Size %age Used
PROGRAM_FLASH: 83524 B 630 KB 12.95%
SRAM: 29408 B 256 KB 11.22%
SRAMX: 0 GB 32 KB 0.00%
USB_RAM: 20224 B 16 KB 123.44%
SRAM4: 0 GB 16 KB 0.00%
How to solve this problem ?
260 次查看
ZhangJennie
Hi inse1979
According to the error message "USB_RAM: 20224 B 16 KB 123.44%", your USB_RAM is overfolow. The reason is that, when you switch your USB Host controller from OHCI -> IP3516HS, the USB_RAM requirement exceeds 16k, which results in the overflow error.
IP3516HS driver needs more USB_RAM memory because its increased complexity.
While USB_RAM is only 16KB, your configuration is 20224B which is over the limit.
I ever tested the the same with SDK demos, switching USB demo from USB0. see article sections 2.1 and 2.2 of following article. There's no issue.
https://community.nxp.com/t5/LPC-Microcontrollers-Knowledge/LPC-ALL-Summary-of-Switching-USB-demo-fr...
Therefore, I suggest you optimize your code by disabling unnecessary USB classes or points to release more memory. Or reduce USB devices or endpoints or buffer sizes.
Hope this helps,
Jun Zhang
%3CLINGO-SUB%20id%3D%22lingo-sub-2173247%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E6%9C%89%E5%85%B3%20keyboard2mouse%20%E7%A4%BA%E4%BE%8B%E7%9A%84%E9%97%AE%E9%A2%98%E3%80%82%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2173247%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%E5%BD%93%E6%88%91%E4%BD%BF%E7%94%A8%E9%BB%98%E8%AE%A4%E8%AE%BE%E7%BD%AE%E5%9C%A8%20LPC55S69-EVK%20%E4%B8%8A%E8%BF%90%E8%A1%8C%20keyboard2mouse%20%E7%A4%BA%E4%BE%8B%E6%97%B6%EF%BC%8C%E5%AE%83%E8%BF%90%E8%A1%8C%E5%BE%97%E9%9D%9E%E5%B8%B8%E5%AE%8C%E7%BE%8E%E3%80%82%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%E4%B8%8D%E8%BF%87%EF%BC%8C%E5%AE%83%E7%9B%AE%E5%89%8D%E7%9A%84%E8%BF%90%E4%BD%9C%E4%BC%BC%E4%B9%8E%E6%98%AF%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3EPC%26lt%3B--%26gt%3B%20LPCIP3511HS%26lt%3B--%26gt%3B%20LPC55S69%26lt%3B--%26gt%3B%20OHCI%26lt%3B--%26gt%3B%20%E9%94%AE%E7%9B%98%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%E4%BD%86%E6%88%91%E6%83%B3%E5%B0%86%E6%93%8D%E4%BD%9C%E6%A8%A1%E5%BC%8F%E4%BF%AE%E6%94%B9%E4%B8%BA%3C%2FFONT%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3EPC%26lt%3B--%26gt%3B%20LPCIP3511FS%26lt%3B--%26gt%3BLPC55s69%26lt%3B--%26gt%3B%20IP3516HS%26lt%3B--%26gt%3B%20%E9%94%AE%E7%9B%98%3C%2FFONT%3E%3C%2FSTRONG%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%E4%BA%8E%E6%98%AF%E6%88%91%E5%B0%9D%E8%AF%95%E5%81%9A%E4%BA%86%E5%A6%82%E4%B8%8B%E4%BF%AE%E6%94%B9%EF%BC%9A%3C%2FFONT%3E%3CBR%20%2F%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3Eusb_host_config.h%EF%BC%9A%3C%2FFONT%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%23define%3CSTRONG%3EUSB_HOST_CONFIG_OHCI%3C%2FSTRONG%3E0U%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%23define%3CSTRONG%3EUSB_HOST_CONFIG_IP3516HS%3C%2FSTRONG%3E1U%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CSTRONG%3E%3CFONT%20size%3D%222%22%3Eusb_device_config.h%3C%2FFONT%3E%3C%2FSTRONG%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%23define%3CSTRONG%3EUSB_DEVICE_CONFIG_LPCIP3511FS%3C%2FSTRONG%3E1U%3C%2FFONT%3E%3CBR%20%2F%3E%3CFONT%20size%3D%222%22%3E%23define%3CSTRONG%3EUSB_DEVICE_CONFIG_LPCIP3511HS%3C%2FSTRONG%3E0U%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%222%22%3E%E6%88%91%E9%81%87%E5%88%B0%E4%BA%86%E4%BB%A5%E4%B8%8B%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%EF%BC%9A%3C%2FFONT%3E%3C%2FP%3E%3CDIV%3E%3CDIV%3E%3CBLOCKQUOTE%3E%3CP%3E%3CFONT%20size%3D%221%202%203%204%205%206%207%22%3E%3CSPAN%3Earm-none-eabi%2Fbin%2Fld.exe%3A%20%E5%8C%BA%E5%9F%9F%20%E2%80%9CUSB_RAM%E2%80%9D%20%E6%BA%A2%E5%87%BA%E4%BA%86%203840%20%E5%AD%97%E8%8A%82%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%221%202%203%204%205%206%207%22%3E%3CSPAN%3E%E5%B7%B2%E7%94%A8%E5%86%85%E5%AD%98%E5%8C%BA%E5%9F%9F%E5%A4%A7%E5%B0%8F%20%E5%8C%BA%E5%9F%9F%E5%A4%A7%E5%B0%8F%25%E5%B7%B2%E7%94%A8%E5%86%85%E5%AD%98%E5%B9%B4%E9%BE%84%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%221%202%203%204%205%206%207%22%3E%3CSPAN%3E%E7%A8%8B%E5%BA%8F%E9%97%AA%E5%AD%98%EF%BC%9A%2083524%20b%20630%20kb%2012.95%25%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%221%202%203%204%205%206%207%22%3E%3CSPAN%3ESram%3A%2029408%20B%20256%20KB%2011.22%25%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%221%202%203%204%205%206%207%22%3E%3CSPAN%3ESramx%3A%200%20GB%2032%20KB%200.00%25%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%221%202%203%204%205%206%207%22%3E%3CSPAN%3Eusb_ram%3A%2020224%20b%2016%20kb%20123.44%25%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%3CP%3E%3CFONT%20size%3D%221%202%203%204%205%206%207%22%3E%3CSPAN%3ESram4%EF%BC%9A%200GB%2016KB%200.00%25%3C%2FSPAN%3E%3C%2FFONT%3E%3C%2FP%3E%3C%2FBLOCKQUOTE%3E%3C%2FDIV%3E%3C%2FDIV%3E%3CP%3E%E5%A6%82%E4%BD%95%E8%A7%A3%E5%86%B3%E8%BF%99%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2173377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20Questions%20regarding%20the%20examples%20of%20keyboard2mouse.%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2173377%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%20inse1979%20%3C%2FP%3E%0A%3CP%3E%E6%A0%B9%E6%8D%AE%E9%94%99%E8%AF%AF%E4%BF%A1%E6%81%AF%22%3CSPAN%3EUSB_RAM%3A%2020224%20B%2016%20KB%20123.44%25%3C%2FSPAN%3E%22%20%2C%20%E6%82%A8%E7%9A%84%20USB_RAM%20%E5%AE%B9%E9%87%8F%E8%BF%87%E4%BD%8E%E3%80%82%E5%8E%9F%E5%9B%A0%E6%98%AF%EF%BC%8C%E5%BD%93%E6%82%A8%E4%BB%8E%20OHCI%20-%26gt%3B%20IP3516HS%20%E5%88%87%E6%8D%A2%20USB%20%E4%B8%BB%E6%9C%BA%E6%8E%A7%E5%88%B6%E5%99%A8%E6%97%B6%EF%BC%8CUSB_RAM%20%E9%9C%80%E6%B1%82%E8%B6%85%E8%BF%87%2016k%EF%BC%8C%E4%BB%8E%E8%80%8C%E5%AF%BC%E8%87%B4%E6%BA%A2%E5%87%BA%E9%94%99%E8%AF%AF%E3%80%82%3C%2FP%3E%0A%3CP%3EIP3516HS%20%E9%A9%B1%E5%8A%A8%E7%A8%8B%E5%BA%8F%E9%9C%80%E8%A6%81%E6%9B%B4%E5%A4%9A%20USB_RAM%20%E5%86%85%E5%AD%98%EF%BC%8C%E5%9B%A0%E4%B8%BA%E5%85%B6%E5%A4%8D%E6%9D%82%E6%80%A7%E5%A2%9E%E5%8A%A0%E4%BA%86%E3%80%82%3C%2FP%3E%0A%3CP%3EUSB_RAM%20%E5%8F%AA%E6%9C%89%2016KB%EF%BC%8C%E8%80%8C%E6%82%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E6%98%AF%2020224B%EF%BC%8C%E8%B6%85%E8%BF%87%E4%BA%86%E4%B8%8A%E9%99%90%E3%80%82%3C%2FP%3E%0A%3CP%3E%E6%88%91%E6%9B%BE%E7%94%A8%20SDK%20%E6%BC%94%E7%A4%BA%E8%BF%9B%E8%A1%8C%E8%BF%87%E5%90%8C%E6%A0%B7%E7%9A%84%E6%B5%8B%E8%AF%95%EF%BC%8C%E4%BB%8E%20USB0%20%E5%88%87%E6%8D%A2%20USB%20%E6%BC%94%E7%A4%BA%E3%80%82%E8%A7%81%E4%BB%A5%E4%B8%8B%E6%9D%A1%E6%AC%BE%E7%AC%AC%202.1%20%E5%92%8C%202.2%20%E8%8A%82%E3%80%82%E6%B2%A1%E6%9C%89%E9%97%AE%E9%A2%98%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLPC-Microcontrollers-Knowledge%2FLPC-ALL-Summary-of-Switching-USB-demo-from-USB0-to-USB1%2Fta-p%2F1428522%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FLPC-Microcontrollers-Knowledge%2FLPC-ALL-Summary-of-Switching-USB-demo-from-USB0-to-USB1%2Fta-p%2F1428522%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%9B%A0%E6%AD%A4%EF%BC%8C%E6%88%91%E5%BB%BA%E8%AE%AE%E4%BD%A0%E9%80%9A%E8%BF%87%E7%A6%81%E7%94%A8%E4%B8%8D%E5%BF%85%E8%A6%81%E7%9A%84%20USB%20%E7%B1%BB%E6%88%96%E7%82%B9%E6%9D%A5%E4%BC%98%E5%8C%96%E4%BB%A3%E7%A0%81%EF%BC%8C%E4%BB%A5%E7%89%88%E6%9C%AC%E6%9B%B4%E5%A4%9A%E5%86%85%E5%AD%98%E3%80%82%E6%88%96%E8%80%85%E5%87%8F%E5%B0%91%20USB%20%E8%AE%BE%E5%A4%87%E6%88%96%E7%AB%AF%E7%82%B9%E6%88%96%E7%BC%93%E5%86%B2%E5%8C%BA%E7%9A%84%E5%A4%A7%E5%B0%8F%E3%80%82%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E8%BF%99%E8%83%BD%E5%B8%AE%E5%88%B0%E6%82%A8%EF%BC%8C%3C%2FP%3E%0A%3CP%3E%E5%BC%A0%E4%BF%8A%3C%2FP%3E%3C%2FLINGO-BODY%3E
