QN9080 bootloader
QN9080 bootloader
1,403 次查看
davideferrario
Hello.
I'd like to made a bootloader for QM9080 ARM Cortex M4 MCU using BLE and gcc compiler.
I am using "QN908XC_connectivity.ld" linker script.
Let's suppose my bootloader use 64K of flash memory; how can I update "QN908XC_connectivity.ld" linker script to relocate correctly the code?
Where may I get information?
Is it possible to have sources of "bootloader_otap_qn908xcdk"?
Thank you
Davide Ferrario
1,315 次查看
Sebastian_Del_Rio
Hi Davide, I hope you're doing well!
The sources for the QN9080's bootloader are available as an example included in the SDK archive for this MCU.
It can be found in the following path of the SDK:
<…\SDK_2.2.1_QN908XCDK\boards\qn908xcdk\wireless_examples\framework\bootloader_otap>
Information about the bootloader can be found in the BLE Application Developer's Guide, in the following path of the SDK:
<…\SDK_2.2.1_QN908XCDK\docs\wireless\Bluetooth\Bluetooth Low Energy Application Developers Guide.pdf>
Please let me know if you need any more information.
Sebastian
