Missing libpython3.6m.so.1.0 when I try to tun arm-none-eabi-gdb (Ubuntu 22.04)
5,729 次查看
hfranco
I am trying to run arm-none-eabi-gdb (gcc-arm-11.2-2022.02-x86_64-arm-none-eabi) with JLink from Segger to debug my iMX8 (SDK_2_9_0_MIMX8QM6xxxFF). I'm using Ubuntu 22.04 and my python installed is 3.10.
I'm getting this error:
$ arm-none-eabi-gdb igpio_led_output_m40.elf
arm-none-eabi-gdb: error while loading shared libraries: libpython3.6m.so.1.0: cannot open shared object file: No such file or directory
Do any of you knows how to solve this issue?
Thanks!
5,712 次查看
hfranco
Unfortunately, this library isn't available for ubuntu 22.04. I had to compile it manually, this guide fixed it: https://community.arm.com/support-forums/f/compilers-and-libraries-forum/52805/gcc-arm-11-2-2022-02-...
Thank you!
5,717 次查看
Bio_TICFSL
Hello hfranco,
It looks like you need to install the library for debug it first:
libpython3.6-dev
5,713 次查看
hfranco
Thank you!
