LPC546xx SDK 2.3.1 IAR power libraries - what has changed?
1,048 次查看
danielgull
Currently I am using the power libraries LPC546xx power libraries SDK 2.3.0 - refering to this file here "SDK 2.3.0\LPC54608\IAR\devices\LPC54608\iar\iar_lib_power.a". I see that this file has changed in the newer SDK version 2.3.1. I would like to know what has changed and if I should use the updated and newer version of this file "SDK 2.3.1\LPC54608\IAR\devices\LPC54608\iar\iar_lib_power.a".
Many Thanks
Dani
829 次查看
victorjimenez
Hello Dani,
Please find attach the release notes of the SDK 2.3.0 for LPC54608. Once you download the new version of the SDK (2.3.1) you can compare the release notes in order to see if something that you are using has change. If nothing changes, anyway I recommend you update the SDK since the new version has bug fixes.
Hope it helps!
Victor.
829 次查看
danielgull
Hi Victor,
Thank you for the feedback. I will follow your recommendation and will update the SDK to the new version
Dani
