I thought I should give you the background behind this request. I originally connected to Google's Firebase using the example code provided, and all was well. We then switched to a different endpoint, googleapis.com, which seems to not like the client certificate I was using (which was the one provided in the example, and which worked just fine with Firebase). Our software architect informed me I should not be using a client certificate, and that the vast majority of IoT devices like ours do not use a client certificate. I've been unable to find an example for mbedTLS that does not use a client certificate, or to figure out how to do it myself. When originally tried using the certificate from the example with hte new googleapis.com endpoint, here is the output I got (there are a few of my own debug statements in the trace, as well, and there are multiple tasks output at the same time, but hopefully it's not too badly garbled):
Initializing PHY...
Link UP 100 MBit Full duplex
Getting IP address from DHCP...
DHCP_STATE_BOUND
hostCNameTas IPv4 Address : 192.168.180.78
IPv4 Netmask : 255.255.255.0
IPv4 Gateway : 192.168.180.1
k Looking up CName for '16662.lb.invue-am.com'
hostCNameTask CName 'dev-ir4-sso.invue-am.com'
hostCNameTask Looking up CName for '16662.lb.invue-am.com'
AM_task AMMessageHeader
"GET /embeddedv1/config/kas/0203cc1fc4040006?kasFirmware=019306212020172700 HTTP/1.1
User-Agent: mbedTLS 2.13.1
Accept: */*
Cache-Control: no-cache
Host: dev-ir4-sso.invue-am.com
Accept-Encoding: identity
Connection: keep-alive
transmitting config request
. Seeding the random number generator...
. Loading the CA root certificate ... ok (0 skipped)
. Loading the client cert and key... ok
Connecting to dev-ir4-sso.invue-am.com/443
. Setting up the SSL/TLS structure...
SSL state connect : 0 ok
. Performing the SSL/TLS handshake...
Verify requested for (Depth 1):
cert. version : 3
serial number : 01:E3:B4:9D:77:CD:F4:0C:06:19:16:B6:E3
issuer name : OU=GlobalSign Root CA - R2, O=GlobalSign, CN=GlobalSign
subject name : C=US, O=Google Trust Services, CN=GTS CA 1D2
issued on : 2017-06-15 00:00:42
expires on : 2021-12-15 00:00:42
signed using : RSA with SHA-256
RSA key size : 2048 bits
basic constraints : CA=true, max_pathlen=0
key usage : Digital Signature, Key Cert Sign, CRL Sign
ext key usage : TLS Web Server Authentication, TLS Web Client Authentication
cert. version : 3
cert. version : 3
Verify requested for (Depth 0):
cert. version : 3
serial number : D1:B2:1B:04:84:E5:BF:5D:0A:00:00:00:00:34:93:20
issuer name : C=US, O=Google Trust Services, CN=GTS CA 1D2
subject name : CN=dev-ir4-sso.invue-am.com
issued on : 2020-05-15 18:33:44
expires on : 2020-08-13 18:33:44
basic constraints : CA=false
subject alt name : dev-ir4-sso.invue-am.com
key usage : Digital Signature, Key Encipherment
This certificate has no flags
x509_verify_cert() returned -9984 (-0x2700)
, at line 5713 in file .ssl_tls.c
ok
[ Protocol is TLSv1.2 ]
[ Ciphersuite is TLS-ECDHE-RSA-WITH-AES-128-GCM-SHA256 ]
[ Record expansion is 29 ]
. Verifying peer X.509 certificate... Server Verification skipped
. Peer certificate information ...
cert. version : 3
> Write to server: 'GET /embeddedv1/config/kas/0203cc1fc4040006?kasFirmware=019306212020172700 HTTP/1.1
Accept: */*
236 bytes written
Accept: */*
read_request 197 Header:
'HTTP/1.1 200 OK
access-control-allow-origin: *
x-dns-prefetch-control: off
x-frame-options: SAMEORIGIN
strict-transport-security: max-age=15552000; includeSubDomains
x-download-options: noopen
x-content-type-options: nosniff
x-xss-protection: 1; mode=block
content-type: application/octet-stream; charset=utf-8
etag: W/"62-1uAAylrO8FBct649sAnpL0iMgmc"
Date: Sun, 21 Jun 2020 21:31:50 GMT
Server: Google Frontend
Content-Length: 98'
HTTPS REQUEST OK
processIncomingMessages, AM message processing takes place here
processEthMsg_hdrRev1
hdrHdr.messageHeaderRev 1
hdrHdr.productId 0203
hdrHdr.productMsgTokenRev 01
flags 01
msgToken 16
status 00
---> COMMAND msgTkn_kasFirmwareURL_e msg received.
processEthMsg_hdrRev1 Outgoing downloadRequestHeader
"GET /ir4-kas-firmware/019306042020102700Application.bin HTTP/1.1
Accept: */*
Host: storage.googleapis.com
Connecting to storage.googleapis.com/443
cert. version : 3
serial number : 01:E3:B4:9A:A1:8D:8A:A9:81:25:69:50:B8
subject name : C=US, O=Google Trust Services, CN=GTS CA 1O1
cert. version : 3
cert. version : 3
cert. version : 3
serial number : 10:7A:C6:83:CE:BF:51:0F:08:00:00:00:00:43:54:D8
issuer name : C=US, O=Google Trust Services, CN=GTS CA 1O1
subject name : C=US, ST=California, L=Mountain View, O=Google LLC, CN=*.storage.googleapis.com
issued on : 2020-05-26 15:27:50
expires on : 2020-08-18 15:27:50
EC key size : 256 bits
subject alt name : *.storage.googleapis.com, *.appspot.com.storage.googleapis.com, *.commondatastorage.googleapis.com, *.content-storage-download.googleapis.com, *.content-storage-upload.googleapis.com, *.content-storage.googleapis.com, *.googleapis.com, *.storage-download.googleapis.com, *.storage-upload.googleapis.com, *.storage.select.googleapis.com, commondatastorage.googleapis.com, storage.googleapis.com, storage.select.googleapis.com, unfiltered.news
mbedtls_ssl_fetch_input() returned -29312 (-0x7280)
, at line 4967 in file .ssl_tls.c
ssl_get_next_record() returned -29312 (-0x7280)
, at line 4338 in file .ssl_tls.c
mbedtls_ssl_read_record() returned -29312 (-0x7280)
, at line 3302 in file .ssl_cli.c
failed
! mbedtls_ssl_handshake returned -7280
https_client_tls_xchg retval -4
cert. version : 3
cert. version : 3
cert. version : 3
cert. version : 3
I cut it off at this point, as it just keeps repeating the same failed attempt.
