NXP Expert,
I need help to decide how much the MPC5744P PLL0 PHI0 output frequency is.
From the above C code(mc_mode_init() in sys.c) from MTRCKTSPS5744P example code you posted, it is telling the PLL0 PHI0 output is 160HZ, its input has been selected using XOSC(the output is 8-40mhz),
where I can find how and why the PLL PHI0 out is set at 160HZ?
question 2: how much and how in this C motor application the system clock is set at?
Thank you.
Susan Li
Hi Susan,
It is good to hear you found the answer, please notice that the MCUXpresso Config Tools supports Cortex-M Kinetis and LPC devices. MPC devices are not supported.
I'd recommend to submit your questions to the MPC related community in the future:
https://community.nxp.com/community/s32/mpc5xxx
Hope it helps!
Carlos Mendoza
Technical Support Engineer
I found answer by myself.
Thank you.
Susan Li
